Firefly-RK3399 won't boot without Type-C cable connected
35
Posted at 1/18/2018 23:18:41      View4711 | Replies7        Print      Only Author   [Copy Link] 1#
Hello:
I have loaded two different Linux releases to the Emmc  and the unit works fine IF the usb Type-C cable is connected.
If I remove the Type C cable from the Firefly the unit will not boot.  The hdmi monitor does not display anything and the serial monitor is flooded with invalid characters mixed in with some readable info.
This seems to have something to do with receiving power over the type-c usb port.    If I plug the type-c cable in to the PC while the PC is Off the firefly still boots so I assume it needs to sense power at the port in order to boot correctly.
Is there some setting I am missing?   Or is there a jumper on the board?
Thanks in advance!
Posted at 1/19/2018 07:07:39        Only Author  2#
Nevermind --- looks like it needs the Type-c cable connected if the debug serial monitor is connected.
If both are disconnected it works fine....
Posted at 1/11/2026 06:05:08        Only Author  3#
Your article is truly inspiring, Im so grateful for your sharing! Good luck on your exams! Free C_FIORD_2502 vce torrent exam papers are now available.
Posted at 2/6/2026 17:59:40        Only Author  4#
The content of the article is very insightful, and Ive benefited a lot. The Latest GCIH associate level exam helped me achieve a promotion and salary increase. Now, its free for everyone. Best wishes for your professional success!
Posted at 2/6/2026 18:37:25        Only Author  5#
ُIµC-BCSPM-2502}100%ɹͨ^C-BCSPM-2502ԇęC҂aƷƷ|ǷdzõģҸµٶҲġ}еĆ}ʹ𰸶c挍ĿԇP҂SAP C-BCSPM-2502ܛ汾}׌w挍Ŀԇhֶ֧_XbʹáC-BCSPM-2502}WYόͨ^˴οԇñC߀ڪqԥʲôՈMSAP C-BCSPM-2502}ɣ
Posted at 2/8/2026 06:54:55        Only Author  6#
Im deeply thankful for your article, it really stood out to me. The Practice test C_THR86_2505 pdf questions helped me secure a raise and promotion, and today, Im sharing them for free!
Posted at 2/19/2026 10:56:37        Only Author  7#
Your article is breathtakingly good, thank you for sharing it! Get free Exam AZ-305 outline to level up your IT knowledge. Wishing you success!
Posted at 2/22/2026 07:16:10        Only Author  8#
Thank you for sharing such a powerful article! Examcode materials are free for everyonegood luck! New CISSP test fee
