SPMC wrong screen resolution
7
Posted at 12/30/2014 07:00:45      View9061 | Replies6        Print      Only Author   [Copy Link] 1#
[size=1.3em]
I would like to use Firefly as main media player for all my content up to 4K on Samsung HU7000 series TV from QNAP NAS. Initially I had a problem with HDMI connection to my TV in 4K/60Hz mode. It works only if HDMI input renamed to PC, HDMI 2.0 cable has length not longer than 3ft and UltraHD colors enabled in Samsung TV menu.Built-in player show video correctly only from USB drive but when I try to watch anything over Gigabit Ethernet network I see "green noise" picture instead 4K Astra demo video or video without any sound for regular HD movies.
So I've installed SPMC from http://spmc.semperpax.com and now can watch almost everything over network (NFS,Samba). I have only two problems now:
  • video showing not smoothly (it looks like very fast slide-show) like 10-20fps in any screen resolution. I can compare video from different HDMI sources and there no any problem with TV here.
  • Full UHD resolution (3840x2160x60) works fine in Home Screen but if I run SPMC from any resolution higher than 1920x1080x60 screen automatically change resolution to 1280x720. Android still think it has original UHD resolution. SPMC always show 3840x2160x60 in system settings even if screen is 3840x2160x25 only. See screenshot...
ATTACHMENTSSPMC screenshot
vip
Rank: 6Rank: 6
Posted at 12/30/2014 15:47:49        Only Author  2#
I find a spmc that support great:
https://drive.google.com/file/d/0BxeflG ... sp=sharing
The second problem , you need to ?close spmc completely and restart it, then you can find it change. I think this is spmc's problem.
close spmc completely,just click this button:
Posted at 12/31/2014 06:25:17        Only Author  3#
SPMC 13.3.4-beta1 was my first version installed on Firefly.
Now I have 13.4.0 but problem still be the same.
Quote from Changelog:
13.4.0 (2014/12/14):
  • Improved Rockchip support
    • overlay, hevc + true 4K on rk3288
  • Auto-framerate switching for Amlogic
    • (Needs 666 on /sys/class/display/mode)
  • Auto-framerate switching for Rockchip
    • (Needs 666 on /sys/class/display/display0.HDMI/mode)
  • Allow forcing passthrough hack on Rockchip via AS ()
How can I change permissions for /sys/class/display0.HDMI/mode in Android?
vip
Rank: 6Rank: 6
Posted at 12/31/2014 17:23:56        Only Author  4#
/sys/class/display/display0.HDMI/mode   already 666
shell@rk3288:/ # ll /sys/class/display/display0.HDMI/mode
-rw-rw-rw- root     root         4096 2011-01-01 12:07 mode
if want to set other mode, you can set it in init.rc
Posted at 1/10/2026 04:44:19        Only Author  5#
The article was quite thought-provoking. The New AAPC-CPC study plan questions are freeuse them to unlock promotions and higher earnings!
Posted at 1/13/2026 14:01:04        Only Author  6#
After reading this article, I feel I have grown a lot. The New study SC-400 questions book test questions are now free. Wishing you all the best of luck!
Posted at 1/16/2026 01:05:04        Only Author  7#
Thank you for your article, it truly broadened my mind and vision. Its nearly time for my Generative-AI-Leader valid dumps demo exam C wish me all the best!
