Board not started - rebooting forever
Posted at 12/29/2017 07:57:46
Board rebooting forever with next messages on UART:
- DDR Version 1.08 20170320
- In
- soft reset
- SRX
- Channel 0: DDR3, 800MHz
- Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
- Channel 1: DDR3, 800MHz
- 256B stride
- ch 0 ddrconfig = 0x101, ddrsize = 0x2020
- ch 1 ddrconfig = 0x101, ddrsize = 0x2020
- pmugrf_os_reg[2] = 0x3AA17AA1, stride = 0xD
- OUT
- Boot1: 2017-03-07, version: 1.06
- CPUId = 0x0
- ChipType = 0x10, 1899
- SdmmcInit=2 0
- BootCapSize=100000
- UserCapSize=14910MB
- FwPartOffset=2000 , 100000
- SdmmcInit=0 20
- StorageInit ok = 66603
- LoadTrustBL
- No find bl30.bin
- No find bl32.bin
- RunBL31 0x10000
- NOTICE: BL31: v1.3(debug):55aa0b4
- NOTICE: BL31: Built : 16:55:03, Mar 31 2017
- INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
- INFO: boot cpu mask: 0
- WARNING: pmu_power_domain_ctr: 5, 1, error!
- INFO: plat_rockchip_pmu_init(1089): pd status 1e
- INFO: BL31: Initializing runtime services
- INFO: BL31: Preparing for EL3 exit to normal world
- INFO: Entry point address = 0x200000
- INFO: SPSR = 0x3c9
- U-Boot 2017.02-RK3399-06 (Aug 29 2017 - 17:28:07)
- CPU: rk3399
- cpu version = 0
- CPU's clock information:
- aplll = 816000000HZ
- apllb = 24000000HZ
- gpll = 800000000HZ
- aclk_periph_h = 133333333HZ, hclk_periph_h = 66666666HZ, pclk_periph_h = 33333333HZ
- aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
- hclk_periph_l1 = 100000000HZ, pclk_periph_l1 = 50000000HZ
- cpll = 800000000HZ
- dpll = 792000000HZ
- vpll = 24000000HZ
- npll = 24000000HZ
- ppll = 676000000HZ
- Board: Rockchip platform Board
- Uboot as second level loader
- DRAM: Found dram banks: 1
- Adding bank:0000000000200000(00000000ffe00000)
- 128 MiB
- SdmmcInit = 0 20
- storage init OK!
- Using default environment
- GetParam
- remotectl v0.1
- pwm freq=0xb8320
- pwm_freq_nstime=0x52d
- Load FDT from resource image.
- power key: bank-0 pin-5
- usb bc: can find node by path: /dwc-control-usb/usb_bc
- dwc_otg_check_dpdm: usb bc disconnected
- pmic:rk808
- can't find dts node for pwm1
- set pwm voltage ok,pwm_id =2 vol=1000000,pwm_value=66
- vpll = 24000000HZ
- npll = 24000000HZ
- SecureBootEn = 0, SecureBootLock = 0
- #Boot ver: 2017-08-29#1.06
- empty serial no.
- normal boot.
- checkKey
- vbus = 0
- board_fbt_key_pressed: ir_keycode = 0x0, frt = 0
- no fuel gauge found
- failed to find phy node
- failed to find panel driver
- read logo on state from dts [1]
- can't find dts node for deviceinfo
- dw_rk_hdmi_register:fail to read deviceinfo
- hdmi baseparamer -1x-1@-1--1
- rockchip_panel_deinit: failed to find panel deinit funcs
- ERROR: [get_entry_ram]: Cannot find logo_kernel.bmp!
- failed to display kernel logo
- checkKey
- vbus = 0
- got recovery cmd from misc.
- load fdt from resouce.
- Secure Boot state: 0
- kernel @ 0x00280000 (0x011f7b60)
- ramdisk @ 0x05bf0000 (0x00778c68)
- bootrk: do_bootm_linux...
- Loading Device Tree to 0000000005600000, end 0000000005614c42 ... OK
- Add bank:0000000000200000, 00000000f7e00000
- WARNING: could not set reg FDT_ERR_BADOFFSET.
- Starting kernel ...
- [ 0.000000] Booting Linux on physical CPU 0x0
- [ 0.000000] Initializing cgroup subsys cpuset
- [ 0.000000] Initializing cgroup subsys cpuacct
- [ 0.000000] Initializing cgroup subsys schedtune
- [ 0.000000] Linux version 4.4.55 (omy@tchipserver2) (gcc version 4.9 20150123 (prerelease) (GCC) ) #609 SMP PREEMPT Tue Aug 29 17:29:18 CST 2017
- [ 0.000000] Boot CPU: AArch64 Processor [410fd034]
- [ 0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
- [ 0.000000] bootconsole [uart0] enabled
- [ 0.000000] hdmi init vic is -1
- [ 0.000000] cma: Reserved 16 MiB at 0x00000000f7000000
- [ 0.000000] psci: probing for conduit method from DT.
- [ 0.000000] psci: PSCIv1.0 detected in firmware.
- [ 0.000000] psci: Using standard PSCI v0.2 function IDs
- [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
- [ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f6ef5000 s45248 r8192 d32576 u86016
- [ 0.000000] Detected VIPT I-cache on CPU0
- [ 0.000000] CPU features: enabling workaround for ARM erratum 845719
- [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 999432
- [ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00010000@0x0002C000(recovery),0x00038000@0x0003C000(backup),0x00040000@0x00074000(cache),0x00300000@0x000B4000(system),0x00008000@0x003B4000(metadata),0x00002000@0x003BC000(baseparamer),-@0x003BE000(userdata) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2017-08-29_17:28:07 hdmi.vic=-1 SecureBootCheckOk=0
- [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
- [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
- [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
- [ 0.000000] software IO TLB [mem 0xf6ead000-0xf6eed000] (0MB) mapped at [ffffffc0f6ead000-ffffffc0f6eecfff]
- [ 0.000000] Memory: 3944000K/4061184K available (11198K kernel code, 1374K rwdata, 4952K rodata, 832K init, 1078K bss, 100800K reserved, 16384K cma-reserved)
- [ 0.000000] Virtual kernel memory layout:
- [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
- [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB)
- [ 0.000000] .init : 0xffffff8009050000 - 0xffffff8009120000 ( 832 KB)
- [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b70000 ( 11200 KB)
- [ 0.000000] .rodata : 0xffffff8008b70000 - 0xffffff8009050000 ( 4992 KB)
- [ 0.000000] .data : 0xffffff8009120000 - 0xffffff8009277a20 ( 1375 KB)
- [ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
- [ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
- [ 0.000000] fixed : 0xffffffbffe7fd000 - 0xffffffbffec00000 ( 4108 KB)
- [ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB)
- [ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
- [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
- [ 0.000000] Preemptible hierarchical RCU implementation.
- [ 0.000000] Build-time adjustment of leaf fanout to 64.
- [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
- [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
- [ 0.000000] NR_IRQS:64 nr_irqs:64 0
- [ 0.000000] GIC: Using split EOI/Deactivate mode
- [ 0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
- [ 0.000000] ITS: allocated 65536 Devices @f2000000 (psz 64K, shr 0)
- [ 0.000000] ITS: using cache flushing for cmd queue
- [ 0.000000] GIC: using LPI property table @0x00000000f2080000
- [ 0.000000] ITS: Allocated 1792 chunks for LPIs
- [ 0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
- [ 0.000000] CPU0: using LPI pending table @0x00000000f2090000
- [ 0.000000] GIC: using cache flushing for LPI property table
- [ 0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
- [ 0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
- [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
- [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
- [ 0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
- [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
- [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
- [ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
- [ 0.001841] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
- [ 0.002824] pid_max: default: 32768 minimum: 301
- [ 0.003329] Security Framework initialized
- [ 0.003726] SELinux: Initializing.
- [ 0.004161] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
- [ 0.004804] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
- [ 0.006307] Initializing cgroup subsys freezer
- [ 0.006744] Initializing cgroup subsys debug
- [ 0.007989] sched-energy: Sched-energy-costs installed from DT
- [ 0.008548] CPU0: update cpu_capacity 401
- [ 0.009004] ASID allocator initialised with 65536 entries
- [ 0.025833] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
- [ 0.027050] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
- [ 0.039215] Detected VIPT I-cache on CPU1
- [ 0.039246] CPU1: found redistributor 1 region 0:0x00000000fef20000
- [ 0.039282] CPU1: using LPI pending table @0x00000000f2200000
- [ 0.039325] CPU1: update cpu_capacity 401
- [ 0.039329] CPU1: Booted secondary processor [410fd034]
- [ 0.049215] Detected VIPT I-cache on CPU2
- [ 0.049233] CPU2: found redistributor 2 region 0:0x00000000fef40000
- [ 0.049266] CPU2: using LPI pending table @0x00000000f2230000
- [ 0.049293] CPU2: update cpu_capacity 401
- [ 0.049296] CPU2: Booted secondary processor [410fd034]
- [ 0.059252] Detected VIPT I-cache on CPU3
- [ 0.059270] CPU3: found redistributor 3 region 0:0x00000000fef60000
- [ 0.059303] CPU3: using LPI pending table @0x00000000f2270000
- [ 0.059329] CPU3: update cpu_capacity 401
- [ 0.059333] CPU3: Booted secondary processor [410fd034]
- [ 0.069293] Detected PIPT I-cache on CPU4
- [ 0.069320] CPU4: found redistributor 100 region 0:0x00000000fef80000
- [ 0.069356] CPU4: using LPI pending table @0x00000000f22b0000
- [ 0.069396] CPU4: update cpu_capacity 1024
- [ 0.069399] CPU4: Booted secondary processor [410fd082]
- [ 1.080693] CPU5: failed to come online
- [ 1.090718] Brought up 5 CPUs
- [ 1.091004] SMP: Total of 5 processors activated.
- [ 1.091465] CPU features: detected feature: GIC system register CPU interface
- [ 1.092149] CPU: All CPU(s) started at EL2
- [ 1.092573] alternatives: patching kernel code
- [ 1.094069] devtmpfs: initialized
- [ 1.113724] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
- [ 1.114672] futex hash table entries: 2048 (order: 5, 131072 bytes)
- [ 1.116320] pinctrl core: initialized pinctrl subsystem
- [ 1.119406] Failed to find legacy iommu devices
- [ 1.120388] NET: Registered protocol family 16
- [ 1.121525] schedtune: init normalization constants...
- [ 1.122021] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
- [ 1.122645] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
- [ 1.123288] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
- [ 1.123912] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
- [ 1.124535] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
- [ 1.125159] schedtune: CLUSTER[4] min_pwr: 65 max_pwr: 1108
- [ 1.125781] schedtune: CPU[4] min_pwr: 65 max_pwr: 1108
- [ 1.126409] Unable to handle kernel NULL pointer dereference at virtual address 00000010
- [ 1.127190] pgd = ffffff8009389000
- [ 1.127517] [00000010] *pgd=00000000f6ffe003, *pud=00000000f6ffe003, *pmd=0000000000000000
- [ 1.128315] Internal error: Oops: 96000005 [#1] PREEMPT SMP
- [ 1.128846] Modules linked in:
- [ 1.129147] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.55 #609
- [ 1.129727] Hardware name: Firefly-RK3399 Board BOX (Android) (DT)
- [ 1.130318] task: ffffffc0f2160000 ti: ffffffc0f2168000 task.ti: ffffffc0f2168000
- [ 1.131031] PC is at schedtune_init+0x20c/0x39c
- [ 1.131465] LR is at schedtune_init+0x1fc/0x39c
- [ 1.131898] pc : [<ffffff80080de890>] lr : [<ffffff80080de880>] pstate: 60000045
- [ 1.132600] sp : ffffffc0f216bcd0
- [ 1.132918] x29: ffffffc0f216bcd0 x28: ffffff8009127bf0
- [ 1.133428] x27: ffffffc0f22929a0 x26: ffffff8009127000
- [ 1.133939] x25: ffffff8008eb8050 x24: ffffffc0f2269400
- [ 1.134450] x23: ffffff80090f2e40 x22: ffffff8008eb8000
- [ 1.134960] x21: ffffffc0f2292980 x20: ffffff8009128000
- [ 1.135471] x19: ffffff800927d000 x18: 0000000000000078
- [ 1.135981] x17: 000000000000000e x16: 0000000000000007
- [ 1.136490] x15: ffffff8008bcd000 x14: 0fffffffffffffff
- [ 1.137001] x13: 0000000000000030 x12: 0101010101010101
- [ 1.137511] x11: 7f7f7f7f7f7f7f7f x10: 59ff5c335a544f42
- [ 1.138021] x9 : ffffffffffffffff x8 : 203536202020203a
- [ 1.138532] x7 : 7277705f6e696d20 x6 : ffffffc0f2269c00
- [ 1.139043] x5 : ffffff8008baa6b8 x4 : 0000000000000004
- [ 1.139553] x3 : 0000000000000000 x2 : cb88537fdc8ba637
- [ 1.140064] x1 : 0000000000000010 x0 : 0000000000000000
- [ 1.140575]
- [ 1.140575] PC: 0xffffff80080de810:
- [ 1.141048] e810 f9400422 51000400 f8607848 aa1903e2 b9401020 f9400c21 51000400 f9003fa8
- [ 1.141852] e830 8b001020 91068261 f9400407 f940d260 f90043a7 8b080000 f900d260 f9400420
- [ 1.142652] e850 8b070000 f9000420 d2800401 910263a0 940a15ef f9403fa8 910263a1 f94043a7
- [ 1.143452] e870 910082c0 aa0803e2 aa0703e3 9401fe57 f9403ba6 f94012a1 f94037a4 f94000c0
- [ 1.144251] e890 f9400800 f9401000 ca000020 92401c00 b4fff900 d4210000 f94002b5 f9400b00
- [ 1.145050] e8b0 eb0002bf 54fff3c1 91068277 9400500e f940d262 90007241 91141421 910082c0
- [ 1.145850] e8d0 f94006e3 d0006ed8 91033318 9401fe3f f94006f6 f940d260 cb0002d6 2a1603e0
- [ 1.146649] e8f0 940a3de7 2a0003e1 f9000ae0 d3609c02 d368bc03 d0006ec0 91016000 52800017
- [ 1.147450]
- [ 1.147450] LR: 0xffffff80080de800:
- [ 1.147925] e800 f90037a4 f9003ba6 f9400c01 b9400020 f9400422 51000400 f8607848 aa1903e2
- [ 1.148724] e820 b9401020 f9400c21 51000400 f9003fa8 8b001020 91068261 f9400407 f940d260
- [ 1.149524] e840 f90043a7 8b080000 f900d260 f9400420 8b070000 f9000420 d2800401 910263a0
- [ 1.150323] e860 940a15ef f9403fa8 910263a1 f94043a7 910082c0 aa0803e2 aa0703e3 9401fe57
- [ 1.151123] e880 f9403ba6 f94012a1 f94037a4 f94000c0 f9400800 f9401000 ca000020 92401c00
- [ 1.151922] e8a0 b4fff900 d4210000 f94002b5 f9400b00 eb0002bf 54fff3c1 91068277 9400500e
- [ 1.152722] e8c0 f940d262 90007241 91141421 910082c0 f94006e3 d0006ed8 91033318 9401fe3f
- [ 1.153522] e8e0 f94006f6 f940d260 cb0002d6 2a1603e0 940a3de7 2a0003e1 f9000ae0 d3609c02
- [ 1.154323]
- [ 1.154323] SP: 0xffffffc0f216bc50:
- [ 1.154797] bc50 08eb8000 ffffff80 090f2e40 ffffff80 f2269400 ffffffc0 08eb8050 ffffff80
- [ 1.155597] bc70 09127000 ffffff80 f22929a0 ffffffc0 09127bf0 ffffff80 f216bcd0 ffffffc0
- [ 1.156397] bc90 080de880 ffffff80 f216bcd0 ffffffc0 080de890 ffffff80 60000045 00000000
- [ 1.157196] bcb0 00000001 00000000 0000ffff 00000000 ffffffff ffffffff 00000454 00000000
- [ 1.157996] bcd0 f216bd90 ffffffc0 08082ba4 ffffff80 080de684 ffffff80 09134b20 ffffff80
- [ 1.158796] bcf0 f23fcb40 ffffffc0 09126000 ffffff80 09134b20 ffffff80 00000000 00000000
- [ 1.159596] bd10 090b06e0 ffffff80 090504a0 ffffff80 090b0650 ffffff80 0927b000 ffffff80
- [ 1.160395] bd30 f2168000 ffffffc0 00000004 00000000 f2269c00 ffffffc0 00000041 00000000
- [ 1.161199]
- [ 1.161199] X5: 0xffffff8008baa638:
- [ 1.161673] a638 00000007 005900c0 00c00060 00c000c0 00c000c0 00c000c0 00c000c0 00a900c0
- [ 1.162473] a658 00c00015 00c000af 00c00000 0026000e 00c000c0 001f00c0 00c000c0 00c000c0
- [ 1.163272] a678 00000007 000d0000 002a001b 006d0056 0100008e 0d000000 4e34271a 00000041
- [ 1.164071] a698 000d0000 00190013 00480038 00970061 09000000 17120d0b 0000001c 00000000
- [ 1.164871] a6b8 30313030 30333032 30353034 30373036 30393038 31313130 31333132 31353134
- [ 1.165670] a6d8 31373136 31393138 32313230 32333232 32353234 32373236 32393238 33313330
- [ 1.166469] a6f8 33333332 33353334 33373336 33393338 34313430 34333432 34353434 34373436
- [ 1.167268] a718 34393438 35313530 35333532 35353534 35373536 35393538 36313630 36333632
- [ 1.168070]
- [ 1.168070] X6: 0xffffffc0f2269b80:
- [ 1.168544] 9b80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.169343] 9ba0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.170142] 9bc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.170941] 9be0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.171739] 9c00 00000000 00000000 00000000 00000000 f2292980 ffffffc0 00000005 00000000
- [ 1.172539] 9c20 0000000a 00000000 00000020 0000007d 00000001 00000002 00000001 00000000
- [ 1.173337] 9c40 00000000 00000000 00000000 00000000 0000102f 00000001 fffea1c1 00000000
- [ 1.174135] 9c60 00000005 00000000 00001c25 00000000 fffea2e5 00000000 00000004 00000000
- [ 1.174940]
- [ 1.174940] X15: 0xffffff8008bccf80:
- [ 1.175423] cf80 00000000 00000000 00000000 00000000 08434f60 ffffff80 00000000 00000000
- [ 1.176222] cfa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.177020] cfc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.177819] cfe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.178618] d000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.179418] d020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.180216] d040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.181015] d060 00000000 00000000 00000000 00000000 08434f54 ffffff80 00000000 00000000
- [ 1.181817]
- [ 1.181817] X19: 0xffffff800927cf80:
- [ 1.182300] cf80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.183099] cfa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.183898] cfc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.184697] cfe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.185496] d000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.186294] d020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.187092] d040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.187891] d060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.188692]
- [ 1.188692] X20: 0xffffff8009127f80:
- [ 1.189175] 7f80 0924f0e0 ffffff80 0924f170 ffffff80 0924f200 ffffff80 0924f290 ffffff80
- [ 1.189975] 7fa0 0924f320 ffffff80 0924f3b0 ffffff80 0924f440 ffffff80 0924f4d0 ffffff80
- [ 1.190774] 7fc0 0924f560 ffffff80 0924f5f0 ffffff80 0924f680 ffffff80 0924f710 ffffff80
- [ 1.191574] 7fe0 0924f7a0 ffffff80 0924f830 ffffff80 0924f8c0 ffffff80 0924f950 ffffff80
- [ 1.192373] 8000 092527c8 ffffff80 09252858 ffffff80 092528e8 ffffff80 09252978 ffffff80
- [ 1.193173] 8020 09252a08 ffffff80 09252a98 ffffff80 09252b28 ffffff80 09252bb8 ffffff80
- [ 1.193973] 8040 09252c48 ffffff80 09252cd8 ffffff80 09252d68 ffffff80 09252df8 ffffff80
- [ 1.194771] 8060 09252e88 ffffff80 09252f18 ffffff80 09252fa8 ffffff80 09253038 ffffff80
- [ 1.195572]
- [ 1.195572] X21: 0xffffffc0f2292900:
- [ 1.196055] 2900 616d6f64 00306e69 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.196854] 2920 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.197653] 2940 30757063 ffffff00 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.198453] 2960 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.199251] 2980 f2292780 ffffffc0 00000001 00000001 f22929c0 ffffffc0 f20e9d00 ffffffc0
- [ 1.200051] 29a0 00000010 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.200850] 29c0 00000001 00000000 00000400 00000000 00000400 00000000 fffea1c3 00000000
- [ 1.201649] 29e0 00000000 00000001 000000ff 00000000 00000000 00000000 00000000 00000000
- [ 1.202450]
- [ 1.202450] X22: 0xffffff8008eb7f80:
- [ 1.202933] 7f80 0a646577 54330100 6e697972 6f742067 65726320 20657461 65726f6d 61687420
- [ 1.203733] 7fa0 6425206e 68635320 75546465 6220656e 74736f6f 20676e69 756f7267 000a7370
- [ 1.204532] 7fc0 63733601 74646568 3a656e75 696e6920 6f6e2074 6c616d72 74617a69 206e6f69
- [ 1.205330] 7fe0 736e6f63 746e6174 2e2e2e73 3601000a 65686373 6e757464 6e203a65 6e65206f
- [ 1.206130] 8000 79677265 646f6d20 64206c65 0a617461 554c4300 52455453 702a255b 005d6c62
- [ 1.206929] 8020 63733601 74646568 3a656e75 312d2520 6d207337 705f6e69 203a7277 756c3525
- [ 1.207727] 8040 78616d20 7277705f 3525203a 000a756c 5b555043 005d6425 63733601 74646568
- [ 1.208526] 8060 3a656e75 69737520 6e20676e 616d726f 617a696c 6e6f6974 6e6f6320 6e617473
- [ 1.209327]
- [ 1.209327] X23: 0xffffff80090f2dc0:
- [ 1.209810] 2dc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.210610] 2de0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.211408] 2e00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.212207] 2e20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.213006] 2e40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.213805] 2e60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.214604] 2e80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.215404] 2ea0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.216205]
- [ 1.216205] X24: 0xffffffc0f2269380:
- [ 1.216687] 9380 00000000 00000000 00000002 00000001 00000000 00000000 09198b10 ffffff80
- [ 1.217486] 93a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.218285] 93c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.219085] 93e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.219884] 9400 00000000 00000000 f2268a00 ffffffc0 f2292780 ffffffc0 00000005 00000000
- [ 1.220683] 9420 0000000a 00000000 00000020 0000007d 00000001 00000002 00000001 00000000
- [ 1.221482] 9440 00000000 00000000 00000000 00000000 0000102f 00000001 fffea1b7 00000000
- [ 1.222281] 9460 0000000a 00000000 00000b41 00000000 fffea2e4 00000000 00000000 00000000
- [ 1.223082]
- [ 1.223082] X25: 0xffffff8008eb7fd0:
- [ 1.223564] 7fd0 6f6e2074 6c616d72 74617a69 206e6f69 736e6f63 746e6174 2e2e2e73 3601000a
- [ 1.224364] 7ff0 65686373 6e757464 6e203a65 6e65206f 79677265 646f6d20 64206c65 0a617461
- [ 1.225163] 8010 554c4300 52455453 702a255b 005d6c62 63733601 74646568 3a656e75 312d2520
- [ 1.225963] 8030 6d207337 705f6e69 203a7277 756c3525 78616d20 7277705f 3525203a 000a756c
- [ 1.226762] 8050 5b555043 005d6425 63733601 74646568 3a656e75 69737520 6e20676e 616d726f
- [ 1.227562] 8070 617a696c 6e6f6974 6e6f6320 6e617473 6d207374 203a6c75 73207525 203a3168
- [ 1.228359] 8090 73207525 203a3268 000a7525 63733601 74646568 3a656e75 72657620 20796669
- [ 1.229160] 80b0 6d726f6e 7a696c61 6f697461 6f63206e 6174736e 2e73746e 000a2e2e 63733601
- [ 1.229961]
- [ 1.229961] X26: 0xffffff8009126f80:
- [ 1.230443] 6f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.231243] 6fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.232042] 6fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.232841] 6fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.233640] 7000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.234440] 7020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.235238] 7040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.236038] 7060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.236838]
- [ 1.236838] X27: 0xffffffc0f2292920:
- [ 1.237321] 2920 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.238120] 2940 30757063 ffffff00 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.238919] 2960 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.239718] 2980 f2292780 ffffffc0 00000001 00000001 f22929c0 ffffffc0 f20e9d00 ffffffc0
- [ 1.240518] 29a0 00000010 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.241316] 29c0 00000001 00000000 00000400 00000000 00000400 00000000 fffea1c3 00000000
- [ 1.242114] 29e0 00000000 00000001 000000ff 00000000 00000000 00000000 00000000 00000000
- [ 1.242912] 2a00 00000001 00000001 00000001 00000001 00000001 ffffffff 00000000 00000000
- [ 1.243713]
- [ 1.243713] X28: 0xffffff8009127b70:
- [ 1.244196] 7b70 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.244995] 7b90 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.245794] 7bb0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.246593] 7bd0 f1840000 ffffffc0 00000800 00000000 00000001 00000000 00000000 00000000
- [ 1.247392] 7bf0 00000006 00000000 00000013 00000000 00000000 00000000 00000000 00000000
- [ 1.248192] 7c10 00000000 00000000 00000000 00000000 00000000 00000000 0926e928 ffffff80
- [ 1.248991] 7c30 00000000 00000000 00000000 00000000 00000000 00000000 0000000a 00000000
- [ 1.249790] 7c50 00400000 0000000a 00000003 00000000 00000000 00000000 00000000 00000000
- [ 1.250591]
- [ 1.250591] X29: 0xffffffc0f216bc50:
- [ 1.251073] bc50 08eb8000 ffffff80 090f2e40 ffffff80 f2269400 ffffffc0 08eb8050 ffffff80
- [ 1.251872] bc70 09127000 ffffff80 f22929a0 ffffffc0 09127bf0 ffffff80 f216bcd0 ffffffc0
- [ 1.252673] bc90 080de880 ffffff80 f216bcd0 ffffffc0 080de890 ffffff80 60000045 00000000
- [ 1.253471] bcb0 00000001 00000000 0000ffff 00000000 ffffffff ffffffff 00000454 00000000
- [ 1.254271] bcd0 f216bd90 ffffffc0 08082ba4 ffffff80 080de684 ffffff80 09134b20 ffffff80
- [ 1.255071] bcf0 f23fcb40 ffffffc0 09126000 ffffff80 09134b20 ffffff80 00000000 00000000
- [ 1.255870] bd10 090b06e0 ffffff80 090504a0 ffffff80 090b0650 ffffff80 0927b000 ffffff80
- [ 1.256670] bd30 f2168000 ffffffc0 00000004 00000000 f2269c00 ffffffc0 00000041 00000000
- [ 1.257470]
- [ 1.257616] Process swapper/0 (pid: 1, stack limit = 0xffffffc0f2168020)
- [ 1.258255] Stack: (0xffffffc0f216bcd0 to 0xffffffc0f216c000)
- [ 1.258805] bcc0: ffffffc0f216bd90 ffffff8008082ba4
- [ 1.259553] bce0: ffffff80080de684 ffffff8009134b20 ffffffc0f23fcb40 ffffff8009126000
- [ 1.260300] bd00: ffffff8009134b20 0000000000000000 ffffff80090b06e0 ffffff80090504a0
- [ 1.261047] bd20: ffffff80090b0650 ffffff800927b000 ffffffc0f2168000 0000000000000004
- [ 1.261794] bd40: ffffffc0f2269c00 0000000000000041 0000000000000454 ffffff8009126000
- [ 1.262541] bd60: ffffffc0f23fcb40 5b005d345b555043 ffffff005d005d34 0000000000000000
- [ 1.263288] bd80: ffffff80090b06e0 cb88537fdc8ba637 ffffffc0f216be20 ffffff8009050df0
- [ 1.264035] bda0: 000000000000022b ffffff80090405d8 ffffff800927b000 0000000000000002
- [ 1.264783] bdc0: ffffff8009126000 ffffff80090b0660 ffffff80090b06e0 ffffff8009050400
- [ 1.265529] bde0: ffffff80090b0650 ffffff800927b000 ffffff8008eb63ed ffffff8008efbc91
- [ 1.266276] be00: ffffff8008baa478 0000000000000000 0000000200000002 cb88537fdc8ba637
- [ 1.267024] be20: ffffffc0f216bea0 ffffff8008b62b34 ffffff8008b62b24 0000000000000000
- [ 1.267770] be40: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.268517] be60: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.269264] be80: 0000000000000000 ffffff80090e66e0 0000000000000000 cb88537fdc8ba637
- [ 1.270012] bea0: 0000000000000000 ffffff8008082690 ffffff8008b62b24 0000000000000000
- [ 1.270758] bec0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.271505] bee0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.272251] bf00: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.272998] bf20: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.273744] bf40: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.274491] bf60: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.275237] bf80: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.275984] bfa0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.276730] bfc0: 0000000000000000 0000000000000005 0000000000000000 0000000000000000
- [ 1.277477] bfe0: 0000000000000000 0000000000000000 ffffffffffffffff ffffffffffffffff
- [ 1.278220] Call trace:
- [ 1.278458] Exception stack(0xffffffc0f216bae0 to 0xffffffc0f216bc10)
- [ 1.279075] bae0: ffffff800927d000 0000008000000000 ffffffc0f216bcd0 ffffff80080de890
- [ 1.279822] bb00: 0000000060000045 000000000000003a ffffff800927e000 0000000000002284
- [ 1.280569] bb20: 0000000000000006 0000000000000000 ffffff8009143618 000000000927e7e8
- [ 1.281317] bb40: ffffffc0f216bbe0 ffffff80080e8ef0 ffffff8009126000 ffffff80080e8ebc
- [ 1.282064] bb60: ffffffc0f2292980 ffffff8008eb8000 ffffff80090f2e40 ffffffc0f2269400
- [ 1.282811] bb80: ffffff8008eb8050 ffffff8009127000 ffffffc0f22929a0 cb88537fdc8ba637
- [ 1.283558] bba0: 0000000000000000 0000000000000010 cb88537fdc8ba637 0000000000000000
- [ 1.284305] bbc0: 0000000000000004 ffffff8008baa6b8 ffffffc0f2269c00 7277705f6e696d20
- [ 1.285052] bbe0: 203536202020203a ffffffffffffffff 59ff5c335a544f42 7f7f7f7f7f7f7f7f
- [ 1.285797] bc00: 0101010101010101 0000000000000030
- [ 1.286266] [<ffffff80080de890>] schedtune_init+0x20c/0x39c
- [ 1.286801] [<ffffff8008082ba4>] do_one_initcall+0x17c/0x198
- [ 1.287347] [<ffffff8009050df0>] kernel_init_freeable+0x1b8/0x270
- [ 1.287933] [<ffffff8008b62b34>] kernel_init+0x10/0xf8
- [ 1.288426] [<ffffff8008082690>] ret_from_fork+0x10/0x40
- [ 1.288936] Code: f9403ba6 f94012a1 f94037a4 f94000c0 (f9400800)
- [ 1.289537] ---[ end trace 05def5689d89a2c3 ]---
- [ 1.290006] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
- [ 1.290006]
- [ 1.290879] CPU2: stopping
- [ 1.291146] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 4.4.55 #609
- [ 1.291840] Hardware name: Firefly-RK3399 Board BOX (Android) (DT)
- [ 1.292428] Call trace:
- [ 1.292670] [<ffffff800808852c>] dump_backtrace+0x0/0x1c8
- [ 1.293188] [<ffffff8008088708>] show_stack+0x14/0x1c
- [ 1.293676] [<ffffff800835835c>] dump_stack+0x8c/0xac
- [ 1.294162] [<ffffff800808e0d8>] handle_IPI+0x140/0x284
- [ 1.294662] [<ffffff8008080e84>] gic_handle_irq+0x10c/0x154
- [ 1.295194] Exception stack(0xffffffc0f6f23000 to 0xffffffc0f6f23130)
- [ 1.295811] 3000: ffffffc0f21c3e20 0000008000000000 ffffffc0f21c3f50 ffffff8008084944
- [ 1.296558] 3020: 0000000060000045 0000000000000000 ffffffc0f6f1f060 0000000000000000
- [ 1.297305] 3040: ffffffc0f21c3f50 ffffffc0f21c3e20 0000000000000000 0000000000000000
- [ 1.298052] 3060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.298799] 3080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.299545] 30a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.300292] 30c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.301038] 30e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.301785] 3100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.302530] 3120: 0000000000000000 0000000000000000
- [ 1.302999] [<ffffff8008081fb4>] el1_irq+0xb4/0x128
- [ 1.303468] [<ffffff8008084944>] arch_cpu_idle+0x84/0x160
- [ 1.303988] [<ffffff80080da9c4>] default_idle_call+0x20/0x28
- [ 1.304531] [<ffffff80080dabf4>] cpu_startup_entry+0x228/0x37c
- [ 1.305090] [<ffffff800808dc70>] secondary_start_kernel+0x188/0x194
- [ 1.305688] [<0000000000282978>] 0x282978
- [ 1.306073] CPU3: stopping
- [ 1.306339] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.4.55 #609
- [ 1.307034] Hardware name: Firefly-RK3399 Board BOX (Android) (DT)
- [ 1.307622] Call trace:
- [ 1.307863] [<ffffff800808852c>] dump_backtrace+0x0/0x1c8
- [ 1.308381] [<ffffff8008088708>] show_stack+0x14/0x1c
- [ 1.308866] [<ffffff800835835c>] dump_stack+0x8c/0xac
- [ 1.309351] [<ffffff800808e0d8>] handle_IPI+0x140/0x284
- [ 1.309852] [<ffffff8008080e84>] gic_handle_irq+0x10c/0x154
- [ 1.310383] Exception stack(0xffffffc0f6f38000 to 0xffffffc0f6f38130)
- [ 1.311000] 8000: ffffffc0f21c7e20 0000008000000000 ffffffc0f21c7f50 ffffff8008084944
- [ 1.311747] 8020: 0000000060000045 0000000000000000 ffffffc0f6f34060 0000000000000000
- [ 1.312494] 8040: ffffffc0f21c7f50 ffffffc0f21c7e20 0000000000000000 0000000000000000
- [ 1.313240] 8060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.313987] 8080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.314734] 80a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.315480] 80c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.316226] 80e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.316973] 8100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.317717] 8120: 0000000000000000 0000000000000000
- [ 1.318185] [<ffffff8008081fb4>] el1_irq+0xb4/0x128
- [ 1.318654] [<ffffff8008084944>] arch_cpu_idle+0x84/0x160
- [ 1.319173] [<ffffff80080da9c4>] default_idle_call+0x20/0x28
- [ 1.319716] [<ffffff80080dabf4>] cpu_startup_entry+0x228/0x37c
- [ 1.320275] [<ffffff800808dc70>] secondary_start_kernel+0x188/0x194
- [ 1.320872] [<0000000000282978>] 0x282978
- [ 1.321255] CPU1: stopping
- [ 1.321522] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G D 4.4.55 #609
- [ 1.322216] Hardware name: Firefly-RK3399 Board BOX (Android) (DT)
- [ 1.322804] Call trace:
- [ 1.323045] [<ffffff800808852c>] dump_backtrace+0x0/0x1c8
- [ 1.323564] [<ffffff8008088708>] show_stack+0x14/0x1c
- [ 1.324049] [<ffffff800835835c>] dump_stack+0x8c/0xac
- [ 1.324534] [<ffffff800808e0d8>] handle_IPI+0x140/0x284
- [ 1.325035] [<ffffff8008080e84>] gic_handle_irq+0x10c/0x154
- [ 1.325566] Exception stack(0xffffffc0f6f0e000 to 0xffffffc0f6f0e130)
- [ 1.326183] e000: ffffffc0f21bbe20 0000008000000000 ffffffc0f21bbf50 ffffff8008084944
- [ 1.326930] e020: 0000000060000045 0000000000000000 ffffffc0f6f0a060 0000000000000000
- [ 1.327677] e040: ffffffc0f21bbf50 ffffffc0f21bbe20 0000000000000000 0000000000000000
- [ 1.328424] e060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.329171] e080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.329917] e0a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.330663] e0c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.331410] e0e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.332157] e100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.332900] e120: 0000000000000000 0000000000000000
- [ 1.333368] [<ffffff8008081fb4>] el1_irq+0xb4/0x128
- [ 1.333835] [<ffffff8008084944>] arch_cpu_idle+0x84/0x160
- [ 1.334354] [<ffffff80080da9c4>] default_idle_call+0x20/0x28
- [ 1.334897] [<ffffff80080dabf4>] cpu_startup_entry+0x228/0x37c
- [ 1.335455] [<ffffff800808dc70>] secondary_start_kernel+0x188/0x194
- [ 1.336052] [<0000000000282978>] 0x282978
- [ 1.336437] CPU4: stopping
- [ 1.336711] CPU: 4 PID: 0 Comm: swapper/4 Tainted: G D 4.4.55 #609
- [ 1.337420] Hardware name: Firefly-RK3399 Board BOX (Android) (DT)
- [ 1.338020] Call trace:
- [ 1.338271] [<ffffff800808852c>] dump_backtrace+0x0/0x1c8
- [ 1.338800] [<ffffff8008088708>] show_stack+0x14/0x1c
- [ 1.339295] [<ffffff800835835c>] dump_stack+0x8c/0xac
- [ 1.339788] [<ffffff800808e0d8>] handle_IPI+0x140/0x284
- [ 1.340297] [<ffffff8008080e84>] gic_handle_irq+0x10c/0x154
- [ 1.340839] Exception stack(0xffffffc0f6f4d000 to 0xffffffc0f6f4d130)
- [ 1.341466] d000: ffffffc0f21cbe20 0000008000000000 ffffffc0f21cbf50 ffffff8008084944
- [ 1.342226] d020: 0000000060000045 0000000000000000 ffffffc0f6f49060 0000000000000000
- [ 1.342986] d040: ffffffc0f21cbf50 ffffffc0f21cbe20 0000000000000000 0000000000000000
- [ 1.343745] d060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.344504] d080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.345263] d0a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.346022] d0c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.346781] d0e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.347539] d100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
- [ 1.348298] d120: 0000000000000000 0000000000000000
- [ 1.348772] [<ffffff8008081fb4>] el1_irq+0xb4/0x128
- [ 1.349249] [<ffffff8008084944>] arch_cpu_idle+0x84/0x160
- [ 1.349777] [<ffffff80080da9c4>] default_idle_call+0x20/0x28
- [ 1.350329] [<ffffff80080dabf4>] cpu_startup_entry+0x228/0x37c
- [ 1.350896] [<ffffff800808dc70>] secondary_start_kernel+0x188/0x194
- [ 1.351505] [<0000000000282978>] 0x282978
- [ 1.351899] CRU:
- [ 1.352091] 00000000: 00000044 00001201 80000000 00000108 00000007 00007f00 00000000 00000000
- [ 1.352910] 00000020: 00000044 00001201 80000000 00000108 00000007 00007f00 00000000 00000000
- [ 1.353727] 00000040: 00000042 00001201 8000031f 00000108 00000007 00007f00 00000000 00000000
- [ 1.354546] 00000060: 00000190 00001206 80000000 00000108 00000007 00007f00 00000000 00000000
- [ 1.355365] 00000080: 00000190 00001206 80000000 00000108 00000007 00007f00 00000000 00000000
- [ 1.356182] 000000a0: 0000004b 00001301 80000000 00000108 00000007 00007f00 00000000 00000000
- [ 1.357001] 000000c0: 000000c6 00001202 8000031f 00000008 00000007 00007f00 00000000 00000000
- [ 1.357819] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.358637] 00000100: 00000300 00000505 00000140 00006404 00000083 00008581 00008320 00000141
- [ 1.359456] 00000120: 00000181 00008181 00000141 00000141 00004141 00008343 00003185 00000500
- [ 1.360274] 00000140: 0000010f 00000300 00004a87 00000103 00009381 00008387 00001103 00001087
- [ 1.361093] 00000160: 00008247 00000187 00003143 000002dc 00000300 00000300 00000300 00000000
- [ 1.361911] 00000180: 00006300 00000200 00000200 00000200 00000200 00000200 00003f3f 00000081
- [ 1.362730] 000001a0: 00000000 00000000 00004141 00000421 00008700 000002dc 00000004 00000381
- [ 1.363548] 000001c0: 00000381 00000001 00000003 00000087 00000087 00000141 00000141 00008181
- [ 1.364367] 000001e0: 0000833f 00000007 00008f1f 00008f8f 00008f8f 00008787 00008787 00008787
- [ 1.365185] 00000200: 000000c5 000000c5 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.366003] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.366820] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.367638] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.368457] 00000280: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60
- [ 1.369276] 000002a0: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 00000000 00000000 00000000 00000000
- [ 1.370094] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.370912] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.371730] 00000300: 00000000 00000000 00000202 00000000 00000000 00000000 00000000 00000000
- [ 1.372549] 00000320: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.373366] 00000340: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.374185] 00000360: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.375003] 00000380: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.375821] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.376637] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.377455] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.378273] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.379092] 00000420: 000000bc 00007070 00000000 00000014 00000000 00000000 00000000 00000000
- [ 1.379909] 00000440: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.380728] 00000460: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.381546] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.382364] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.383182] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.384000] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.384819] 00000500: 00000000 00000000 00640064 00000000 00000003 00000001 00000000 00000000
- [ 1.385637] 00000520: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.386455] 00000540: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.387274] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.388088] 00000580: 00000004 00000000 00000004 00000000 00000004
- [ 1.388676] PMU CRU:
- [ 1.388898] 00000000: 000000a9 00001203 80000000 00000108 00000007 00007f00 00000000 00000000
- [ 1.389718] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.390538] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.391358] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.392178] 00000080: 0000800d 00001986 00000d0d 0000000d 000002dc 00000200 0bb8ea60 0bb8ea60
- [ 1.392999] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.393819] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.394639] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.395460] 00000100: 00000000 00000000 00000000 00000000 00000024 00000000 00000000 00000000
- [ 1.396276] 00000120: 00000000 00000180 00000000 00000000 00000003
- [ 1.396866] Rebooting in 5 seconds..
Copy the code |
