[Linux] Firefly-RK3399-ubuntu18.04_20181017.img upgrade fail
164
【Linux】 Firefly-RK3399-ubuntu18.04_20181017.img upgrade fail
Posted at 12/10/2018 16:48:45      View:3980 | Replies:4        Print      Only Author   [Copy Link] 1#
Dear All,
When I try to upgrade this img file I gave check firmware error. Pls check shared picture.
Best regards,
vip
Rank: 6Rank: 6
Posted at 12/11/2018 17:58:20        Only Author  2#
Please see: http://wiki.t-firefly.com/en/Firefly-RK3399/flashing-notes.html
Use Android Tool 2.58 to flash.
Posted at 12/11/2018 20:58:26        Only Author  3#
I tried and it is ok now. But at that time i have this bug and i gave the same bug for 16.04 ubuntu also;
[   14.456018] CONFIG-ERROR) dhd_conf_set_bufiovar: country setting failed -2
[FAILED] Failed to start Network Manager.
See 'systemctl status NetworkManager.service' for details.
[  OK  ] Reached target Network.
         Starting OpenBSD Secure Shell server...
[  OK  ] Reached target Network is Online.
[  OK  ] Started crash report submission daemon.
         Starting Tool to automatically coll… submit kernel crash signatures...
         Starting Permit User Sessions...
         Starting /etc/rc.local Compatibility...
[  OK  ] Started Permit User Sessions.
         Starting Light Display Manager...
[  OK  ] Started OpenBSD Secure Shell server.
[  OK  ] Stopped Network Manager.
         Starting Network Manager...
[  OK  ] Started Tool to automatically colle…nd submit kernel crash signatures.
[  OK  ] Started Light Display Manager.
[  OK  ] Started /etc/rc.local Compatibility.
         Starting Hold until boot process finishes up...
[  OK  ] Started Hold until boot process finishes up.
[  OK  ] Started Serial Getty on ttyFIQ0.
[  OK  ] Started Getty on tty1.
[  OK  ] Reached target Login Prompts.
[   16.227619] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   16.228457] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   16.229298] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   16.230118] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   16.231001] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   16.231840] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   16.296056] CONFIG-ERROR) dhd_conf_set_bufiovar: country setting failed -2
[  OK  ] Started Network Manager.
[  OK  ] Reached target Multi-User System.
[  OK  ] Reached target Graphical Interface.
         Starting Update UTMP about System Runlevel Changes...
[  OK  ] Started Update UTMP about System Runlevel Changes.
Ubuntu 18.04.1 LTS firefly ttyFIQ0
firefly login: root (automatic login)
[   17.226951] rc.local[479]: Patch not found, continue anyway
Welcome to Ubuntu 18.04.1 LTS (GNU/Linux 4.4.154 aarch64)
* Documentation:  https://help.ubuntu.com
* Management:     https://landscape.canonical.com
* Support:        https://ubuntu.com/advantage
This system has been minimized by removing packages and content that are
not required on a system that users do not log into.
To restore this content, you can run the 'unminimize' command.
16 ????????
0 ??????
The programs included with the Ubuntu system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by
applicable law.
There is no any video on hdmi.What do i have to do?
Posted at 12/11/2018 21:52:43        Only Author  4#
I love my hdmi cable. So now everything is ok but why i'm getting this message "[drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property". Is it about related to EDID?
vip
Rank: 6Rank: 6
Posted at 12/12/2018 14:29:53        Only Author  5#
This message is just about some unsupported property set of the hdmi connector.
It is okay to ignore that.
