New Topic
wifi not connecting -- SOLVED last post
2
Posted at 12/26/2014 09:48:10      View:7169 | Replies:11        Print      Only Author   [Copy Link] 1#
I have a wifi access point.? I can connect to it with my phone and my Debian laptop.
I install wicd, the same program I use on the laptop.
With the same wpa_supplicant.conf file I use on the laptop the Firefly won't connect.? It maybe because I'm not familiar with Ubuntu and don't have the file in the right location or ???
I'm not sure the config file actually gets read.
Any clues on troubleshooting?
Posted at 12/17/2014 16:53:31        Only Author  recommend
Im looking at getting a heavy duty power adapter here for overclocking and heavy stress testing
http://www.adafruit.com/products/658
What I want to know is does the board already have a 2.1mm plug or should i purchase the usb converter for the Power adapter?
http://www.adafruit.com/products/988
if this is in the wiki im sorry i missed it
Posted at 12/26/2014 12:04:39        Only Author  3#
You need to connect your phone to Firefly through WIFI, so your phone can share the Firefly's network, right? On Ubuntu?
Posted at 12/26/2014 13:17:30        Only Author  4#
No.
I have a wifi router that connects to the Internet.
I want the Firefly to be able to connect to that router.
I know the router works because my phone, (and others) can access the Internet via the router.
My Debian laptop can connect via the router.
Using wpa_supplicant.conf from the laptop doesn't work on the Firefly. ?However, Ubuntu uses different locations for certain config files than Debian and I'm not sure I have the file in the correct location for Ubuntu.
Thanks.
vip
Rank: 6Rank: 6
Posted at 12/26/2014 14:55:09        Only Author  5#
does the android?firmware be?able to connect the router?
Posted at 12/26/2014 15:00:12        Only Author  6#
In the default factory Ubuntu OS, there's a NetworkManager applet in the tray.?
You can try that first to make sure the connection is ok. Then try the wpa_supplicant
method.
Posted at 12/26/2014 15:22:15        Only Author  7#
Thanks,
I had to log in as root to set that up and it connected.
Posted at 10/1/2025 13:24:35        Only Author  8#
Cool! Seems like someone finally figured out the Wi-Fi issue on their Firefly-RK3288. This reminds me of how people solve issues on the Shindo Life Wiki for that Naruto-inspired Roblox game! Glad it's solved.
Posted at 1/11/2026 04:58:07        Only Author  9#
一般的には、あなたは多くの時間と精力を利用してAdvanced-Administrator試験を準備する必要があります。悩んでいるなら、弊社のAdvanced-Administrator資料を利用して、あなたは試験に関する情報を了解することができます。我々の問題集の的中率は高いですから、CertJukenの資料を利用して試験を準備して、あなたの学習効率を高めることができます。
Posted at 1/12/2026 13:39:40        Only Author  10#
Your article was a true standout, I’m really grateful for it. Test D-PSC-DY-23 tips offers valuable insights, and it’s all free.
Posted at 1/18/2026 23:19:09        Only Author  11#
I appreciate you sharing this motivating article! I achieved my promotion and salary raise using this Trustworthy FCP_FML_AD-7.4 exam content. Now it’s free to everyone. Best of luck with your own career advancements!
Return to List
12
