New Topic
【Mutil-Boot】Multi-OS launcher release
391
super moderator
Rank: 8Rank: 8
Posted at 9/10/2018 20:54:57      View:11906 | Replies:15        Print      Only Author   [Copy Link] 1#
Firefly Mutil-Boot
Multi-OS installation and launcher
Mutil-Boot is developed for the firefly hardware platform. It can realize online installation and startup of multiple systems. The interface design is simple and easy to operate. It is easy for beginners to get started with multiple operating systems.
Installation system online
Three steps to easily install the system online, the operation is very simple
Optional System Boot
The installed system will be listed , and the user can select the system that he wants to start.
Multi-Language Support
Built-in multi-language package for fast switching to familiar languages
Multiple Networking Methods
It has two networking modes: Ethernet and WiFi, and supports WPS function of WiFi.
----------------------------- Dividing Line ----------------------------
▍System login
* Linux system requires a login password (the Armbian system also needs to be initialized)
1. Ubuntu
    (default username: firefly, password: firefly)
2. Debian
3. Armbian Stretch
    A lightweight Debian for ARM development boards. You need to set the user and password according to the
    system prompts to complete the initialization.  (Default username: root, password: 1234)
4. OpenMediaVault
    A network attached storage (NAS) system that requires remote access via the web
    (default username: admin, password: openmediavault)
Firmware Programming
1. Firefly-RK3399
    Firmware Programming:Firefly-RK3399 firmware programming >>
2. ROC-RK3328-CC
    Firmware Programming:ROC-RK3328-CC firmware programming >>
Posted at 9/11/2018 02:16:08        Only Author  2#
How can i:1/ copy remote config file to android file system?
2/ install google play
3/ plug xiaomi wifi mini dongle
Please help me
super moderator
Rank: 8Rank: 8
Posted at 9/11/2018 09:47:44        Only Author  3#
khanhduy8 Posted at 9/11/2018 02:16
3/ plug xiaom ...
Hello, you can find your Devboard directory in our WiKi, which provides SDK download and related driver tutorials.
Link:http://wiki.t-firefly.com/en/
Posted at 10/14/2018 10:13:13        Only Author  4#
I only have 3 options to install : Apologies - I forgot to mention I am running the RK3399
Station OS
Armbian stretch
open media vault
How do I get the others to show up?
Thanks
Joe
Posted at 10/15/2018 16:19:27        Only Author  5#
I thought this would be an easy one.
super moderator
Rank: 8Rank: 8
Posted at 10/17/2018 09:43:48        Only Author  6#
jospehgwatkins Posted at 10/14/2018 10:13
Statio ...
Hello, RK3399 only supports these three systems now, and other systems will be added later.
Posted at 10/23/2018 00:07:56        Only Author  7#
What are the tree keys/buttons to enter recovery-mode on an English keyboard?
super moderator
Rank: 8Rank: 8
Posted at 10/23/2018 10:02:12        Only Author  8#
Razputin Posted at 10/23/2018 00:07
Hello,You can press Shift to enter setup mode
Posted at 11/6/2018 11:56:30        Only Author  9#
No possibility to use android or ubuntu in multy boot ?
the system OS where a lot of part are still in chinese (?), even when you configure the language in English ?
Issue (for not say impossibility) for the use of the camera with MIPI sell with the RK3399 under ubuntu (yes apparently somebody succeed to make it work for ONE camera) that still don't have solution ? ( by the way since the start of the sells of those camera when will we have a tuto or a driver for this?)
(and I don't speak about the fact that the board reboot continuously when you press shutdown (still under ubuntu) if you don't unplug the power source)
do you want to kill your product ? because it's how you do.
PS: people can understand that there aren't a big dev team and the fact that you can meet a lot of issue but don't advertise something that doesn't work.
Sorry for the long post here an unipotato
super moderator
Rank: 8Rank: 8
Posted at 11/12/2018 16:07:08        Only Author  10#
Yolo19048 Posted at 11/6/2018 11:56
the system OS where a lot of part are stil ...
Hi Yolo19048, this is one of the most thoughtful comments I have ever seen. Thank you very much, we are constantly optimizing the system and trying to give users a better experience.
Return to List
12
