AIO-3399J latest Android 7.1 ROM with LVDS ?
80
Posted at 1/10/2018 19:34:21      View:5607 | Replies:6        Print      Only Author   [Copy Link] 1#
I need to use the LVDS connection on the AIO-3399J with Android 7.1
I cannot find the ROM pre-built.  The "download" tab for this specific board is empty : http://en.t-firefly.com/doc/download/index/id/31.html
This page http://en.t-firefly.com/doc/product/info/id/437.html mentions "You can download firmwares on compiled update.img" but the link goes nowhere.
Where can I find AIO-3399J Android 7.1 ROM with LVDS support ?
Regards
Tim
Posted at 1/11/2018 09:34:51        Only Author  2#
they have no lvds modules to sell temporary, but you can take a sample rk3399-firefly-aio-lvds.dts for debug
Posted at 1/11/2018 10:01:21        Only Author  3#
1) I am looking for pre-built Android 7.1 ROM with LVDS support enabled.  I cannot find this ROM / img file(s).
2) As I cannot find a pre-built ROM I have just custom built a ROM and tried to enable LVDS using:
  $ make -j72 -d KERNEL_DTS=rk3399-firefly-aio-lvds
and flashed the AIO-3399J board with the new system.img
I have connected my LVDS display controller to the LVDS connector on the board.  I have also connected the LVDS power.  I have set the LCD_VCC to 12v using jumper pin.
I disconnect HDMI display, reboot the board with only LVDS connected but the display is off.
How do I get LVDS to work on the board in terms of ROM/software and hardware connection ?
I think you are referring me to the file kernel/arch/arm64/boot/dts/rockchip/rk3399-firefly-aio-lvds.dts but I don't know what to do next !
Regards
Tim
Posted at 1/11/2018 17:53:06        Only Author  4#
ducksoft Posted at 1/11/2018 10:01
1) I am looking for pre-built Android 7.1 ROM with LVDS support enabled.  I cannot find this ROM / i ...
1. make sure your LVDS connector data io is suitable for the board connector .
2. LVDS need backlight power, which voltage your LVDS needed , just short the power  silk-screen 'LCD_VCC'  on the board . These are 3.3v/5v/12v.
Posted at 1/11/2018 18:11:24        Only Author  5#
1. Yes I have confirmed the LVDS pin connector between the AOI-3399J board and the display controller using the documentation.
2. Yes I have set theLCD_VCC pins (see above "I have set the LCD_VCC to 12v using jumper pin.") and also tried 3.3V and 5V just incase :-)
I think I need to set the display panel characteristics in some .dts file but I'm not sure if I need to just update the rk3399-firefly-aio-lvds.dts file directly or if I need to copy this file to a new file and update the new file?
Posted at 1/11/2018 19:09:33        Only Author  6#
ducksoft Posted at 1/11/2018 18:11
1. Yes I have confirmed the LVDS pin connector between the AOI-3399J board and the display controlle ...
1."make ARCH=arm64 rk3399-firefly-aio-lvds.img -j8 " for making kernel.img and resource.img
flash them just fine .
2. After that, backlight is the first stuff to make sure.
3. Follow your LVDS datasheet to comfirm the timing .
Posted at 6/6/2018 17:06:17        Only Author  7#
Hi,
I try to get LVDS work on AIO-3399J board (Ubuntu) , but i cant find rk3399-firefly-aio-lvds.dts file anywhere? Is the LVDS support some other dts file?
BR,
Pekka
