Cannot switch the device to upgrade mode.
23
Posted at 8/13/2018 10:36:26      View:4971 | Replies:7        Print      Only Author   [Copy Link] 1#
I have a problem with connecting AIO-3399J to Host PC.
I refered a guide from this link. http://en.t-firefly.com/doc/prod ... ll20RK20USB20Driver
and followed both method for AIO-3399J MainBoard & AIO-3399J but not working (Not able to find the device from Device manager)
Tried Uninstall & Re-install the driver many times but the same.
What can I try in this situation? Did anyone go through the same problem and solve it?
Posted at 8/13/2018 11:37:57        Only Author  2#
Insert USB3.0 AIO-3399J OTG port .
Posted at 8/13/2018 12:48:20        Only Author  3#
Thanks for reply. But USB3.0 AIO-3399J OTG port didn't work also.
Below is the step I tried:
1. Cut off the power sources, such as power adapter and dual male usb3.0 data cable connection
2.Keep dual male usb3.0 data cable connected with host PC
3.Press and hold RECOVERY key.
4.Connect dual male usb3.0 data cable to the device. (OTG port)
5.After around two seconds, release RECOVERY key.
Can you correct me if I am doing something wrong here?
Posted at 8/13/2018 15:16:23        Only Author  4#
bg81011 Posted at 8/13/2018 12:48
If PC do not recognize  the board , just install Install "RK USB Driver" .
1. Keep power on
2 .Keep dual male usb3.0 data cable connected with host PC
3. Press and hold RECOVERY key,  short time press the reset for restart the power.
4. After around two seconds, release RECOVERY key
Then PC will catch the usb device.
Posted at 8/13/2018 15:55:12        Only Author  5#
leung先森 Posted at 8/13/2018 15:16
1. Keep power on
2 . ...
Thank you Could you help a bit more?
I made sure the driver installed but still can't catch the device.
1. Does the type of cable matter? It seems the blue cable from the inbox package is useless. So I'm using 3.0 dual-male cable.
2. Is RK USB driver compatible with window 10? I'm using windows10.
3. Below are the last logs messages when I followed your instruction. Is that saying my board ready to connect?
persist.sys.media.avsync=true
persist.sys.dalvik.vm.lib.2=libart.so
persist.sys.timezone=
persist.sys.strictmode.visual=false
persist.sys.framebuffer.main=1920x1080
ro.ril.ecclist=112,911
ril.function.dataonly=1
sys.usb.config=adb
sys.usb.configfs=1
Supported API: 3
I:Saving locale "en_US"
[    5.236418] fs_mgr: Warning: unknown flag resize
Join led thread error!
[   12.053036] random: nonblocking pool is initialized
[   13.551989] read descriptors
[   13.552069] read descriptors
[   13.552095] read strings
In the end, I see this Android recovery screen somtimes. I want to choose the second (reboot to bootloader). But can't do without Volume Button. Is this screen saying that device is ready to connect update mode?
Thanks for reading!
Posted at 8/13/2018 17:50:58        Only Author  6#
bg81011 Posted at 8/13/2018 15:55
I made sure the driver installed but still can't catch  ...
Might be the win10 problem.
Change another system and try.
Follow the log , it seems it is your cable or connecting problem.
If success , it is impossible go into recovery mode.
Posted at 8/13/2018 20:41:00        Only Author  7#
I used "upgrade_tool" under Linux environment. and was able to flash the img.
Thanks a lot!!  leung先森
Posted at 9/4/2018 15:39:49        Only Author  8#
follow next step.
1.power on with external 12V adapter
    AIO-3399J needs external power for mode change
2.plug usb cable to upper side
3.push and hold recover swich
4.push and release reset switch
5.you can see next device on your PC
good luck
