New Topic
[Linux] GBT uboot compile
164
【Linux】 GBT uboot compile
Posted at 12/13/2018 21:15:20      View:10024 | Replies:20        Print      Only Author   [Copy Link] 1#
Dear All,
I have problem when I try to compile boot and getting these messages;
met@met:~/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk$ ./build.sh firefly-rk3399.mk
/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/rk3399/firefly-rk3399.mk
met@met:~/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk$ ./build.sh uboot
============Start build uboot============
TARGET_UBOOT_CONFIG=firefly-rk3399
.........-------PREPARE----------..........
make for firefly-rk3399_defconfig by -j2
arch/../configs/firefly-rk3399_defconfig:17:warning: override: reassigning to symbol ANDROID_BOOTLOADER
# configuration written to .config
/bin/sh: 1: Syntax error: word unexpected (expecting ")")
/bin/sh: 1: Syntax error: "(" unexpected
scripts/kconfig/conf  --silentoldconfig Kconfig
  CHK     include/config.h
scripts/Makefile.autoconf:50: recipe for target 'include/autoconf.mk.dep' failed
make[1]: *** [include/autoconf.mk.dep] Error 2
make[1]: *** Waiting for unfinished jobs....
scripts/Makefile.autoconf:79: recipe for target 'u-boot.cfg' failed
make[1]: *** [u-boot.cfg] Error 2
make: *** No rule to make target 'include/config/auto.conf', needed by 'include/config/uboot.release'.  Stop.
====Build uboot failed!====
Could you pls  share idea about the problem.How can i solve it?
Best regards,
Posted at 12/13/2018 21:51:54        Only Author  2#
[u-boot.cfg] Error 2  - some config issues?
Posted at 12/13/2018 23:31:31        Only Author  3#
I did only what steps say. Is there any body tried it?
Posted at 12/14/2018 16:20:54        Only Author  4#
is there any person who can help me about this subject. I did all steps explain from your web site and gave this error. Think this error /bin/sh: 1: Syntax error: word unexpected (expecting ")") related to compiler toolchain not supported. Try to export CROSS_COMPILE=aarch64-linux-gnu- and is same.  did you test it and eveything is ok?
Posted at 12/17/2018 16:15:39        Only Author  5#
Is there anybody who wants to answer this problem. Board is perfect as properties, contains all and ok it is for development but if we saw any problem and try to find a solution where is support? When i check the non english part of this web site, there are much more activity so means this board is not for others?Pls help...
vip
Rank: 6Rank: 6
Posted at 12/17/2018 17:39:54        Only Author  6#
Will you please post your environment and full steps?
vip
Rank: 6Rank: 6
Posted at 12/18/2018 09:59:20        Only Author  7#
Try to use:
  bash -x ./build.sh uboot
to get the verbose output of the build script, which will help to locate the problem.
Posted at 12/18/2018 14:53:57        Only Author  8#
Dear pengeuin,
Pls check the log file;
met@met:~$ ls
Desktop  Documents  Downloads  examples.desktop  jd2  Music  Pictures  Public  Templates  Videos
met@met:~$ cd Desktop/Compile_Ubuntu_firmware\(GPT\)/linux/
linux-sdk/ repo/
linux-sdk/ repo/
met@met:~$ cd Desktop/Compile_Ubuntu_firmware\(GPT\)/linux/linux-sdk/
met@met:~/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk$ bash -x ./build.sh firefly-rk3399.mk
+++ dirname ./build.sh
++ cd .
++ pwd
+ COMMON_DIR='/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk'
+ '[' -h ./build.sh ']'
++ readlink ./build.sh
+ CMD=device/rockchip/common/build.sh
++ dirname device/rockchip/common/build.sh
+ COMMON_DIR=device/rockchip/common
+ cd device/rockchip/common
+ cd ../../..
++ pwd
+ TOP_DIR='/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk'
+ COMMON_DIR='/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/common'
+ BOARD_CONFIG='/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/.BoardConfig.mk'
+ CFG_DIR='/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip'
+ ROCKDEV='/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/rockdev'
+ source '/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/.BoardConfig.mk'
+ PARAMETER='/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/rk3399/parameter-ubuntu.txt'
+ SD_PARAMETER='/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/rk3399/parameter-recovery.txt'
+ '[' '!' -n firefly-rk3399.mk ']'
+ BUILD_TARGET=firefly-rk3399.mk
++ find '/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip' -name firefly-rk3399.mk
+ NEW_BOARD_CONFIG='/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/rk3399/firefly-rk3399.mk'
+ '[' firefly-rk3399.mk == uboot ']'
+ '[' firefly-rk3399.mk == kernel ']'
+ '[' firefly-rk3399.mk == extboot ']'
+ '[' firefly-rk3399.mk == rootfs ']'
+ '[' firefly-rk3399.mk == buildroot ']'
+ '[' firefly-rk3399.mk == recovery ']'
+ '[' firefly-rk3399.mk == pcba ']'
+ '[' firefly-rk3399.mk == yocto ']'
+ '[' firefly-rk3399.mk == ros ']'
+ '[' firefly-rk3399.mk == debian ']'
+ '[' firefly-rk3399.mk == updateimg ']'
+ '[' firefly-rk3399.mk == sdbootimg ']'
+ '[' firefly-rk3399.mk == sdupdateimg ']'
+ '[' firefly-rk3399.mk == all ']'
+ '[' firefly-rk3399.mk == firmware ']'
+ '[' firefly-rk3399.mk == save ']'
+ '[' firefly-rk3399.mk == cleanall ']'
+ '[' firefly-rk3399.mk == --help ']'
+ '[' firefly-rk3399.mk == help ']'
+ '[' firefly-rk3399.mk == -h ']'
+ '[' firefly-rk3399.mk == allsave ']'
+ '[' -f '/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/rk3399/firefly-rk3399.mk' ']'
+ '[' '!' -n '/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/rk3399/firefly-rk3399.mk' ']'
+ echo '/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/rk3399/firefly-rk3399.mk'
+ rm -f '/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/.BoardConfig.mk'
+ ln -s '/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/rk3399/firefly-rk3399.mk' '/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/.BoardConfig.mk'
+ unset RK_PACKAGE_FILE
+ unset RK_MKUPDATE_FILE
+ source '/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip/rk3399/firefly-rk3399.mk'
++ export RK_ARCH=arm64
++ RK_ARCH=arm64
++ export RK_UBOOT_DEFCONFIG=firefly-rk3399
++ RK_UBOOT_DEFCONFIG=firefly-rk3399
++ export RK_KERNEL_DEFCONFIG=firefly_linux_defconfig
++ RK_KERNEL_DEFCONFIG=firefly_linux_defconfig
++ export RK_KERNEL_DTS=rk3399-firefly
++ RK_KERNEL_DTS=rk3399-firefly
++ export RK_BOOT_IMG=boot.img
++ RK_BOOT_IMG=boot.img
++ export RK_PARAMETER=parameter-ubuntu.txt
++ RK_PARAMETER=parameter-ubuntu.txt
++ export RK_SD_PARAMETER=parameter-recovery.txt
++ RK_SD_PARAMETER=parameter-recovery.txt
++ export RK_PACKAGE_FILE=rk3399-ubuntu-package-file
++ RK_PACKAGE_FILE=rk3399-ubuntu-package-file
++ export RK_SD_PACKAGE_FILE=rk3399-recovery-package-file
++ RK_SD_PACKAGE_FILE=rk3399-recovery-package-file
++ export RK_CFG_BUILDROOT=rockchip_rk3399
++ RK_CFG_BUILDROOT=rockchip_rk3399
++ export RK_CFG_RECOVERY=rockchip_rk3399_recovery
++ RK_CFG_RECOVERY=rockchip_rk3399_recovery
++ export RK_CFG_PCBA=rockchip_rk3399_pcba
++ RK_CFG_PCBA=rockchip_rk3399_pcba
++ export RK_JOBS=8
++ RK_JOBS=8
++ export RK_TARGET_PRODUCT=rk3399
++ RK_TARGET_PRODUCT=rk3399
++ export RK_ROOTFS_TYPE=ext4
++ RK_ROOTFS_TYPE=ext4
++ export RK_ROOTFS_IMG=buildroot/output/rockchip_rk3399/images/rootfs.ext4
++ RK_ROOTFS_IMG=buildroot/output/rockchip_rk3399/images/rootfs.ext4
++ export RK_OEM_FS_TYPE=ext2
++ RK_OEM_FS_TYPE=ext2
++ export RK_USERDATA_FS_TYPE=ext2
++ RK_USERDATA_FS_TYPE=ext2
++ export RK_STORAGE_TYPE=emmc
++ RK_STORAGE_TYPE=emmc
++ export RK_OEM_DIR=oem_normal
++ RK_OEM_DIR=oem_normal
++ export RK_USERDATA_DIR=userdata_normal
++ RK_USERDATA_DIR=userdata_normal
+ [[ xrk3399-ubuntu-package-file != x ]]
+ PACK_TOOL_DIR='/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/tools/linux/Linux_Pack_Firmware/rockdev/'
+ cd '/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/tools/linux/Linux_Pack_Firmware/rockdev/'
+ rm -f package-file
+ ln -sf rk3399-ubuntu-package-file package-file
+ MKUPDATE_FILE=rk3399-mkupdate.sh
+ [[ xrk3399-mkupdate.sh != x-mkupdate.sh ]]
+ rm -f mkupdate.sh
+ ln -sf rk3399-mkupdate.sh mkupdate.sh
+ exit 0
met@met:~/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk$ bash -x ./build.sh uboot
++ cd .
++ pwd
+ cd ../../..
++ pwd
+ '[' '!' -n uboot ']'
+ BUILD_TARGET=uboot
++ find '/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/device/rockchip' -name uboot
+ NEW_BOARD_CONFIG=
+ '[' uboot == uboot ']'
+ build_uboot
+ echo '============Start build uboot============'
+ echo TARGET_UBOOT_CONFIG=firefly-rk3399
+ echo =========================================
+ '[' -f 'u-boot/*_loader_*.bin' ']'
+ cd u-boot
+ ./make.sh firefly-rk3399
.........-------PREPARE cmd=----------..........
.........-------PREPARE BOARD=firefly-rk3399----------..........
.........-------PREPARE OUTDIR=.----------..........
RKBIN=/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/rkbin
RKTOOLS=/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/rkbin/tools
.........------- metin after prepare----------..........
.........-------select_toolchain----------..........
TOOLCHAIN_GCC=/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-
TOOLCHAIN_OBJDUMP=/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-objdump
TOOLCHAIN_ADDR2LINE=/home/met/Desktop/Compile_Ubuntu_firmware(GPT)/linux/linux-sdk/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-addr2line
.........------- metin after select_toolchain----------..........
.........-------select_chip_info----------..........
.........-------RKCHIP_LABEL=RK3399----------..........
.........-------RKCHIP_LOADER=RK3399----------..........
.........-------RKCHIP_TRUST=RK3399----------..........
.........------- metin after select_chip_info----------..........
.........-------fixup_platform_configure----------..........
.........-------PLATFORM_RSA=----------..........
.........-------PLATFORM_SHA=----------..........
.........-------PLATFORM_UBOOT_IMG_SIZE=----------..........
.........-------PLATFORM_AARCH32=----------..........
.........------- metin after fixup_platform_configure----------..........
.........-------sub_commands----------..........
.........-------sub_commands cmd=firefly----------..........
.........------- metin after sub_commands----------..........
+ '[' 2 -eq 0 ']'
+ echo '====Build uboot failed!===='
+ exit 1
And only do the related steps at http://wiki.t-firefly.com/en/Fir ... ux_compile_gpt.html
Best regards,
Metin
Posted at 12/18/2018 14:55:28        Only Author  9#
I include some echo or prints to understand to understand what happend...
vip
Rank: 6Rank: 6
Posted at 12/19/2018 09:53:42        Only Author  10#
@metind  what's your os and filesystem used?
Post result of:
  cd u-boot
  git log -n2
  git status
Return to List
123
