Original SDK files?
Posted at 1/3/2015 21:24:36
Hi!
Tested your pad version of the SDK on firefly and it works fine! Now I want to check this software on a different setup. But I I miss the original files for rockchips evaluation kits. Normally the SDKs are having these files like rk3188_defconfig or similar. But in this SDK ther is no rk3288_defconfig for the rockchip original evaluation kit.
As these kits are often used as a design example, they are good reference. Did you remove the files and can you add them to the SDK again on bitbucket or are these files not available for any special reason?
I am talking about defconfig, dtb and uboot config.
kind regards
Astralix |
