How do you increase the system.img
40
Posted at 7/5/2018 04:28:46      View:5387 | Replies:5        Print      Only Author   [Copy Link] 1#
Hi there,
I am compiling the android OS and adding 5 custom apps to the build. The build is failing due to lack of space on the system.img file system.
From the documentation it says that the limit can be increased in the parameter.txt, which I did based on the following http://en.t-firefly.com/doc/product/info/id/276.html.
This didn't have any effect and the build failed again. Please help.
Posted at 7/5/2018 05:08:03        Only Author  2#
So I found the file where the limit is being checked. See snipet below:
$(INSTALLED_FILES_FILE): $(FULL_SYSTEMIMAGE_DEPS)
        @echo Installed file list: $@
        @mkdir -p $(dir $@)
        @rm -f $@
        $(hide) build/tools/fileslist.py $(TARGET_OUT) > $(@:.txt=.json)
        $(hide) build/tools/fileslist_util.py -c $(@:.txt=.json) > $@
      $(TARGET_OUT) $(systemimage_intermediates)/system_image_info.txt $(1) $(TARGET_OUT) \
      || ( echo "Out of space? the tree size of $(TARGET_OUT) is (MB): " 1>&2 ;\
           du -sm $(TARGET_OUT) 1>&2;\
           if [ "$(INTERNAL_USERIMAGES_EXT_VARIANT)" == "ext4" ]; then \
               maxsize=$(BOARD_SYSTEMIMAGE_PARTITION_SIZE); \
               if [ "$(BOARD_HAS_EXT4_RESERVED_BLOCKS)" == "true" ]; then \
                   maxsize=$$((maxsize - 4096 * 4096)); \
               fi; \
               echo "The max is $$(( maxsize / 1048576 )) MB." 1>&2 ;\
           else \
               echo "The max is $$(( $(BOARD_SYSTEMIMAGE_PARTITION_SIZE) / 1048576 )) MB." 1>&2 ;\
           fi; \
           mkdir -p $(DIST_DIR); cp $(INSTALLED_FILES_FILE) $(DIST_DIR)/installed-files-rescued.txt; \
           exit 1 )
endef
Any idea which file it's getting the max size for the file system?
Posted at 7/5/2018 05:26:49        Only Author  3#
Think I may have found it.... The file that sets the limit is:
device/rockchip/rk3399/BoardConfig.mk
The following variable sets the limit:
//MAX-SIZE=2G, for generate out/.../system.img
BOARD_SYSTEMIMAGE_PARTITION_SIZE := 2147483648
Posted at 7/5/2018 06:05:39        Only Author  4#
No, this didn't work. Someone please help  me....
Posted at 7/5/2018 18:04:00        Only Author  5#
Though I only shrinked it, for me I had to modify the file in the target folder not the generic one.
The target file seems to be the one actually defining BOARD_SYSTEMIMAGE_PARTITION_SIZE that is used.
For the deault box target this is located under:
device/rockchip/rk3399/rk3399_firefly_box/BoardConfig.mk
Posted at 7/6/2018 06:25:11        Only Author  6#
Thanks dbe_dev, I actually grepped for the number of bits last night and got the following files:
device/rockchip/rk3399/rk3399_firefly_aio_box/BoardConfig.mk
device/rockchip/rk3399/rk3399_firefly_aio_edp_box/BoardConfig.mk
device/rockchip/rk3399/rk3399_firefly_aio_lvds_box/BoardConfig.mk
device/rockchip/rk3399/rk3399_firefly_aio_mipi_box/BoardConfig.mk
device/rockchip/rk3399/rk3399_firefly_edp_box/BoardConfig.mk
device/rockchip/rk3399/rk3399_firefly_mipi_box/BoardConfig.mk
I updated them all in hopes that my build would work as I was leaving for the night. I can confirm I was able to set the partition to 1.4 GB with no issue. When I came back in this morning, the build was successful. Anyways appreciate the answer anyways and hope this might help someone in the future.
