Kernel hanging on PCIe detect
102
Posted at 6/26/2018 16:43:09      View:5150 | Replies:3        Print      Only Author   [Copy Link] 1#
Hello
We are developing under firefly RK3399 module using PEX8608 PCIe switch.
and occured boot hanging following captures
How can I fix this problem?
if i using 32bit debian image, will fix this problem?
[    0.334313] NET: Registered protocol family 2
[    0.335145] TCP established hash table entries: 16384 (order: 5, 131072 bytes        )
[    0.335891] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[    0.336738] TCP: Hash tables configured (established 16384 bind 16384)
[    0.337401] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[    0.338004] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[    0.338826] NET: Registered protocol family 1
[    0.339514] RPC: Registered named UNIX socket transport module.
[    0.340053] RPC: Registered udp transport module.
[    0.340469] RPC: Registered tcp transport module.
[    0.340893] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.342092] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counte        rs available
[    0.342906] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counte        rs available
[    0.346694] Initialise system trusted keyring
[    0.355088] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.357344] NFS: Registering the id_resolver key type
[    0.357823] Key type id_resolver registered
[    0.358206] Key type id_legacy registered
[    0.358579] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.359871] fuse init (API version 7.23)
[    0.360692] SGI XFS with security attributes, no debug enabled
[    0.366566] NET: Registered protocol family 38
[    0.366993] Key type asymmetric registered
[    0.367366] Asymmetric key parser 'x509' registered
[    0.367961] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2        47)
[    0.368619] io scheduler noop registered
[    0.368978] io scheduler deadline registered
[    0.369476] io scheduler cfq registered (default)
[    0.371214] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not a        ssigned
[    0.373056] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not a        ssigned
[    0.378787] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[    0.379386] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    0.379975] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    0.427101] PCI host bridge /pcie@f8000000 ranges:
[    0.427544]   MEM 0xfa000000..0xfa5fffff -> 0xfa000000
[    0.428015]    IO 0xfa600000..0xfa6fffff -> 0xfa600000
[    0.428709] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[    0.429309] pci_bus 0000:00: root bus resource [bus 00-01]
[    0.429798] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfa5fffff]
[    0.430417] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus addr        ess [0xfa600000-0xfa6fffff])
[    0.431659] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), rec        onfiguring
[    0.434881] pci 0000:01:00.0: bridge configuration invalid ([bus 00-00]), rec        onfiguring
[    0.449896] pci 0000:02:00.0: bridge configuration invalid ([bus 02-ff]), rec        onfiguring
[    0.450608] pci 0000:02:01.0: bridge configuration invalid ([bus 00-00]), rec        onfiguring
[    0.451328] pci 0000:02:02.0: bridge configuration invalid ([bus 00-00]), rec        onfiguring
[    0.452047] pci 0000:02:03.0: bridge configuration invalid ([bus 00-00]), rec        onfiguring
[    0.452758] pci 0000:02:04.0: bridge configuration invalid ([bus 00-00]), rec        onfiguring
[    0.453477] pci 0000:02:05.0: bridge configuration invalid ([bus 00-00]), rec        onfiguring
[    0.454195] pci 0000:02:06.0: bridge configuration invalid ([bus 00-00]), rec
Posted at 1/20/2026 21:43:44        Only Author  2#
Your article was a true standout, I’m really grateful for it. The Valid test EX316 experience questions are essential for your career—get them for free now!
Posted at 1/31/2026 08:11:31        Only Author  3#
Um die EXIN CDFOM Zertifizierungsprüfung zu bestehen, wählen Sie doch unseren Fast2test. Sie werden sicher nicht bereuen, dass Sie mit so wenigem Geld die Prüfung bestehen können. Unser Fast2test wird Ihnen helfen, sich auf die Prüfung gut vorzubereiten und die EXIN CDFOM Zertifizierungsprüfung (Certified Data Center Facilities Operations Manager) erfolgreich zu bestehen. Außerdem bieten wir Ihnen kostenlos einen einjährigen Update-Service.
Posted at 2/16/2026 21:39:24        Only Author  4#
21世紀には、{Examcode}認定は受験者の特定の能力を表すため、社会でますます認知されるようになりました。ただし、{Examcode}認定を取得するには、Revenue-Cloud-Consultant-Accredited-Professional試験の準備に多くの時間を費やす必要があります。合格しなくても、Revenue-Cloud-Consultant-Accredited-Professional模擬試験の価格を支払う必要はありません。私たちがあなたに感銘を与えるのに十分な誠意を持っていることを望みます。
