New Topic
Android 7.1.1 Dual MIPI Camera Support ...
37
Posted at 1/27/2018 16:38:30      View:14150 | Replies:17        Print      Only Author   [Copy Link] 1#
Hello.
Configuration:
Firefly-RK3399_Android7.1.1_170516.img
OV13850 x 2
It seems the camera app has no menu to switch between two cameras.
Is there any way to test dual MIPI camera support visually thru HDMI monitor?
I am getting the following image referrring from Binocular camera data acquisition(http://en.t-firefly.com/doc/case/info/id/210.html).
DualCam-Firefly-RK3399_Android7.1.1_MP_180122.7z
Thanks in advance.
Posted at 1/27/2018 18:00:42        Only Author  2#
DualCam-Firefly-RK3399_Android7.1.1_MP_180122.7z actuallty contains Firefly-RK3399_Android7.1.1_MP_180122.img.
And it showed me what I want through a custom CameraExample app.
Where can I get the source code of the CameraExample app?
Posted at 3/1/2018 15:04:09        Only Author  3#
Hey, I want to interface the same camera with rk3399 but it is not working means, when I open up a camera application it says "Camera not found".
FYI : I am using OV13850 13MP camera and I am connecting this camera to 24 Pins DVP interface of rk3399.
Am I missing something?
Posted at 3/27/2018 13:34:30        Only Author  4#
KrunalShah Posted at 3/1/2018 15:04
Hey, I want to interface the same camera with rk3399 but it is not working means, when I open up a c ...
Plase check "Firefly-RK3399_Android7.1.1_MultiCodec_180125.img"
Posted at 8/14/2018 18:00:25        Only Author  5#
Hi
Where this image can be downloaded ?
Posted at 8/24/2018 09:33:12        Only Author  6#
Posted at 9/3/2018 21:12:10        Only Author  7#
leung先森 Posted at 8/24/2018 09:33
http://en.t-firefly.com/doc/case/info/id/214/product_id/3.html
The link to the image of rk3399
http://www.t-firefly.com/share/i ... 5544c37219b64f.html
lead to a page with "no data" text
Posted at 9/4/2018 15:57:27        Only Author  8#
Have already change GoogleDriver download Have a try.
Posted at 9/6/2018 17:24:42        Only Author  9#
Thanks
Already downloading
is there any difference between the two files ?
Posted at 9/7/2018 14:28:05        Only Author  10#
Arkady Posted at 9/6/2018 17:24
Thanks
Already downloading
Using for diff board . Firefly-RK3288, Firefly-RK3399 , AIO-3399J
Return to List
12
