Building The compiler environment
10
Posted at 11/25/2014 15:10:44      View:4454 | Replies:1        Print      Only Author   [Copy Link] 1#
This post will introduce on how to build the compiler environment.
Step one : Install the Ubuntu12.04.
You can use the CD image to finish the installation.
After finishing the installation. Update the system
Step two:
Download the SDK from the official website and buid the compiler environment.
You can download the SDK using git or download the compressed package directory.
The SDK website is : http://pan.baidu.com/s/1eQjBGQI?qq-pf-to=pcqq.c2c
While finish the download,you can follow the official steps to accomplish the compiler environment.
You can also use the scripts of java6.sh,ubuntu1204_evn.sh and arm.sh to install the environment.
1. Enter the command:
  1. ./java6.sh
Copy the code
This command will install the JDK6(During the installation you may input "y"or "yes" to finish it)
Then the JDK installation is finished.
2. Enter the command :
  1. ./ubuntu1204_evn.sh
Copy the code
Install the libs and packages which nedds for the compiling .
(During the installation you may input  “y” or “yes” to finish it)
3. Enter the command:
  1. ./arm.sh
Copy the code
Install the cross compile tools and the software package which needs for the kernel compiling.
Now, you have finished the compile environment installation .
4.If you download the SDK is compress package. You should check the MD5 code .
  1. $ md5sum /path/to/firefly-rk3288_sdk_git.tar.gz
  2. 0db2e0c5c2a1cb344f923cd538ed9443 firefly-rk3288_sdk_git.tar.gz
Copy the code
5. Decompress the SDK
After the SDK compression, you will get a “.git” file. This file is the management of git project.  There is no source code in your directory. You
  1. $git reset
Copy the code
After run this command you can see the structure of source code.
6. Synchronous the source code
  1. git remote add bitbucket <!-- m --><a class="postlink" href="https://TeeFirefly@bitbucket.org/T-Firefly/firefly-rk3288.git"><!-- m --></a><a class="postlink" href="https://TeeFirefly@bitbucket.org/T-Fire"><!-- m --></a><a class="postlink" href="https://TeeFirefly@bitbucket.org/T-Fire"><!-- m --></a><a class="postlink" href="https://TeeFirefly@bitbucket.org/T-Fire"><!-- m --></a><a class="postlink" href="https://TeeFirefly@bitbucket.org/T-Fire"><!-- m --></a><a class="postlink" href="https://TeeFirefly@bitbucket.org/T-Fire"><!-- m --></a><a class="postlink" href="https://TeeFirefly@bitbucket.org/T-Fire">https://TeeFirefly@bitbucket.org/T-Fire</a><!-- m --><!-- m --><!-- m --><!-- m --><!-- m --><!-- m --> ... rk3288.git<!-- m -->
  2. git pull bitbucket master:master
Copy the code
Now ,you have get the source code.
Go to the source code path
1.Source code compiling(Note:the kernel must be compiled first or android compiling will occur errors)
After go into the kernel path,run the command:
  1. make firefly-rk3288_beta_defconfigmake -j8 firefly-rk3288_beta.img
Copy the code
Then the kernel is build successfully.
2.Android compiling
Go into the root directory of SDK,run the command:
  1. source build/envsetup.sh && lunch rk3288-eng && make -j8
Copy the code
This will spend a long time. I use the lenovo L440 I5+2G laptop,it needs about 4 hours to compile.
Now , you have finished the android compiling.
Posted at 12/6/2014 04:40:44        Only Author  2#
@Andy
Will try this, first time I have seen the build done this way.  Just one question and that is; Does this allow one to download the source files to the computer.
