New Topic
Network Performance problem (with Gigabyte Lan)
2
Posted at 12/18/2014 04:20:21      View8444 | Replies16        Print      Only Author   [Copy Link] 1#
Hi ,
I compiled an android image using instructions on the wiki. Compilation is ok but after flash there is no vido on hdmi nor on vga.
I plugged the board with serial connection, boot process seems ?k. I can access the prompt
What did i miss with kernel compil ??
Thx for answer
Pacopad
Posted at 12/18/2014 09:23:17        Only Author  2#
Could you please show us the log?
Posted at 12/18/2014 14:45:24        Only Author  3#
Hi Andy, here is the output?
http://pastebin.com/9TJcG62d
Actually , there is no display connected for the logs because my computer is too far away my tv set . Is it important ??
Thank you for you help?
Pacopad
Posted at 12/19/2014 09:53:05        Only Author  4#
The log seems not complete.
Did it stop at this point??[ ? 38.07457t? ?f??????}??????734): camsys_marvin(ed8e9510) is closed
Posted at 12/19/2014 10:09:09        Only Author  5#
Please revert back to factory firmware, and flash your self compiled kernel.img and resource.img to see if it works.
BTW, your kernel log is strange. We do not have "D1:camsys ..." lines in normal boot.
Posted at 12/19/2014 15:59:19        Only Author  6#
Hi all,
i solved this problem by building a full upgrade.mg file.
I got a new problem
Wired Network performances are very very poor. Same as factory image.
I tried some other TV Box images and i found one , i dont remember which one, that offers good network speed.
Which side must i check , kernel or software ? My image is based on the latest SDK provided by Firefly.
Thx for return
Pacopad
Posted at 12/19/2014 16:08:16        Only Author  7#
Have you?plunged? the Antenna yet?
Posted at 12/19/2014 16:44:58        Only Author  8#
Hi
I got matter with wired (ethernet) network. I got ip from dhcp but transfer rates are very bad
Pacopad
Posted at 12/22/2014 11:16:21        Only Author  9#
Hi pacopad,  please do a iperf test on the wired ethernet and post the result here.
Posted at 12/22/2014 14:29:32        Only Author  10#
Hi Guys,?
i done iperf test on saturday , here is the report i got about 3,5 Mbits/s on a gigabyte switch (which work correctly with other devices like my ps3 and ps4) and i got 95 MBits/s when plugged on a 100MBps port of my internet box. I got about 30Mbps with wifi.?
I think there it is a kernel bug with mac part ....
is it possible to force 100Mbps Full duplex on the board with android ??
Thank you for return ??
Return to List
12
