[Linux] ROC-RK3399-PC - clinfo shows no devices
75
【Linux】 ROC-RK3399-PC - clinfo shows no devices
Posted at 1/4/2019 13:27:02      View:5138 | Replies:4        Print      Only Author   [Copy Link] 1#
Using the ubuntu image on the downloads page for the ROC-RK3399-PC
Running the command "clinfo" should show the OpenCL information about the Mali GPU, however, it shows
Number of platforms                               0
How can OpenCL support be enabled?
vip
Rank: 6Rank: 6
Posted at 1/4/2019 15:14:59        Only Author  2#
1. git clone https://github.com/simleb/clinfo.git
2. apt install opencl-headers
3. cd clinfo;make;make install
4. cd /usr/lib/aarch64-linux-gnu/ ; ln -sf libOpenCL.so  libMali.so.7.0
5. ./clinfo
Posted at 1/5/2019 13:12:19        Only Author  3#
Thanks for getting back to me.
I have done the above, but now it gives a segmentation fault.
root@firefly:~# clinfo
Platform #0
  Version:                               OpenCL 1.2 v1.r14p0-01rel0-git(966ed26).f44c85cb3d2ceb87e8be88e7592755c3
  Device #0
    Type:                                GPU
    Global memory size:                  3 GB 772 MB 664 kB
    Local memory size:                   32 kB
    Max work group size:                 256
    Max work item sizes:                 (256, 256, 256)
Segmentation fault (core dumped)
vip
Rank: 6Rank: 6
Posted at 1/5/2019 15:47:08        Only Author  4#
Just a print bug
-               buffer_size += (dims[i] > 0 ? lrint(log10(dims[i])) + 1 : 1) + 2;
+               buffer_size += (dims[i] > 0 ? lrint(log10(dims[i])) + 2 : 1) * ndims + 2;
Posted at 1/30/2019 02:00:03        Only Author  5#
Tried it but got make error
cc -Wall -O3 -std=c99 -o clinfo clinfo.c  -lOpenCL -lm
clinfo.c: In function ‘printStringValue’:
clinfo.c:642:11: warning: format ‘%s’ expects argument of type ‘char *’, but argument 2 has type ‘void *’ [-Wformat=]
  printf("%s\n", value);
          %p
clinfo.c: In function ‘printUlong’:
clinfo.c:696:22: warning: format ‘%llu’ expects argument of type ‘long long unsigned int’, but argument 3 has type ‘cl_ulong {aka const long unsigned int}’ [-Wformat=]
  sprintf(buffer, "%llu", num);
                   %lu
If I run clinfo iget
clinfo: Cannot get the number of OpenCL platforms available.
