Xubuntu 16.04 HDMI Support ....
37
Posted at 1/27/2018 19:34:53      View:4350 | Replies:3        Print      Only Author   [Copy Link] 1#
Hello.
             HD Monitor    UHD Monitor
Android 7.1.1    OK            OK
Xubutu 16.04    OK            FAIL
Android 7.1.1: Firefly-RK3399_Android7.1.1_MP_170829.img or Firefly-RK3399_Android7.1.1_MP_180122.img
Xubutu 16.04: Firefly-rk3399_xubuntu1604_201705111112.img or Firefly-RK3399_xubuntu1604_201711301130.img
Is there any other version of official Xubuntu from Firefly which fixes this problem?
BTW, scale mode (100%/Cinema/Wide/General) of my UHD monitor is not perfectly supported in Android 7.1.1 in that it fails to display any image in 100% scale mode although HDMI signal is emitted to the monitor.
Thanks in advance.
Posted at 1/30/2018 09:05:27        Only Author  2#
hi,
you need to updat resource.img
or add these at the end of ‘rk3399-firefly-linux.dts’ , then compilie..
  1. &hdmi_in_vopb {
  2. status = "okay";
  3. };
Copy the code
resource.rar
68.42 KB, Down times: 9
Posted at 1/30/2018 15:04:23        Only Author  3#
Thanks to luvings.
Updating the Resource partition with the luvings' attached 'resource.img' works with my UHD monitor.
(Firefly-RK3399_xubuntu1604_201711301130.img)
I'll try with modifying device tree as recommened by luvings tonight in my spare time.
BTW, be warned not to use too long path for resource.img in AndroidTool v2.38.
Posted at 2/5/2026 06:09:05        Only Author  4#
Your article is outstanding; thank you for sharing it! Explore SOL-C01 new exam cram materials, which is packed with valuable content, freely available to help you.
