Question on AIO-3399J Hdmi input capabilities
115
Posted at 2/9/2018 17:18:47      View:7271 | Replies:6        Print      Only Author   [Copy Link] 1#
From the AIO-3399J spec sheet I can see the HDMI input can capture up to 1080p60.
In spec sheet of the used toshiba component  https://toshiba.semicon-storage. ... rodName=TC358749XBG it is stated that the component can also be used to support for 3D framepacked modes.
Is the AIO-3399J capable of capturing the HDMI Fp720 and Fp1080 signals ?
Posted at 2/10/2018 10:50:39        Only Author  2#
yep, its prevew resolution support 1080p60.
capture can get to 1080p55
Posted at 2/12/2018 22:55:37        Only Author  3#
Thank you for the provided information leung先森!
Can one get the rk3399 to capture/preview the 3D fp1080p HDMI/CSI signal towards 1920x2160@24 as is common for 1080fp or does it need to be treated as multiple 1920x1080 sequential frames somehow ?
As I assume most of the modifications for supporting this would need to land under hardware/rockchip/camera/CameraHal,  is there some additional documentation this part by any chance?
Posted at 2/23/2018 11:58:31        Only Author  4#
dbe_dev Posted at 2/12/2018 22:55
Can one get the rk3399 to capture/preview the  ...
http://en.t-firefly.com/doc/product/info/id/292.htmlthe chipset pdf
Posted at 1/10/2026 12:30:58        Only Author  5#
なぜみんなが順調にPMIのPMI-CPMAI試験に合格できることに対する好奇心がありますか。PMIのPMI-CPMAI試験に合格したいんですか。実は、彼らが試験に合格したコツは我々GoShikenの提供するPMIのPMI-CPMAI試験ソフトを利用したんです。豊富の問題集、専門的な研究と購入の後の一年間の無料更新、ソフトで復習して、自分の能力の高めを感じられます。PMIのPMI-CPMAI試験に合格することができます。
Posted at 1/16/2026 23:18:26        Only Author  6#
I’m so thankful for your article, it really opened my eyes. I used the Valid 401 exam discount to achieve a promotion and salary hike. Now, it’s free to all. Hope you all advance in your careers!
Posted at 2/5/2026 17:15:33        Only Author  7#
Google인증Associate-Cloud-Engineer시험의자격증은 여러분에 많은 도움이 되리라 믿습니다. 하시는 일에서 한층 더 업그레이드될 것이고 생활에서도 분명히 많은 도움이 될 것입니다. 자격증취득 즉 재산을 얻었죠.Google인증Associate-Cloud-Engineer시험은 여러분이 it지식테스트시험입니다. DumpTOP에서는 여러분의 편리를 위하여 DumpTOP만의 최고의 최신의Google Associate-Cloud-Engineer덤프를 추천합니다. DumpTOP를 선택은 여러분이 최고의 선택입니다. DumpTOP는 제일 전면적인Google Associate-Cloud-Engineer인증시험자료의 문제와 답을 가지고 잇습니다.
