Issues with HDMI display resolution
Posted at 2/6/2018 21:47:51
View5960
Replies4
Hello,
I have an RK-3288 and I'm running into issues getting the correct display resolution over HDMI. It looks like i'm maybe getting 720 or lower, which is then upscaled in my monitor and looks horrible.
If I instead plug in VGA cable it looks good though.
I've tried forcing the HDMI to 1080p but I'm having issues. It looks like xrandr does not properly detect the HDMI port:
sudo xrandr --newmode "1920x1080_60.00" 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync
xrandr: Failed to get size of gamma for output default
sudo xrandr --addmode HDMI-0 1920x1080_60.60
xrandr: cannot find output "HDMI-0"
sudo xrandr --query
Screen 0: minimum 1920 x 1080, current 1920 x 1080, maximum 1920 x 1080
default connected 1920x1080+0+0 0mm x 0mm
1920x1080 60.0*
1920x1080_60.00 (0x6c) 173.0MHz
h: width 1920 start 2048 end 2248 total 2576 skew 0 clock 67.2KHz
v: height 1080 start 1083 end 1088 total 1120 clock 60.0Hz
I'm using the built in Ubuntu version which was delivered with the device. I've run "apt-get update/upgrade" to download patches.
Additional commands that I've tried:
firefly@firefly:~$ sudo lspci
pcilib: Cannot open /proc/bus/pci
lspci: Cannot find any working access method.
firefly@firefly:~$ sudo lshw -C display
firefly@firefly:~$ cat /etc/X11/xorg.conf.d/*
Section "InputClass"
Identifier "gslX680 evdev touchscreen"
MatchProduct "gslX680"
MatchDevicePath "/dev/input/event*"
Option "EmulateThirdButton" "true"
Option "EmulateThirdButtonTimeout" "500"
Option "EmulateThirdButtonMoveThreshold" "50"
Driver "evdev"
EndSection
Identifier "evdev gsl680"
#MatchIsTouchscreen "on"
MatchProduct "gsl680"
Driver "evdev"
EndSection
Thanks for your help
