3V SPI/I2C voltage translation
38
Posted at 1/31/2018 15:59:12      View:4740 | Replies:6        Print      Only Author   [Copy Link] 1#
I want to connect my MCU that run on 3.3V with your board via SPI and I2C, but FireFly voltage level on these buses is 3V. Will I need voltage translation or will it be on spec with FireFly ?
Posted at 1/31/2018 17:00:05        Only Author  2#
Basiclly, 3.3v is the same as 3v .
But if your MCU is serious about voltage controled, just try apply 3v to your MCU.
I trust your MCU have its Float voltage.
Posted at 1/31/2018 19:46:12        Only Author  3#
Ok, thanks.
Posted at 2/5/2018 03:13:58        Only Author  4#
Does anyone actually knows if the RK3399 VDDIOs bank @3.0V are Voltage tolerant to VDD+0.3V . Trying to find the information in the RK3399 datasheet but can't find anything.
As per the RK3399 carrier board schematic - the UART2DBG_RX net it directly tied to a 3.3V pullup and the IO bank is set to 3.0V. Any long term issue with this ?
Posted at 2/5/2018 09:35:57        Only Author  5#
big_whit Posted at 2/5/2018 03:13
Does anyone actually knows if the RK3399 VDDIOs bank @3.0V are Voltage tolerant to VDD+0.3V . Trying ...
u can try to set up the group gpio of the UART2DBG_RX  from the hardware datasheet.
It is controled by pmu.
Posted at 1/11/2026 18:23:59        Only Author  6#
Such an enlightening read, I appreciate your sharing! The Question AWS-Solutions-Architect-Associate explanations content is very helpful, and you don’t need to pay for it.
Posted at 1/24/2026 00:23:08        Only Author  7#
The article was quite thought-provoking. Reliable Revenue-Cloud-Consultant-Accredited-Professional exam questions helped me achieve the promotion and raise I dreamed of, and now I’m giving it to you for free!
