New Topic
firefly .IMG can be used to boot linux on any rk3288
10
Posted at 12/19/2014 00:39:17      View:8216 | Replies:15        Print      Only Author   [Copy Link] 1#
i have OTT-928 (cs928) Android TV box HELP,can be used to boot linux? Dual boot ? firefly .IMG can be used to boot linux on any rk3288 ?
CS928 / OTT928 hardware specifications:
SoC – Rockchip RK3288 quad core CortexA17 @ 1.8 GHz + Mali-T764 GPU with support for OpenGL ES 1.1/2.0 /3.0, and OpenCL 1.1
System Memory – 2GB DDR3
Storage
OTT928 – 16GB NAND Flash + micro SD ?slot (up to 32 GB)
Connectivity – 100M/1000M Ethernet, dual band WiFi 802.11 b/g/n (2.4GHz/5GHz) and 802.11 a/c using external Wi-Fi antenna, and Bluetooth 4.0
Video Output – HDMI output, AV output (3.5mm jack)
Audio Output – HDMI, AV, and optical S/PDIF
USB – 3x USB 2.0 host port, 1x micro USB OTG
Camera – 5MP retractable camera
Power Supply – 5V/2A
Posted at 12/26/2014 16:21:32        Only Author  2#
Currently there is no Ubuntu 14.10 firmware yet.
14.04 is the LTS version. Anything it does not fit your need?
Posted at 12/25/2014 15:59:52        Only Author  3#
Hi
How can I upgrade Lubuntu 14.04 to 14.10?
There is only a 14.04 precompiled linuxrootfs with dual-boot firmware.
Can you post 14.10 precompiled dual-boot firmware?
Followed instructions here
http://www.unixmen.com/upgrade-ubuntu-1 ... 10-utopic/
but gets stuck on reboot to recovery when update is finished and boot back to Ubuntu/Lubuntu.
Posted at 12/22/2014 10:31:34        Only Author  4#
I think some rk3288 board similar Firefly-RK3288 can work it
Posted at 12/22/2014 11:10:05        Only Author  5#
The linux rootfs can be reused.
And the kernel, you can have a try, but might not work due to hardware differences.
Posted at 12/26/2014 19:18:00        Only Author  6#
Lbuntu 14.04 is fine.
Just saw that UGOOS is making frequent updated Ubuntu 14.10 firmware for RK3288 devices here.
http://ugoos.net/blog/ugoos-ut3-android ... alboot-v02
http://ugoos.net/blog/ugoos-ut3-um3-fir ... lboot-v021
Would be nice if Firefly can also include some of the fixes/improvements in future versions.
Posted at 12/19/2014 03:57:35        Only Author  7#
you might be able to use the source to make something for this device but it will most likely not work. If youre feeling brave you can give it a try and see if it does but dont blame me if you brick your device xP
Posted at 1/31/2015 03:34:30        Only Author  8#
Re: firefly .IMG can be used to boot linux on any rk3288
Dual Boot BETA ROM OTT- 928 { CS928 } Android 4.4 & Ubuntu 14.04 working
https://www.youtube.com/watch?v=G9KJoZQ-QB4
update link
https://mega.co.nz/#!P5xmlRAB!x0uPysVhEwMXz-iTosjalgsOnzbU6zklc7NKD1eKoW8
Posted at 1/31/2015 05:57:01        Only Author  9#
Can?t download the image file. Need decriptation code...
Any help?
Thanks
Posted at 1/31/2015 06:17:10        Only Author  10#
Return to List
12
