Android SDK Build fails to boot
42
Posted at 12/27/2014 04:29:48      View15827 | Replies8        Print      Only Author   [Copy Link] 1#
I've built an Android image as per the wiki instructions and flashed the follow to replace the exsiting emmc partitions from the directory rockdev/Image-rk3288.
misc.img
boot.img
system.img
resource.img
kernel.img
Android fails to start, boot output is below. Unfortunately the instructions are vague about what need be flashed.
  1. U-Boot 2014.10-RK3288-02 (Dec 19 2014 - 19:50:49)
  2. CPU: rk3288
  3. CPU's clock information:
  4.     arm pll = 600000000HZ
  5.     periph pll = 300000000HZ
  6.     ddr pll = 200000000HZ
  7.     codec pll = 594000000HZ
  8. Board:  Rockchip platform Board
  9. DRAM:  Found dram banks:1
  10. Adding bank:0000000000000000(0000000080000000)
  11. 128 MiB
  12. storage init OK!
  13. Using default environment
  14. GetParam
  15. check parameter success
  16. Unknow param: MACHINE_MODEL:rk30sdk!
  17. Unknow param: MACHINE_ID:007!
  18. Unknow param: MANUFACTURER:RK30SDK!
  19. Unknow param: PWR_HLD: 0,0,A,0,1!
  20. failed to prepare fdt from boot!
  21. power key: bank-0 pin-5
  22. can't find dts node for ricoh619
  23. pmic:act8846
  24. Can't find dts node for fuel guage cw201x
  25. SecureBootEn = 0, SecureBootLock = 0
  26. #Boot ver: 2014-12-19#2.17
  27. sn:1006120001000110
  28. checkKey
  29. vbus = 1
  30. no fuel gauge found
  31. no fuel gauge found
  32. read logo_on switch from dts [0]
  33. no fuel gauge found
  34. Hit any key to stop autoboot:  0
  35. failed to load fdt from boot!
  36. kernel   @ 0x02000000 (0x005f05b0)
  37. ramdisk  @ 0x04bf0000 (0x00120f7d)
  38. Secure Boot state: 0
  39. bootrk: do_bootm_linux...
  40.    Loading Device Tree to 0480c000, end 04827200 ... OK
  41. Add bank:0000000000000000, 0000000080000000
  42. Starting kernel ...[    0.000000] Booting Linux on physical CPU 0x500
  43. [    0.000000] Initializing cgroup subsys cpu
  44. [    0.000000] Initializing cgroup subsys cpuacct
  45. [    0.000000] Linux version 3.10.0 (mtx512@mtx512-Inspiron-620) (gcc version 4.8.2 (Ubuntu/Linaro 4.8.2-16ubuntu4) ) #4 SMP PREEMP4
  46. [    0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
  47. [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
  48. [    0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288
  49. [    0.000000] hdmi init vic is -1
  50. [    0.000000] rockchip_ion_reserve
  51. [    0.000000] cma: CMA: reserved 16 MiB at 2e800000
  52. [    0.000000] Memory policy: ECC disabled, Data cache writealloc
  53. [    0.000000] PERCPU: Embedded 9 pages/cpu @c1e86000 s13952 r8192 d14720 u36864
  54. [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 522768
  55. [    0.000000] Kernel command line: console=ttyFIQ0 androidboot.hardware=rk30board androidboot.console=ttyFIQ0 board.ap_has_alsa=0 0
  56. [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
  57. [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
  58. [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
  59. [    0.000000] Memory: 2048MB = 2048MB total
  60. [    0.000000] Memory: 2047276k/2047276k available, 49876k reserved, 1318912K highmem
  61. [    0.000000] Virtual kernel memory layout:
  62. [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
  63. [    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
  64. [    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
  65. [    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
  66. [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
  67. [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
  68. [    0.000000]       .text : 0xc0008000 - 0xc0a3b784   (10446 kB)
  69. [    0.000000]       .init : 0xc0a3c000 - 0xc0c8c680   (2370 kB)
  70. [    0.000000]       .data : 0xc0c8e000 - 0xc0d30f18   ( 652 kB)
  71. [    0.000000]        .bss : 0xc0d30f18 - 0xc0e4d9cc   (1139 kB)
  72. [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  73. [    0.000000] Preemptible hierarchical RCU implementation.
  74. [    0.000000]  RCU dyntick-idle grace-period acceleration is enabled.
  75. [    0.000000] NR_IRQS:16 nr_irqs:16 16
  76. [    0.000000] rk_clk_tree_init start! cru base = 0xfed00000
  77. [    0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0
  78. [    0.000000] rkclk_init_clks: cnt_parent = 7
  79. [    0.000000] rkclk_init_clks: cnt_rate = 32
  80. [    0.000000] Architected local timer running at 24.00MHz (phys).
  81. [    0.000000] Switching to timer-based delay loop
  82. [    0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns
  83. [    0.000000] process version: 0
  84. [    0.000000] channel:0, lkg:0
  85. [    0.000000] target-temp:95
  86. [    0.000000] channel:2, lkg:0
  87. [    0.000000] target-temp:95
  88. [    0.000000] channel:0, lkg:0
  89. [    0.000000] target-temp:95
  90. [    0.000000] channel:1, lkg:0
  91. [    0.000000] target-temp:95
  92. [    0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
  93. [    0.000000] Console: colour dummy device 80x30
  94. [    0.542594] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
  95. [    0.542644] pid_max: default: 32768 minimum: 301
  96. [    0.542987] Security Framework initialized
  97. [    0.543027] SELinux:  Initializing.
  98. [    0.543256] Mount-cache hash table entries: 512
  99. [    0.545284] Initializing cgroup subsys debug
  100. [    0.545329] Initializing cgroup subsys freezer
  101. [    0.545417] CPU: Testing write buffer coherency: ok
  102. [    0.546163] /cpus/cpu@0 missing clock-frequency property
  103. [    0.546205] /cpus/cpu@1 missing clock-frequency property
  104. [    0.546238] /cpus/cpu@2 missing clock-frequency property
  105. [    0.546271] /cpus/cpu@3 missing clock-frequency property
  106. [    0.546391] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
  107. [    0.546501] Setting up static identity map for 0xc0765120 - 0xc0765178
  108. [    0.550878] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x154a (version 3.0)
  109. [    0.630146] CPU1: Booted secondary processor
  110. [    0.630234] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
  111. [    0.649879] CPU2: Booted secondary processor
  112. [    0.649962] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
  113. [    0.669663] CPU3: Booted secondary processor
  114. [    0.669744] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
  115. [    0.670097] Brought up 4 CPUs
  116. [    0.670197] SMP: Total of 4 processors activated (192.00 BogoMIPS).
  117. [    0.670227] CPU: All CPU(s) started in SVC mode.
  118. [    0.672448] devtmpfs: initialized
  119. [    0.690429] pinctrl core: initialized pinctrl subsystem
  120. [    0.691179] regulator-dummy: no parameters
  121. [    0.692795] NET: Registered protocol family 16
  122. [    0.698470] DMA: preallocated 256 KiB pool for atomic coherent allocations
  123. [    0.699425] ion_snapshot: 0x2e1b0000 map to 0xf0107000 and copy to 0xc0e28c94 (version 0.1)
  124. [    0.699916] Registered FIQ tty driver
  125. [    0.703401] console [ttyFIQ0] enabled
  126. [    0.703949] Registered fiq debugger ttyFIQ0
  127. [    0.706299] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
  128. [    0.706387] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
  129. [    0.706476] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
  130. [    0.706549] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
  131. [    0.706821] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
  132. [    0.707059] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
  133. [    0.707291] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
  134. [    0.707520] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
  135. [    0.707748] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
  136. [    0.707977] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
  137. [    0.708204] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
  138. [    0.708506] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
  139. [    0.708762] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
  140. [    0.709002] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
  141. [    0.709061] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
  142. [    0.709114] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
  143. [    0.709167] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
  144. [    0.710909] rockchip_interrupts_register:bank_num=7
  145. [    0.717596] of_get_gpio_init_config:gpio[0] = 256, value = 0
  146. [    0.717683] of_get_gpio_init_config:gpio[1] = 233, value = 0
  147. [    0.717768] of_get_gpio_init_config:gpio[2] = 136, value = 0
  148. [    0.717978] rockchip_pinctrl_probe:init ok
  149. [    0.738644] rk_iommu ff900800.iep_mmu: (iep) Enter
  150. [    0.739003] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
  151. [    0.739062] rk_iommu ff900800.iep_mmu: (iep) Initialized
  152. [    0.739652] rk_iommu ff950800.vip_mmu: (vip) Enter
  153. [    0.739980] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
  154. [    0.740034] rk_iommu ff950800.vip_mmu: (vip) Initialized
  155. [    0.740584] rk_iommu ff930300.vopb_mmu: (vopb) Enter
  156. [    0.740910] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
  157. [    0.740964] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
  158. [    0.741531] rk_iommu ff940300.vopl_mmu: (vopl) Enter
  159. [    0.741857] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
  160. [    0.741911] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
  161. [    0.742494] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
  162. [    0.742882] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
  163. [    0.742937] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
  164. [    0.743513] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
  165. [    0.743836] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
  166. [    0.743890] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
  167. [    0.744507] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
  168. [    0.744887] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
  169. [    0.744941] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
  170. [    0.750711] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
  171. [    0.750765] hw-breakpoint: maximum watchpoint size is 4 bytes.
  172. [    0.751403] DDR DEBUG: version 1.00 20140603
  173. [    0.751487] DDR DEBUG: Channel a:
  174. [    0.751524] DDR DEBUG: DDR3 Device
  175. [    0.751572] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
  176. [    0.751614] DDR DEBUG: Channel b:
  177. [    0.751646] DDR DEBUG: DDR3 Device
  178. [    0.751693] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
  179. [    0.751736] DDR DEBUG: addr=0xd36000
  180. [    0.751776] DDR DEBUG: stride=9, size=256, halfcap=40000000
  181. [    0.751817] DDR DEBUG: socAddr[0]=0xd36000, socAddr[1]=0xd36100
  182. [    0.751859] DDR DEBUG: chAddr[0]=0xd36000, chAddr[1]=0xd36000
  183. [    0.751904] DDR DEBUG: dtar[0]=0x601a6000, dtar[1]=0x601a6000
  184. [    0.752063] DDR DEBUG: init success!!! freq=200MHz
  185. [    0.752100] DDR DEBUG: Channel a:
  186. [    0.752149] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
  187. [    0.752208] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
  188. [    0.752268] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
  189. [    0.752326] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
  190. [    0.752380] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
  191. [    0.752424] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
  192. [    0.752463] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
  193. [    0.752499] DDR DEBUG: Channel b:
  194. [    0.752546] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
  195. [    0.752606] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
  196. [    0.752664] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
  197. [    0.752722] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
  198. [    0.752776] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
  199. [    0.752818] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
  200. [    0.752857] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
  201. [    0.829554] bio: create slabat 0
  202. [    0.831405] Enter firefly_noatx8_init
  203. [    0.831894] firefly_noatx8_probe 51
  204. [    0.832614] SCSI subsystem initialized
  205. [    0.833104] usbcore: registered new interface driver usbfs
  206. [    0.833255] usbcore: registered new interface driver hub
  207. [    0.833532] usbcore: registered new device driver usb
  208. [    0.836598] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
  209. [    0.840937] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
  210. [    0.842403] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
  211. [    0.843851] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
  212. [    0.844681] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
  213. [    0.847570] media: Linux media interface: v0.10
  214. [    0.847712] Linux video capture interface: v2.00
  215. [    0.847870] pps_core: LinuxPPS API ver. 1 registered
  216. [    0.847914] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
  217. [    0.847997] PTP clock support registered
  218. [    0.848442] rockchip_temp_probe,line=362
  219. [    0.849225] tsadc ff280000.tsadc: initialized
  220. [    0.850442] rockchip_ion_parse_dt: num_heaps = 1
  221. [    0.850503] 0:  0  3  vmalloc  0x  (null)
  222. [    0.851288] Rockchip ion module is successfully loaded (v1.0)
  223. [    0.851817] Advanced Linux Sound Architecture Driver Initialized.
  224. [    0.853034] Bluetooth: Core ver 2.16
  225. [    0.853161] NET: Registered protocol family 31
  226. [    0.853203] Bluetooth: HCI device and connection manager initialized
  227. [    0.853264] Bluetooth: HCI socket layer initialized
  228. [    0.853315] Bluetooth: L2CAP socket layer initialized
  229. [    0.853408] Bluetooth: SCO socket layer initialized
  230. [    0.854059] cfg80211: Calling CRDA to update world regulatory domain
  231. [    0.856302] act8846_i2c_probe,line=898
  232. [    0.857695] act8846_parse_dt,line=746
  233. [    0.859217] act8846_i2c_probe: act8846_pmic_hold=1
  234. [    0.859290] act8846_i2c_probe: act8846_pmic_sleep=1
  235. [    0.859349] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
  236. [    0.859407] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
  237. [    0.861867] act_dcdc1: 1200 mV
  238. [    0.865546] vccio: 3300 mV
  239. [    0.868194] vdd_logic: 7001500 mV at 1100 mV
  240. [    0.871886] act_dcdc4: 2000 mV
  241. [    0.873702] vccio_sd: 18003300 mV at 3300 mV
  242. [    0.876612] act_ldo2: 1050 mV
  243. [    0.879470] act_ldo3: 1800 mV
  244. [    0.882325] act_ldo4: 3300 mV
  245. [    0.885164] act_ldo5: 3300 mV
  246. [    0.888000] act_ldo6: 1100 mV
  247. [    0.890872] vcc_18: 1800 mV
  248. [    0.893771] act_ldo8: 1850 mV
  249. [    0.900298] vdd_arm: 7121500 mV at 1000 mV
  250. [    0.906662] vdd_gpu: 7121500 mV at 1000 mV
  251. [    0.907615] rk808_i2c_probe,line=1368
  252. [    0.909257] The device is not rk808 -11
  253. [    0.909516] rk808: probe of 0-001b failed with error -11
  254. [    0.914423] Switching to clocksource arch_sys_counter
  255. [    0.934962] usb_battery_charger_detect_synop , battery_charger_detect 1, pass DCD, dcd_state = 1
  256. [    0.980284] rk-fb rockchip-fb: rk fb ion client create success!
  257. [    0.980353] rk-fb rockchip-fb: rockchip framebuffer driver probe
  258. [    0.981431] rk-screen rk_screen.9: rockchip screen probe success
  259. [    0.982219] rk32-lvds rk32-lvds: rk32 lvds driver probe success
  260. [    0.982952] rk32-edp ff970000.edp: screen is not edp!
  261. [    0.983022] rk32-edp: probe of ff970000.edp failed with error -22
  262. [    0.984273] rk3288-lcdc lcdc0: can't find power_ctr node for lcdc0
  263. [    0.985028] graphics fb0: rockchip framebuffer registerd:fb0
  264. [    0.986050] graphics fb1: rockchip framebuffer registerd:fb1
  265. [    0.986582] graphics fb2: rockchip framebuffer registerd:fb2
  266. [    0.987134] graphics fb3: rockchip framebuffer registerd:fb3
  267. [    0.987676] graphics fb4: rockchip framebuffer registerd:fb4
  268. [    0.989427] rk_iommu ff930300.vopb_mmu: (vopb) Enabled
  269. [    0.989853] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
  270. [    0.989925] rk3288-lcdc lcdc0: wakeup from standby!
  271. [    1.111728] alloc_buffer:ion_phy_addr=0x10000000
  272. [    1.155043] fb0:phy:10000000>>vir:f0191000>>len:0x1800000
  273. [    1.297568] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
  274. [    1.298803] rockchip_set_mux:warning ignore bank num 15
  275. [    1.299248] rockchip_set_mux:warning ignore bank num 15
  276. [    1.299642] rockchip_set_mux:warning ignore bank num 15
  277. [    1.300029] rockchip_set_mux:warning ignore bank num 15
  278. [    1.300425] rockchip_set_mux:warning ignore bank num 15
  279. [    1.300817] rockchip_set_mux:warning ignore bank num 15
  280. [    1.301708] rockchip_set_mux:warning ignore bank num 15
  281. [    1.302248] rockchip_set_mux:warning ignore bank num 15
  282. [    1.303078] rockchip_set_mux:warning ignore bank num 15
  283. [    1.303573] rockchip_set_mux:warning ignore bank num 15
  284. [    1.304397] rockchip_set_mux:warning ignore bank num 15
  285. [    1.304887] rockchip_set_mux:warning ignore bank num 15
  286. [    1.305724] rockchip_set_mux:warning ignore bank num 15
  287. [    1.306223] rockchip_set_mux:warning ignore bank num 15
  288. [    1.329074] NET: Registered protocol family 2
  289. [    1.330487] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
  290. [    1.330977] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
  291. [    1.331473] TCP: Hash tables configured (established 8192 bind 8192)
  292. [    1.331628] TCP: reno registered
  293. [    1.331681] UDP hash table entries: 512 (order: 2, 16384 bytes)
  294. [    1.331810] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
  295. [    1.332450] NET: Registered protocol family 1
  296. [    1.333048] Unpacking initramfs...
  297. [    1.559100] Freeing initrd memory: 1152K (c4bf0000 - c4d10000)
  298. [    1.561393] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
  299. [    1.562923] probe device ff9a0000.vpu_service
  300. [    1.563389] vpu_service: power on
  301. [    1.564542] checking hw id 4831
  302. [    1.565528] vpu_service set to auto frequency mode
  303. [    1.565693] vcodec vpu_service: vcodec ion client create success!
  304. [    1.566847] rk_iommu ff9a0800.vpu_mmu: (vpu) Enabled
  305. [    1.566952] rk_iommu ff9a0800.vpu_mmu: (vpu) Disabled
  306. [    1.567006] rk_iommu ff9a0800.vpu_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e277000
  307. [    1.567053] vpu_service: power off...
  308. [    1.567137] done
  309. [    1.567170] init success
  310. [    1.567328] probe device ff9c0000.hevc_service
  311. [    1.567962] hevc_service: power on
  312. [    1.569084] checking hw id 6867
  313. [    1.569892] vcodec hevc_service: vcodec ion client create success!
  314. [    1.570836] rk_iommu ff9c0440.hevc_mmu: (hevc) Enabled
  315. [    1.570942] rk_iommu ff9c0440.hevc_mmu: (hevc) Disabled
  316. [    1.570995] rk_iommu ff9c0440.hevc_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e274000
  317. [    1.571043] hevc_service: power off...
  318. [    1.571130] done
  319. [    1.571163] init success
  320. [    1.571517] rknandbase v1.0 2014-03-31
  321. [    1.572164] rknand_probe clk rate = 148500000
  322. [    1.572542] rknand_driver:ret = 0
  323. [    1.573619] audit: initializing netlink socket (disabled)
  324. [    1.573731] type=2000 audit(1.030:1): initialized
  325. [    1.575977] bounce pool size: 64 pages
  326. [    1.591466] fuse init (API version 7.22)
  327. [    1.592685] msgmni has been set to 1456
  328. [    1.598572] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  329. [    1.598637] io scheduler noop registered
  330. [    1.598678] io scheduler deadline registered
  331. [    1.599023] io scheduler cfq registered (default)
  332. [    1.600486] Console: switching to colour frame buffer device 240x67
  333. [    1.655372] rga ff920000.rga: rga ion client create success!
  334. [    1.655806] rga: Driver loaded succesfully
  335. [    1.657276] IEP Power ON
  336. [    1.657391] iep ion client create success!
  337. [    1.658416] rk_iommu ff900800.iep_mmu: (iep) Enabled
  338. [    1.658507] IEP Power OFF
  339. [    1.658552] rk_iommu ff900800.iep_mmu: (iep) Disabled
  340. [    1.658604] rk_iommu ff900800.iep_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e26a000
  341. [    1.658667] IEP Driver loaded succesfully
  342. [    1.658965] Module initialized.
  343. [    1.661407] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
  344. [    1.661480] dma-pl330 ffb20000.pdma:         DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
  345. [    1.665745] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
  346. [    1.665816] dma-pl330 ff250000.pdma:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
  347. [    1.666572] pwm-voltage-regulator pwm_regulator.23: unable to request PWM, trying legacy API
  348. [    1.666637] pwm-voltage-regulator pwm_regulator.23: unable to request legacy PWM
  349. [    1.666679] pwm_regulator_probe:error
  350. [    1.666751] platform pwm_regulator.23: Driver pwm-voltage-regulator requests probe deferral
  351. [    1.667818] rk_serial.c v1.8 2014-03-04
  352. [    1.668464] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
  353. [    1.669060] serial ff180000.serial: membase 0xf0172000
  354. [    1.678615] loop: module loaded
  355. [    1.680478] SCSI Media Changer driver v0.25
  356. [    1.681562] tun: Universal TUN/TAP device driver, 1.6
  357. [    1.681610] tun: (C) 1999-2004 Max Krasnyansky
  358. [    1.683334] stmmac_probe_config_dt: Can not read property: pmu_regulator.
  359. [    1.683393] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
  360. [    1.683442] stmmac_probe_config_dt: clock input or output? (input).
  361. [    1.683488] stmmac_probe_config_dt: TX delay(0x30).
  362. [    1.683529] stmmac_probe_config_dt: RX delay(0x10).
  363. [    1.683653] stmmac_probe_config_dt: is rockchip,rk3288-gmac
  364. [    1.683694] stmmc_pltfr_init:
  365. [    1.683730] stmmc_pltfr_init: ERROR: Get power-gpio failed.
  366. [    1.683805] stmmc_pltfr_init: ERROR: Request gmac phy reset pin failed.
  367. [    1.683845] stmmc_pltfr_init: init for RGMII
  368. [    1.683885] tx delay=0x30
  369. [    1.683885] rx delay=0x10
  370. [    1.685414] stmmac - user ID: 0x10, Synopsys ID: 0x35
  371. [    1.685456]  Normal descriptors
  372. [    1.685487]  Ring mode enabled
  373. [    1.685520]  DMA HW capability register supported
  374. [    1.685558]  RX Checksum Offload Engine supported (type 2)
  375. [    1.685596]  TX Checksum insertion supported
  376. [    1.685630]  Wake-Up On Lan supported
  377. [    1.685761]  Enable RX Mitigation via HW Watchdog Timer
  378. [    1.687104] PPP generic driver version 2.4.2
  379. [    1.687585] PPP BSD Compression module registered
  380. [    1.687631] PPP Deflate Compression module registered
  381. [    1.687696] PPP MPPE Compression module registered
  382. [    1.687738] NET: Registered protocol family 24
  383. [    1.687833] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
  384. [    1.687882] CSLIP: code copyright 1989 Regents of the University of California.
  385. [    1.687927] Rockchip WiFi SYS interface (V1.00) ...
  386. [    1.688165] usbcore: registered new interface driver catc
  387. [    1.688294] usbcore: registered new interface driver kaweth
  388. [    1.688340] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
  389. [    1.688468] usbcore: registered new interface driver pegasus
  390. [    1.688605] usbcore: registered new interface driver rtl8150
  391. [    1.688733] usbcore: registered new interface driver r8152
  392. [    1.688775] hso: drivers/net/usb/hso.c: Option Wireless
  393. [    1.688972] usbcore: registered new interface driver hso
  394. [    1.689119] usbcore: registered new interface driver asix
  395. [    1.689243] usbcore: registered new interface driver ax88179_178a
  396. [    1.689368] usbcore: registered new interface driver cdc_ether
  397. [    1.689530] usbcore: registered new interface driver cdc_eem
  398. [    1.689658] usbcore: registered new interface driver dm9601
  399. [    1.689781] usbcore: registered new interface driver dm9620
  400. [    1.689937] usbcore: registered new interface driver smsc75xx
  401. [    1.690091] usbcore: registered new interface driver smsc95xx
  402. [    1.690217] usbcore: registered new interface driver gl620a
  403. [    1.690352] usbcore: registered new interface driver net1080
  404. [    1.690483] usbcore: registered new interface driver plusb
  405. [    1.690614] usbcore: registered new interface driver rndis_host
  406. [    1.690740] usbcore: registered new interface driver cdc_subset
  407. [    1.690860] usbcore: registered new interface driver zaurus
  408. [    1.690993] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
  409. [    1.691170] usbcore: registered new interface driver int51x1
  410. [    1.691299] usbcore: registered new interface driver kalmia
  411. [    1.691450] usbcore: registered new interface driver ipheth
  412. [    1.691595] usbcore: registered new interface driver sierra_net
  413. [    1.691727] usbcore: registered new interface driver cx82310_eth
  414. [    1.691886] usbcore: registered new interface driver cdc_ncm
  415. [    1.692087] usbcore: registered new interface driver qmi_wwan
  416. [    1.692221] usbcore: registered new interface driver cdc_mbim
  417. [    1.692265] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  418. [    1.695554] ehci_rk_probe f1a00000 f1a00010
  419. [    1.695613] rockchip_ehci_host ff500000.usb: Rockchip On-Chip EHCI Host Controller
  420. [    1.695710] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
  421. [    1.696712] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
  422. [    1.711695] rockchip_ehci_host ff500000.usb: USB 0.0 started, EHCI 1.00
  423. [    1.711929] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
  424. [    1.711993] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  425. [    1.712048] usb usb1: Product: Rockchip On-Chip EHCI Host Controller
  426. [    1.712100] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
  427. [    1.712147] usb usb1: SerialNumber: ff500000.usb
  428. [    1.713526] hub 1-0:1.0: USB hub found
  429. [    1.713608] hub 1-0:1.0: 1 port detected
  430. [    1.741183] ehci_rk_probe ok
  431. [    1.741629] usbcore: registered new interface driver cdc_acm
  432. [    1.741675] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
  433. [    1.741878] usbcore: registered new interface driver usblp
  434. [    1.742027] usbcore: registered new interface driver cdc_wdm
  435. [    1.742239] usbcore: registered new interface driver usb-storage
  436. [    1.742371] usbcore: registered new interface driver ums-alauda
  437. [    1.742513] usbcore: registered new interface driver ums-cypress
  438. [    1.742645] usbcore: registered new interface driver ums-datafab
  439. [    1.742772] usbcore: registered new interface driver ums_eneub6250
  440. [    1.742912] usbcore: registered new interface driver ums-freecom
  441. [    1.743042] usbcore: registered new interface driver ums-isd200
  442. [    1.743169] usbcore: registered new interface driver ums-jumpshot
  443. [    1.743295] usbcore: registered new interface driver ums-karma
  444. [    1.743422] usbcore: registered new interface driver ums-onetouch
  445. [    1.743548] usbcore: registered new interface driver ums-sddr09
  446. [    1.743673] usbcore: registered new interface driver ums-sddr55
  447. [    1.743799] usbcore: registered new interface driver ums-usbat
  448. [    1.744086] usbcore: registered new interface driver usbserial
  449. [    1.744225] usbcore: registered new interface driver usbserial_generic
  450. [    1.744335] usbserial: USB Serial support registered for generic
  451. [    1.744472] usbcore: registered new interface driver option
  452. [    1.744579] usbserial: USB Serial support registered for GSM modem (1-port)
  453. [    1.744834] usbcore: registered new interface driver trancevibrator
  454. [    1.744879] usb20_otg: version 3.10a 21-DEC-2012
  455. [    1.745935] f1a80040
  456. [    1.745984] Core Release: 3.10a
  457. [    1.746023] Setting default values for core params
  458. [    1.746435] Using Buffer DMA mode
  459. [    1.746477] Periodic Transfer Interrupt Enhancement - disabled
  460. [    1.746518] Multiprocessor Interrupt Enhancement - disabled
  461. [    1.746560] OTG VER PARAM: 0, OTG VER FLAG: 0
  462. [    1.746597] ^^^^^^^^^^^^^^^^^Device Mode
  463. [    1.746641] Dedicated Tx FIFOs mode
  464. [    1.746698] pcd_init otg_dev = ed9b2b40
  465. [    1.747194] usb20_otg ff580000.usb: DWC OTG Controller
  466. [    1.747291] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
  467. [    1.747399] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
  468. [    1.747584] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
  469. [    1.747644] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  470. [    1.747698] usb usb2: Product: DWC OTG Controller
  471. [    1.747745] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
  472. [    1.747793] usb usb2: SerialNumber: ff580000.usb
  473. [    1.749115] hub 2-0:1.0: USB hub found
  474. [    1.749195] hub 2-0:1.0: 1 port detected
  475. [    1.750116] usb20_host: version 3.10a 21-DEC-2012
  476. [    1.753673] f1b00040
  477. [    1.753722] Core Release: 3.10a
  478. [    1.753761] Setting default values for core params
  479. [    1.754206] Using Buffer DMA mode
  480. [    1.754248] Periodic Transfer Interrupt Enhancement - disabled
  481. [    1.754286] Multiprocessor Interrupt Enhancement - disabled
  482. [    1.754327] OTG VER PARAM: 0, OTG VER FLAG: 0
  483. [    1.754363] ^^^^^^^^^^^^^^^^^^Host Mode
  484. [    1.754446] usb20_host ff540000.usb: DWC OTG Controller
  485. [    1.754536] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
  486. [    1.754639] usb20_host ff540000.usb: irq 57, io mem 0x00000000
  487. [    1.754801] Init: Power Port (0)
  488. [    1.754984] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
  489. [    1.755045] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  490. [    1.755099] usb usb3: Product: DWC OTG Controller
  491. [    1.755147] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
  492. [    1.755195] usb usb3: SerialNumber: ff540000.usb
  493. [    1.756547] hub 3-0:1.0: USB hub found
  494. [    1.756624] hub 3-0:1.0: 1 port detected
  495. [    1.758270] .. rk pwm remotectl v1.0 init
  496. [    1.758536] remotectl probe j=0x0
  497. [    1.759035] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
  498. [    1.759667] pwm enable val=0x646205
  499. [    1.760549] usbcore: registered new interface driver xpad
  500. [    1.760720] usbcore: registered new interface driver usb_acecad
  501. [    1.760955] usbcore: registered new interface driver aiptek
  502. [    1.761131] usbcore: registered new interface driver gtco
  503. [    1.761293] usbcore: registered new interface driver hanwang
  504. [    1.761447] usbcore: registered new interface driver kbtab
  505. [    1.761625] usbcore: registered new interface driver wacom
  506. [    1.762739] sensor_register_slave:mma8452,id=17
  507. [    1.762788] sensor_register_slave:cm3217,id=44
  508. [    1.762828] sensor_register_slave:cm3218,id=45
  509. [    1.769220] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
  510. [    1.769382] i2c /dev entries driver
  511. [    1.771614] IR NEC protocol handler initialized
  512. [    1.771664] IR RC5(x) protocol handler initialized
  513. [    1.771702] IR RC6 protocol handler initialized
  514. [    1.771738] IR JVC protocol handler initialized
  515. [    1.771774] IR Sony protocol handler initialized
  516. [    1.771809] IR RC5 (streamzap) protocol handler initialized
  517. [    1.771847] IR SANYO protocol handler initialized
  518. [    1.771884] IR MCE Keyboard/mouse protocol handler initialized
  519. [    1.772133] usbcore: registered new interface driver uvcvideo
  520. [    1.772175] USB Video Class driver (1.1.1)
  521. [    1.772222] CamSys driver version: v0.19.0,  CamSys head file version: v0.8.0
  522. [    1.775380] D1:camsys_platform_probe(1061): 1-gpios-cifpower: gpio=236
  523. [    1.775469] D1:camsys_platform_probe(1064): gpios-cifpower: gpio_request
  524. [    1.775533] D1:camsys_platform_probe(1066): 1-gpios-cifpower: gpio_request=0
  525. [    1.775598] D1:camsys_platform_probe(1075): gpios-cifpower: 236 high
  526. [    1.775823] D1:camsys_mipiphy_probe_cb(163): ff910000.isp mipi phy0 probe success(reg_phy: 0x0  reg_vir: 0x0  size: 0x0)
  527. [    1.776327] D1:camsys_mipiphy_probe_cb(160): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000  reg_vir: 0xf19b0000  size)
  528. [    1.778569] D1:camsys_platform_probe(1208): ff910000.isp memory:
  529. [    1.778632] D1:camsys_platform_probe(1218):     Register memory (phy: 0xff910000 vir: 0xf19e0000 size: 0x10000)
  530. [    1.778691] D1:camsys_platform_probe(1213):     I2c memory (phy: 0x2da43000 vir: 0xeda43000 size: 0x1000)
  531. [    1.778744] D1:camsys_platform_probe(1233): Probe ff910000.isp device success
  532. [    1.781685] device-mapper: uevent: version 1.0.3
  533. [    1.782420] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
  534. [    1.783342] Bluetooth: HCI UART driver ver 2.2
  535. [    1.783396] Bluetooth: HCI H4 protocol initialized
  536. [    1.783436] Bluetooth: HCILL protocol initialized
  537. [    1.789324] cpufreq version 1.0, suspend freq 1200 MHz
  538. [    1.789906] cpuidle: using governor ladder
  539. [    1.789952] cpuidle: using governor menu
  540. [    1.790070] Synopsys Designware Multimedia Card Interface Driver
  541. [    1.790900] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
  542. [    1.791772] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
  543. [    1.792273] 3230..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
  544. [    1.792329] Line3235..dw_mci_init_slot: The rk_sdmmc Ver 1.12 2014-07-08
  545. [    1.792739] 1357..dw_mci_set_ios:  no card. [mmc0]
  546. [    1.810037] 1357..dw_mci_set_ios:  no card. [mmc0]
  547. [    1.829765] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
  548. [    1.829797] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
  549. [    1.829822] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
  550. [    1.830184] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
  551. [    1.830950] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
  552. [    1.831134] 3224..dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
  553. [    1.831666] 1357..dw_mci_set_ios:  no card. [mmc1]
  554. [    1.849389] 1357..dw_mci_set_ios:  no card. [mmc1]
  555. [    1.861880] mmc0: BKOPS_EN bit is not set
  556. [    1.863798] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
  557. [    1.866107] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
  558. [    1.866135] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
  559. [    1.869239] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
  560. [    1.869258] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
  561. [    1.869607] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
  562. [    1.869838] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
  563. [    1.869993] 3230..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
  564. [    1.870110] 1357..dw_mci_set_ios:  no card. [mmc2]
  565. [    1.881165] rk_sdmmc: BOOT
  566. [    1.881165]  execute tuning: candidates_degree = SDMMC_SHIFT_DEGREE_0        SDMMC_SHIFT_DEGREE_90   SDMMC_SHIFT_DEGREE_180  SDM]
  567. [    1.881268] mmc0: new HS200 MMC card at address 0001
  568. [    1.881527] mmcblk0: mmc0:0001 AWMB3R 14.5 GiB
  569. [    1.881838]      uboot: 0x000400000 -- 0x000800000 (4 MB)
  570. [    1.881851]       misc: 0x000800000 -- 0x000c00000 (4 MB)
  571. [    1.881861]   resource: 0x000c00000 -- 0x001c00000 (16 MB)
  572. [    1.881869]     kernel: 0x001c00000 -- 0x002c00000 (16 MB)
  573. [    1.881878]       boot: 0x002c00000 -- 0x004c00000 (32 MB)
  574. [    1.881887]   recovery: 0x004c00000 -- 0x006c00000 (32 MB)
  575. [    1.881896]     backup: 0x006c00000 -- 0x00a000000 (52 MB)
  576. [    1.881905]      cache: 0x00a000000 -- 0x012000000 (128 MB)
  577. [    1.881914]     kpanic: 0x012000000 -- 0x012400000 (4 MB)
  578. [    1.881923]     system: 0x012400000 -- 0x042400000 (768 MB)
  579. [    1.881932]   metadata: 0x042400000 -- 0x042800000 (4 MB)
  580. [    1.881941]   userdata: 0x042800000 -- 0x082800000 (1024 MB)
  581. [    1.881950]  linuxroot: 0x082800000 -- 0x146800000 (3136 MB)
  582. [    1.881959]       user: 0x146800000 -- 0x3a3a00000 (9682 MB)
  583. [    1.881982]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141357..dw_mci_set_ios:  no card. [mmc1]
  584. [    1.888736] 1357..dw_mci_set_ios:  no card. [mmc2]
  585. [    1.908414] 1357..dw_mci_set_ios:  no card. [mmc2]
  586. [    1.908611] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
  587. [    1.908623] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
  588. [    1.908872] leds-gpio leds.31: pins are not configured from the driver
  589. [    1.909099] hidraw: raw HID events driver (C) Jiri Kosina
  590. [    1.910394] usbcore: registered new interface driver usbhid
  591. [    1.910405] usbhid: USB HID core driver
  592. [    1.910716] ashmem: initialized
  593. [    1.910819] logger: created 256K log 'log_main'
  594. [    1.910918] logger: created 256K log 'log_events'
  595. [    1.911005] logger: created 256K log 'log_radio'
  596. [    1.911096] logger: created 256K log 'log_system'
  597. [    1.912100] input: rk29-keypad as /devices/ff100000.adc/key.34/input/input1
  598. [    1.912674] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by smp; cannot claim for 2-0010
  599. [    1.912690] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
  600. [    1.912702] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
  601. [    1.912714] ES8323 2-0010: Error applying setting, reverse things back
  602. [    1.912999] es8323 probe i2c recv ok
  603. [    1.913217] i2c-core: driver [ES8323] using legacy suspend method
  604. [    1.913228] i2c-core: driver [ES8323] using legacy resume method
  605. [    1.913552] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered
  606. [    1.913583] rockchip_hdmi_spdif_audio_probe() register card failed:-517
  607. [    1.913602] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral
  608. [    1.913828] es8323_probe
  609. [    1.913913] es8323_probe:register ISR (irq=194)
  610. [    2.548366] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> NULL --> Left Line Mux
  611. [    2.548378] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> NULL -> Left Line Mux
  612. [    2.548390] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> NULL --> Left Line Mux
  613. [    2.548399] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> NULL -> Left Line Mux
  614. [    2.548409] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux --> NULL --> Left Line Mux
  615. [    2.548418] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux -> NULL -> Left Line Mux
  616. [    2.548428] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> NULL --> Right Line Mux
  617. [    2.548436] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> NULL -> Right Line Mux
  618. [    2.548446] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> NULL --> Right Line Mux
  619. [    2.548454] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> NULL -> Right Line Mux
  620. [    2.548463] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux --> NULL --> Right Line Mux
  621. [    2.548472] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux -> NULL -> Right Line Mux
  622. [    2.548481] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Left PGA Mux
  623. [    2.548489] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Left PGA Mux
  624. [    2.548498] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Left PGA Mux
  625. [    2.548506] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Left PGA Mux
  626. [    2.548514] ES8323 2-0010: ASoC: no dapm match for Differential Mux --> LAMP --> Left PGA Mux
  627. [    2.548523] ES8323 2-0010: ASoC: Failed to add route Differential Mux -> LAMP -> Left PGA Mux
  628. [    2.548532] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Right PGA Mux
  629. [    2.548540] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Right PGA Mux
  630. [    2.548549] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Right PGA Mux
  631. [    2.548556] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Right PGA Mux
  632. [    2.548566] ES8323 2-0010: ASoC: no dapm match for Differential Mux --> RAMP --> Right PGA Mux
  633. [    2.548574] ES8323 2-0010: ASoC: Failed to add route Differential Mux -> RAMP -> Right PGA Mux
  634. [    2.548583] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Differential Mux
  635. [    2.548591] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Differential Mux
  636. [    2.548600] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Differential Mux
  637. [    2.548608] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Differential Mux
  638. [    2.548617] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Differential Mux
  639. [    2.548625] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Differential Mux
  640. [    2.548634] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Differential Mux
  641. [    2.548642] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Differential Mux
  642. [    2.548663] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Left Line Mux
  643. [    2.548671] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Left Line Mux
  644. [    2.548680] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Left Line Mux
  645. [    2.548688] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Left Line Mux
  646. [    2.548697] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux --> LAMP --> Left Line Mux
  647. [    2.548706] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux -> LAMP -> Left Line Mux
  648. [    2.548715] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Right Line Mux
  649. [    2.548724] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Right Line Mux
  650. [    2.548733] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Right Line Mux
  651. [    2.548741] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Right Line Mux
  652. [    2.548750] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux --> RAMP --> Right Line Mux
  653. [    2.548758] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux -> RAMP -> Right Line Mux
  654. [    2.548884] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
  655. [    2.548896] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
  656. [    2.548906] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
  657. [    2.548915] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
  658. [    2.548947] ES8323 2-0010: ASoC: mux Differential Mux has no paths
  659. [    2.551789] Enter::rk29_es8323_init----135
  660. [    2.555158] rockchip-es8323 rockchip-es8323.29:  ES8323 HiFirockchip-i2s.0 mapping ok
  661. [    2.555657] u32 classifier
  662. [    2.555665]     Actions configured
  663. [    2.555676] Netfilter messages via NETLINK v0.30.
  664. [    2.555727] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
  665. [    2.556006] ctnetlink v0.93: registering with nfnetlink.
  666. [    2.556069] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
  667. [    2.556076] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
  668. [    2.556303] xt_time: kernel timezone is -0000
  669. [    2.556476] ip_tables: (C) 2000-2006 Netfilter Core Team
  670. [    2.556590] arp_tables: (C) 2002 David S. Miller
  671. [    2.556627] TCP: cubic registered
  672. [    2.556635] Initializing XFRM netlink socket
  673. [    2.556813] NET: Registered protocol family 10
  674. [    2.557239] mip6: Mobile IPv6
  675. [    2.557261] ip6_tables: (C) 2000-2006 Netfilter Core Team
  676. [    2.557368] sit: IPv6 over IPv4 tunneling driver
  677. [    2.557644] NET: Registered protocol family 17
  678. [    2.557668] NET: Registered protocol family 15
  679. [    2.557720] Bridge firewalling registered
  680. [    2.557732] Ebtables v2.0 registered
  681. [    2.557890] Bluetooth: RFCOMM TTY layer initialized
  682. [    2.557920] Bluetooth: RFCOMM socket layer initialized
  683. [    2.557927] Bluetooth: RFCOMM ver 1.11
  684. [    2.557934] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
  685. [    2.557939] Bluetooth: BNEP filters: protocol multicast
  686. [    2.557949] Bluetooth: BNEP socket layer initialized
  687. [    2.557956] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
  688. [    2.557965] Bluetooth: HIDP socket layer initialized
  689. [    2.557986] l2tp_core: L2TP core driver, V2.0
  690. [    2.557998] l2tp_ppp: PPPoL2TP kernel driver, V2.0
  691. [    2.558005] [WLAN_RFKILL]: Enter rfkill_wlan_init
  692. [    2.558204] [WLAN_RFKILL]: Enter rfkill_wlan_probe
  693. [    2.558213] wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
  694. [    2.558221] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
  695. [    2.558229] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
  696. [    2.558237] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
  697. [    2.558258] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
  698. [    2.558276] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
  699. [    2.558284] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
  700. [    2.558307] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
  701. [    2.558345] [WLAN_RFKILL]: Exit rfkill_wlan_probe
  702. [    2.558388] [BT_RFKILL]: Enter rfkill_rk_init
  703. [    2.558497] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
  704. [    2.558512] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
  705. [    2.558525] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
  706. [    2.558537] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
  707. [    2.558550] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
  708. [    2.558595] [BT_RFKILL]: Request irq for bt wakeup host
  709. [    2.558684] [BT_RFKILL]: ** disable irq
  710. [    2.558757] [BT_RFKILL]: ap6335 device registered.
  711. [    2.559366] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess.
  712. [    2.559759] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
  713. [    2.559779] rk3288_init_suspend
  714. [    2.559787] rk3288_suspend_init enter
  715. [    2.559908] rk3288_suspend_init: pm_ctrbits =40017
  716. [    2.559938] gpio_get_dts_info suspend:8
  717. [    2.559944] gpio_get_dts_info resume:8
  718. [    2.559950] rockchip,pmic-suspend_gpios:1007c30 1007c40 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
  719. [    2.559974] rockchip,pmic-resume_gpios:2007c32 2007c42 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
  720. [    2.560091] clks_gating_suspend_init:clkgt info ok
  721. [    2.560183] Registering SWP/SWPB emulation handler
  722. [    2.560469] ddrfreq: verion 1.2 20140526
  723. [    2.560480] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
  724. [    2.560489] ddrfreq: auto-freq=0
  725. [    2.560494] ddrfreq: auto-freq-table[0] 240MHz
  726. [    2.560500] ddrfreq: auto-freq-table[1] 324MHz
  727. [    2.560505] ddrfreq: auto-freq-table[2] 456MHz
  728. [    2.560510] ddrfreq: auto-freq-table[3] 528MHz
  729. [    2.562091] act_ldo3: operation not allowed
  730. [    2.562329] vga_edid_probe: turn on ldo3 done.
  731. [    2.562353] act_ldo4: operation not allowed
  732. [    2.562586] vga_edid_probe: turn on ldo done.
  733. [    2.562606] act_ldo2: operation not allowed
  734. [    2.562833] vga_edid_probe: turn on ldo2 done.
  735. [    2.562854] act_ldo8: operation not allowed
  736. [    2.563081] vga_edid_probe: turn on ldo done.
  737. [    2.588168] vga-ddc: read and parse vga edid success.
  738. [    2.588177] vga-ddc: max mode 1680x1050@59[pixclock-119005 KHZ]
  739. [    2.588194] vga-ddc: best mode 1680x1050@60[pixclock-6 KHZ]
  740. [    2.588200] vga_edid_probe: success. 9
  741. [    2.588294] firefly_vga_get_enable 180, 0
  742. [    2.588301] firefly_vga_get_status 186
  743. [    2.588312] firefly_vga_set_enable 159 enable:1
  744. [    2.588328] firefly_vga_enable 130 start
  745. [    2.588335] firefly_switch_fb 55
  746. [    2.588342]
  747. [    2.588342] rk_fb_switch_screen lcdc_id 0 type 1 enable 1
  748. [    2.588352] fb0 win id 1 state 1
  749. [    2.588362] regulator-dummy: disabling
  750. [    2.588386] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:61
  751. [    2.588407] fb1 win id 0 state 0
  752. [    2.588413] fb2 win id 2 state 0
  753. [    2.588418] fb3 win id 3 state 0
  754. [    2.588424] fb4 win id 4 state 0
  755. [    2.588429]
  756. [    2.588429] rk_fb_switch_screen lcdc_id 0 type 1 enable 1 done
  757. [    2.588429]
  758. [    2.588459] VGA ENABLE
  759. [    2.588719] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered
  760. [    2.588744] rockchip_hdmi_spdif_audio_probe() register card failed:-517
  761. [    2.588757] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral
  762. [    2.588832] pcd_pullup, is_on 0
  763. [    2.588864] file system registered
  764. [    2.589357] android_usb gadget: Mass Storage Function, version: 2009/09/11
  765. [    2.589365] android_usb gadget: Number of LUNs=2
  766. [    2.589372]  lun0: LUN: removable file: (no medium)
  767. [    2.589379]  lun1: LUN: removable file: (no medium)
  768. [    2.589495] android_usb gadget: android_usb ready
  769. [    2.589569] sensor_init: Probe name sensors
  770. [    2.589583] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
  771. [    2.590104] rtc_hym8563 0-0051: setting system clock to 2014-12-26 20:16:49 UTC (1419625009)
  772. [    2.595336] usbcore: registered new interface driver snd-usb-audio
  773. [    2.595362] ALSA device list:
  774. [    2.595368]   #0: RK_ES8323
  775. [    2.596651] Freeing unused kernel memory: 2368K (c0a3c000 - c0c8c000)
  776. [    2.596907] rockchip-hdmi-spdif rockchip-hdmi-spdif.27:  rk-hdmi-spdif-hifirockchip-spdif mapping ok
  777. [    2.601414] SELinux:  Permission attach_queue in class tun_socket not defined in policy.
  778. [    2.601427] SELinux: the above unknown classes and permissions will be denied
  779. [    2.826458] type=1403 audit(1419625009.730:2): policy loaded auid=4294967295 ses=4294967295
  780. [    2.826553] SELinux: Loaded policy from /sepolicy
  781. [    2.827969] type=1404 audit(1419625009.730:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
  782. [    3.204881] vga-ddc: read and parse vga edid success.
  783. [    3.204894] vga-ddc: max mode 1680x1050@59[pixclock-119005 KHZ]
  784. [    3.204910] vga-ddc: best mode 1680x1050@60[pixclock-6 KHZ]
  785. [    3.204916] VGA Devie connected 9
  786. [    3.204921] firefly_vga_set_mode 203
  787. [    3.204927] firefly_vga_set_mode 219 1680 1050 60 146200000
  788. [    3.204933] firefly_vga_enable 130 start
  789. [    3.204938] firefly_switch_fb 55
  790. [    3.204945]
  791. [    3.204945] rk_fb_switch_screen lcdc_id 0 type 1 enable 1
  792. [    3.204955] fb0 win id 1 state 1
  793. [    3.204997] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:61
  794. [    3.205019] fb1 win id 0 state 0
  795. [    3.205024] fb2 win id 2 state 0
  796. [    3.205030] fb3 win id 3 state 0
  797. [    3.205035] fb4 win id 4 state 0
  798. [    3.205040]
  799. [    3.205040] rk_fb_switch_screen lcdc_id 0 type 1 enable 1 done
  800. [    3.205040]
  801. [    3.728799] dwc_otg_hcd_enable, enable host controller
  802. [    3.832476] Using Buffer DMA mode
  803. [    3.832486] Periodic Transfer Interrupt Enhancement - disabled
  804. [    3.832493] Multiprocessor Interrupt Enhancement - disabled
  805. [    3.832499] OTG VER PARAM: 0, OTG VER FLAG: 0
  806. [    3.832505] ^^^^^^^^^^^^^^^^^^Host Mode
  807. [    3.847006] init: init.rk30board.bootmode.emmc.rc: 8: invalid command '/devices/ff0f0000.rksdmmc/mmc_host/mmc'
  808. [    3.847025] init: init.rk30board.bootmode.emmc.rc: 9: invalid command '/devices/ff0c0000.rksdmmc/mmc_host/mmc'
  809. [    3.847038] init: init.rk30board.bootmode.emmc.rc: 10: invalid command '/devices/ff580000.usb'
  810. [    3.847048] init: init.rk30board.bootmode.emmc.rc: 11: invalid command '/devices/ff580000.usb'
  811. [    3.847058] init: init.rk30board.bootmode.emmc.rc: 12: invalid command '/devices/ff500000.usb'
  812. [    3.847068] init: init.rk30board.bootmode.emmc.rc: 13: invalid command '/devices/ff500000.usb'
  813. [    3.847077] init: init.rk30board.bootmode.emmc.rc: 14: invalid command '/devices/ff540000.usb'
  814. [    3.847087] init: init.rk30board.bootmode.emmc.rc: 15: invalid command '/devices/ff540000.usb'
  815. [    3.847376] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
  816. [    3.876492] Init: Power Port (0)
  817. [    3.907716] init: /dev/hw_random not found
  818. [    3.907773] keychord: using input dev ff680000.pwm for fevent
  819. [    3.907782] keychord: using input dev rk29-keypad for fevent
  820. [    3.907936] init: cannot open '/initlogo.rle'
  821. [    3.920169] fs_mgr: parse_link_device : path = NULL
  822. [    3.920192] fs_mgr: parse_link_device : path = NULL
  823. [    3.920209] fs_mgr: parse_link_device : path = NULL
  824. [    3.920225] fs_mgr: parse_link_device : path = NULL
  825. [    3.920241] fs_mgr: parse_link_device : path = NULL
  826. [    3.920257] fs_mgr: parse_link_device : path = NULL
  827. [    3.920273] fs_mgr: parse_link_device : path = NULL
  828. [    3.920288] fs_mgr: parse_link_device : path = NULL
  829. [    3.920343] fs_mgr: ---------------resize_fs blk_dev /dev/block/platform/ff0f0000.rksdmmc/by-name/system, type ext4fs_mgr: Runnim
  830. [    3.921113] resize2fs: resize2fs 1.41.14 (22-Dec-2010)resize2fs: The filesystem is already 196608 blocks long.  Nothing to do!re
  831. [    3.927764] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
  832. [    3.941577] EXT4-fs (mmcblk0p8): recovery complete
  833. [    3.945343] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
  834. [    3.947457] EXT4-fs (mmcblk0p11): recovery complete
  835. [    3.947469] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
  836. [    3.955089] EXT4-fs (mmcblk0p12): recovery complete
  837. [    3.955665] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
  838. [    3.960589] drmboot: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ' should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 '
  839. [    3.965686] mali pd enabled
  840. [    3.965699] clk enabled
  841. [    3.965708] MALI_DVFS_STEP=4,div_dvfs=10
  842. [    3.965715] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
  843. [    3.965722] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
  844. [    3.965729] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
  845. [    3.965736] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
  846. [    3.966851] turn on mali power
  847. [    3.966875] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
  848. [    3.967241] mali ffa30000.gpu: Probed as mali0
  849. [    4.191280] Indeed it is in host mode hprt0 = 00021501
  850. [    4.368390] usb 3-1: new high-speed USB device number 2 using usb20_host
  851. [    4.368454] Indeed it is in host mode hprt0 = 00001101
  852. [    4.565389] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
  853. [    4.565400] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  854. [    4.565408] usb 3-1: Product: USB 2.0 Hub [MTT]
  855. [    4.565711] hub 3-1:1.0: USB hub found
  856. [    4.565765] hub 3-1:1.0: 4 ports detected
  857. [    4.840799] usb 3-1.1: new full-speed USB device number 3 using usb20_host
  858. [    4.940291] usb 3-1.1: New USB device found, idVendor=058f, idProduct=9254
  859. [    4.940305] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  860. [    4.940313] usb 3-1.1: Product: Generic USB Hub
  861. [    4.940319] usb 3-1.1: Manufacturer: ALCOR
  862. [    4.940661] hub 3-1.1:1.0: USB hub found
  863. [    4.940909] hub 3-1.1:1.0: 4 ports detected
  864. [    5.214718] usb 3-1.1.3: new low-speed USB device number 4 using usb20_host
  865. [    5.319076] usb 3-1.1.3: New USB device found, idVendor=413c, idProduct=3016
  866. [    5.319090] usb 3-1.1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
  867. [    5.319098] usb 3-1.1.3: Product: Dell Premium USB Optical Mouse
  868. [    5.324981] input: Dell Premium USB Optical Mouse as /devices/ff540000.usb/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3:1.0/input/input2
  869. [    5.325451] hid-generic 0003:413C:3016.0001: input,hidraw0: USB HID v1.11 Mouse [Dell Premium USB Optical Mouse] on usb-ff5400000
  870. [    5.401728] usb 3-1.1.4: new low-speed USB device number 5 using usb20_host
  871. [    5.507779] usb 3-1.1.4: New USB device found, idVendor=413c, idProduct=2107
  872. [    5.507793] usb 3-1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  873. [    5.507801] usb 3-1.1.4: Product: Dell USB Entry Keyboard
  874. [    5.507808] usb 3-1.1.4: Manufacturer: Dell
  875. [    5.512370] input: Dell Dell USB Entry Keyboard as /devices/ff540000.usb/usb3/3-1/3-1.1/3-1.1.4/3-1.1.4:1.0/input/input3
  876. [    5.512512] keychord: using input dev Dell Dell USB Entry Keyboard for fevent
  877. [    5.512840] hid-generic 0003:413C:2107.0002: input,hidraw1: USB HID v1.10 Keyboard [Dell Dell USB Entry Keyboard] on usb-ff540000
  878. [    5.598384] iep dpi mode inactivity
  879. [    9.800881] es8323_mic_state_ctrl read: 0
  880. [    9.800892] mic_state_switch 0
  881. [    9.800898] hp_det = 0,insert hp
  882. [    9.800903] hp mic use intern
  883. [   17.514622] *****************vbus detect*******************
Copy the code
Posted at 12/27/2014 08:03:57        Only Author  2#
Hi, I too have been unable to create an image from the released SDK.
The only method where I have successfully booted the device is:
1) Flash with the factory Android 4.4 image, 'Firefly-RK3288_Android4.4_201412111722.img'
2) Overwrite 'system.img' with your 'system.img' image
Replacing kernel.img with one generated from the SDK locks up on the Firefly logo screen on bootup.
Replacing boot.img with one generated from the SDK is OK.
I'm also unsure which bootloader, uboot images are used in the factory image. Knowing this would be helpful.
super moderator
Rank: 8Rank: 8
Posted at 12/27/2014 11:43:53        Only Author  3#
you can unpack the factory image by? Firmware Upgrade Tool for Windows which you can get from our website
http://www.t-firefly.com/en/download/
then, follow these steps:
1. edit the file: AndroidTool_Release_v2.3/config.ini ,change Selected=1 to 2;
2. execute the AndroidTool.exe
3. find the Advanced Function , then you will find the fireware unpack function.
finally you will get all the image file from Output folder.
Have? fun !
Posted at 12/27/2014 13:56:53        Only Author  4#
Thank you isle. That was very helpful!
I think my issue is I compiled the kernel incorrectly with the linaro cross compile toolchain. I've used it successfully for other Android builds, I'm not sure why it does not work here... maybe answers to the the following will explain why... [SOLVED]
On Ubuntu 12.04, when running:
make ARCH=arm CROSS_COMPILE=CROSS_COMPILE=arm-linux-gnueabihf- firefly-rk3288_defconfig
make ARCH=arm CROSS_COMPILE=CROSS_COMPILE=arm-linux-gnueabihf- -j8 firefly-rk3288.img
Results in a linking error:
make[1]: *** [pie/pie_stage3.o] Error 1
However, if the ARCH and CROSS_COMPILE are not specified:
make firefly-rk3288_defconfig
make -j8 firefly-rk3288.img
It works OK. Why is this??
Update:?https://plus.google.com/u/0/110719562692786994119/posts/MyGmGKPY4jF
Answers a lot of questions: Rockchip method specifies a CROSS_COMPILE toolchain inside the Makefile
super moderator
Rank: 8Rank: 8
Posted at 12/29/2014 16:14:40        Only Author  5#
I think your specified CROSS_COMPILE is not right .
when you have no specified CROSS_COMPILE.
it use the default .
see Makefile in kernel folder.
the CROSS_COMPILE tools is here:
../prebuilts/gcc/linux-x86/arm/
Posted at 1/24/2026 01:04:38        Only Author  6#
Die Real Estate New-Jersey-Real-Estate-Salesperson Zertifizierungsunterlagen von PrfungFrage sind unbedingt die Unterlagen fr Real Estate New-Jersey-Real-Estate-Salesperson Zertifizierungsprfung, an der Sie glauben können. Falls Sie nicht glauben, probieren Sie bitte persönlich, dann können Sie diese Tatsachen wissen. Klicken Sie bitte die Demo von PrfungFrage Website. PDF-Versionen und Software-Versionen sind beide vorhanden. Probieren Sie bitte zuerst. Sie können persönlich die Qualität der Real Estate New-Jersey-Real-Estate-Salesperson Dumps berprfen.
Posted at 2/17/2026 05:09:01        Only Author  7#
Your article is so inspiring, thank you for sharing! Boost your IT knowledge with free CWNA-109 valid dumps ebook. Wishing you all the best in your studies!
