[Linux] ubuntu 16.04 - Bluetooth missing
66
【Linux】 ubuntu 16.04 - Bluetooth missing
Posted at 12/6/2018 01:14:22      View:2405 | Replies:1        Print      Only Author   [Copy Link] 1#
The Bluetooth is  not working at all.   Not the AP6356S wifi-bt module nor 2 USB dongle that i have got.
Saw it some ware that AP6356S is now in the kernel.   So ti is just a question of compiling the drivers in to the kernel.
Kernel module is hci_bcm and the kernel compile support is
enable HCI_BCM, SERIAL_DEV_BUS, BT_HCI_UART_SERDEV
The manufacturer might be AMPAC - Broadcom
When will we see newer kernel and Ubuntu 18.04 for firefly?
I have also got rockpro64 board and it is also using kernel 4.4.
What is good about rockpro64 is that you can bypass emmc with a jumper and start from SD card or USB if you put bootloader in to the SPI module with a SD image.
vip
Rank: 6Rank: 6
Posted at 12/6/2018 17:33:49        Only Author  2#
Bluetooth support of AP6356S in Ubuntu has long been a nasty bug. We took the effort
to contact with Rockchip, but got little help.
In the Ubuntu 18.04 (which can be downloaded from Baidu Pan, soon be available
in Google Drive), this bug still exists.
root@firefly:/usr/local/bin# hciconfig -a
hci0:   Type: Primary  Bus: UART
        BD Address: 11:A7:37:7D:EF:06  ACL MTU: 1021:8  SCO MTU: 64:1
        UP RUNNING
        RX bytes:883 acl:0 sco:0 events:64 errors:0
        TX bytes:5561 acl:0 sco:0 commands:68 errors:0
        Features: 0xbf 0xfe 0xcf 0xfe 0xdb 0xff 0x7b 0x87
        Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
        Link policy: RSWITCH SNIFF
        Link mode: SLAVE ACCEPT
root@firefly:/usr/local/bin# hcitool scan
Scanning ...
[  810.248285] Bluetooth: hci0: Frame reassembly failed (-84)
[  810.248983] Bluetooth: hci0: Frame reassembly failed (-84)
[  812.253433] Bluetooth: hci0 command 0x0401 tx timeout
Inquiry failed: Connection timed out
