New Topic
Cannot connect using adb
34
Posted at 12/14/2017 04:35:21      View7739 | Replies10        Print      Only Author   [Copy Link] 1#
We have two RK3399 boards. Once is a 2GB version running Android 6, which I can connect using adb no problem. However, we just received another board which is 4GB and is running Android 7. I am not able to connect to it using adb. The driver loads and reports no errors, but "adb devices" shows nothing.
Posted at 12/15/2017 09:41:13        Only Author  2#
  1. --- a/system/core/drmservice/drmservice.c
  2. +++ b/system/core/drmservice/drmservice.c
  3. @@ -1096,11 +1096,13 @@ int main( int argc, char *argv[] )
  4.                 write_serialno2kernel(sn_buf_idb);
  5.                 SLOGE("get serialno from idb,serialno = %s",sn_buf_idb);
  6.         }
  7. -       else//auto generate serialno
  8. +
  9. +       if (sn_buf_idb[0]=='\0')
  10. +       //auto generate serialno
  11.         {
  12.                 generate_device_serialno(10,sn_buf_auto);
  13.                 property_set("sys.serialno", sn_buf_auto[0] ? sn_buf_auto : "");
Copy the code
Posted at 1/5/2018 06:01:01        Only Author  3#
Posted at 1/5/2018 06:02:06        Only Author  4#
Thanks for the response. Is this change something that was made to the released images? I have been using other boards that don't have this issue. I have not yet tried re-flashing this board with the latest image.
Posted at 1/5/2018 10:11:15        Only Author  5#
terry.lim Posted at 1/5/2018 06:02
Thanks for the response. Is this change something that was made to the released images? I have been  ...
u just go to download the lastest firmware which have already fix that bug .
Posted at 1/11/2026 10:30:11        Only Author  6#
Your article is breathtaking, thank you for sharing! Reliable Databricks-Certified-Data-Analyst-Associate exam syllabus offers premium content, and it's available to you at no charge.
restricted members
Posted at 1/12/2026 10:41:20        Only Author  7#
Wollen Sie Ihre Fähigkeit beim Lernen der Palo Alto Networks SD-WAN-Engineer Zertifzierungsunterlagen verbessern und sich von anderen besser anerkannt? Palo Alto Networks Prfungen helfen Ihnen, Ihre Fähigkeit zu verbessern. Wenn Sie die SD-WAN-Engineer Zertifizierung besitzen, können Sie Ihre Arbeit besser erledigen. Obwohl die SD-WAN-Engineer Prfung sehr schwierig ist, können Sie sich nicht um die Vorbereitung der Prfung sorgen. Nach der Nutzung der DeutschPrfung SD-WAN-Engineer Dumps können Sie die Palo Alto Networks SD-WAN-Engineer Prfung zu bestehen und auch die entsprechenden Kenntnisse beherrschen.
Posted at 1/12/2026 19:37:31        Only Author  8#
Your article was very memorable, thank you for sharing it. The C-S4CFI-2504 test notes exam questions are key to advancing in your careerget them for free!
restricted members
Posted at 1/22/2026 23:46:51        Only Author  9#
Thank you for sharing; it truly left me in awe! The New APP C-ARCON-2508 simulations content is of high quality and available for free.
Posted at 1/31/2026 20:09:15        Only Author  10#
Thank you for the brilliant share, the article is truly eye-opening! Latest exam CDCS simulator online is a free resource, offering rich content to aid your learning experience.
Return to List
12
