【Hardware】[Indiegogo crowdfunding] $99 cost-effective RK3399 ultra-small mini PC
Posted at 9/5/2018 11:07:57View:3568|Replies:0 Print
[Copy Link]1#
ROC-RK3399-PC adopts Rockchip high-performance core configuration, unique power supply mode, unique plate design, access to expansion board, superior performance, excellent combination of metal casing, it becomes a pocket portable personal computer.
Large and small core architecture with built-in core
It adopts the "server-class" dual-core Cortex-72+ quad-core Cortex-A53 core architecture, clocked at up to 2.0GHz, and is equipped with 4GB LPDDR4 dual-channel 64-bit RAM high-performance memory to improve motherboard performance.
Small size, card computer
The unique plate design, the golden ratio, is only 120 x 72 x 11.9mm, and combined with the metal case, it becomes a pocket portable personal PC.
Expansion board combination, powerful
Expansion board onboard balanced charging circuit, can charge onboard battery, can also be powered by POE+ enhanced Ethernet, has M.2 M-Key interface and M.2 E-Key interface, expand SSD and provide SDIO 3.0 , USB 2.0 signal, ROC-RK3399-PC motherboard with expansion board, performance will be greatly improved.
Support multiple systems, start fast
Support Android, Ubuntu, Debian9, Linux+QT multiple operating systems, support xserver and wayland display framework. Onboard SPI flash, support TF card, EMMC, SSD, U disk boot, make system startup more convenient and fast.
Multiple power supply modes, flexible application
The ROC-RK3399-PC motherboard can be powered by POE+ (802.3 AT, output power 30W) enhanced Power over Ethernet or dual-cell battery. It has a Type-C PD 2.0 power control chip and supports wide voltage (5V-15V) input. A variety of power supply methods can meet the application choices of users in different scenarios, and the use is more flexible and convenient.
Rich peripheral interface
It has MIPI/eDP screen interface, dual MIPI CSI interface (supports two-way camera), Type-C x 2, USB 2.0 Host x 3, HDMI 2.0, Gigabit Ethernet (RJ45), GPIO and other rich interfaces.
More details can be found on the Firefly website
ROC-RK3399-PC has been launched in Indiegogo crowdfunding, deadline September 10, 2018, only $99, you can get ROC-RK3399-PC high performance open source motherboard.
