New Topic
[Hardware] Thanks for helping me, usb to uart do not connect
156
【Hardware】 Thanks for helping me, usb to uart do not connect
Posted at 1/9/2019 21:34:15      View:5579 | Replies:14        Print      Only Author   [Copy Link] 1#
Hello,
I just received today the modul usb to uart oficial but it does not work as expected!
link :  http://shop.t-firefly.com/goods.php?id=32
Can you help me please ? I can not parramétrer the module USB to uart oficial of firefly, I followed the tutorial of the site but I have an error which tells me that the conexion is impossible. I made a 3 minute video, can you watch it and tell me where I made a mistake?
Thank you also for telling me how to fix the problem. I'm going crazy with this card, nothing works as it should, it's not much, but even the color of the cables are not the same as on the site, I still have everything connected, but it's just to say. I tell you frankly I'm sorry for my card, I regret every day not to have bought a rasberry pi3, with the shipping and all my purchases I am 250 ?and it still does not work. I will pay until when to have what is promised by the site in its advertising?
I bought this module to try to solve this problem, but now it is the module that is problematic, I go crazy !
http://bbs.t-firefly.com/forum.p ... tra=page%3D1&page=1
PS: if your internet speed allows, put the video in 1080p you will see better
Posted at 1/10/2019 18:53:22        Only Author  2#
Hello,
- I managed to connect the USB to Uart with the firefly RK3399, but I can not exceed the flow of 128000 bit/s I supose because I do not have the usb3 on my computer.
- I also set the configuration in putty when connected in 128000 because I can not put 1500000 bit/s
- When I try to update the firmware, I have the IDB fail er er but putty in the symbols terminal incomprehensible for months on a single line (see photo)
- To test, I put the SD card with linux sd available on the site, of course it does not boot, but putty then shows me in the terminal signs incomprehensible for 2 minutes then stops at once, we do not see anything on the screen of the tv, I tried with 3 other screens in hdmi em even with the cable hdmi oficial firefly with gold connectors and we do not see anything. thank you for watching the video that I will add for you to judge for yourself. Do you have any tip ? I'm very good at the end, I do not know what to do.
NOTE: on the last picture you see the putty display when I put the SD card in the RK3399
Thanks in advance.
Posted at 1/10/2019 19:42:12        Only Author  3#
Here is the video when I boot with the SD card.
The SD boot firmware Firefly-rk3399_xubuntu1604_SD_201705151725.7z downloaded from https://drive.google.com/drive/f ... gAqAamx6cXd6b205eEk
As I said in the previous post, I can not update firmware but I do not boot with the SD card either.
The Putty terminal displays things that I do not understand, it's the same thing when I update a firmware mode maskrom or loader, nothing works but especially I do not know what to do.
My card is broken? How to make sure I understand what putty prints? Thank you, the video is not long, it only takes 5 minutes.
How to display a bitrate of 1500000 bit/s as in the tutorial since the maximum I can with my windows10 machine is 128000 bit/s ?
Posted at 1/10/2019 20:28:58        Only Author  4#
this is in my opinion a problem of font encoding. In Putty there is a "translation" option but I do not know what to choose, I tried several and each time I do not understand the text. I used in this example "use font encoding" of putty and it shows me this code when I try to make a firmware update followed by the message idb fail in android tool
  1. ýÜÎœs쭧õÏýåþœs쭧õÏýåþ¼þl
Copy the code
What coding standard to use in the available putty options? (On windows10)
putty option.png (18.57 KB, Down times: 186)
vip
Rank: 6Rank: 6
Posted at 1/11/2019 10:32:34        Only Author  5#
We're sorry to cause you so much trouble. The last time we checked it  worked in Window 7.
With the updated driver in the official cp2403 site, it fails in Window 10.
Please try this old version driver:
CP210x_VCP_Windows.zip (3.5 MB, Down times: 1)
1. Extract the attachment, and run the setup file inside to install the driver.
2. Change the com port's driver.
    a. go to the device manager.
    b. double click the comX port, select Driver tab and click "Update Driver" button.
    c. Select the second item: “Browse my computer for driver software”.
    d. Select the bottom list saying: "Let me pick from a list of available drivers on my computer".
    e. Select the driver WITHOUT version 10.x
    f. Check the "Driver Version" to be 6.6.1.0, and "Driver Date" to be "2012-12-10"
The baud rate of 1,500,000 won't be listed in the port setting of the com port either.
But you can manually specify "1500000" in the putty serial connect dialog.
Good luck.
Good luck.
Posted at 1/11/2019 15:18:22        Only Author  6#
Hello Penguin,
Thank you for this support, I will try to follow your solution step by step, I hope it will work.
Anyway thank you for your help because I am alone in this problem. when I have tried this afternoon I will report results here.
Posted at 1/11/2019 16:24:11        Only Author  7#
Hello Pinguin, thank you again for your help, your solution works perfectly, but it is even simply, I uninstalled the driver that did not work and installed the one you gave me and it is without any problem, everything works in putty.
I did 2 tests, the first test is to update the firmware, regardless of the firmware is always the same result, IDB Fail. Here is the report of Putty for this test, it is worrying because it tells me that it is not the right voltage, but I have the official power of Firefly bought at the same time as the card RK3399. Something does not work electrically?
  1. DDR Version 1.12 20180518
  2. In
  3. Channel 0: DDR3, 800MHz
  4. Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
  5. Channel 1: DDR3, 800MHz
  6. Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
  7. 256B stride
  8. ch 0 ddrconfig = 0x101, ddrsize = 0x20
  9. ch 1 ddrconfig = 0x101, ddrsize = 0x20
  10. pmugrf_os_reg[2] = 0x32817281, stride = 0x9
  11. OUT
  12. Boot1: 2018-04-08, version: 1.12
  13. CPUId = 0x0
  14. mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000
  15. mmc: ERROR: Card did not respond to voltage select!
  16. emmc reinit
  17. mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000
  18. mmc: ERROR: Card did not respond to voltage select!
  19. emmc reinit
  20. mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000
  21. mmc: ERROR: Card did not respond to voltage select!
  22. SdmmcInit=2 1
  23. UsbHook 469715
  24. powerOn 469798
Copy the code
The 2nd test is a startup test with the SD card, it was long more than 5 minutes, I shortened the report to the "connection has disconnected" section of the line [4.235355] to [240.197125] because is the same thing "connection has disconnected". Of course once the loading of the card is completed, it does not work, nothing is displayed on any of my 4 hdmi screens that I tried, in my opinion there is a very big problem. Here is the Putty report of the startup test with the SD card.
  1. [    1.555834] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
  2. [    1.556381] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
  3. [    1.557394] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
  4. [    1.568948] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  5. [    1.580915] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
  6. [    1.597854] asoc-simple-card rt5640-sound: rt5640-aif1 <-> ff890000.i2s mapping ok
  7. [    1.605701] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card0/input0
  8. [    1.609771] asoc-simple-card hdmi-codec: i2s-hifi <-> ff8a0000.i2s mapping ok
  9. [    1.613932] rockchip-spdif ff870000.spdif: Missing dma channel for stream: 0
  10. [    1.614598] rockchip-spdif ff870000.spdif: ASoC: pcm constructor failed: -22
  11. [    1.615232] asoc-simple-card spdif-sound: ASoC: can't create pcm ff870000.spdif-dit-hifi :-22
  12. [    1.616011] asoc-simple-card spdif-sound: ASoC: failed to instantiate card -22
  13. [    1.617057] asoc-simple-card: probe of spdif-sound failed with error -22
  14. [    1.618278]
  15. [    1.618366] dhd_module_init: in
  16. [    1.618375] ======== bcm_wlan_set_plat_data ========
  17. [    1.618381] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
  18. [    1.618390] host_oob_irq: 68
  19. [    1.618394] host_oob_irq_flags=0x4
  20. [    1.618398] dhd_wifi_platform_load: Enter
  21. [    1.618427] Power-up adapter 'DHD generic adapter'
  22. [    1.618504] wifi_platform_set_power = 1
  23. [    1.618543] ======== PULL WL_REG_ON HIGH! ========
  24. [    1.618550] [WLAN_RFKILL]: rockchip_wifi_power: 1
  25. [    1.618555] [WLAN_RFKILL]: wifi turn on power. -1
  26. [    1.622640] =======================================================
  27. [    1.623194] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
  28. [    1.623761] =======================================================
  29. [    1.624316] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 2.20.WFD) init.
  30. [    1.625003] [WLAN_RFKILL]: rockchip_wifi_power: 1
  31. [    1.625422] [WLAN_RFKILL]: wifi turn on power. -1
  32. [    1.625853] RTL871X: module init start
  33. [    1.626190] RTL871X: rtl8188eu v4.3.24_16705.20160509
  34. [    1.626864] usbcore: registered new interface driver rtl8188eu
  35. [    1.627381] RTL871X: module init ret=0
  36. [    1.628981] input: gpio-keys as /devices/platform/gpio-keys/input/input1
  37. [    1.631919] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:54:42 UTC (1358499282)
  38. [    1.642375] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
  39. [    1.644954] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
  40. [    1.647469] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
  41. [    1.651725] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  42. [    1.653769] fusb302 4-0022: connection has disconnected
  43. [    1.715372] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
  44. [    1.793155] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 313
  45. [    1.806826] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
  46. [    1.807384] mmc2: new ultra high speed SDR104 SDIO card at address 0001
  47. [    1.819681] wifi_platform_bus_enumerate device present 1
  48. [    1.820157] ======== Card detection to detect SDIO card! ========
  49. [    1.820721] mmc2:mmc host rescan start!
  50. [    1.837170] bcmsdh_register: register client driver
  51. [    1.837967] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
  52. [    1.838758] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
  53. [    1.839193] bus num (host idx)=2, slot num (rca)=1
  54. [    1.839647] found adapter info 'DHD generic adapter'
  55. [    1.840366] sdioh_attach: set sd_f2_blocksize 128
  56. [    1.841783] F1 signature read @0x18000000=0x17224356
  57. [    1.845717] vendor storage:20160801 ret = -1
  58. [    1.846833] fusb302 4-0022: connection has disconnected
  59. [    1.851488] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x2 pkg:0x2
  60. [    1.853495] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
  61. [    1.854333] wifi_platform_get_mac_addr
  62. [    1.854694] ======== bcm_wlan_get_mac_address ========
  63. [    1.855152] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
  64. [    1.855646] [WLAN_RFKILL]: get_wifi_addr_vendor: rk_vendor_read wifi mac address failed (-1)
  65. [    1.856396] dhd_conf_set_chiprev: chip=0x4354, chiprev=2
  66. [    1.857018] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
  67. [    1.858726] wl_create_event_handler(): thread:wl_event_handler:a8 started
  68. [    1.858741] tsk Enter, tsk = 0xffffffc077d61be8
  69. [    1.859992] wl_escan_attach: Enter
  70. [    1.860330] wl_escan_init: Enter
  71. [    1.860858] wl_create_event_handler(): thread:wl_escan_handler:a9 started
  72. [    1.861011] tsk Enter, tsk = 0xffffffc077e301b0
  73. [    1.862028] dhd_attach(): thread:dhd_watchdog_thread:aa started
  74. [    1.862914] dhd_attach(): thread:dhd_dpc:ab started
  75. [    1.863038] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
  76. [    1.864138] dhd_attach(): thread:dhd_rxf:ac started
  77. [    1.864613] dhd_deferred_work_init: work queue initialized
  78. [    1.896498] Dongle Host Driver, version 1.363.59.144.1 (r)
  79. [    1.898007] Register interface [wlan0]  MAC: cc:4b:73:1d:1a:78
  80. [    1.898007]
  81. [    1.898717] wl_event_handler: was terminated
  82. [    1.899131] wl_destroy_event_handler(): thread:wl_event_handler:a8 terminated OK
  83. [    1.899811] dhd_wl_ioctl: returning as busstate=0
  84. [    1.900306] bcmsdh_oob_intr_unregister: Enter
  85. [    1.900717] bcmsdh_oob_intr_unregister: irq is not registered
  86. [    1.901235] dhd_txglom_enable: enable 0
  87. [    1.901594] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0
  88. [    1.902125] dhd_conf_set_txglom_params: txglom_bucket_size=0
  89. [    1.902642] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=0
  90. [    1.903330] dhd_conf_set_txglom_params: tx_in_rx=1, tx_max_offset=0
  91. [    1.903896] dhd_bus_devreset:  WLAN OFF DONE
  92. [    1.904382] wifi_platform_set_power = 0
  93. [    1.904747] ======== PULL WL_REG_ON LOW! ========
  94. [    1.905167] [WLAN_RFKILL]: rockchip_wifi_power: 0
  95. [    1.905611] [WLAN_RFKILL]: wifi shut off power.
  96. [    1.906088] dhd_module_init: Exit err=0
  97. [    2.027305] fusb302 4-0022: connection has disconnected
  98. [    2.211596] fusb302 4-0022: connection has disconnected
  99. [    2.395302] fusb302 4-0022: connection has disconnected
  100. [    2.578679] fusb302 4-0022: connection has disconnected
  101. [    2.762923] fusb302 4-0022: connection has disconnected
  102. [    2.948048] fusb302 4-0022: connection has disconnected
  103. [    3.136435] fusb302 4-0022: connection has disconnected
  104. [    3.321499] fusb302 4-0022: connection has disconnected
  105. [    3.503302] fusb302 4-0022: connection has disconnected
  106. [    3.614011] phy phy-ff770000.syscon:usb2-phy@e450.6: charger = USB_SDP_CHARGER
  107. [    3.683379] fusb302 4-0022: connection has disconnected
  108. [    3.867505] fusb302 4-0022: connection has disconnected
  109. [    3.982624] random: nonblocking pool is initialized
  110. [    4.050727] fusb302 4-0022: connection has disconnected
  111. [    4.235355] fusb302 4-0022: connection has disconnected
  112. // Personal note to shorten the text : since [4.235355] ======= at ==========> [240.197125] = connection has disconnected
  113. [  240.197125] fusb302 4-0022: connection has disconnected
  114. [  240.267775] INFO: task swapper/0:1 blocked for more than 120 seconds.
  115. [  240.268354]       Not tainted 4.4.52 #22
  116. [  240.268734] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
  117. [  240.269424] swapper/0       D ffffff8008084e84     0     1      0 0x00000000
  118. [  240.270082] Call trace:
  119. [  240.270327] [<ffffff8008084e84>] __switch_to+0xb4/0xc0
  120. [  240.270810] [<ffffff8008b9c2f8>] __schedule+0x3e4/0x62c
  121. [  240.271277] [<ffffff8008b9c5c4>] schedule+0x84/0x98
  122. [  240.271734] [<ffffff8008b9ed88>] schedule_timeout+0x34/0x21c
  123. [  240.272239] [<ffffff8008b9d024>] wait_for_common+0x12c/0x16c
  124. [  240.272761] [<ffffff8008b9d08c>] wait_for_completion+0x28/0x34
  125. [  240.273283] [<ffffff8008481004>] drm_dev_wait+0x1c/0x24
  126. [  240.273773] [<ffffff8008fcdc8c>] drm_misc_init+0x10/0x84
  127. [  240.274247] [<ffffff8008082b48>] do_one_initcall+0xfc/0x180
  128. [  240.274765] [<ffffff8008fa0d74>] kernel_init_freeable+0x1a8/0x248
  129. [  240.275306] [<ffffff8008b9b130>] kernel_init+0x18/0x100
  130. [  240.275790] [<ffffff8008082690>] ret_from_fork+0x10/0x40
  131. [  240.276263] Kernel panic - not syncing: hung_task: blocked tasks
  132. [  240.276800] CPU: 5 PID: 39 Comm: khungtaskd Not tainted 4.4.52 #22
  133. [  240.277346] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
  134. [  240.277995] Call trace:
  135. [  240.278225] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  136. [  240.278709] [<ffffff8008088368>] show_stack+0x20/0x28
  137. [  240.279164] [<ffffff8008386cf8>] dump_stack+0x8c/0xac
  138. [  240.279617] [<ffffff800815de88>] panic+0xf4/0x23c
  139. [  240.280042] [<ffffff8008127d60>] watchdog+0x2e0/0x30c
  140. [  240.280494] [<ffffff80080b9284>] kthread+0xe4/0xec
  141. [  240.280922] [<ffffff8008082690>] ret_from_fork+0x10/0x40
  142. [  240.281407] CPU0: stopping
  143. [  240.281672] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.52 #22
  144. [  240.282207] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
  145. [  240.282859] Call trace:
  146. [  240.283105] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  147. [  240.283595] [<ffffff8008088368>] show_stack+0x20/0x28
  148. [  240.284056] [<ffffff8008386cf8>] dump_stack+0x8c/0xac
  149. [  240.284516] [<ffffff800808d944>] handle_IPI+0x134/0x240
  150. [  240.284987] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
  151. [  240.285487] Exception stack(0xffffffc07ff03000 to 0xffffffc07ff03130)
  152. [  240.286065] 3000: ffffff80090c3d80 0000008000000000 ffffff80090c3eb0 ffffff80088742c4
  153. [  240.286763] 3020: 0000000060000045 ffffff80091ae1a0 ffffffc07feff060 0000000000000000
  154. [  240.287459] 3040: ffffff80090c3eb0 ffffff80090c3d80 0000000000000000 0000000000000000
  155. [  240.288156] 3060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  156. [  240.288852] 3080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  157. [  240.289548] 30a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  158. [  240.290244] 30c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  159. [  240.290940] 30e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  160. [  240.291636] 3100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  161. [  240.292329] 3120: 0000000000000000 0000000000000000
  162. [  240.292770] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
  163. [  240.293218] [<ffffff80088742c4>] cpuidle_enter_state+0x1fc/0x2a8
  164. [  240.293759] [<ffffff80088743e4>] cpuidle_enter+0x34/0x40
  165. [  240.294244] [<ffffff80080dd108>] cpu_startup_entry+0x26c/0x300
  166. [  240.294769] [<ffffff8008b9b110>] rest_init+0x78/0x80
  167. [  240.295221] [<ffffff8008fa0bb8>] start_kernel+0x3d4/0x3e8
  168. [  240.295709] [<ffffff8008fa01c4>] __primary_switched+0x30/0x6c
  169. [  240.296224] CPU1: stopping
  170. [  240.296483] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.4.52 #22
  171. [  240.297016] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
  172. [  240.297668] Call trace:
  173. [  240.297903] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  174. [  240.298392] [<ffffff8008088368>] show_stack+0x20/0x28
  175. [  240.298849] [<ffffff8008386cf8>] dump_stack+0x8c/0xac
  176. [  240.299306] [<ffffff800808d944>] handle_IPI+0x134/0x240
  177. [  240.299776] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
  178. [  240.300274] Exception stack(0xffffffc07ff18000 to 0xffffffc07ff18130)
  179. [  240.300852] 8000: ffffffc07964bdc0 0000008000000000 ffffffc07964bef0 ffffff80088742c4
  180. [  240.301550] 8020: 0000000060000045 ffffff80091ae1a0 ffffffc07ff14060 0000000000000000
  181. [  240.302247] 8040: ffffffc07964bef0 ffffffc07964bdc0 0000000000000000 0000000000000000
  182. [  240.302944] 8060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  183. [  240.303641] 8080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  184. [  240.304336] 80a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  185. [  240.305033] 80c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  186. [  240.305729] 80e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  187. [  240.306425] 8100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  188. [  240.307118] 8120: 0000000000000000 0000000000000000
  189. [  240.307559] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
  190. [  240.308004] [<ffffff80088742c4>] cpuidle_enter_state+0x1fc/0x2a8
  191. [  240.308545] [<ffffff80088743e4>] cpuidle_enter+0x34/0x40
  192. [  240.309028] [<ffffff80080dd108>] cpu_startup_entry+0x26c/0x300
  193. [  240.309553] [<ffffff800808d46c>] secondary_start_kernel+0x184/0x190
  194. [  240.310111] [<0000000000282978>] 0x282978
  195. [  240.310475] CPU2: stopping
  196. [  240.310734] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.4.52 #22
  197. [  240.311268] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
  198. [  240.311919] Call trace:
  199. [  240.312155] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  200. [  240.312645] [<ffffff8008088368>] show_stack+0x20/0x28
  201. [  240.313102] [<ffffff8008386cf8>] dump_stack+0x8c/0xac
  202. [  240.313559] [<ffffff800808d944>] handle_IPI+0x134/0x240
  203. [  240.314030] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
  204. [  240.314528] Exception stack(0xffffffc07ff2d000 to 0xffffffc07ff2d130)
  205. [  240.315107] d000: ffffffc07964fdc0 0000008000000000 ffffffc07964fef0 ffffff80088742c4
  206. [  240.315804] d020: 0000000060000045 ffffff80091ae1a0 ffffffc07ff29060 0000000000000000
  207. [  240.316501] d040: ffffffc07964fef0 ffffffc07964fdc0 0000000000000000 0000000000000000
  208. [  240.317197] d060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  209. [  240.317893] d080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  210. [  240.318589] d0a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  211. [  240.319285] d0c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  212. [  240.319981] d0e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  213. [  240.320677] d100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  214. [  240.321370] d120: 0000000000000000 0000000000000000
  215. [  240.321810] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
  216. [  240.322256] [<ffffff80088742c4>] cpuidle_enter_state+0x1fc/0x2a8
  217. [  240.322797] [<ffffff80088743e4>] cpuidle_enter+0x34/0x40
  218. [  240.323279] [<ffffff80080dd108>] cpu_startup_entry+0x26c/0x300
  219. [  240.323804] [<ffffff800808d46c>] secondary_start_kernel+0x184/0x190
  220. [  240.324361] [<0000000000282978>] 0x282978
  221. [  240.324726] CPU4: stopping
  222. [  240.324987] CPU: 4 PID: 0 Comm: swapper/4 Not tainted 4.4.52 #22
  223. [  240.325520] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
  224. [  240.326171] Call trace:
  225. [  240.326405] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  226. [  240.326890] [<ffffff8008088368>] show_stack+0x20/0x28
  227. [  240.327344] [<ffffff8008386cf8>] dump_stack+0x8c/0xac
  228. [  240.327797] [<ffffff800808d944>] handle_IPI+0x134/0x240
  229. [  240.328263] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
  230. [  240.328758] Exception stack(0xffffffc07ff57000 to 0xffffffc07ff57130)
  231. [  240.329331] 7000: ffffffc07965bdc0 0000008000000000 ffffffc07965bef0 ffffff80088742c4
  232. [  240.330023] 7020: 0000000060000045 ffffff80091ae1a0 ffffffc07ff53060 0000000000000000
  233. [  240.330715] 7040: ffffffc07965bef0 ffffffc07965bdc0 0000000000000000 0000000000000000
  234. [  240.331406] 7060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  235. [  240.332096] 7080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  236. [  240.332785] 70a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  237. [  240.333476] 70c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  238. [  240.334166] 70e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  239. [  240.334856] 7100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  240. [  240.335545] 7120: 0000000000000000 0000000000000000
  241. [  240.335981] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
  242. [  240.336424] [<ffffff80088742c4>] cpuidle_enter_state+0x1fc/0x2a8
  243. [  240.336960] [<ffffff80088743e4>] cpuidle_enter+0x34/0x40
  244. [  240.337438] [<ffffff80080dd108>] cpu_startup_entry+0x26c/0x300
  245. [  240.337958] [<ffffff800808d46c>] secondary_start_kernel+0x184/0x190
  246. [  240.338513] [<0000000000282978>] 0x282978
  247. [  240.338876] CPU3: stopping
  248. [  240.339138] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.4.52 #22
  249. [  240.339672] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
  250. [  240.340323] Call trace:
  251. [  240.340558] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  252. [  240.341047] [<ffffff8008088368>] show_stack+0x20/0x28
  253. [  240.341504] [<ffffff8008386cf8>] dump_stack+0x8c/0xac
  254. [  240.341961] [<ffffff800808d944>] handle_IPI+0x134/0x240
  255. [  240.342432] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
  256. [  240.342930] Exception stack(0xffffffc07ff42000 to 0xffffffc07ff42130)
  257. [  240.343509] 2000: ffffffc079657dc0 0000008000000000 ffffffc079657ef0 ffffff80088742c4
  258. [  240.344206] 2020: 0000000060000045 ffffff80091ae1a0 ffffffc07ff3e060 0000000000000000
  259. [  240.344903] 2040: ffffffc079657ef0 ffffffc079657dc0 0000000000000000 0000000000000000
  260. [  240.345599] 2060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  261. [  240.346296] 2080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  262. [  240.346992] 20a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  263. [  240.347689] 20c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  264. [  240.348385] 20e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  265. [  240.349080] 2100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  266. [  240.349773] 2120: 0000000000000000 0000000000000000
  267. [  240.350213] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
  268. [  240.350658] [<ffffff80088742c4>] cpuidle_enter_state+0x1fc/0x2a8
  269. [  240.351200] [<ffffff80088743e4>] cpuidle_enter+0x34/0x40
  270. [  240.351682] [<ffffff80080dd108>] cpu_startup_entry+0x26c/0x300
  271. [  240.352207] [<ffffff800808d46c>] secondary_start_kernel+0x184/0x190
  272. [  240.352765] [<0000000000282978>] 0x282978
  273. [  240.353129] CRU:
  274. [  240.353316] 00000000: 00000044 00002201 80000000 00000108 00000007 00007f00 00000000 00000000
  275. [  240.354077] 00000020: 00000044 00002201 80000000 00000108 00000007 00007f00 00000000 00000000
  276. [  240.354836] 00000040: 00000037 00001201 8000031f 00000108 00000007 00007f00 00000000 00000000
  277. [  240.355594] 00000060: 00000190 00001206 80000000 00000108 00000007 00007f00 00000000 00000000
  278. [  240.356351] 00000080: 00000032 00001101 80000000 00000108 00000007 00007f00 00000000 00000000
  279. [  240.357108] 000000a0: 00000190 00001206 80000000 00000108 00000007 00007f00 00000000 00000000
  280. [  240.357867] 000000c0: 000000c6 00001202 8000031f 00000008 00000007 00007f00 00000000 00000000
  281. [  240.358624] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  282. [  240.359382] 00000100: 00000100 00000202 00000140 00006202 00000047 00008743 00008520 00000142
  283. [  240.360140] 00000120: 00000143 00004343 00000142 00000142 00004242 00008545 00003187 0000010b
  284. [  240.360897] 00000140: 0000010b 00000300 00004a87 00000113 00009382 0000838b 00001105 0000108b
  285. [  240.361655] 00000160: 0000834b 0000018b 00001745 0000001f 00000380 00000380 00000380 00000000
  286. [  240.362413] 00000180: 00006380 00009200 00000200 00000200 00000200 00000200 00003f3f 00000043
  287. [  240.363171] 000001a0: 00000000 00000000 00004242 00000421 00008b00 000002dc 00000004 00000182
  288. [  240.363928] 000001c0: 00000182 00000001 00000003 0000008b 0000008b 00000142 00000142 00008181
  289. [  240.364686] 000001e0: 0000853f 0000000b 0000971f 00009797 00009797 00008b8b 00008b8b 00008b8b
  290. [  240.365443] 00000200: 000000d7 000000d7 00000000 00000000 00000000 00000000 00000000 00000000
  291. [  240.366199] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  292. [  240.366957] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  293. [  240.367713] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  294. [  240.368472] 00000280: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60
  295. [  240.369229] 000002a0: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 00000000 00000000 00000000 00000000
  296. [  240.369987] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  297. [  240.370743] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  298. [  240.371500] 00000300: 00000000 00000000 00000000 00000000 00000030 00000000 00000004 00000000
  299. [  240.372256] 00000320: 00008000 00000000 00000001 00000000 0000000a 00000031 00000000 00000000
  300. [  240.373014] 00000340: 00000505 00000505 00000000 00000000 00000c04 00000000 00004441 00000000
  301. [  240.373771] 00000360: 00000000 00000020 00000000 00000000 000000cc 00000000 00000102 00000038
  302. [  240.374528] 00000380: 00002000 00000000 00000008 00000000 00000000 00000000 00000000 00000000
  303. [  240.375284] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  304. [  240.376041] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  305. [  240.376798] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  306. [  240.377555] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  307. [  240.378311] 00000420: 00000000 00004070 00000000 00000014 00000000 00000000 00000000 00000000
  308. [  240.379068] 00000440: 00000000 00000000 00000000 00000000 00001000 00000000 00000000 00000000
  309. [  240.379824] 00000460: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  310. [  240.380581] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  311. [  240.381338] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  312. [  240.382095] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  313. [  240.382851] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  314. [  240.383608] 00000500: 00000000 00000000 00640064 00000000 00000003 00000000 00000000 00000000
  315. [  240.384364] 00000520: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  316. [  240.385121] 00000540: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  317. [  240.385878] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  318. [  240.386632] 00000580: 00000004 00000000 00000004 00000946 00000004
  319. [  240.387175] PMU CRU:
  320. [  240.387388] 00000000: 000000a9 00001203 80000000 00000108 00000007 00007f00 00000000 00000000
  321. [  240.388146] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  322. [  240.388904] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  323. [  240.389663] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  324. [  240.390422] 00000080: 0000070d 00001986 00000d0d 0000000d 000002dc 00000200 0bb8ea60 0bb8ea60
  325. [  240.391180] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  326. [  240.391938] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  327. [  240.392696] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  328. [  240.393456] 00000100: 00000600 00000180 00000000 00000000 00000024 00000000 00000000 00000000
  329. [  240.394210] 00000120: 00000000 00000180 00000000 00000000 00000000
  330. [  240.394756] Kernel Offset: disabled
  331. [  240.395068] Memory Limit: none
  332. [  240.395355] rockchip-thermal ff260000.tsadc: channal 0: temperature(22 C)
  333. [  240.395953] THERMAL REGS:
  334. [  240.396201] 00000000: 00000200 00030133 00000031 00000002 00000000 00000000 00000000 00000000
  335. [  240.396959] 00000020: 000001fe 000001fa 00000000 00000000 0000024e 00000000 00000000 00000000
  336. [  240.397717] 00000040: 00000279 00000279 00000000 00000000 00000000 00000000 00000000 00000000
  337. [  240.398475] 00000060: 00000004 00000004 00000753 00000753 00000000 00000000 00000000 00000000
  338. [  240.399225] 00000080: 00000000 00000000
  339. [  240.399575] ---[ end Kernel panic - not syncing: hung_task: blocked tasks
  340. [  252.137511] Watchdog detected hard LOCKUP on cpu 0
  341. [  252.137935] ------------[ cut here ]------------
  342. [  252.138364] WARNING: at kernel/watchdog.c:352
  343. [  252.138750] Modules linked in:
  344. [  252.139031]
  345. [  252.139176] CPU: 5 PID: 39 Comm: khungtaskd Not tainted 4.4.52 #22
  346. [  252.139721] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
  347. [  252.140373] task: ffffffc0797924c0 ti: ffffffc078e40000 task.ti: ffffffc078e40000
  348. [  252.141038] PC is at watchdog_timer_fn+0x104/0x2f0
  349. [  252.141468] LR is at watchdog_timer_fn+0x104/0x2f0
  350. [  252.141895] pc : [<ffffff80081284c0>] lr : [<ffffff80081284c0>] pstate: 600001c5
  351. [  252.142546] sp : ffffffc07ff6bde0
  352. [  252.142844] x29: ffffffc07ff6bde0 x28: ffffff80090cdf70
  353. [  252.143327] x27: 0000000000000000 x26: ffffff800908f1f8
  354. [  252.143810] x25: ffffffc07ff6e210 x24: ffffffc078e43b60
  355. [  252.144291] x23: 0000000000000000 x22: 0000000000000000
  356. [  252.144773] x21: ffffff80090cc000 x20: ffffff800908f270
  357. [  252.145255] x19: ffffff800908f000 x18: 0000000030d00800
  358. [  252.145736] x17: 0000000000000000 x16: 0000000000000000
  359. [  252.146217] x15: 0000000000000000 x14: 0ffffffffffffffd
  360. [  252.146698] x13: 0000000000000000 x12: 0101010101010101
  361. [  252.147179] x11: 7f7f7f7f7f7f7f7f x10: fefefefefefefeff
  362. [  252.147660] x9 : 7f7f7f7f7f7f7f7f x8 : 4c20647261682064
  363. [  252.148141] x7 : 6574636574656420 x6 : ffffff800921982d
  364. [  252.148621] x5 : 0000000000000002 x4 : 0000000000000005
  365. [  252.149102] x3 : 0000000000000000 x2 : 0000000000000001
  366. [  252.149583] x1 : 00000000000001c0 x0 : 0000000000000026
  367. [  252.150067]
  368. [  252.150067] PC: 0xffffff8008128440:
  369. [  252.150509] 8440  b9401c00 f90033a3 f90037a4 97fffeb4 2a0003fb 90007d20 b94f0000 6b00037f
  370. [  252.151286] 8460  54000382 d50339bf b0007d3c 91002281 913dc39c f94037a4 f87b5b82 38626825
  371. [  252.152058] 8480  34000085 f94033a3 38226823 14000011 91020280 f8626b41 f8626803 91022294
  372. [  252.152831] 84a0  eb01007f 54000e40 f8226801 f87b5b80 38206a85 14000007 2a1b03e1 9400d714
  373. [  252.153604] 84c0  d4210000 f87b5b80 52800021 38206a81 9107a274 913d62ba d538d081 91008280
  374. [  252.154376] 84e0  f8606820 97fe764c f9401b20 f9401f42 f90037a2 f9401000 d63f0000 aa0003e1
  375. [  252.155148] 8500  f94037a2 aa1903e0 97ff55b8 b50000f6 91022694 d538d080 38746801 34000361
  376. [  252.155920] 8520  38346816 14000019 97fe8afc 90007d21 f947ac21 36080921 b9403741 340008e1
  377. [  252.156694]
  378. [  252.156694] LR: 0xffffff8008128440:
  379. [  252.157135] 8440  b9401c00 f90033a3 f90037a4 97fffeb4 2a0003fb 90007d20 b94f0000 6b00037f
  380. [  252.157906] 8460  54000382 d50339bf b0007d3c 91002281 913dc39c f94037a4 f87b5b82 38626825
  381. [  252.158678] 8480  34000085 f94033a3 38226823 14000011 91020280 f8626b41 f8626803 91022294
  382. [  252.159451] 84a0  eb01007f 54000e40 f8226801 f87b5b80 38206a85 14000007 2a1b03e1 9400d714
  383. [  252.160224] 84c0  d4210000 f87b5b80 52800021 38206a81 9107a274 913d62ba d538d081 91008280
  384. [  252.160996] 84e0  f8606820 97fe764c f9401b20 f9401f42 f90037a2 f9401000 d63f0000 aa0003e1
  385. [  252.161767] 8500  f94037a2 aa1903e0 97ff55b8 b50000f6 91022694 d538d080 38746801 34000361
  386. [  252.162540] 8520  38346816 14000019 97fe8afc 90007d21 f947ac21 36080921 b9403741 340008e1
  387. [  252.163315]
  388. [  252.163315] SP: 0xffffffc07ff6bd60:
  389. [  252.163755] bd60  00000000 00000000 00000000 00000000 78e43b60 ffffffc0 7ff6e210 ffffffc0
  390. [  252.164527] bd80  0908f1f8 ffffff80 00000000 00000000 090cdf70 ffffff80 7ff6bde0 ffffffc0
  391. [  252.165300] bda0  081284c0 ffffff80 7ff6bde0 ffffffc0 081284c0 ffffff80 600001c5 00000000
  392. [  252.166072] bdc0  090ccf58 ffffff80 00000000 00000000 00000000 00000080 ffffffff 00ffffff
  393. [  252.166843] bde0  7ff6be50 ffffffc0 080fe76c ffffff80 7ff6e210 ffffffc0 7ff6dbc0 ffffffc0
  394. [  252.167615] be00  7ff6dc40 ffffffc0 00000001 00000000 0920a24f ffffff80 090cbed0 ffffff80
  395. [  252.168388] be20  081283bc ffffff80 af2c0a07 0000003a 0920a000 ffffff80 78e40000 ffffffc0
  396. [  252.169160] be40  00000000 00000000 090ccf58 ffffff80 7ff6bec0 ffffffc0 080fea88 ffffff80
  397. [  252.169939]
  398. [  252.169939] X6: 0xffffff80092197ad:
  399. [  252.170379] 97ac  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  400. [  252.171152] 97cc  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  401. [  252.171922] 97ec  00000000 00000001 00000000 30303020 32303330 32393130 39205d32 20636537
  402. [  252.172695] 980c  312e3235 33393936 58205d39 30203a36 66666678 38666666 32393030 61373931
  403. [  252.173469] 982c  300a3a64 32313830 30633438 70205d3e 74617473 36203a65 30303030 0a356331
  404. [  252.174242] 984c  2030300a 30303030 30303030 4830300a 6964205a 203d2076 730a2930 646e756f
  405. [  252.175013] 986c  275d305b 65730a0a 7665645f 71657266 696e695f 3b292874 63757320 73736563
  406. [  252.175785] 988c  696e6920 676e6974 776f7020 6d5f7265 6c65646f 6d69735f 2e656c70 7830200a
  407. [  252.176556] 98ac  66666666 64626666 66666662 30303030 28202020 32202020 47203634 5b0a2942
  408. [  252.177338]
  409. [  252.177338] X19: 0xffffff800908ef80:
  410. [  252.177785] ef80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  411. [  252.178557] efa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  412. [  252.179328] efc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  413. [  252.180101] efe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  414. [  252.180873] f000  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  415. [  252.181645] f020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  416. [  252.182418] f040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  417. [  252.183190] f060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  418. [  252.183962]
  419. [  252.183962] X20: 0xffffff800908f1f0:
  420. [  252.184410] f1f0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  421. [  252.185183] f210  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  422. [  252.185955] f230  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  423. [  252.186727] f250  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  424. [  252.187500] f270  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  425. [  252.188272] f290  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  426. [  252.189046] f2b0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  427. [  252.189817] f2d0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  428. [  252.190591]
  429. [  252.190591] X21: 0xffffff80090cbf80:
  430. [  252.191038] bf80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  431. [  252.191810] bfa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  432. [  252.192581] bfc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  433. [  252.193354] bfe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  434. [  252.194125] c000  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  435. [  252.194896] c020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  436. [  252.195669] c040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  437. [  252.196441] c060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  438. [  252.197217]
  439. [  252.197217] X24: 0xffffffc078e43ae0:
  440. [  252.197665] 3ae0  0000003d 00000000 00000000 00000000 00000000 00000000 0000003d 00000000
  441. [  252.198436] 3b00  0925c05a ffffff80 00000000 00000000 00033878 00000000 00000006 00000000
  442. [  252.199208] 3b20  78e43b40 ffffffc0 090e5680 ffffff80 08e27177 ffffff80 00000000 00000000
  443. [  252.199980] 3b40  78e43be0 ffffffc0 080e9868 ffffff80 08e22f2a ffffff80 09216850 ffffff80
  444. [  252.200753] 3b60  6c64d134 00000001 00003854 00000000 000003e8 00000000 00000000 00000000
  445. [  252.201526] 3b80  00000005 00000000 00000002 00000000 09219844 ffffff80 61745f67 203a6b73
  446. [  252.202298] 3ba0  636f6c62 2064656b 7f7f7f7f 7f7f7f7f fefefeff fefefefe 7f7f7f7f 7f7f7f7f
  447. [  252.203072] 3bc0  01010101 01010101 00000000 00000000 fffffffd 0fffffff 00000000 00000000
  448. [  252.203847]
  449. [  252.203847] X25: 0xffffffc07ff6e190:
  450. [  252.204294] e190  ffffffff 00000000 ffffffff ffffffff 00000001 00000000 7ff6e1a8 ffffffc0
  451. [  252.205067] e1b0  7ff6e1a8 ffffffc0 7ff6e1b8 ffffffc0 7ff6e1b8 ffffffc0 08126f0c ffffff80
  452. [  252.205840] e1d0  79517cf8 ffffffc0 79517c40 ffffffc0 00020002 00000000 00000000 00000000
  453. [  252.206612] e1f0  00000001 00000000 0000003f 00000000 0000003c 00000000 796ebd40 ffffffc0
  454. [  252.207385] e210  7ff6e210 ffffffc0 7ff6e080 ffffffc0 00000000 00000000 af2c01c0 0000003a
  455. [  252.208157] e230  af2c01c0 0000003a 081283bc ffffff80 7ff6dc40 ffffffc0 00000000 0000001f
  456. [  252.208928] e250  0812838c ffffff80 63746177 676f6468 0000352f 00000000 0000003b 00000000
  457. [  252.209700] e270  00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000
  458. [  252.210474]
  459. [  252.210474] X26: 0xffffff800908f178:
  460. [  252.210923] f178  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  461. [  252.211694] f198  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  462. [  252.212466] f1b8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  463. [  252.213238] f1d8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  464. [  252.214009] f1f8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  465. [  252.214780] f218  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  466. [  252.215551] f238  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  467. [  252.216323] f258  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  468. [  252.217097]
  469. [  252.217097] X28: 0xffffff80090cdef0:
  470. [  252.217544] def0  00000001 00000000 00000001 00000000 000003e8 00000000 7ff7d540 ffffffc0
  471. [  252.218317] df10  00000015 00000000 7ff7d500 ffffffc0 00000001 00000000 00000060 00000000
  472. [  252.219089] df30  00015000 00000000 7ff7d5c0 ffffffc0 7ff7d580 ffffffc0 00000001 00001000
  473. [  252.219861] df50  00000006 00000000 00000005 00000010 7ff7d400 ffffffc0 7feff000 ffffffc0
  474. [  252.220632] df70  76e76000 00000040 76e8b000 00000040 76ea0000 00000040 76eb5000 00000040
  475. [  252.221405] df90  76eca000 00000040 76edf000 00000040 00000000 00000000 00000000 00000000
  476. [  252.222175] dfb0  00000002 00000000 00001415 00000000 00010000 00000000 0007ffff 00000000
  477. [  252.222947] dfd0  0000effd 00000000 00002000 00000000 00000000 0000fffa 00000000 00000000
  478. [  252.223719]
  479. [  252.223719] X29: 0xffffffc07ff6bd60:
  480. [  252.224167] bd60  00000000 00000000 00000000 00000000 78e43b60 ffffffc0 7ff6e210 ffffffc0
  481. [  252.224938] bd80  0908f1f8 ffffff80 00000000 00000000 090cdf70 ffffff80 7ff6bde0 ffffffc0
  482. [  252.225709] bda0  081284c0 ffffff80 7ff6bde0 ffffffc0 081284c0 ffffff80 600001c5 00000000
  483. [  252.226481] bdc0  090ccf58 ffffff80 00000000 00000000 00000000 00000080 ffffffff 00ffffff
  484. [  252.227253] bde0  7ff6be50 ffffffc0 080fe76c ffffff80 7ff6e210 ffffffc0 7ff6dbc0 ffffffc0
  485. [  252.228027] be00  7ff6dc40 ffffffc0 00000001 00000000 0920a24f ffffff80 090cbed0 ffffff80
  486. [  252.228799] be20  081283bc ffffff80 af2c0a07 0000003a 0920a000 ffffff80 78e40000 ffffffc0
  487. [  252.229573] be40  00000000 00000000 090ccf58 ffffff80 7ff6bec0 ffffffc0 080fea88 ffffff80
  488. [  252.230344]
  489. [  252.230484] ---[ end trace b865bb1dd0ac9b52 ]---
  490. [  252.230893] Call trace:
  491. [  252.231118] Exception stack(0xffffffc07ff6bc10 to 0xffffffc07ff6bd40)
  492. [  252.231689] bc00:                                   ffffff800908f000 0000008000000000
  493. [  252.232381] bc20: ffffffc07ff6bde0 ffffff80081284c0 ffffff80090e5680 0000000000000004
  494. [  252.233072] bc40: ffffffc07ff6bc60 ffffff80090e5680 ffffff8008e27177 0000000000000004
  495. [  252.233763] bc60: ffffffc07ff6bd00 ffffff80080e9868 ffffff8008e2a2af ffffff800908f270
  496. [  252.234453] bc80: ffffff80090cc000 0000000000000000 0000000000000000 ffffffc078e43b60
  497. [  252.235144] bca0: ffffffc07ff6e210 ffffff800908f1f8 0000000000000026 00000000000001c0
  498. [  252.235835] bcc0: 0000000000000001 0000000000000000 0000000000000005 0000000000000002
  499. [  252.236525] bce0: ffffff800921982d 6574636574656420 4c20647261682064 7f7f7f7f7f7f7f7f
  500. [  252.237217] bd00: fefefefefefefeff 7f7f7f7f7f7f7f7f 0101010101010101 0000000000000000
  501. [  252.237908] bd20: 0ffffffffffffffd 0000000000000000 0000000000000000 0000000000000000
  502. [  252.238603] [<ffffff80081284c0>] watchdog_timer_fn+0x104/0x2f0
  503. [  252.239128] [<ffffff80080fe76c>] __hrtimer_run_queues+0x164/0x290
  504. [  252.239672] [<ffffff80080fea88>] hrtimer_interrupt+0xac/0x1c4
  505. [  252.240188] [<ffffff800889a9d0>] arch_timer_handler_phys+0x3c/0x48
  506. [  252.240739] [<ffffff80080eea08>] handle_percpu_devid_irq+0xc4/0x178
  507. [  252.241301] [<ffffff80080ea394>] generic_handle_irq+0x30/0x44
  508. [  252.241815] [<ffffff80080ea6fc>] __handle_domain_irq+0x90/0xc0
  509. [  252.242333] [<ffffff8008080dfc>] gic_handle_irq+0xcc/0x188
  510. [  252.242819] Exception stack(0xffffffc07ff6c000 to 0xffffffc07ff6c130)
  511. [  252.243390] c000: ffffffc078e43b60 0000008000000000 ffffffc078e43c90 ffffff80083856a4
  512. [  252.244082] c020: 0000000080000045 ffffff80090cc000 ffffffc07ff68060 0000000000000000
  513. [  252.244773] c040: ffffffc078e43c90 ffffffc078e43b60 0000000000000000 0000000000000000
  514. [  252.245463] c060: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  515. [  252.246154] c080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  516. [  252.246844] c0a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  517. [  252.247535] c0c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  518. [  252.248225] c0e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  519. [  252.248916] c100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  520. [  252.249605] c120: 0000000000000000 0000000000000000
  521. [  252.250040] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
  522. [  252.250478] [<ffffff80083856a4>] __delay+0x24/0x48
  523. [  252.250907] [<ffffff80083856ec>] __const_udelay+0x24/0x2c
  524. [  252.251388] [<ffffff800815dfc4>] panic+0x230/0x23c
  525. [  252.251818] [<ffffff8008127d60>] watchdog+0x2e0/0x30c
  526. [  252.252269] [<ffffff80080b9284>] kthread+0xe4/0xec
  527. [  252.252697] [<ffffff8008082690>] ret_from_fork+0x10/0x40
Copy the code
Thank you for explaining to me the problem if you understand something with all its putty codes .
vip
Rank: 6Rank: 6
Posted at 1/14/2019 10:12:01        Only Author  8#
From these lines from U-Boot
  1. mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000
  2. mmc: ERROR: Card did not respond to voltage select!
  3. emmc reinit
  6. emmc reinit
Copy the code
Since the emmc did not respond to voltage select, it is very likely that
the eMMC storage has broken. However, we would like to have a
COMPLETE kernel log (kernel log from the start) with sdcard booting.
Posted at 1/14/2019 16:32:01        Only Author  9#
Hello Penguin,
Thank you for your answer. Here is the full report I got with putty. I set the usb to UART exactly as you explained it to me then I put the SD card in the RK3399. I connected the rk3399 electrically in very last. What putty displays is the full report. Have I done everything right or need to do something else? I made a short video of my hookup and putty display over the last 1.15 minutes as the full load procedure took at least 5 minutes. Thank you for telling me what to do. If my card is broken, how to guarantee. I will not return the card in China from France by DHL which costs $ 30 can pay $ 30 again to receive my repaired card (or new) it's $ 60 If I have to do that, the Firefly Rk3399 will have cost me over $ 300 since I bought it in December. I hope there will be another solution. Thank you.
  1. [    1.147040] usbcore: registered new interface driver usb-storage
  2. [    1.147654] usbcore: registered new interface driver usbserial
  3. [    1.148192] usbcore: registered new interface driver usbserial_generic
  4. [    1.148796] usbserial: USB Serial support registered for generic
  5. [    1.149358] usbcore: registered new interface driver cp210x
  6. [    1.149877] usbserial: USB Serial support registered for cp210x
  7. [    1.150453] usbcore: registered new interface driver ftdi_sio
  8. [    1.150985] usbserial: USB Serial support registered for FTDI USB Serial Device
  9. [    1.151778] usbcore: registered new interface driver keyspan
  10. [    1.152293] usbserial: USB Serial support registered for Keyspan - (without firmware)
  11. [    1.153008] usbserial: USB Serial support registered for Keyspan 1 port adapter
  12. [    1.153677] usbserial: USB Serial support registered for Keyspan 2 port adapter
  13. [    1.154333] usbserial: USB Serial support registered for Keyspan 4 port adapter
  14. [    1.155026] usbcore: registered new interface driver option
  15. [    1.155545] usbserial: USB Serial support registered for GSM modem (1-port)
  16. [    1.156346] usbcore: registered new interface driver oti6858
  17. [    1.156871] usbserial: USB Serial support registered for oti6858
  18. [    1.157434] usbcore: registered new interface driver pl2303
  19. [    1.157955] usbserial: USB Serial support registered for pl2303
  20. [    1.158530] usbcore: registered new interface driver qcserial
  21. [    1.159052] usbserial: USB Serial support registered for Qualcomm USB modem
  22. [    1.159727] usbcore: registered new interface driver sierra
  23. [    1.160233] usbserial: USB Serial support registered for Sierra USB modem
  24. [    1.161699] usbcore: registered new interface driver iforce
  25. [    1.162247] usbcore: registered new interface driver xpad
  26. [    1.163015] usbcore: registered new interface driver usbtouchscreen
  27. [    1.163904] i2c /dev entries driver
  28. [    1.165363] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
  29. [    1.168007] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
  30. [    1.170897] rk808 0-001b: Pmic Chip id: 0x0
  31. [    1.174197] rk808-regulator rk808-regulator: there is no dvs0 gpio
  32. [    1.174798] rk808-regulator rk808-regulator: there is no dvs1 gpio
  33. [    1.187174] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
  34. [    1.188184] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009596000
  35. [    1.189435] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009598000
  36. [    1.190519] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff800959a000
  37. [    1.201154] fusb302 4-0022: port 0 probe success
  38. [    1.201603] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff800959c000
  39. [    1.203250] IR NEC protocol handler initialized
  40. [    1.203666] IR RC5(x/sz) protocol handler initialized
  41. [    1.204114] IR RC6 protocol handler initialized
  42. [    1.204526] IR JVC protocol handler initialized
  43. [    1.204928] IR Sony protocol handler initialized
  44. [    1.205336] IR SANYO protocol handler initialized
  45. [    1.205760] IR Sharp protocol handler initialized
  46. [    1.206177] IR MCE Keyboard/mouse protocol handler initialized
  47. [    1.206702] IR XMP protocol handler initialized
  48. [    1.207187] usbcore: registered new interface driver uvcvideo
  49. [    1.207699] USB Video Class driver (1.1.1)
  50. [    1.208612] vcc_3v0: supplied by vcc3v3_sys
  51. [    1.209204] vcc1v8_dvp: supplied by vcc3v3_sys
  52. [    1.209716] vcca1v8_codec: supplied by vcc3v3_sys
  53. [    1.210231] vcc_sd: supplied by vcc3v3_sys
  54. [    1.211136] rockchip_cpu_avs: cluster0 leakage=19 adjust_volt=0
  55. [    1.211694] rockchip_cpu_avs: cluster1 leakage=33 adjust_volt=0
  56. [    1.213471] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
  57. [    1.215016] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
  58. [    1.215904] Bluetooth: Virtual HCI driver ver 1.5
  59. [    1.216425] Bluetooth: HCI UART driver ver 2.3
  60. [    1.216830] Bluetooth: HCI UART protocol H4 registered
  61. [    1.217281] Bluetooth: HCI UART protocol LL registered
  62. [    1.217738] Bluetooth: HCI UART protocol ATH3K registered
  63. [    1.218282] usbcore: registered new interface driver bfusb
  64. [    1.218830] usbcore: registered new interface driver btusb
  65. [    1.219752] vdd_cpu_l: supplied by vcc3v3_sys
  66. [    1.221668] vdd_cpu_b: supplied by vcc5v0_sys
  67. [    1.224458] sdhci: Secure Digital Host Controller Interface driver
  68. [    1.225014] sdhci: Copyright(c) Pierre Ossman
  69. [    1.225402] Synopsys Designware Multimedia Card Interface Driver
  70. [    1.226748] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
  71. [    1.227408] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
  72. [    1.228019] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
  73. [    1.228574] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
  74. [    1.229434] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
  75. [    1.230214] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
  76. [    1.230762] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
  77. [    1.232091] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
  78. [    1.232769] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
  79. [    1.233369] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
  80. [    1.233922] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
  81. [    1.234789] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
  82. [    1.235606] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
  83. [    1.236398] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
  84. [    1.237199] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
  85. [    1.248640] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  86. [    1.260605] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
  87. [    1.261417] sdhci-pltfm: SDHCI platform and OF driver helper
  88. [    1.263754] sdhci-arasan fe330000.sdhci: No vmmc regulator found
  89. [    1.264286] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
  90. [    1.276054] fusb302 4-0022: connection has disconnected
  91. [    1.290516] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
  92. [    1.293084] hidraw: raw HID events driver (C) Jiri Kosina
  93. [    1.294387] usbcore: registered new interface driver usbhid
  94. [    1.294901] usbhid: USB HID core driver
  95. [    1.295539] ashmem: initialized
  96. [    1.295645] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
  97. [    1.295719] mmc0: new high speed SDHC card at address 0001
  98. [    1.296165] mmcblk0: mmc0:0001 ASTC 7.44 GiB
  99. [    1.299460] usbcore: registered new interface driver snd-usb-audio
  100. [    1.309776]  mmcblk0: p1
  101. [    1.319099] u32 classifier
  102. [    1.319358] Netfilter messages via NETLINK v0.30.
  103. [    1.320151] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
  104. [    1.321102] ctnetlink v0.93: registering with nfnetlink.
  105. [    1.321794] ip_set: protocol 6
  106. [    1.322079] IPVS: Registered protocols ()
  107. [    1.322643] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
  108. [    1.323396] IPVS: Creating netns size=1592 id=0
  109. [    1.323846] IPVS: ipvs loaded.
  110. [    1.324587] ip_tables: (C) 2000-2006 Netfilter Core Team
  111. [    1.325217] Initializing XFRM netlink socket
  112. [    1.326425] NET: Registered protocol family 10
  113. [    1.328290] ip6_tables: (C) 2000-2006 Netfilter Core Team
  114. [    1.328991] sit: IPv6 over IPv4 tunneling driver
  115. [    1.330044] NET: Registered protocol family 17
  116. [    1.330461] NET: Registered protocol family 15
  117. [    1.330911] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
  118. [    1.332052] Bridge firewalling registered
  119. [    1.332893] Bluetooth: RFCOMM socket layer initialized
  120. [    1.333371] Bluetooth: RFCOMM ver 1.11
  121. [    1.333741] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
  122. [    1.334270] Bluetooth: HIDP socket layer initialized
  123. [    1.334781] 8021q: 802.1Q VLAN Support v1.8
  124. [    1.335179] lib80211: common routines for IEEE802.11 drivers
  125. [    1.335768] [WLAN_RFKILL]: Enter rfkill_wlan_init
  126. [    1.336524] [WLAN_RFKILL]: Enter rfkill_wlan_probe
  127. [    1.337008] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6354
  128. [    1.337621] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
  129. [    1.338244] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
  130. [    1.338949] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
  131. [    1.339746] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
  132. [    1.340205] [WLAN_RFKILL]: Exit rfkill_wlan_probe
  133. [    1.340677] [BT_RFKILL]: Enter rfkill_rk_init
  134. [    1.341394] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
  135. [    1.342145] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
  136. [    1.342864] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
  137. [    1.343585] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
  138. [    1.345235] [BT_RFKILL]: Request irq for bt wakeup host
  139. [    1.345769] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
  140. [    1.345784] [BT_RFKILL]: ** disable irq
  141. [    1.346674] [BT_RFKILL]: bt_default device registered.
  142. [    1.347211] Key type dns_resolver registered
  143. [    1.348517] Registered cp15_barrier emulation handler
  144. [    1.349108] Registered setend emulation handler
  145. [    1.350701] Loading compiled-in X.509 certificates
  146. [    1.352157] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
  147. [    1.355023] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008c302d8)
  148. [    1.355899] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008c302d8)
  149. [    1.356801] dwhdmi-rockchip ff940000.hdmi: Detected HDMI controller 0x21:0x1a:0xa0:0xc1
  150. [    1.358186] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008c2c6c8)
  151. [    1.358926] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
  152. [    1.359638] [drm:drm_vblank_init] No driver support for vblank timestamp query.
  153. [    1.360361] rockchip-drm display-subsystem: failed to parse loader memory
  154. [    1.360982] rockchip-drm display-subsystem: No connectors reported connected with modes
  155. [    1.361723] [drm:drm_fb_helper_single_fb_probe] Cannot find any crtc or sizes - going 1024x768
  156. [    1.374289] Console: switching to colour frame buffer device 128x48
  157. [    1.374314] usb 1-1: new high-speed USB device number 2 using ehci-platform
  158. [    1.382092] rockchip-drm display-subsystem: fb0:  frame buffer device
  159. [    1.388376] vdd_gpu: supplied by vcc5v0_sys
  160. [    1.389948] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
  161. [    1.391108] I : [File] : drivers/gpu/arm/midgard_for_linux/backend/gpu/mali_kbase_devfreq.c; [Line] : 265; [Func] : kbase_devfreq_init(); success initing power_model_simple.
  162. [    1.392952] mali ff9a0000.gpu: Probed as mali0
  163. [    1.396797] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
  164. [    1.397497] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 5
  165. [    1.398291] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00030010
  166. [    1.399096] xhci-hcd xhci-hcd.6.auto: irq 227, io mem 0xfe800000
  167. [    1.399733] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
  168. [    1.400328] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  169. [    1.400968] usb usb5: Product: xHCI Host Controller
  170. [    1.401396] usb usb5: Manufacturer: Linux 4.4.52 xhci-hcd
  171. [    1.401879] usb usb5: SerialNumber: xhci-hcd.6.auto
  172. [    1.402705] hub 5-0:1.0: USB hub found
  173. [    1.403059] hub 5-0:1.0: 1 port detected
  174. [    1.403629] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
  175. [    1.404229] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 6
  176. [    1.404951] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
  177. [    1.405736] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
  178. [    1.406330] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  179. [    1.406968] usb usb6: Product: xHCI Host Controller
  180. [    1.407396] usb usb6: Manufacturer: Linux 4.4.52 xhci-hcd
  181. [    1.407873] usb usb6: SerialNumber: xhci-hcd.6.auto
  182. [    1.408648] hub 6-0:1.0: USB hub found
  183. [    1.408998] hub 6-0:1.0: 1 port detected
  184. [    1.410290] xhci-hcd xhci-hcd.6.auto: remove, state 1
  185. [    1.410762] usb usb6: USB disconnect, device number 1
  186. [    1.434925] xhci-hcd xhci-hcd.6.auto: Host not halted after 16000 microseconds.
  187. [    1.435564] xhci-hcd xhci-hcd.6.auto: Host controller not halted, aborting reset.
  188. [    1.436254] xhci-hcd xhci-hcd.6.auto: USB bus 6 deregistered
  189. [    1.437146] xhci-hcd xhci-hcd.6.auto: remove, state 1
  190. [    1.437610] usb usb5: USB disconnect, device number 1
  191. [    1.438418] xhci-hcd xhci-hcd.6.auto: USB bus 5 deregistered
  192. [    1.440761] ehci-platform fe380000.usb: EHCI Host Controller
  193. [    1.441365] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
  194. [    1.442143] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
  195. [    1.468773] fusb302 4-0022: connection has disconnected
  196. [    1.493753] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
  197. [    1.494612] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
  198. [    1.495223] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  199. [    1.495890] usb usb5: Product: EHCI Host Controller
  200. [    1.496329] usb usb5: Manufacturer: Linux 4.4.52 ehci_hcd
  201. [    1.496828] usb usb5: SerialNumber: fe380000.usb
  202. [    1.498393] hub 5-0:1.0: USB hub found
  203. [    1.498811] hub 5-0:1.0: 1 port detected
  204. [    1.500478] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
  205. [    1.500684] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
  206. [    1.500697] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  207. [    1.500707] usb 1-1: Product: USB 2.0 Hub [MTT]
  208. [    1.501574] hub 1-1:1.0: USB hub found
  209. [    1.501674] hub 1-1:1.0: 7 ports detected
  210. [    1.503896] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
  211. [    1.504822] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
  212. [    1.560026] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
  213. [    1.560666] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  214. [    1.561311] usb usb6: Product: Generic Platform OHCI controller
  215. [    1.561858] usb usb6: Manufacturer: Linux 4.4.52 ohci_hcd
  216. [    1.562340] usb usb6: SerialNumber: fe3a0000.usb
  217. [    1.563946] hub 6-0:1.0: USB hub found
  218. [    1.564342] hub 6-0:1.0: 1 port detected
  219. [    1.566628] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
  220. [    1.567323] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
  221. [    1.567957] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
  222. [    1.568525] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
  223. [    1.569401] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
  224. [    1.570249] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
  225. [    1.570815] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
  226. [    1.571825] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
  227. [    1.583784] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  228. [    1.595695] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
  229. [    1.607397] asoc-simple-card rt5640-sound: rt5640-aif1 <-> ff890000.i2s mapping ok
  230. [    1.613852] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card0/input0
  231. [    1.617240] asoc-simple-card hdmi-codec: i2s-hifi <-> ff8a0000.i2s mapping ok
  232. [    1.621483] rockchip-spdif ff870000.spdif: Missing dma channel for stream: 0
  233. [    1.622165] rockchip-spdif ff870000.spdif: ASoC: pcm constructor failed: -22
  234. [    1.622813] asoc-simple-card spdif-sound: ASoC: can't create pcm ff870000.spdif-dit-hifi :-22
  235. [    1.623583] asoc-simple-card spdif-sound: ASoC: failed to instantiate card -22
  236. [    1.624575] asoc-simple-card: probe of spdif-sound failed with error -22
  237. [    1.625837]
  238. [    1.625981] =======================================================
  239. [    1.626558] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
  240. [    1.627111] =======================================================
  241. [    1.627708] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 2.20.WFD) init.
  242. [    1.628384] [WLAN_RFKILL]: rockchip_wifi_power: 1
  243. [    1.628845] [WLAN_RFKILL]: wifi turn on power. -1
  244. [    1.629263] RTL871X: module init start
  245. [    1.629622] RTL871X: rtl8188eu v4.3.24_16705.20160509
  246. [    1.630349] usbcore: registered new interface driver rtl8188eu
  247. [    1.630910] RTL871X: module init ret=0
  248. [    1.632590] input: gpio-keys as /devices/platform/gpio-keys/input/input1
  249. [    1.633412] dhd_module_init: in
  250. [    1.633775] ======== bcm_wlan_set_plat_data ========
  251. [    1.634229] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
  252. [    1.634747] host_oob_irq: 68
  253. [    1.634802] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:04 UTC (1358499004)
  254. [    1.635769] host_oob_irq_flags=0x4
  255. [    1.636074] dhd_wifi_platform_load: Enter
  256. [    1.636561] Power-up adapter 'DHD generic adapter'
  257. [    1.637101] wifi_platform_set_power = 1
  258. [    1.637466] ======== PULL WL_REG_ON HIGH! ========
  259. [    1.637916] [WLAN_RFKILL]: rockchip_wifi_power: 1
  260. [    1.638335] [WLAN_RFKILL]: wifi turn on power. -1
  261. [    1.647575] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
  262. [    1.649733] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
  263. [    1.651918] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
  264. [    1.655418] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  265. [    1.666568] fusb302 4-0022: connection has disconnected
  266. [    1.716702] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
  267. [    1.738509] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 313
  268. [    1.747041] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
  269. [    1.747624] mmc2: new ultra high speed SDR104 SDIO card at address 0001
  270. [    1.839568] wifi_platform_bus_enumerate device present 1
  271. [    1.840049] ======== Card detection to detect SDIO card! ========
  272. [    1.840616] mmc2:mmc host rescan start!
  273. [    1.848621] vendor storage:20160801 ret = -1
  274. [    1.852830] fusb302 4-0022: connection has disconnected
  275. [    1.856631] bcmsdh_register: register client driver
  276. [    1.857431] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
  277. [    1.858246] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
  278. [    1.858723] bus num (host idx)=2, slot num (rca)=1
  279. [    1.859150] found adapter info 'DHD generic adapter'
  280. [    1.859923] sdioh_attach: set sd_f2_blocksize 128
  281. [    1.865844] F1 signature read @0x18000000=0x17224356
  282. [    1.880202] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x2 pkg:0x2
  283. [    1.882178] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
  284. [    1.882976] wifi_platform_get_mac_addr
  285. [    1.883316] ======== bcm_wlan_get_mac_address ========
  286. [    1.883800] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
  287. [    1.884281] [WLAN_RFKILL]: get_wifi_addr_vendor: rk_vendor_read wifi mac address failed (-1)
  288. [    1.885058] dhd_conf_set_chiprev: chip=0x4354, chiprev=2
  289. [    1.885680] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
  290. [    1.887527] wl_create_event_handler(): thread:wl_event_handler:a8 started
  291. [    1.887545] tsk Enter, tsk = 0xffffffc077de1be8
  292. [    1.888783] wl_escan_attach: Enter
  293. [    1.889122] wl_escan_init: Enter
  294. [    1.889665] wl_create_event_handler(): thread:wl_escan_handler:a9 started
  295. [    1.889680] tsk Enter, tsk = 0xffffffc077e301b0
  296. [    1.890948] dhd_attach(): thread:dhd_watchdog_thread:aa started
  297. [    1.891795] dhd_attach(): thread:dhd_dpc:ab started
  298. [    1.891830] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
  299. [    1.893086] dhd_attach(): thread:dhd_rxf:ac started
  300. [    1.893550] dhd_deferred_work_init: work queue initialized
  301. [    1.922229] Dongle Host Driver, version 1.363.59.144.1 (r)
  302. [    1.923704] Register interface [wlan0]  MAC: cc:4b:73:1d:1a:78
  303. [    1.923704]
  304. [    1.924475] wl_event_handler: was terminated
  305. [    1.924942] wl_destroy_event_handler(): thread:wl_event_handler:a8 terminated OK
  306. [    1.925622] dhd_wl_ioctl: returning as busstate=0
  307. [    1.926120] bcmsdh_oob_intr_unregister: Enter
  308. [    1.926531] bcmsdh_oob_intr_unregister: irq is not registered
  309. [    1.927048] dhd_txglom_enable: enable 0
  310. [    1.927392] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0
  311. [    1.927936] dhd_conf_set_txglom_params: txglom_bucket_size=0
  312. [    1.928437] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=0
  313. [    1.929141] dhd_conf_set_txglom_params: tx_in_rx=1, tx_max_offset=0
  314. [    1.929707] dhd_bus_devreset:  WLAN OFF DONE
  315. [    1.930200] wifi_platform_set_power = 0
  316. [    1.930565] ======== PULL WL_REG_ON LOW! ========
  317. [    1.930983] [WLAN_RFKILL]: rockchip_wifi_power: 0
  318. [    1.931413] [WLAN_RFKILL]: wifi shut off power.
  319. [    1.931900] dhd_module_init: Exit err=0
  320. [    2.037817] fusb302 4-0022: connection has disconnected
  321. [    2.223601] fusb302 4-0022: connection has disconnected
  322. [    2.412600] fusb302 4-0022: connection has disconnected
  323. [    2.599722] fusb302 4-0022: connection has disconnected
  324. [    2.784419] fusb302 4-0022: connection has disconnected
  325. [    2.973780] fusb302 4-0022: connection has disconnected
  326. [    3.163376] fusb302 4-0022: connection has disconnected
  327. [    3.351348] fusb302 4-0022: connection has disconnected
  328. [    3.539333] fusb302 4-0022: connection has disconnected
  329. [    3.614814] phy phy-ff770000.syscon:usb2-phy@e450.6: charger = USB_SDP_CHARGER
  330. [    3.728981] fusb302 4-0022: connection has disconnected
  331. [    3.916746] fusb302 4-0022: connection has disconnected
  332. [    4.050833] random: nonblocking pool is initialized
  333. [    4.105116] fusb302 4-0022: connection has disconnected
  334. [    4.303187] fusb302 4-0022: connection has disconnected
  335. [    4.511206] fusb302 4-0022: connection has disconnected
  336. [    4.717910] fusb302 4-0022: connection has disconnected
  337. [    4.926030] fusb302 4-0022: connection has disconnected
  338. [    5.133007] fusb302 4-0022: connection has disconnected
  339. [    5.339817] fusb302 4-0022: connection has disconnected
  340. [    5.546523] fusb302 4-0022: connection has disconnected
  341. [    5.751383] fusb302 4-0022: connection has disconnected
  342. [    5.957577] fusb302 4-0022: connection has disconnected
  343. [    6.157551] fusb302 4-0022: connection has disconnected
  344. [    6.357088] fusb302 4-0022: connection has disconnected
  345. [    6.556918] fusb302 4-0022: connection has disconnected
  346. [    6.756373] fusb302 4-0022: connection has disconnected
  347. [    6.956425] fusb302 4-0022: connection has disconnected
  348. [    7.150533] fusb302 4-0022: connection has disconnected
  349. [    7.338922] fusb302 4-0022: connection has disconnected
  350. [    7.527485] fusb302 4-0022: connection has disconnected
  351. [    7.715631] fusb302 4-0022: connection has disconnected
  352. [    7.904643] fusb302 4-0022: connection has disconnected
  353. [    8.096544] fusb302 4-0022: connection has disconnected
  354. [    8.294416] fusb302 4-0022: connection has disconnected
  355. [    8.501481] fusb302 4-0022: connection has disconnected
  356. [    8.710251] fusb302 4-0022: connection has disconnected
  357. [    8.916852] fusb302 4-0022: connection has disconnected
  358. [    9.123891] fusb302 4-0022: connection has disconnected
  359. [    9.330760] fusb302 4-0022: connection has disconnected
  360. [    9.538035] fusb302 4-0022: connection has disconnected
  361. [    9.744077] fusb302 4-0022: connection has disconnected
  362. [    9.950305] fusb302 4-0022: connection has disconnected
  363. [   10.150364] fusb302 4-0022: connection has disconnected
  364. [   10.347469] fusb302 4-0022: connection has disconnected
  365. [   10.545697] fusb302 4-0022: connection has disconnected
  366. [   10.745826] fusb302 4-0022: connection has disconnected
  367. [   10.945533] fusb302 4-0022: connection has disconnected
  368. [   11.138456] fusb302 4-0022: connection has disconnected
  369. [   11.327415] fusb302 4-0022: connection has disconnected
  370. [   11.515953] fusb302 4-0022: connection has disconnected
  371. [   11.704938] fusb302 4-0022: connection has disconnected
  372. [   11.892487] fusb302 4-0022: connection has disconnected
  373. [   12.082972] fusb302 4-0022: connection has disconnected
  374. [   12.282900] fusb302 4-0022: connection has disconnected
  375. [   12.489653] fusb302 4-0022: connection has disconnected
  376. [   12.695709] fusb302 4-0022: connection has disconnected
  377. [   12.902580] fusb302 4-0022: connection has disconnected
  378. [   13.111410] fusb302 4-0022: connection has disconnected
  379. [   13.319022] fusb302 4-0022: connection has disconnected
  380. [   13.526131] fusb302 4-0022: connection has disconnected
  381. [   13.732862] fusb302 4-0022: connection has disconnected
  382. [   13.940379] fusb302 4-0022: connection has disconnected
  383. [   14.140557] fusb302 4-0022: connection has disconnected
  384. [   14.341011] fusb302 4-0022: connection has disconnected
  385. [   14.539342] fusb302 4-0022: connection has disconnected
  386. [   14.739469] fusb302 4-0022: connection has disconnected
  387. [   14.939981] fusb302 4-0022: connection has disconnected
  388. [   15.131941] fusb302 4-0022: connection has disconnected
  389. [   15.321458] fusb302 4-0022: connection has disconnected
  390. [   15.509137] fusb302 4-0022: connection has disconnected
  391. [   15.696313] fusb302 4-0022: connection has disconnected
  392. [   15.884773] fusb302 4-0022: connection has disconnected
  393. [   16.076381] fusb302 4-0022: connection has disconnected
  394. [   16.276051] fusb302 4-0022: connection has disconnected
  395. [   16.482540] fusb302 4-0022: connection has disconnected
  396. [   16.688804] fusb302 4-0022: connection has disconnected
  397. [   16.894782] fusb302 4-0022: connection has disconnected
  398. [   17.102183] fusb302 4-0022: connection has disconnected
  399. [   17.311221] fusb302 4-0022: connection has disconnected
  400. [   17.518797] fusb302 4-0022: connection has disconnected
  401. [   17.726237] fusb302 4-0022: connection has disconnected
  402. [   17.931137] fusb302 4-0022: connection has disconnected
  403. [   18.132138] fusb302 4-0022: connection has disconnected
  404. [   18.331902] fusb302 4-0022: connection has disconnected
  405. [   18.532203] fusb302 4-0022: connection has disconnected
  406. [   18.730690] fusb302 4-0022: connection has disconnected
  407. [   18.929079] fusb302 4-0022: connection has disconnected
  408. [   19.123032] fusb302 4-0022: connection has disconnected
  409. [   19.313062] fusb302 4-0022: connection has disconnected
  410. [   19.500432] fusb302 4-0022: connection has disconnected
  411. [   19.688294] fusb302 4-0022: connection has disconnected
  412. [   19.874390] fusb302 4-0022: connection has disconnected
  413. [   20.065686] fusb302 4-0022: connection has disconnected
  414. [   20.254124] fusb302 4-0022: connection has disconnected
  415. [   20.442136] fusb302 4-0022: connection has disconnected
  416. [   20.630045] fusb302 4-0022: connection has disconnected
  417. [   20.818812] fusb302 4-0022: connection has disconnected
  418. [   21.012190] fusb302 4-0022: connection has disconnected
  419. [   21.212735] fusb302 4-0022: connection has disconnected
  420. [   21.413338] fusb302 4-0022: connection has disconnected
  421. [   21.615570] fusb302 4-0022: connection has disconnected
  422. [   21.817143] fusb302 4-0022: connection has disconnected
  423. [   22.018114] fusb302 4-0022: connection has disconnected
  424. [   22.219693] fusb302 4-0022: connection has disconnected
  425. [   22.421044] fusb302 4-0022: connection has disconnected
  426. [   22.624361] fusb302 4-0022: connection has disconnected
  427. [   22.824686] fusb302 4-0022: connection has disconnected
  428. [   23.024414] fusb302 4-0022: connection has disconnected
  429. [   23.217403] fusb302 4-0022: connection has disconnected
  430. [   23.405847] fusb302 4-0022: connection has disconnected
  431. [   23.593390] fusb302 4-0022: connection has disconnected
  432. [   23.780689] fusb302 4-0022: connection has disconnected
  433. [   23.967668] fusb302 4-0022: connection has disconnected
  434. [   24.162519] fusb302 4-0022: connection has disconnected
  435. [   24.349658] fusb302 4-0022: connection has disconnected
  436. [   24.537654] fusb302 4-0022: connection has disconnected
  437. [   24.725477] fusb302 4-0022: connection has disconnected
  438. [   24.912402] fusb302 4-0022: connection has disconnected
  439. [   25.100468] fusb302 4-0022: connection has disconnected
  440. [   25.301562] fusb302 4-0022: connection has disconnected
  441. [   25.500614] fusb302 4-0022: connection has disconnected
  442. [   25.699068] fusb302 4-0022: connection has disconnected
  443. [   25.902361] fusb302 4-0022: connection has disconnected
  444. [   26.103981] fusb302 4-0022: connection has disconnected
  445. [   26.306428] fusb302 4-0022: connection has disconnected
  446. [   26.511366] fusb302 4-0022: connection has disconnected
  447. [   26.715146] fusb302 4-0022: connection has disconnected
  448. [   26.917687] fusb302 4-0022: connection has disconnected
  449. [   27.115104] fusb302 4-0022: connection has disconnected
  450. [   27.304196] fusb302 4-0022: connection has disconnected
  451. [   27.492205] fusb302 4-0022: connection has disconnected
  452. [   27.680449] fusb302 4-0022: connection has disconnected
  453. [   27.868378] fusb302 4-0022: connection has disconnected
  454. [   28.056786] fusb302 4-0022: connection has disconnected
  455. [   28.244544] fusb302 4-0022: connection has disconnected
  456. [   28.432222] fusb302 4-0022: connection has disconnected
  457. [   28.620937] fusb302 4-0022: connection has disconnected
  458. [   28.807311] fusb302 4-0022: connection has disconnected
  459. [   28.998194] fusb302 4-0022: connection has disconnected
  460. [   29.197776] fusb302 4-0022: connection has disconnected
  461. [   29.398093] fusb302 4-0022: connection has disconnected
  462. [   29.599928] fusb302 4-0022: connection has disconnected
  463. [   29.800838] fusb302 4-0022: connection has disconnected
  464. [   30.000852] fusb302 4-0022: connection has disconnected
  465. [   30.204977] fusb302 4-0022: connection has disconnected
  466. [   30.408995] fusb302 4-0022: connection has disconnected
  467. [   30.613309] fusb302 4-0022: connection has disconnected
  468. [   30.817001] fusb302 4-0022: connection has disconnected
  469. [   31.019787] fusb302 4-0022: connection has disconnected
  470. [   31.212220] fusb302 4-0022: connection has disconnected
  471. [   31.400919] fusb302 4-0022: connection has disconnected
  472. [   31.588395] fusb302 4-0022: connection has disconnected
  473. [   31.774193] fusb302 4-0022: connection has disconnected
  474. [   31.959943] fusb302 4-0022: connection has disconnected
  475. [   32.153245] fusb302 4-0022: connection has disconnected
  476. [   32.342285] fusb302 4-0022: connection has disconnected
  477. [   32.530788] fusb302 4-0022: connection has disconnected
  478. [   32.719667] fusb302 4-0022: connection has disconnected
  479. [   32.908170] fusb302 4-0022: connection has disconnected
  480. [   33.092951] fusb302 4-0022: connection has disconnected
  481. [   33.294706] fusb302 4-0022: connection has disconnected
  482. [   33.496347] fusb302 4-0022: connection has disconnected
  483. [   33.698140] fusb302 4-0022: connection has disconnected
  484. [   33.901726] fusb302 4-0022: connection has disconnected
  485. [   34.107064] fusb302 4-0022: connection has disconnected
  486. [   34.309591] fusb302 4-0022: connection has disconnected
  487. [   34.511918] fusb302 4-0022: connection has disconnected
  488. [   34.716273] fusb302 4-0022: connection has disconnected
  489. [   34.918791] fusb302 4-0022: connection has disconnected
  490. [   35.114481] fusb302 4-0022: connection has disconnected
  491. [   35.304361] fusb302 4-0022: connection has disconnected
  492. [   35.492109] fusb302 4-0022: connection has disconnected
  493. [   35.680444] fusb302 4-0022: connection has disconnected
  494. [   35.868331] fusb302 4-0022: connection has disconnected
  495. [   36.058294] fusb302 4-0022: connection has disconnected
  496. [   36.257769] fusb302 4-0022: connection has disconnected
  497. [   36.458699] fusb302 4-0022: connection has disconnected
  498. [   36.658337] fusb302 4-0022: connection has disconnected
  499. [   36.859325] fusb302 4-0022: connection has disconnected
  500. [   37.059772] fusb302 4-0022: connection has disconnected
  501. [   37.259904] fusb302 4-0022: connection has disconnected
  502. [   37.461351] fusb302 4-0022: connection has disconnected
  503. [   37.662046] fusb302 4-0022: connection has disconnected
  504. [   37.863463] fusb302 4-0022: connection has disconnected
  505. [   38.063040] fusb302 4-0022: connection has disconnected
  506. [   38.262384] fusb302 4-0022: connection has disconnected
  507. [   38.460016] fusb302 4-0022: connection has disconnected
  508. [   38.657472] fusb302 4-0022: connection has disconnected
  509. [   38.855100] fusb302 4-0022: connection has disconnected
  510. [   39.049916] fusb302 4-0022: connection has disconnected
  511. [   39.241859] fusb302 4-0022: connection has disconnected
  512. [   39.430744] fusb302 4-0022: connection has disconnected
  513. [   39.619252] fusb302 4-0022: connection has disconnected
  514. [   39.806330] fusb302 4-0022: connection has disconnected
  515. [   39.995213] fusb302 4-0022: connection has disconnected
  516. [   40.188307] fusb302 4-0022: connection has disconnected
  517. [   40.375655] fusb302 4-0022: connection has disconnected
  518. [   40.564002] fusb302 4-0022: connection has disconnected
  519. [   40.751449] fusb302 4-0022: connection has disconnected
  520. [   40.938522] fusb302 4-0022: connection has disconnected
  521. [   41.140947] fusb302 4-0022: connection has disconnected
  522. [   41.342922] fusb302 4-0022: connection has disconnected
  523. [   41.543445] fusb302 4-0022: connection has disconnected
  524. [   41.743776] fusb302 4-0022: connection has disconnected
  525. [   41.942764] fusb302 4-0022: connection has disconnected
  526. [   42.141592] fusb302 4-0022: connection has disconnected
  527. [   42.339312] fusb302 4-0022: connection has disconnected
  528. [   42.537339] fusb302 4-0022: connection has disconnected
  529. [   42.737954] fusb302 4-0022: connection has disconnected
  530. [   42.936182] fusb302 4-0022: connection has disconnected
  531. [   43.128329] fusb302 4-0022: connection has disconnected
  532. [   43.318009] fusb302 4-0022: connection has disconnected
  533. [   43.505592] fusb302 4-0022: connection has disconnected
  534. [   43.692531] fusb302 4-0022: connection has disconnected
  535. [   43.879667] fusb302 4-0022: connection has disconnected
  536. [   44.068602] fusb302 4-0022: connection has disconnected
  537. [   44.257391] fusb302 4-0022: connection has disconnected
  538. [   44.445446] fusb302 4-0022: connection has disconnected
  539. [   44.632995] fusb302 4-0022: connection has disconnected
  540. [   44.821120] fusb302 4-0022: connection has disconnected
  541. [   45.013900] fusb302 4-0022: connection has disconnected
  542. [   45.213745] fusb302 4-0022: connection has disconnected
  543. [   45.416574] fusb302 4-0022: connection has disconnected
  544. [   45.619082] fusb302 4-0022: connection has disconnected
  545. [   45.818145] fusb302 4-0022: connection has disconnected
  546. [   46.019823] fusb302 4-0022: connection has disconnected
  547. [   46.222797] fusb302 4-0022: connection has disconnected
  548. [   46.423898] fusb302 4-0022: connection has disconnected
  549. [   46.624207] fusb302 4-0022: connection has disconnected
  550. [   46.824821] fusb302 4-0022: connection has disconnected
  551. [   47.024829] fusb302 4-0022: connection has disconnected
  552. [   47.217546] fusb302 4-0022: connection has disconnected
  553. [   47.404828] fusb302 4-0022: connection has disconnected
  554. [   47.591948] fusb302 4-0022: connection has disconnected
  555. [   47.778852] fusb302 4-0022: connection has disconnected
  556. [   47.965863] fusb302 4-0022: connection has disconnected
  557. [   48.160521] fusb302 4-0022: connection has disconnected
  558. [   48.348482] fusb302 4-0022: connection has disconnected
  559. [   48.536317] fusb302 4-0022: connection has disconnected
  560. [   48.724542] fusb302 4-0022: connection has disconnected
  561. [   48.910610] fusb302 4-0022: connection has disconnected
  562. [   49.097003] fusb302 4-0022: connection has disconnected
  563. [   49.300004] fusb302 4-0022: connection has disconnected
  564. [   49.502877] fusb302 4-0022: connection has disconnected
  565. [   49.705931] fusb302 4-0022: connection has disconnected
  566. [   49.911304] fusb302 4-0022: connection has disconnected
  567. [   50.113379] fusb302 4-0022: connection has disconnected
  568. [   50.316375] fusb302 4-0022: connection has disconnected
  569. [   50.520235] fusb302 4-0022: connection has disconnected
  570. [   50.720659] fusb302 4-0022: connection has disconnected
  571. [   50.924173] fusb302 4-0022: connection has disconnected
  572. [   51.119150] fusb302 4-0022: connection has disconnected
  573. [   51.308170] fusb302 4-0022: connection has disconnected
  574. [   51.496393] fusb302 4-0022: connection has disconnected
  575. [   51.683889] fusb302 4-0022: connection has disconnected
  576. [   51.870209] fusb302 4-0022: connection has disconnected
  577. [   52.057786] fusb302 4-0022: connection has disconnected
  578. [   52.245910] fusb302 4-0022: connection has disconnected
  579. [   52.434918] fusb302 4-0022: connection has disconnected
  580. [   52.623581] fusb302 4-0022: connection has disconnected
  581. [   52.811023] fusb302 4-0022: connection has disconnected
  582. [   53.002748] fusb302 4-0022: connection has disconnected
  583. [   53.202545] fusb302 4-0022: connection has disconnected
  584. [   53.403849] fusb302 4-0022: connection has disconnected
  585. [   53.607033] fusb302 4-0022: connection has disconnected
  586. [   53.809407] fusb302 4-0022: connection has disconnected
  587. [   54.011852] fusb302 4-0022: connection has disconnected
  588. [   54.214987] fusb302 4-0022: connection has disconnected
  589. [   54.418393] fusb302 4-0022: connection has disconnected
  590. [   54.621960] fusb302 4-0022: connection has disconnected
  591. [   54.822608] fusb302 4-0022: connection has disconnected
  592. [   55.023901] fusb302 4-0022: connection has disconnected
  593. [   55.216212] fusb302 4-0022: connection has disconnected
  594. [   55.403958] fusb302 4-0022: connection has disconnected
  595. [   55.591472] fusb302 4-0022: connection has disconnected
  596. [   55.779208] fusb302 4-0022: connection has disconnected
  597. [   55.966217] fusb302 4-0022: connection has disconnected
  598. [   56.161434] fusb302 4-0022: connection has disconnected
  599. [   56.349697] fusb302 4-0022: connection has disconnected
  600. [   56.537797] fusb302 4-0022: connection has disconnected
  601. [   56.725721] fusb302 4-0022: connection has disconnected
  602. [   56.912208] fusb302 4-0022: connection has disconnected
  603. [   57.099401] fusb302 4-0022: connection has disconnected
  604. [   57.301758] fusb302 4-0022: connection has disconnected
  605. [   57.503964] fusb302 4-0022: connection has disconnected
  606. [   57.707160] fusb302 4-0022: connection has disconnected
  607. [   57.913814] fusb302 4-0022: connection has disconnected
  608. [   58.116701] fusb302 4-0022: connection has disconnected
  609. [   58.320178] fusb302 4-0022: connection has disconnected
  610. [   58.523011] fusb302 4-0022: connection has disconnected
  611. [   58.723245] fusb302 4-0022: connection has disconnected
  612. [   58.923555] fusb302 4-0022: connection has disconnected
  613. [   59.121064] fusb302 4-0022: connection has disconnected
  614. [   59.308155] fusb302 4-0022: connection has disconnected
  615. [   59.494205] fusb302 4-0022: connection has disconnected
  616. [   59.681583] fusb302 4-0022: connection has disconnected
  617. [   59.868672] fusb302 4-0022: connection has disconnected
  618. [   60.057467] fusb302 4-0022: connection has disconnected
  619. [   60.256213] fusb302 4-0022: connection has disconnected
  620. [   60.457426] fusb302 4-0022: connection has disconnected
  621. [   60.657710] fusb302 4-0022: connection has disconnected
  622. [   60.857541] fusb302 4-0022: connection has disconnected
  623. [   61.058486] fusb302 4-0022: connection has disconnected
  624. [   61.258929] fusb302 4-0022: connection has disconnected
  625. [   61.459541] fusb302 4-0022: connection has disconnected
  626. [   61.661026] fusb302 4-0022: connection has disconnected
  627. [   61.862249] fusb302 4-0022: connection has disconnected
  628. [   62.059906] fusb302 4-0022: connection has disconnected
  629. [   62.258121] fusb302 4-0022: connection has disconnected
  630. [   62.455778] fusb302 4-0022: connection has disconnected
  631. [   62.650987] fusb302 4-0022: connection has disconnected
  632. [   62.846378] fusb302 4-0022: connection has disconnected
  633. [   63.043367] fusb302 4-0022: connection has disconnected
  634. [   63.236147] fusb302 4-0022: connection has disconnected
  635. [   63.425039] fusb302 4-0022: connection has disconnected
  636. [   63.613658] fusb302 4-0022: connection has disconnected
  637. [   63.800711] fusb302 4-0022: connection has disconnected
  638. [   63.988577] fusb302 4-0022: connection has disconnected
  639. [   64.181091] fusb302 4-0022: connection has disconnected
  640. [   64.369263] fusb302 4-0022: connection has disconnected
  641. [   64.556951] fusb302 4-0022: connection has disconnected
  642. [   64.744316] fusb302 4-0022: connection has disconnected
  643. [   64.931541] fusb302 4-0022: connection has disconnected
  644. [   65.129999] fusb302 4-0022: connection has disconnected
  645. [   65.330711] fusb302 4-0022: connection has disconnected
  646. [   65.531437] fusb302 4-0022: connection has disconnected
  647. [   65.732921] fusb302 4-0022: connection has disconnected
  648. [   65.934909] fusb302 4-0022: connection has disconnected
  649. [   66.133776] fusb302 4-0022: connection has disconnected
  650. [   66.332111] fusb302 4-0022: connection has disconnected
  651. [   66.532788] fusb302 4-0022: connection has disconnected
  652. [   66.731857] fusb302 4-0022: connection has disconnected
  653. [   66.932299] fusb302 4-0022: connection has disconnected
  654. [   67.123668] fusb302 4-0022: connection has disconnected
  655. [   67.311641] fusb302 4-0022: connection has disconnected
  656. [   67.497529] fusb302 4-0022: connection has disconnected
  657. [   67.685169] fusb302 4-0022: connection has disconnected
  658. [   67.871481] fusb302 4-0022: connection has disconnected
  659. [   68.059384] fusb302 4-0022: connection has disconnected
  660. [   68.257813] fusb302 4-0022: connection has disconnected
  661. [   68.458559] fusb302 4-0022: connection has disconnected
  662. [   68.659822] fusb302 4-0022: connection has disconnected
  663. [   68.860709] fusb302 4-0022: connection has disconnected
  664. [   69.060049] fusb302 4-0022: connection has disconnected
  665. [   69.261117] fusb302 4-0022: connection has disconnected
  666. [   69.461451] fusb302 4-0022: connection has disconnected
  667. [   69.660882] fusb302 4-0022: connection has disconnected
  668. [   69.862045] fusb302 4-0022: connection has disconnected
  669. [   70.057319] fusb302 4-0022: connection has disconnected
  670. [   70.257403] fusb302 4-0022: connection has disconnected
  671. [   70.455750] fusb302 4-0022: connection has disconnected
  672. [   70.650924] fusb302 4-0022: connection has disconnected
  673. [   70.846331] fusb302 4-0022: connection has disconnected
  674. [   71.043187] fusb302 4-0022: connection has disconnected
  675. [   71.234945] fusb302 4-0022: connection has disconnected
  676. [   71.424540] fusb302 4-0022: connection has disconnected
  677. [   71.611625] fusb302 4-0022: connection has disconnected
  678. [   71.798136] fusb302 4-0022: connection has disconnected
  679. [   71.985398] fusb302 4-0022: connection has disconnected
  680. [   72.178898] fusb302 4-0022: connection has disconnected
  681. [   72.367288] fusb302 4-0022: connection has disconnected
  682. [   72.555795] fusb302 4-0022: connection has disconnected
  683. [   72.743298] fusb302 4-0022: connection has disconnected
  684. [   72.930459] fusb302 4-0022: connection has disconnected
  685. [   73.128433] fusb302 4-0022: connection has disconnected
  686. [   73.328821] fusb302 4-0022: connection has disconnected
  687. [   73.530273] fusb302 4-0022: connection has disconnected
  688. [   73.732020] fusb302 4-0022: connection has disconnected
  689. [   73.933882] fusb302 4-0022: connection has disconnected
  690. [   74.132405] fusb302 4-0022: connection has disconnected
  691. [   74.331823] fusb302 4-0022: connection has disconnected
  692. [   74.532473] fusb302 4-0022: connection has disconnected
  693. [   74.731464] fusb302 4-0022: connection has disconnected
  694. [   74.932175] fusb302 4-0022: connection has disconnected
  695. [   75.124910] fusb302 4-0022: connection has disconnected
  696. [   75.314871] fusb302 4-0022: connection has disconnected
  697. [   75.503323] fusb302 4-0022: connection has disconnected
  698. [   75.690393] fusb302 4-0022: connection has disconnected
  699. [   75.877832] fusb302 4-0022: connection has disconnected
  700. [   76.066119] fusb302 4-0022: connection has disconnected
  701. [   76.265692] fusb302 4-0022: connection has disconnected
  702. [   76.464482] fusb302 4-0022: connection has disconnected
  703. [   76.664336] fusb302 4-0022: connection has disconnected
  704. [   76.865161] fusb302 4-0022: connection has disconnected
  705. [   77.064459] fusb302 4-0022: connection has disconnected
  706. [   77.264306] fusb302 4-0022: connection has disconnected
  707. [   77.465550] fusb302 4-0022: connection has disconnected
  708. [   77.666334] fusb302 4-0022: connection has disconnected
  709. [   77.867037] fusb302 4-0022: connection has disconnected
  710. [   78.066113] fusb302 4-0022: connection has disconnected
  711. [   78.266453] fusb302 4-0022: connection has disconnected
  712. [   78.466815] fusb302 4-0022: connection has disconnected
  713. [   78.666907] fusb302 4-0022: connection has disconnected
  714. [   78.866182] fusb302 4-0022: connection has disconnected
  715. [   79.065265] fusb302 4-0022: connection has disconnected
  716. [   79.256448] fusb302 4-0022: connection has disconnected
  717. [   79.444204] fusb302 4-0022: connection has disconnected
  718. [   79.632303] fusb302 4-0022: connection has disconnected
  719. [   79.820808] fusb302 4-0022: connection has disconnected
  720. [   80.008726] fusb302 4-0022: connection has disconnected
  721. [   80.202752] fusb302 4-0022: connection has disconnected
  722. [   80.391297] fusb302 4-0022: connection has disconnected
  723. [   80.579294] fusb302 4-0022: connection has disconnected
  724. [   80.766352] fusb302 4-0022: connection has disconnected
  725. [   80.952480] fusb302 4-0022: connection has disconnected
  726. [   81.161144] fusb302 4-0022: connection has disconnected
  727. [   81.361338] fusb302 4-0022: connection has disconnected
  728. [   81.561361] fusb302 4-0022: connection has disconnected
  729. [   81.761091] fusb302 4-0022: connection has disconnected
  730. [   81.961984] fusb302 4-0022: connection has disconnected
  731. [   82.162237] fusb302 4-0022: connection has disconnected
  732. [   82.360307] fusb302 4-0022: connection has disconnected
  733. [   82.557270] fusb302 4-0022: connection has disconnected
  734. [   82.752411] fusb302 4-0022: connection has disconnected
  735. [   82.950326] fusb302 4-0022: connection has disconnected
  736. [   83.140629] fusb302 4-0022: connection has disconnected
  737. [   83.330220] fusb302 4-0022: connection has disconnected
  738. [   83.519005] fusb302 4-0022: connection has disconnected
  739. [   83.706559] fusb302 4-0022: connection has disconnected
  740. [   83.895526] fusb302 4-0022: connection has disconnected
  741. [   84.084925] fusb302 4-0022: connection has disconnected
  742. [   84.283812] fusb302 4-0022: connection has disconnected
  743. [   84.485009] fusb302 4-0022: connection has disconnected
  744. [   84.685425] fusb302 4-0022: connection has disconnected
  745. [   84.886348] fusb302 4-0022: connection has disconnected
  746. [   85.087873] fusb302 4-0022: connection has disconnected
  747. [   85.288540] fusb302 4-0022: connection has disconnected
  748. [   85.490714] fusb302 4-0022: connection has disconnected
  749. [   85.692350] fusb302 4-0022: connection has disconnected
  750. [   85.893913] fusb302 4-0022: connection has disconnected
  751. [   86.093833] fusb302 4-0022: connection has disconnected
  752. [   86.294057] fusb302 4-0022: connection has disconnected
  753. [   86.492762] fusb302 4-0022: connection has disconnected
  754. [   86.689112] fusb302 4-0022: connection has disconnected
  755. [   86.889538] fusb302 4-0022: connection has disconnected
  756. [   87.090406] fusb302 4-0022: connection has disconnected
  757. [   87.279093] fusb302 4-0022: connection has disconnected
  758. [   87.466578] fusb302 4-0022: connection has disconnected
  759. [   87.655378] fusb302 4-0022: connection has disconnected
  760. [   87.842314] fusb302 4-0022: connection has disconnected
  761. [   88.030578] fusb302 4-0022: connection has disconnected
  762. [   88.219406] fusb302 4-0022: connection has disconnected
  763. [   88.407305] fusb302 4-0022: connection has disconnected
  764. [   88.594220] fusb302 4-0022: connection has disconnected
  765. [   88.780310] fusb302 4-0022: connection has disconnected
  766. [   88.966658] fusb302 4-0022: connection has disconnected
  767. [   89.170773] fusb302 4-0022: connection has disconnected
  768. [   89.373343] fusb302 4-0022: connection has disconnected
  769. [   89.574359] fusb302 4-0022: connection has disconnected
  770. [   89.775859] fusb302 4-0022: connection has disconnected
  771. [   89.979527] fusb302 4-0022: connection has disconnected
  772. [   90.176204] fusb302 4-0022: connection has disconnected
  773. [   90.380525] fusb302 4-0022: connection has disconnected
  774. [   90.572165] fusb302 4-0022: connection has disconnected
  775. [   90.760902] fusb302 4-0022: connection has disconnected
  776. [   90.949375] fusb302 4-0022: connection has disconnected
  777. [   91.136424] fusb302 4-0022: connection has disconnected
  778. [   91.324440] fusb302 4-0022: connection has disconnected
  779. [   91.517241] fusb302 4-0022: connection has disconnected
  780. [   91.703904] fusb302 4-0022: connection has disconnected
  781. [   91.891693] fusb302 4-0022: connection has disconnected
  782. [   92.082310] fusb302 4-0022: connection has disconnected
  783. [   92.281420] fusb302 4-0022: connection has disconnected
  784. [   92.482088] fusb302 4-0022: connection has disconnected
  785. [   92.682424] fusb302 4-0022: connection has disconnected
  786. [   92.882537] fusb302 4-0022: connection has disconnected
  787. [   93.084751] fusb302 4-0022: connection has disconnected
  788. [   93.285080] fusb302 4-0022: connection has disconnected
  789. [   93.485564] fusb302 4-0022: connection has disconnected
  790. [   93.686423] fusb302 4-0022: connection has disconnected
  791. [   93.888340] fusb302 4-0022: connection has disconnected
  792. [   94.089062] fusb302 4-0022: connection has disconnected
  793. [   94.290696] fusb302 4-0022: connection has disconnected
  794. [   94.489537] fusb302 4-0022: connection has disconnected
  795. [   94.691183] fusb302 4-0022: connection has disconnected
  796. [   94.893012] fusb302 4-0022: connection has disconnected
  797. [   95.093168] fusb302 4-0022: connection has disconnected
  798. [   95.281151] fusb302 4-0022: connection has disconnected
  799. [   95.468412] fusb302 4-0022: connection has disconnected
  800. [   95.655849] fusb302 4-0022: connection has disconnected
  801. [   95.842948] fusb302 4-0022: connection has disconnected
  802. [   96.030485] fusb302 4-0022: connection has disconnected
  803. [   96.219557] fusb302 4-0022: connection has disconnected
  804. [   96.408176] fusb302 4-0022: connection has disconnected
  805. [   96.595313] fusb302 4-0022: connection has disconnected
  806. [   96.782390] fusb302 4-0022: connection has disconnected
  807. [   96.970651] fusb302 4-0022: connection has disconnected
  808. [   97.184989] fusb302 4-0022: connection has disconnected
  809. [   97.385313] fusb302 4-0022: connection has disconnected
  810. [   97.586532] fusb302 4-0022: connection has disconnected
  811. [   97.786546] fusb302 4-0022: connection has disconnected
  812. [   97.985917] fusb302 4-0022: connection has disconnected
  813. [   98.186193] fusb302 4-0022: connection has disconnected
  814. [   98.386310] fusb302 4-0022: connection has disconnected
  815. [   98.588223] fusb302 4-0022: connection has disconnected
  816. [   98.790046] fusb302 4-0022: connection has disconnected
  817. [   98.992187] fusb302 4-0022: connection has disconnected
  818. [   99.184284] fusb302 4-0022: connection has disconnected
  819. [   99.373206] fusb302 4-0022: connection has disconnected
  820. [   99.561673] fusb302 4-0022: connection has disconnected
  821. [   99.748813] fusb302 4-0022: connection has disconnected
  822. [   99.935779] fusb302 4-0022: connection has disconnected
  823. [  100.122574] fusb302 4-0022: connection has disconnected
  824. [  100.323341] fusb302 4-0022: connection has disconnected
  825. [  100.524540] fusb302 4-0022: connection has disconnected
  826. [  100.726265] fusb302 4-0022: connection has disconnected
  827. [  100.927859] fusb302 4-0022: connection has disconnected
  828. [  101.129279] fusb302 4-0022: connection has disconnected
  829. [  101.331046] fusb302 4-0022: connection has disconnected
  830. [  101.532172] fusb302 4-0022: connection has disconnected
  831. [  101.733899] fusb302 4-0022: connection has disconnected
  832. [  101.936194] fusb302 4-0022: connection has disconnected
  833. [  102.135261] fusb302 4-0022: connection has disconnected
  834. [  102.332838] fusb302 4-0022: connection has disconnected
  835. [  102.531360] fusb302 4-0022: connection has disconnected
  836. [  102.731838] fusb302 4-0022: connection has disconnected
  837. [  102.929809] fusb302 4-0022: connection has disconnected
  838. [  103.121533] fusb302 4-0022: connection has disconnected
  839. [  103.310150] fusb302 4-0022: connection has disconnected
  840. [  103.498474] fusb302 4-0022: connection has disconnected
  841. [  103.686084] fusb302 4-0022: connection has disconnected
  842. [  103.872226] fusb302 4-0022: connection has disconnected
  843. [  104.059570] fusb302 4-0022: connection has disconnected
  844. [  104.248140] fusb302 4-0022: connection has disconnected
  845. [  104.436736] fusb302 4-0022: connection has disconnected
  846. [  104.625095] fusb302 4-0022: connection has disconnected
  847. [  104.813259] fusb302 4-0022: connection has disconnected
  848. [  105.005168] fusb302 4-0022: connection has disconnected
  849. [  105.203447] fusb302 4-0022: connection has disconnected
  850. [  105.405996] fusb302 4-0022: connection has disconnected
  851. [  105.609789] fusb302 4-0022: connection has disconnected
  852. [  105.810807] fusb302 4-0022: connection has disconnected
  853. [  106.013095] fusb302 4-0022: connection has disconnected
  854. [  106.216196] fusb302 4-0022: connection has disconnected
  855. [  106.419577] fusb302 4-0022: connection has disconnected
  856. [  106.620188] fusb302 4-0022: connection has disconnected
  857. [  106.820761] fusb302 4-0022: connection has disconnected
  858. [  107.022939] fusb302 4-0022: connection has disconnected
  859. [  107.215690] fusb302 4-0022: connection has disconnected
  860. [  107.404219] fusb302 4-0022: connection has disconnected
  861. [  107.591459] fusb302 4-0022: connection has disconnected
  862. [  107.778787] fusb302 4-0022: connection has disconnected
  863. [  107.965697] fusb302 4-0022: connection has disconnected
  864. [  108.160055] fusb302 4-0022: connection has disconnected
  865. [  108.348578] fusb302 4-0022: connection has disconnected
  866. [  108.536674] fusb302 4-0022: connection has disconnected
  867. [  108.724611] fusb302 4-0022: connection has disconnected
  868. [  108.911739] fusb302 4-0022: connection has disconnected
  869. [  109.098209] fusb302 4-0022: connection has disconnected
  870. [  109.299903] fusb302 4-0022: connection has disconnected
  871. [  109.502555] fusb302 4-0022: connection has disconnected
  872. [  109.703904] fusb302 4-0022: connection has disconnected
  873. [  109.910830] fusb302 4-0022: connection has disconnected
  874. [  110.113461] fusb302 4-0022: connection has disconnected
  875. [  110.316880] fusb302 4-0022: connection has disconnected
  876. [  110.520182] fusb302 4-0022: connection has disconnected
  877. [  110.721014] fusb302 4-0022: connection has disconnected
  878. [  110.921954] fusb302 4-0022: connection has disconnected
  879. [  111.117194] fusb302 4-0022: connection has disconnected
  880. [  111.306537] fusb302 4-0022: connection has disconnected
  881. [  111.495111] fusb302 4-0022: connection has disconnected
  882. [  111.682383] fusb302 4-0022: connection has disconnected
  883. [  111.868675] fusb302 4-0022: connection has disconnected
  884. [  112.056090] fusb302 4-0022: connection has disconnected
  885. [  112.255005] fusb302 4-0022: connection has disconnected
  886. [  112.455142] fusb302 4-0022: connection has disconnected
  887. [  112.656185] fusb302 4-0022: connection has disconnected
  888. [  112.856427] fusb302 4-0022: connection has disconnected
  889. [  113.056430] fusb302 4-0022: connection has disconnected
  890. [  113.256029] fusb302 4-0022: connection has disconnected
  891. [  113.457160] fusb302 4-0022: connection has disconnected
  892. [  113.657042] fusb302 4-0022: connection has disconnected
  893. [  113.859553] fusb302 4-0022: connection has disconnected
  894. [  114.057516] fusb302 4-0022: connection has disconnected
  895. [  114.255745] fusb302 4-0022: connection has disconnected
  896. [  114.451556] fusb302 4-0022: connection has disconnected
  897. [  114.646527] fusb302 4-0022: connection has disconnected
  898. [  114.844376] fusb302 4-0022: connection has disconnected
  899. [  115.040303] fusb302 4-0022: connection has disconnected
  900. [  115.231546] fusb302 4-0022: connection has disconnected
  901. [  115.419850] fusb302 4-0022: connection has disconnected
  902. [  115.607321] fusb302 4-0022: connection has disconnected
  903. [  115.795179] fusb302 4-0022: connection has disconnected
  904. [  115.981667] fusb302 4-0022: connection has disconnected
  905. [  116.175730] fusb302 4-0022: connection has disconnected
  906. [  116.364567] fusb302 4-0022: connection has disconnected
  907. [  116.552126] fusb302 4-0022: connection has disconnected
  908. [  116.739677] fusb302 4-0022: connection has disconnected
  909. [  116.926922] fusb302 4-0022: connection has disconnected
  910. [  117.124455] fusb302 4-0022: connection has disconnected
  911. [  117.324844] fusb302 4-0022: connection has disconnected
  912. [  117.526552] fusb302 4-0022: connection has disconnected
  913. [  117.727886] fusb302 4-0022: connection has disconnected
  914. [  117.929448] fusb302 4-0022: connection has disconnected
  915. [  118.131006] fusb302 4-0022: connection has disconnected
  916. [  118.331965] fusb302 4-0022: connection has disconnected
  917. [  118.528590] fusb302 4-0022: connection has disconnected
  918. [  118.727826] fusb302 4-0022: connection has disconnected
  919. [  118.928891] fusb302 4-0022: connection has disconnected
  920. [  119.121107] fusb302 4-0022: connection has disconnected
  921. [  119.310324] fusb302 4-0022: connection has disconnected
  922. [  119.498270] fusb302 4-0022: connection has disconnected
  923. [  119.686330] fusb302 4-0022: connection has disconnected
  924. [  119.872333] fusb302 4-0022: connection has disconnected
  925. [  120.061193] fusb302 4-0022: connection has disconnected
  926. [  120.259299] fusb302 4-0022: connection has disconnected
  927. [  120.460318] fusb302 4-0022: connection has disconnected
  928. [  120.660775] fusb302 4-0022: connection has disconnected
  929. [  120.862109] fusb302 4-0022: connection has disconnected
  930. [  121.062574] fusb302 4-0022: connection has disconnected
  931. [  121.262888] fusb302 4-0022: connection has disconnected
  932. [  121.462238] fusb302 4-0022: connection has disconnected
  933. [  121.663110] fusb302 4-0022: connection has disconnected
  934. [  121.861623] fusb302 4-0022: connection has disconnected
  935. [  122.058691] fusb302 4-0022: connection has disconnected
  936. [  122.256702] fusb302 4-0022: connection has disconnected
  937. [  122.457355] fusb302 4-0022: connection has disconnected
  938. [  122.655537] fusb302 4-0022: connection has disconnected
  939. [  122.850897] fusb302 4-0022: connection has disconnected
  940. [  123.048619] fusb302 4-0022: connection has disconnected
  941. [  123.239164] fusb302 4-0022: connection has disconnected
  942. [  123.427673] fusb302 4-0022: connection has disconnected
  943. [  123.616844] fusb302 4-0022: connection has disconnected
  944. [  123.803538] fusb302 4-0022: connection has disconnected
  945. [  123.991334] fusb302 4-0022: connection has disconnected
  946. [  124.185391] fusb302 4-0022: connection has disconnected
  947. [  124.373583] fusb302 4-0022: connection has disconnected
  948. [  124.561793] fusb302 4-0022: connection has disconnected
  949. [  124.748777] fusb302 4-0022: connection has disconnected
  950. [  124.935834] fusb302 4-0022: connection has disconnected
  951. [  125.137549] fusb302 4-0022: connection has disconnected
  952. [  125.338682] fusb302 4-0022: connection has disconnected
  953. [  125.538945] fusb302 4-0022: connection has disconnected
  954. [  125.739891] fusb302 4-0022: connection has disconnected
  955. [  125.941461] fusb302 4-0022: connection has disconnected
  956. [  126.140399] fusb302 4-0022: connection has disconnected
  957. [  126.338364] fusb302 4-0022: connection has disconnected
  958. [  126.536579] fusb302 4-0022: connection has disconnected
  959. [  126.734349] fusb302 4-0022: connection has disconnected
  960. [  126.933181] fusb302 4-0022: connection has disconnected
  961. [  127.124174] fusb302 4-0022: connection has disconnected
  962. [  127.313884] fusb302 4-0022: connection has disconnected
  963. [  127.500979] fusb302 4-0022: connection has disconnected
  964. [  127.688297] fusb302 4-0022: connection has disconnected
  965. [  127.876578] fusb302 4-0022: connection has disconnected
  966. [  128.065306] fusb302 4-0022: connection has disconnected
  967. [  128.264000] fusb302 4-0022: connection has disconnected
  968. [  128.469772] fusb302 4-0022: connection has disconnected
  969. [  128.675655] fusb302 4-0022: connection has disconnected
  970. [  128.881994] fusb302 4-0022: connection has disconnected
  971. [  129.088163] fusb302 4-0022: connection has disconnected
  972. [  129.293796] fusb302 4-0022: connection has disconnected
  973. [  129.499918] fusb302 4-0022: connection has disconnected
  974. [  129.706986] fusb302 4-0022: connection has disconnected
  975. [  129.916979] fusb302 4-0022: connection has disconnected
  976. [  130.120801] fusb302 4-0022: connection has disconnected
  977. [  130.324207] fusb302 4-0022: connection has disconnected
  978. [  130.527708] fusb302 4-0022: connection has disconnected
  979. [  130.731721] fusb302 4-0022: connection has disconnected
  980. [  130.932404] fusb302 4-0022: connection has disconnected
  981. [  131.125786] fusb302 4-0022: connection has disconnected
  982. [  131.315409] fusb302 4-0022: connection has disconnected
  983. [  131.503442] fusb302 4-0022: connection has disconnected
  984. [  131.691224] fusb302 4-0022: connection has disconnected
  985. [  131.877526] fusb302 4-0022: connection has disconnected
  986. [  132.068693] fusb302 4-0022: connection has disconnected
  987. [  132.257178] fusb302 4-0022: connection has disconnected
  988. [  132.445086] fusb302 4-0022: connection has disconnected
  989. [  132.632804] fusb302 4-0022: connection has disconnected
  990. [  132.821244] fusb302 4-0022: connection has disconnected
  991. [  133.014303] fusb302 4-0022: connection has disconnected
  992. [  133.214124] fusb302 4-0022: connection has disconnected
  993. [  133.417679] fusb302 4-0022: connection has disconnected
  994. [  133.619807] fusb302 4-0022: connection has disconnected
  995. [  133.821542] fusb302 4-0022: connection has disconnected
  996. [  134.020887] fusb302 4-0022: connection has disconnected
  997. [  134.222015] fusb302 4-0022: connection has disconnected
  998. [  134.425325] fusb302 4-0022: connection has disconnected
  999. [  134.627689] fusb302 4-0022: connection has disconnected
  1000. [  134.828340] fusb302 4-0022: connection has disconnected
  1001. [  135.029009] fusb302 4-0022: connection has disconnected
  1002. [  135.221124] fusb302 4-0022: connection has disconnected
  1003. [  135.410141] fusb302 4-0022: connection has disconnected
  1004. [  135.597294] fusb302 4-0022: connection has disconnected
  1005. [  135.783388] fusb302 4-0022: connection has disconnected
  1006. [  135.971855] fusb302 4-0022: connection has disconnected
  1007. [  136.165926] fusb302 4-0022: connection has disconnected
  1008. [  136.354582] fusb302 4-0022: connection has disconnected
  1009. [  136.543296] fusb302 4-0022: connection has disconnected
  1010. [  136.730824] fusb302 4-0022: connection has disconnected
  1011. [  136.918734] fusb302 4-0022: connection has disconnected
  1012. [  137.112338] fusb302 4-0022: connection has disconnected
  1013. [  137.314787] fusb302 4-0022: connection has disconnected
  1014. [  137.517027] fusb302 4-0022: connection has disconnected
  1015. [  137.719654] fusb302 4-0022: connection has disconnected
  1016. [  137.923773] fusb302 4-0022: connection has disconnected
  1017. [  138.127790] fusb302 4-0022: connection has disconnected
  1018. [  138.328419] fusb302 4-0022: connection has disconnected
  1019. [  138.528925] fusb302 4-0022: connection has disconnected
  1020. [  138.729416] fusb302 4-0022: connection has disconnected
  1021. [  138.928237] fusb302 4-0022: connection has disconnected
  1022. [  139.120014] fusb302 4-0022: connection has disconnected
  1023. [  139.306854] fusb302 4-0022: connection has disconnected
  1024. [  139.493786] fusb302 4-0022: connection has disconnected
  1025. [  139.680307] fusb302 4-0022: connection has disconnected
  1026. [  139.867383] fusb302 4-0022: connection has disconnected
  1027. [  140.056547] fusb302 4-0022: connection has disconnected
  1028. [  140.255031] fusb302 4-0022: connection has disconnected
  1029. [  140.454373] fusb302 4-0022: connection has disconnected
  1030. [  140.654421] fusb302 4-0022: connection has disconnected
  1031. [  140.854436] fusb302 4-0022: connection has disconnected
  1032. [  141.054455] fusb302 4-0022: connection has disconnected
  1033. [  141.254365] fusb302 4-0022: connection has disconnected
  1034. [  141.454560] fusb302 4-0022: connection has disconnected
  1035. [  141.654432] fusb302 4-0022: connection has disconnected
  1036. [  141.854683] fusb302 4-0022: connection has disconnected
  1037. [  142.049535] fusb302 4-0022: connection has disconnected
  1038. [  142.245246] fusb302 4-0022: connection has disconnected
  1039. [  142.440777] fusb302 4-0022: connection has disconnected
  1040. [  142.641349] fusb302 4-0022: connection has disconnected
  1041. [  142.839073] fusb302 4-0022: connection has disconnected
  1042. [  143.036422] fusb302 4-0022: connection has disconnected
  1043. [  143.229124] fusb302 4-0022: connection has disconnected
  1044. [  143.418214] fusb302 4-0022: connection has disconnected
  1045. [  143.606160] fusb302 4-0022: connection has disconnected
  1046. [  143.793937] fusb302 4-0022: connection has disconnected
  1047. [  143.981827] fusb302 4-0022: connection has disconnected
  1048. [  144.175546] fusb302 4-0022: connection has disconnected
  1049. [  144.363794] fusb302 4-0022: connection has disconnected
  1050. [  144.551668] fusb302 4-0022: connection has disconnected
  1051. [  144.739900] fusb302 4-0022: connection has disconnected
  1052. [  144.928188] fusb302 4-0022: connection has disconnected
  1053. [  145.125933] fusb302 4-0022: connection has disconnected
  1054. [  145.327909] fusb302 4-0022: connection has disconnected
  1055. [  145.530346] fusb302 4-0022: connection has disconnected
  1056. [  145.731898] fusb302 4-0022: connection has disconnected
  1057. [  145.935059] fusb302 4-0022: connection has disconnected
  1058. [  146.134096] fusb302 4-0022: connection has disconnected
  1059. [  146.334625] fusb302 4-0022: connection has disconnected
  1060. [  146.532123] fusb302 4-0022: connection has disconnected
  1061. [  146.730397] fusb302 4-0022: connection has disconnected
  1062. [  146.929821] fusb302 4-0022: connection has disconnected
  1063. [  147.123676] fusb302 4-0022: connection has disconnected
  1064. [  147.313827] fusb302 4-0022: connection has disconnected
  1065. [  147.501456] fusb302 4-0022: connection has disconnected
  1066. [  147.689211] fusb302 4-0022: connection has disconnected
  1067. [  147.875094] fusb302 4-0022: connection has disconnected
  1068. [  148.063670] fusb302 4-0022: connection has disconnected
  1069. [  148.251936] fusb302 4-0022: connection has disconnected
  1070. [  148.440403] fusb302 4-0022: connection has disconnected
  1071. [  148.628543] fusb302 4-0022: connection has disconnected
  1072. [  148.816031] fusb302 4-0022: connection has disconnected
  1073. [  149.008160] fusb302 4-0022: connection has disconnected
  1074. [  149.208240] fusb302 4-0022: connection has disconnected
  1075. [  149.408240] fusb302 4-0022: connection has disconnected
  1076. [  149.612314] fusb302 4-0022: connection has disconnected
  1077. [  149.811962] fusb302 4-0022: connection has disconnected
  1078. [  150.013925] fusb302 4-0022: connection has disconnected
  1079. [  150.217700] fusb302 4-0022: connection has disconnected
  1080. [  150.421150] fusb302 4-0022: connection has disconnected
  1081. [  150.621950] fusb302 4-0022: connection has disconnected
  1082. [  150.822421] fusb302 4-0022: connection has disconnected
  1083. [  151.024827] fusb302 4-0022: connection has disconnected
  1084. [  151.217337] fusb302 4-0022: connection has disconnected
  1085. [  151.406018] fusb302 4-0022: connection has disconnected
  1086. [  151.592690] fusb302 4-0022: connection has disconnected
  1087. [  151.779858] fusb302 4-0022: connection has disconnected
  1088. [  151.966895] fusb302 4-0022: connection has disconnected
  1089. [  152.161735] fusb302 4-0022: connection has disconnected
  1090. [  152.349687] fusb302 4-0022: connection has disconnected
  1091. [  152.537692] fusb302 4-0022: connection has disconnected
  1092. [  152.726203] fusb302 4-0022: connection has disconnected
  1093. [  152.914179] fusb302 4-0022: connection has disconnected
  1094. [  153.102773] fusb302 4-0022: connection has disconnected
  1095. [  153.305975] fusb302 4-0022: connection has disconnected
  1096. [  153.510059] fusb302 4-0022: connection has disconnected
  1097. [  153.713939] fusb302 4-0022: connection has disconnected
  1098. [  153.918356] fusb302 4-0022: connection has disconnected
  1099. [  154.121154] fusb302 4-0022: connection has disconnected
  1100. [  154.324415] fusb302 4-0022: connection has disconnected
  1101. [  154.527624] fusb302 4-0022: connection has disconnected
  1102. [  154.727551] fusb302 4-0022: connection has disconnected
  1103. [  154.927460] fusb302 4-0022: connection has disconnected
  1104. [  155.121628] fusb302 4-0022: connection has disconnected
  1105. [  155.311639] fusb302 4-0022: connection has disconnected
  1106. [  155.499874] fusb302 4-0022: connection has disconnected
  1107. [  155.687235] fusb302 4-0022: connection has disconnected
  1108. [  155.873393] fusb302 4-0022: connection has disconnected
  1109. [  156.061583] fusb302 4-0022: connection has disconnected
  1110. [  156.260007] fusb302 4-0022: connection has disconnected
  1111. [  156.461126] fusb302 4-0022: connection has disconnected
  1112. [  156.661154] fusb302 4-0022: connection has disconnected
  1113. [  156.861231] fusb302 4-0022: connection has disconnected
  1114. [  157.060443] fusb302 4-0022: connection has disconnected
  1115. [  157.260167] fusb302 4-0022: connection has disconnected
  1116. [  157.460312] fusb302 4-0022: connection has disconnected
  1117. [  157.660854] fusb302 4-0022: connection has disconnected
  1118. [  157.862101] fusb302 4-0022: connection has disconnected
  1119. [  158.059913] fusb302 4-0022: connection has disconnected
  1120. [  158.257778] fusb302 4-0022: connection has disconnected
  1121. [  158.455464] fusb302 4-0022: connection has disconnected
  1122. [  158.653459] fusb302 4-0022: connection has disconnected
  1123. [  158.849260] fusb302 4-0022: connection has disconnected
  1124. [  159.046405] fusb302 4-0022: connection has disconnected
  1125. [  159.236528] fusb302 4-0022: connection has disconnected
  1126. [  159.424605] fusb302 4-0022: connection has disconnected
  1127. [  159.613035] fusb302 4-0022: connection has disconnected
  1128. [  159.800076] fusb302 4-0022: connection has disconnected
  1129. [  159.987937] fusb302 4-0022: connection has disconnected
  1130. [  160.180718] fusb302 4-0022: connection has disconnected
  1131. [  160.368929] fusb302 4-0022: connection has disconnected
  1132. [  160.556811] fusb302 4-0022: connection has disconnected
  1133. [  160.744305] fusb302 4-0022: connection has disconnected
  1134. [  160.931299] fusb302 4-0022: connection has disconnected
  1135. [  161.129258] fusb302 4-0022: connection has disconnected
  1136. [  161.331112] fusb302 4-0022: connection has disconnected
  1137. [  161.531927] fusb302 4-0022: connection has disconnected
  1138. [  161.732616] fusb302 4-0022: connection has disconnected
  1139. [  161.932965] fusb302 4-0022: connection has disconnected
  1140. [  162.133805] fusb302 4-0022: connection has disconnected
  1141. [  162.332406] fusb302 4-0022: connection has disconnected
  1142. [  162.531829] fusb302 4-0022: connection has disconnected
  1143. [  162.732348] fusb302 4-0022: connection has disconnected
  1144. [  162.932912] fusb302 4-0022: connection has disconnected
  1145. [  163.124184] fusb302 4-0022: connection has disconnected
  1146. [  163.314177] fusb302 4-0022: connection has disconnected
  1147. [  163.502306] fusb302 4-0022: connection has disconnected
  1148. [  163.690054] fusb302 4-0022: connection has disconnected
  1149. [  163.876089] fusb302 4-0022: connection has disconnected
  1150. [  164.064671] fusb302 4-0022: connection has disconnected
  1151. [  164.253347] fusb302 4-0022: connection has disconnected
  1152. [  164.441460] fusb302 4-0022: connection has disconnected
  1153. [  164.629406] fusb302 4-0022: connection has disconnected
  1154. [  164.817299] fusb302 4-0022: connection has disconnected
  1155. [  165.010312] fusb302 4-0022: connection has disconnected
  1156. [  165.209758] fusb302 4-0022: connection has disconnected
  1157. [  165.413304] fusb302 4-0022: connection has disconnected
  1158. [  165.616569] fusb302 4-0022: connection has disconnected
  1159. [  165.817658] fusb302 4-0022: connection has disconnected
  1160. [  166.018895] fusb302 4-0022: connection has disconnected
  1161. [  166.220764] fusb302 4-0022: connection has disconnected
  1162. [  166.421942] fusb302 4-0022: connection has disconnected
  1163. [  166.624809] fusb302 4-0022: connection has disconnected
  1164. [  166.827718] fusb302 4-0022: connection has disconnected
  1165. [  167.026749] fusb302 4-0022: connection has disconnected
  1166. [  167.219429] fusb302 4-0022: connection has disconnected
  1167. [  167.408138] fusb302 4-0022: connection has disconnected
  1168. [  167.595925] fusb302 4-0022: connection has disconnected
  1169. [  167.783728] fusb302 4-0022: connection has disconnected
  1170. [  167.969905] fusb302 4-0022: connection has disconnected
  1171. [  168.164539] fusb302 4-0022: connection has disconnected
  1172. [  168.351581] fusb302 4-0022: connection has disconnected
  1173. [  168.539676] fusb302 4-0022: connection has disconnected
  1174. [  168.727317] fusb302 4-0022: connection has disconnected
  1175. [  168.914281] fusb302 4-0022: connection has disconnected
  1176. [  169.102347] fusb302 4-0022: connection has disconnected
  1177. [  169.304113] fusb302 4-0022: connection has disconnected
  1178. [  169.506947] fusb302 4-0022: connection has disconnected
  1179. [  169.711386] fusb302 4-0022: connection has disconnected
  1180. [  169.916197] fusb302 4-0022: connection has disconnected
  1181. [  170.117073] fusb302 4-0022: connection has disconnected
  1182. [  170.319538] fusb302 4-0022: connection has disconnected
  1183. [  170.520649] fusb302 4-0022: connection has disconnected
  1184. [  170.720765] fusb302 4-0022: connection has disconnected
  1185. [  170.921773] fusb302 4-0022: connection has disconnected
  1186. [  171.117217] fusb302 4-0022: connection has disconnected
  1187. [  171.306558] fusb302 4-0022: connection has disconnected
  1188. [  171.495281] fusb302 4-0022: connection has disconnected
  1189. [  171.682687] fusb302 4-0022: connection has disconnected
  1190. [  171.870390] fusb302 4-0022: connection has disconnected
  1191. [  172.058754] fusb302 4-0022: connection has disconnected
  1192. [  172.246789] fusb302 4-0022: connection has disconnected
  1193. [  172.435684] fusb302 4-0022: connection has disconnected
  1194. [  172.624012] fusb302 4-0022: connection has disconnected
  1195. [  172.811174] fusb302 4-0022: connection has disconnected
  1196. [  173.003641] fusb302 4-0022: connection has disconnected
  1197. [  173.203354] fusb302 4-0022: connection has disconnected
  1198. [  173.406063] fusb302 4-0022: connection has disconnected
  1199. [  173.610692] fusb302 4-0022: connection has disconnected
  1200. [  173.811207] fusb302 4-0022: connection has disconnected
  1201. [  174.016005] fusb302 4-0022: connection has disconnected
  1202. [  174.216950] fusb302 4-0022: connection has disconnected
  1203. [  174.421040] fusb302 4-0022: connection has disconnected
  1204. [  174.622036] fusb302 4-0022: connection has disconnected
  1205. [  174.822837] fusb302 4-0022: connection has disconnected
  1206. [  175.022791] fusb302 4-0022: connection has disconnected
  1207. [  175.215157] fusb302 4-0022: connection has disconnected
  1208. [  175.403208] fusb302 4-0022: connection has disconnected
  1209. [  175.590222] fusb302 4-0022: connection has disconnected
  1210. [  175.778407] fusb302 4-0022: connection has disconnected
  1211. [  175.964773] fusb302 4-0022: connection has disconnected
  1212. [  176.158783] fusb302 4-0022: connection has disconnected
  1213. [  176.347278] fusb302 4-0022: connection has disconnected
  1214. [  176.535671] fusb302 4-0022: connection has disconnected
  1215. [  176.723332] fusb302 4-0022: connection has disconnected
  1216. [  176.910135] fusb302 4-0022: connection has disconnected
  1217. [  177.096414] fusb302 4-0022: connection has disconnected
  1218. [  177.299250] fusb302 4-0022: connection has disconnected
  1219. [  177.501588] fusb302 4-0022: connection has disconnected
  1220. [  177.703617] fusb302 4-0022: connection has disconnected
  1221. [  177.905165] fusb302 4-0022: connection has disconnected
  1222. [  178.109711] fusb302 4-0022: connection has disconnected
  1223. [  178.313310] fusb302 4-0022: connection has disconnected
  1224. [  178.516098] fusb302 4-0022: connection has disconnected
  1225. [  178.719483] fusb302 4-0022: connection has disconnected
  1226. [  178.922709] fusb302 4-0022: connection has disconnected
  1227. [  179.118793] fusb302 4-0022: connection has disconnected
  1228. [  179.306560] fusb302 4-0022: connection has disconnected
  1229. [  179.493377] fusb302 4-0022: connection has disconnected
  1230. [  179.680164] fusb302 4-0022: connection has disconnected
  1231. [  179.867199] fusb302 4-0022: connection has disconnected
  1232. [  180.055583] fusb302 4-0022: connection has disconnected
  1233. [  180.243479] fusb302 4-0022: connection has disconnected
  1234. [  180.431279] fusb302 4-0022: connection has disconnected
  1235. [  180.619844] fusb302 4-0022: connection has disconnected
  1236. [  180.806936] fusb302 4-0022: connection has disconnected
  1237. [  180.997932] fusb302 4-0022: connection has disconnected
  1238. [  181.197422] fusb302 4-0022: connection has disconnected
  1239. [  181.400105] fusb302 4-0022: connection has disconnected
  1240. [  181.602343] fusb302 4-0022: connection has disconnected
  1241. [  181.801994] fusb302 4-0022: connection has disconnected
  1242. [  182.003364] fusb302 4-0022: connection has disconnected
  1243. [  182.207074] fusb302 4-0022: connection has disconnected
  1244. [  182.411951] fusb302 4-0022: connection has disconnected
  1245. [  182.615157] fusb302 4-0022: connection has disconnected
  1246. [  182.817665] fusb302 4-0022: connection has disconnected
  1247. [  183.019988] fusb302 4-0022: connection has disconnected
  1248. [  183.212201] fusb302 4-0022: connection has disconnected
  1249. [  183.400555] fusb302 4-0022: connection has disconnected
  1250. [  183.589532] fusb302 4-0022: connection has disconnected
  1251. [  183.775675] fusb302 4-0022: connection has disconnected
  1252. [  183.963100] fusb302 4-0022: connection has disconnected
  1253. [  184.156533] fusb302 4-0022: connection has disconnected
  1254. [  184.345006] fusb302 4-0022: connection has disconnected
  1255. [  184.532768] fusb302 4-0022: connection has disconnected
  1256. [  184.720938] fusb302 4-0022: connection has disconnected
  1257. [  184.907219] fusb302 4-0022: connection has disconnected
  1258. [  185.092240] fusb302 4-0022: connection has disconnected
  1259. [  185.292783] fusb302 4-0022: connection has disconnected
  1260. [  185.493778] fusb302 4-0022: connection has disconnected
  1261. [  185.695787] fusb302 4-0022: connection has disconnected
  1262. [  185.899279] fusb302 4-0022: connection has disconnected
  1263. [  186.101598] fusb302 4-0022: connection has disconnected
  1264. [  186.304824] fusb302 4-0022: connection has disconnected
  1265. [  186.509393] fusb302 4-0022: connection has disconnected
  1266. [  186.713915] fusb302 4-0022: connection has disconnected
  1267. [  186.916585] fusb302 4-0022: connection has disconnected
  1268. [  187.114643] fusb302 4-0022: connection has disconnected
  1269. [  187.301562] fusb302 4-0022: connection has disconnected
  1270. [  187.489484] fusb302 4-0022: connection has disconnected
  1271. [  187.675386] fusb302 4-0022: connection has disconnected
  1272. [  187.862592] fusb302 4-0022: connection has disconnected
  1273. [  188.052525] fusb302 4-0022: connection has disconnected
  1274. [  188.251164] fusb302 4-0022: connection has disconnected
  1275. [  188.451540] fusb302 4-0022: connection has disconnected
  1276. [  188.651535] fusb302 4-0022: connection has disconnected
  1277. [  188.853012] fusb302 4-0022: connection has disconnected
  1278. [  189.053668] fusb302 4-0022: connection has disconnected
  1279. [  189.252365] fusb302 4-0022: connection has disconnected
  1280. [  189.452708] fusb302 4-0022: connection has disconnected
  1281. [  189.652183] fusb302 4-0022: connection has disconnected
  1282. [  189.851755] fusb302 4-0022: connection has disconnected
  1283. [  190.047297] fusb302 4-0022: connection has disconnected
  1284. [  190.243955] fusb302 4-0022: connection has disconnected
  1285. [  190.441977] fusb302 4-0022: connection has disconnected
  1286. [  190.637744] fusb302 4-0022: connection has disconnected
  1287. [  190.836242] fusb302 4-0022: connection has disconnected
  1288. [  191.033984] fusb302 4-0022: connection has disconnected
  1289. [  191.225911] fusb302 4-0022: connection has disconnected
  1290. [  191.415435] fusb302 4-0022: connection has disconnected
  1291. [  191.603887] fusb302 4-0022: connection has disconnected
  1292. [  191.790944] fusb302 4-0022: connection has disconnected
  1293. [  191.978784] fusb302 4-0022: connection has disconnected
  1294. [  192.172794] fusb302 4-0022: connection has disconnected
  1295. [  192.361452] fusb302 4-0022: connection has disconnected
  1296. [  192.549013] fusb302 4-0022: connection has disconnected
  1297. [  192.736783] fusb302 4-0022: connection has disconnected
  1298. [  192.926102] fusb302 4-0022: connection has disconnected
  1299. [  193.123750] fusb302 4-0022: connection has disconnected
  1300. [  193.326140] fusb302 4-0022: connection has disconnected
  1301. [  193.527447] fusb302 4-0022: connection has disconnected
  1302. [  193.727915] fusb302 4-0022: connection has disconnected
  1303. [  193.931767] fusb302 4-0022: connection has disconnected
  1304. [  194.132556] fusb302 4-0022: connection has disconnected
  1305. [  194.333225] fusb302 4-0022: connection has disconnected
  1306. [  194.533406] fusb302 4-0022: connection has disconnected
  1307. [  194.732775] fusb302 4-0022: connection has disconnected
  1308. [  194.929450] fusb302 4-0022: connection has disconnected
  1309. [  195.123973] fusb302 4-0022: connection has disconnected
  1310. [  195.313412] fusb302 4-0022: connection has disconnected
  1311. [  195.502367] fusb302 4-0022: connection has disconnected
  1312. [  195.690094] fusb302 4-0022: connection has disconnected
  1313. [  195.876305] fusb302 4-0022: connection has disconnected
  1314. [  196.065106] fusb302 4-0022: connection has disconnected
  1315. [  196.263184] fusb302 4-0022: connection has disconnected
  1316. [  196.462875] fusb302 4-0022: connection has disconnected
  1317. [  196.663433] fusb302 4-0022: connection has disconnected
  1318. [  196.863427] fusb302 4-0022: connection has disconnected
  1319. [  197.063370] fusb302 4-0022: connection has disconnected
  1320. [  197.263476] fusb302 4-0022: connection has disconnected
  1321. [  197.463311] fusb302 4-0022: connection has disconnected
  1322. [  197.663461] fusb302 4-0022: connection has disconnected
  1323. [  197.863451] fusb302 4-0022: connection has disconnected
  1324. [  198.063106] fusb302 4-0022: connection has disconnected
  1325. [  198.262905] fusb302 4-0022: connection has disconnected
  1326. [  198.462119] fusb302 4-0022: connection has disconnected
  1327. [  198.659908] fusb302 4-0022: connection has disconnected
  1328. [  198.857427] fusb302 4-0022: connection has disconnected
  1329. [  199.055331] fusb302 4-0022: connection has disconnected
  1330. [  199.246300] fusb302 4-0022: connection has disconnected
  1331. [  199.434903] fusb302 4-0022: connection has disconnected
  1332. [  199.623336] fusb302 4-0022: connection has disconnected
  1333. [  199.811038] fusb302 4-0022: connection has disconnected
  1334. [  199.998390] fusb302 4-0022: connection has disconnected
  1335. [  200.192377] fusb302 4-0022: connection has disconnected
  1336. [  200.380309] fusb302 4-0022: connection has disconnected
  1337. [  200.567121] fusb302 4-0022: connection has disconnected
  1338. [  200.753946] fusb302 4-0022: connection has disconnected
  1339. [  200.942791] fusb302 4-0022: connection has disconnected
  1340. [  201.147758] fusb302 4-0022: connection has disconnected
  1341. [  201.349095] fusb302 4-0022: connection has disconnected
  1342. [  201.550038] fusb302 4-0022: connection has disconnected
  1343. [  201.750111] fusb302 4-0022: connection has disconnected
  1344. [  201.946406] fusb302 4-0022: connection has disconnected
  1345. [  202.146263] fusb302 4-0022: connection has disconnected
  1346. [  202.342386] fusb302 4-0022: connection has disconnected
  1347. [  202.540588] fusb302 4-0022: connection has disconnected
  1348. [  202.737174] fusb302 4-0022: connection has disconnected
  1349. [  202.935055] fusb302 4-0022: connection has disconnected
  1350. [  203.126352] fusb302 4-0022: connection has disconnected
  1351. [  203.316848] fusb302 4-0022: connection has disconnected
  1352. [  203.504621] fusb302 4-0022: connection has disconnected
  1353. [  203.691652] fusb302 4-0022: connection has disconnected
  1354. [  203.880773] fusb302 4-0022: connection has disconnected
  1355. [  204.069577] fusb302 4-0022: connection has disconnected
  1356. [  204.258106] fusb302 4-0022: connection has disconnected
  1357. [  204.446122] fusb302 4-0022: connection has disconnected
  1358. [  204.633574] fusb302 4-0022: connection has disconnected
  1359. [  204.821898] fusb302 4-0022: connection has disconnected
  1360. [  205.014303] fusb302 4-0022: connection has disconnected
  1361. [  205.214693] fusb302 4-0022: connection has disconnected
  1362. [  205.416565] fusb302 4-0022: connection has disconnected
  1363. [  205.619034] fusb302 4-0022: connection has disconnected
  1364. [  205.821185] fusb302 4-0022: connection has disconnected
  1365. [  206.021671] fusb302 4-0022: connection has disconnected
  1366. [  206.224213] fusb302 4-0022: connection has disconnected
  1367. [  206.427055] fusb302 4-0022: connection has disconnected
  1368. [  206.625686] fusb302 4-0022: connection has disconnected
  1369. [  206.826304] fusb302 4-0022: connection has disconnected
  1370. [  207.027186] fusb302 4-0022: connection has disconnected
  1371. [  207.219307] fusb302 4-0022: connection has disconnected
  1372. [  207.408158] fusb302 4-0022: connection has disconnected
  1373. [  207.595942] fusb302 4-0022: connection has disconnected
  1374. [  207.783130] fusb302 4-0022: connection has disconnected
  1375. [  207.968897] fusb302 4-0022: connection has disconnected
  1376. [  208.163182] fusb302 4-0022: connection has disconnected
  1377. [  208.350861] fusb302 4-0022: connection has disconnected
  1378. [  208.539401] fusb302 4-0022: connection has disconnected
  1379. [  208.727390] fusb302 4-0022: connection has disconnected
  1380. [  208.913879] fusb302 4-0022: connection has disconnected
  1381. [  209.102225] fusb302 4-0022: connection has disconnected
  1382. [  209.305097] fusb302 4-0022: connection has disconnected
  1383. [  209.512594] fusb302 4-0022: connection has disconnected
  1384. [  209.717340] fusb302 4-0022: connection has disconnected
  1385. [  209.922665] fusb302 4-0022: connection has disconnected
  1386. [  210.127162] fusb302 4-0022: connection has disconnected
  1387. [  210.332241] fusb302 4-0022: connection has disconnected
  1388. [  210.536022] fusb302 4-0022: connection has disconnected
  1389. [  210.735541] fusb302 4-0022: connection has disconnected
  1390. [  210.926438] fusb302 4-0022: connection has disconnected
  1391. [  211.116777] fusb302 4-0022: connection has disconnected
  1392. [  211.304855] fusb302 4-0022: connection has disconnected
  1393. [  211.491921] fusb302 4-0022: connection has disconnected
  1394. [  211.681793] fusb302 4-0022: connection has disconnected
  1395. [  211.868292] fusb302 4-0022: connection has disconnected
  1396. [  212.059289] fusb302 4-0022: connection has disconnected
  1397. [  212.257824] fusb302 4-0022: connection has disconnected
  1398. [  212.458716] fusb302 4-0022: connection has disconnected
  1399. [  212.659351] fusb302 4-0022: connection has disconnected
  1400. [  212.859355] fusb302 4-0022: connection has disconnected
  1401. [  213.059431] fusb302 4-0022: connection has disconnected
  1402. [  213.259164] fusb302 4-0022: connection has disconnected
  1403. [  213.459363] fusb302 4-0022: connection has disconnected
  1404. [  213.659120] fusb302 4-0022: connection has disconnected
  1405. [  213.860965] fusb302 4-0022: connection has disconnected
  1406. [  214.058559] fusb302 4-0022: connection has disconnected
  1407. [  214.255763] fusb302 4-0022: connection has disconnected
  1408. [  214.451577] fusb302 4-0022: connection has disconnected
  1409. [  214.645878] fusb302 4-0022: connection has disconnected
  1410. [  214.843651] fusb302 4-0022: connection has disconnected
  1411. [  215.040174] fusb302 4-0022: connection has disconnected
  1412. [  215.231545] fusb302 4-0022: connection has disconnected
  1413. [  215.420058] fusb302 4-0022: connection has disconnected
  1414. [  215.608158] fusb302 4-0022: connection has disconnected
  1415. [  215.794949] fusb302 4-0022: connection has disconnected
  1416. [  215.983299] fusb302 4-0022: connection has disconnected
  1417. [  216.177895] fusb302 4-0022: connection has disconnected
  1418. [  216.365918] fusb302 4-0022: connection has disconnected
  1419. [  216.553191] fusb302 4-0022: connection has disconnected
  1420. [  216.740863] fusb302 4-0022: connection has disconnected
  1421. [  216.929533] fusb302 4-0022: connection has disconnected
  1422. [  217.128688] fusb302 4-0022: connection has disconnected
  1423. [  217.329093] fusb302 4-0022: connection has disconnected
  1424. [  217.530093] fusb302 4-0022: connection has disconnected
  1425. [  217.730425] fusb302 4-0022: connection has disconnected
  1426. [  217.932978] fusb302 4-0022: connection has disconnected
  1427. [  218.131451] fusb302 4-0022: connection has disconnected
  1428. [  218.332425] fusb302 4-0022: connection has disconnected
  1429. [  218.530694] fusb302 4-0022: connection has disconnected
  1430. [  218.731762] fusb302 4-0022: connection has disconnected
  1431. [  218.932124] fusb302 4-0022: connection has disconnected
  1432. [  219.125682] fusb302 4-0022: connection has disconnected
  1433. [  219.316113] fusb302 4-0022: connection has disconnected
  1434. [  219.503658] fusb302 4-0022: connection has disconnected
  1435. [  219.691218] fusb302 4-0022: connection has disconnected
  1436. [  219.877851] fusb302 4-0022: connection has disconnected
  1437. [  220.065669] fusb302 4-0022: connection has disconnected
  1438. [  220.254383] fusb302 4-0022: connection has disconnected
  1439. [  220.442401] fusb302 4-0022: connection has disconnected
  1440. [  220.630387] fusb302 4-0022: connection has disconnected
  1441. [  220.818241] fusb302 4-0022: connection has disconnected
  1442. [  221.011892] fusb302 4-0022: connection has disconnected
  1443. [  221.212339] fusb302 4-0022: connection has disconnected
  1444. [  221.414779] fusb302 4-0022: connection has disconnected
  1445. [  221.617377] fusb302 4-0022: connection has disconnected
  1446. [  221.821577] fusb302 4-0022: connection has disconnected
  1447. [  222.019882] fusb302 4-0022: connection has disconnected
  1448. [  222.221225] fusb302 4-0022: connection has disconnected
  1449. [  222.422354] fusb302 4-0022: connection has disconnected
  1450. [  222.622708] fusb302 4-0022: connection has disconnected
  1451. [  222.825756] fusb302 4-0022: connection has disconnected
  1452. [  223.024913] fusb302 4-0022: connection has disconnected
  1453. [  223.217530] fusb302 4-0022: connection has disconnected
  1454. [  223.404952] fusb302 4-0022: connection has disconnected
  1455. [  223.592307] fusb302 4-0022: connection has disconnected
  1456. [  223.780584] fusb302 4-0022: connection has disconnected
  1457. [  223.967287] fusb302 4-0022: connection has disconnected
  1458. [  224.161611] fusb302 4-0022: connection has disconnected
  1459. [  224.349804] fusb302 4-0022: connection has disconnected
  1460. [  224.538315] fusb302 4-0022: connection has disconnected
  1461. [  224.726486] fusb302 4-0022: connection has disconnected
  1462. [  224.913855] fusb302 4-0022: connection has disconnected
  1463. [  225.101882] fusb302 4-0022: connection has disconnected
  1464. [  225.304161] fusb302 4-0022: connection has disconnected
  1465. [  225.507026] fusb302 4-0022: connection has disconnected
  1466. [  225.711478] fusb302 4-0022: connection has disconnected
  1467. [  225.916556] fusb302 4-0022: connection has disconnected
  1468. [  226.120372] fusb302 4-0022: connection has disconnected
  1469. [  226.322302] fusb302 4-0022: connection has disconnected
  1470. [  226.524912] fusb302 4-0022: connection has disconnected
  1471. [  226.725355] fusb302 4-0022: connection has disconnected
  1472. [  226.925795] fusb302 4-0022: connection has disconnected
  1473. [  227.120633] fusb302 4-0022: connection has disconnected
  1474. [  227.310560] fusb302 4-0022: connection has disconnected
  1475. [  227.498347] fusb302 4-0022: connection has disconnected
  1476. [  227.685665] fusb302 4-0022: connection has disconnected
  1477. [  227.872589] fusb302 4-0022: connection has disconnected
  1478. [  228.062099] fusb302 4-0022: connection has disconnected
  1479. [  228.249442] fusb302 4-0022: connection has disconnected
  1480. [  228.437136] fusb302 4-0022: connection has disconnected
  1481. [  228.625011] fusb302 4-0022: connection has disconnected
  1482. [  228.813173] fusb302 4-0022: connection has disconnected
  1483. [  229.004938] fusb302 4-0022: connection has disconnected
  1484. [  229.203547] fusb302 4-0022: connection has disconnected
  1485. [  229.405811] fusb302 4-0022: connection has disconnected
  1486. [  229.610089] fusb302 4-0022: connection has disconnected
  1487. [  229.813923] fusb302 4-0022: connection has disconnected
  1488. [  230.015080] fusb302 4-0022: connection has disconnected
  1489. [  230.218591] fusb302 4-0022: connection has disconnected
  1490. [  230.422302] fusb302 4-0022: connection has disconnected
  1491. [  230.622620] fusb302 4-0022: connection has disconnected
  1492. [  230.822038] fusb302 4-0022: connection has disconnected
  1493. [  231.024320] fusb302 4-0022: connection has disconnected
  1494. [  231.216414] fusb302 4-0022: connection has disconnected
  1495. [  231.403956] fusb302 4-0022: connection has disconnected
  1496. [  231.591276] fusb302 4-0022: connection has disconnected
  1497. [  231.779093] fusb302 4-0022: connection has disconnected
  1498. [  231.965726] fusb302 4-0022: connection has disconnected
  1499. [  232.160437] fusb302 4-0022: connection has disconnected
  1500. [  232.348478] fusb302 4-0022: connection has disconnected
  1501. [  232.536786] fusb302 4-0022: connection has disconnected
  1502. [  232.724630] fusb302 4-0022: connection has disconnected
  1503. [  232.914430] fusb302 4-0022: connection has disconnected
  1504. [  233.102928] fusb302 4-0022: connection has disconnected
  1505. [  233.305573] fusb302 4-0022: connection has disconnected
  1506. [  233.508278] fusb302 4-0022: connection has disconnected
  1507. [  233.712383] fusb302 4-0022: connection has disconnected
  1508. [  233.914173] fusb302 4-0022: connection has disconnected
  1509. [  234.115267] fusb302 4-0022: connection has disconnected
  1510. [  234.316968] fusb302 4-0022: connection has disconnected
  1511. [  234.520173] fusb302 4-0022: connection has disconnected
  1512. [  234.722711] fusb302 4-0022: connection has disconnected
  1513. [  234.925759] fusb302 4-0022: connection has disconnected
  1514. [  235.120597] fusb302 4-0022: connection has disconnected
  1515. [  235.310135] fusb302 4-0022: connection has disconnected
  1516. [  235.498479] fusb302 4-0022: connection has disconnected
  1517. [  235.686303] fusb302 4-0022: connection has disconnected
  1518. [  235.872245] fusb302 4-0022: connection has disconnected
  1519. [  236.061217] fusb302 4-0022: connection has disconnected
  1520. [  236.259699] fusb302 4-0022: connection has disconnected
  1521. [  236.460781] fusb302 4-0022: connection has disconnected
  1522. [  236.661468] fusb302 4-0022: connection has disconnected
  1523. [  236.861585] fusb302 4-0022: connection has disconnected
  1524. [  237.061886] fusb302 4-0022: connection has disconnected
  1525. [  237.262113] fusb302 4-0022: connection has disconnected
  1526. [  237.461526] fusb302 4-0022: connection has disconnected
  1527. [  237.663536] fusb302 4-0022: connection has disconnected
  1528. [  237.863716] fusb302 4-0022: connection has disconnected
  1529. [  238.063190] fusb302 4-0022: connection has disconnected
  1530. [  238.260105] fusb302 4-0022: connection has disconnected
  1531. [  238.457714] fusb302 4-0022: connection has disconnected
  1532. [  238.655011] fusb302 4-0022: connection has disconnected
  1533. [  238.850266] fusb302 4-0022: connection has disconnected
  1534. [  239.044757] fusb302 4-0022: connection has disconnected
  1535. [  239.236640] fusb302 4-0022: connection has disconnected
  1536. [  239.425906] fusb302 4-0022: connection has disconnected
  1537. [  239.614263] fusb302 4-0022: connection has disconnected
  1538. [  239.801331] fusb302 4-0022: connection has disconnected
  1539. [  239.989536] fusb302 4-0022: connection has disconnected
  1540. [  240.181899] fusb302 4-0022: connection has disconnected
  1541. [  240.269755] INFO: task swapper/0:1 blocked for more than 120 seconds.
  1542. [  240.270336]       Not tainted 4.4.52 #22
  1543. [  240.270716] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this
  1544. [  240.271407] swapper/0       D ffffff8008084e84     0     1      0 0x00000000
  1545. [  240.272065] Call trace:
  1546. [  240.272311] [<ffffff8008084e84>] __switch_to+0xb4/0xc0
  1547. [  240.272794] [<ffffff8008b9c2f8>] __schedule+0x3e4/0x62c
  1548. [  240.273260] [<ffffff8008b9c5c4>] schedule+0x84/0x98
  1549. [  240.273720] [<ffffff8008b9ed88>] schedule_timeout+0x34/0x21c
  1550. [  240.274224] [<ffffff8008b9d024>] wait_for_common+0x12c/0x16c
  1551. [  240.274746] [<ffffff8008b9d08c>] wait_for_completion+0x28/0x34
  1552. [  240.275269] [<ffffff8008481004>] drm_dev_wait+0x1c/0x24
  1553. [  240.275758] [<ffffff8008fcdc8c>] drm_misc_init+0x10/0x84
  1554. [  240.276234] [<ffffff8008082b48>] do_one_initcall+0xfc/0x180
  1555. [  240.276751] [<ffffff8008fa0d74>] kernel_init_freeable+0x1a8/0x248
  1556. [  240.277292] [<ffffff8008b9b130>] kernel_init+0x18/0x100
  1557. [  240.277775] [<ffffff8008082690>] ret_from_fork+0x10/0x40
  1558. [  240.278249] Kernel panic - not syncing: hung_task: blocked tasks
  1559. [  240.278787] CPU: 5 PID: 39 Comm: khungtaskd Not tainted 4.4.52 #22
  1560. [  240.279333] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (
  1561. [  240.279982] Call trace:
  1562. [  240.280211] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  1563. [  240.280694] [<ffffff8008088368>] show_stack+0x20/0x28
  1564. [  240.281149] [<ffffff8008386cf8>] dump_stack+0x8c/0xac
  1565. [  240.281602] [<ffffff800815de88>] panic+0xf4/0x23c
  1566. [  240.282026] [<ffffff8008127d60>] watchdog+0x2e0/0x30c
  1567. [  240.282478] [<ffffff80080b9284>] kthread+0xe4/0xec
  1568. [  240.282906] [<ffffff8008082690>] ret_from_fork+0x10/0x40
  1569. [  240.283405] CPU0: stopping
  1570. [  240.283679] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.52 #22
  1571. [  240.284214] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (
  1572. [  240.284867] Call trace:
  1573. [  240.285114] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  1574. [  240.285604] [<ffffff8008088368>] show_stack+0x20/0x28
  1575. [  240.286066] [<ffffff8008386cf8>] dump_stack+0x8c/0xac
  1576. [  240.286526] [<ffffff800808d944>] handle_IPI+0x134/0x240
  1577. [  240.286997] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
  1578. [  240.287497] Exception stack(0xffffffc07ff03000 to 0xffffffc07ff03130)
  1579. [  240.288076] 3000: ffffff80090c3d80 0000008000000000 ffffff80090c3eb0 ffffff80
  1580. [  240.288773] 3020: 0000000060000045 ffffff80091ae1a0 ffffffc07feff060 00000000
  1581. [  240.289471] 3040: ffffff80090c3eb0 ffffff80090c3d80 0000000000000000 00000000
  1582. [  240.290167] 3060: 0000000000000000 0000000000000000 0000000000000000 00000000
  1583. [  240.290863] 3080: 0000000000000000 0000000000000000 0000000000000000 00000000
  1584. [  240.291559] 30a0: 0000000000000000 0000000000000000 0000000000000000 00000000
  1585. [  240.292254] 30c0: 0000000000000000 0000000000000000 0000000000000000 00000000
  1586. [  240.292950] 30e0: 0000000000000000 0000000000000000 0000000000000000 00000000
  1587. [  240.293647] 3100: 0000000000000000 0000000000000000 0000000000000000 00000000
  1588. [  240.294340] 3120: 0000000000000000 0000000000000000
  1589. [  240.294780] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
  1590. [  240.295228] [<ffffff80088742c4>] cpuidle_enter_state+0x1fc/0x2a8
  1591. [  240.295771] [<ffffff80088743e4>] cpuidle_enter+0x34/0x40
  1592. [  240.296254] [<ffffff80080dd108>] cpu_startup_entry+0x26c/0x300
  1593. [  240.296780] [<ffffff8008b9b110>] rest_init+0x78/0x80
  1594. [  240.297231] [<ffffff8008fa0bb8>] start_kernel+0x3d4/0x3e8
  1595. [  240.297720] [<ffffff8008fa01c4>] __primary_switched+0x30/0x6c
  1596. [  240.298235] CPU4: stopping
  1597. [  240.298495] CPU: 4 PID: 0 Comm: swapper/4 Not tainted 4.4.52 #22
  1598. [  240.299027] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (
  1599. [  240.299678] Call trace:
  1600. [  240.299913] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  1601. [  240.300399] [<ffffff8008088368>] show_stack+0x20/0x28
  1602. [  240.300853] [<ffffff8008386cf8>] dump_stack+0x8c/0xac
  1603. [  240.301306] [<ffffff800808d944>] handle_IPI+0x134/0x240
  1604. [  240.301771] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
  1605. [  240.302266] Exception stack(0xffffffc07ff57000 to 0xffffffc07ff57130)
  1606. [  240.302840] 7000: ffffffc07965bdc0 0000008000000000 ffffffc07965bef0 ffffff80
  1607. [  240.303532] 7020: 0000000060000045 ffffff80091ae1a0 ffffffc07ff53060 00000000
  1608. [  240.304224] 7040: ffffffc07965bef0 ffffffc07965bdc0 0000000000000000 00000000
  1609. [  240.304914] 7060: 0000000000000000 0000000000000000 0000000000000000 00000000
  1610. [  240.305605] 7080: 0000000000000000 0000000000000000 0000000000000000 00000000
  1611. [  240.306295] 70a0: 0000000000000000 0000000000000000 0000000000000000 00000000
  1612. [  240.306985] 70c0: 0000000000000000 0000000000000000 0000000000000000 00000000
  1613. [  240.307676] 70e0: 0000000000000000 0000000000000000 0000000000000000 00000000
  1614. [  240.308365] 7100: 0000000000000000 0000000000000000 0000000000000000 00000000
  1615. [  240.309054] 7120: 0000000000000000 0000000000000000
  1616. [  240.309490] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
  1617. [  240.309933] [<ffffff80088742c4>] cpuidle_enter_state+0x1fc/0x2a8
  1618. [  240.310469] [<ffffff80088743e4>] cpuidle_enter+0x34/0x40
  1619. [  240.310948] [<ffffff80080dd108>] cpu_startup_entry+0x26c/0x300
  1620. [  240.311467] [<ffffff800808d46c>] secondary_start_kernel+0x184/0x190
  1621. [  240.312022] [<0000000000282978>] 0x282978
  1622. [  240.312386] CPU2: stopping
  1623. [  240.312647] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.4.52 #22
  1624. [  240.313181] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (
  1625. [  240.313832] Call trace:
  1626. [  240.314068] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  1627. [  240.314556] [<ffffff8008088368>] show_stack+0x20/0x28
  1628. [  240.315014] [<ffffff8008386cf8>] dump_stack+0x8c/0xac
  1629. [  240.315470] [<ffffff800808d944>] handle_IPI+0x134/0x240
  1630. [  240.315940] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
  1631. [  240.316439] Exception stack(0xffffffc07ff2d000 to 0xffffffc07ff2d130)
  1632. [  240.317017] d000: ffffffc07964fdc0 0000008000000000 ffffffc07964fef0 ffffff80
  1633. [  240.317715] d020: 0000000060000045 ffffff80091ae1a0 ffffffc07ff29060 00000000
  1634. [  240.318412] d040: ffffffc07964fef0 ffffffc07964fdc0 0000000000000000 00000000
  1635. [  240.319107] d060: 0000000000000000 0000000000000000 0000000000000000 00000000
  1636. [  240.319803] d080: 0000000000000000 0000000000000000 0000000000000000 00000000
  1637. [  240.320499] d0a0: 0000000000000000 0000000000000000 0000000000000000 00000000
  1638. [  240.321195] d0c0: 0000000000000000 0000000000000000 0000000000000000 00000000
  1639. [  240.321891] d0e0: 0000000000000000 0000000000000000 0000000000000000 00000000
  1640. [  240.322587] d100: 0000000000000000 0000000000000000 0000000000000000 00000000
  1641. [  240.323280] d120: 0000000000000000 0000000000000000
  1642. [  240.323720] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
  1643. [  240.324165] [<ffffff80088742c4>] cpuidle_enter_state+0x1fc/0x2a8
  1644. [  240.324706] [<ffffff80088743e4>] cpuidle_enter+0x34/0x40
  1645. [  240.325189] [<ffffff80080dd108>] cpu_startup_entry+0x26c/0x300
  1646. [  240.325714] [<ffffff800808d46c>] secondary_start_kernel+0x184/0x190
  1647. [  240.326273] [<0000000000282978>] 0x282978
  1648. [  240.326637] CPU1: stopping
  1649. [  240.326896] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.4.52 #22
  1650. [  240.327430] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (
  1651. [  240.328081] Call trace:
  1652. [  240.328317] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  1653. [  240.328806] [<ffffff8008088368>] show_stack+0x20/0x28
  1654. [  240.329263] [<ffffff8008386cf8>] dump_stack+0x8c/0xac
  1655. [  240.329721] [<ffffff800808d944>] handle_IPI+0x134/0x240
  1656. [  240.330191] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
  1657. [  240.330689] Exception stack(0xffffffc07ff18000 to 0xffffffc07ff18130)
  1658. [  240.331268] 8000: ffffffc07964bdc0 0000008000000000 ffffffc07964bef0 ffffff80
  1659. [  240.331965] 8020: 0000000060000045 ffffff80091ae1a0 ffffffc07ff14060 00000000
  1660. [  240.332662] 8040: ffffffc07964bef0 ffffffc07964bdc0 0000000000000000 00000000
  1661. [  240.333358] 8060: 0000000000000000 0000000000000000 0000000000000000 00000000
  1662. [  240.334054] 8080: 0000000000000000 0000000000000000 0000000000000000 00000000
  1663. [  240.334751] 80a0: 0000000000000000 0000000000000000 0000000000000000 00000000
  1664. [  240.335447] 80c0: 0000000000000000 0000000000000000 0000000000000000 00000000
  1665. [  240.336142] 80e0: 0000000000000000 0000000000000000 0000000000000000 00000000
  1666. [  240.336838] 8100: 0000000000000000 0000000000000000 0000000000000000 00000000
  1667. [  240.337531] 8120: 0000000000000000 0000000000000000
  1668. [  240.337972] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
  1669. [  240.338417] [<ffffff80088742c4>] cpuidle_enter_state+0x1fc/0x2a8
  1670. [  240.338958] [<ffffff80088743e4>] cpuidle_enter+0x34/0x40
  1671. [  240.339441] [<ffffff80080dd108>] cpu_startup_entry+0x26c/0x300
  1672. [  240.339966] [<ffffff800808d46c>] secondary_start_kernel+0x184/0x190
  1673. [  240.340523] [<0000000000282978>] 0x282978
  1674. [  240.340886] CPU3: stopping
  1675. [  240.341145] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.4.52 #22
  1676. [  240.341679] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (
  1677. [  240.342330] Call trace:
  1678. [  240.342566] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  1679. [  240.343054] [<ffffff8008088368>] show_stack+0x20/0x28
  1680. [  240.343512] [<ffffff8008386cf8>] dump_stack+0x8c/0xac
  1681. [  240.343968] [<ffffff800808d944>] handle_IPI+0x134/0x240
  1682. [  240.344439] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
  1683. [  240.344937] Exception stack(0xffffffc07ff42000 to 0xffffffc07ff42130)
  1684. [  240.345515] 2000: ffffffc079657dc0 0000008000000000 ffffffc079657ef0 ffffff80
  1685. [  240.346213] 2020: 0000000060000045 ffffff80091ae1a0 ffffffc07ff3e060 00000000
  1686. [  240.346910] 2040: ffffffc079657ef0 ffffffc079657dc0 0000000000000000 00000000
  1687. [  240.347607] 2060: 0000000000000000 0000000000000000 0000000000000000 00000000
  1688. [  240.348303] 2080: 0000000000000000 0000000000000000 0000000000000000 00000000
  1689. [  240.348999] 20a0: 0000000000000000 0000000000000000 0000000000000000 00000000
  1690. [  240.349695] 20c0: 0000000000000000 0000000000000000 0000000000000000 00000000
  1691. [  240.350391] 20e0: 0000000000000000 0000000000000000 0000000000000000 00000000
  1692. [  240.351087] 2100: 0000000000000000 0000000000000000 0000000000000000 00000000
  1693. [  240.351780] 2120: 0000000000000000 0000000000000000
  1694. [  240.352220] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
  1695. [  240.352665] [<ffffff80088742c4>] cpuidle_enter_state+0x1fc/0x2a8
  1696. [  240.353206] [<ffffff80088743e4>] cpuidle_enter+0x34/0x40
  1697. [  240.353688] [<ffffff80080dd108>] cpu_startup_entry+0x26c/0x300
  1698. [  240.354212] [<ffffff800808d46c>] secondary_start_kernel+0x184/0x190
  1699. [  240.354771] [<0000000000282978>] 0x282978
  1700. [  240.355135] CRU:
  1701. [  240.355323] 00000000: 00000044 00002201 80000000 00000108 00000007 00007f00 0
  1702. [  240.356083] 00000020: 00000044 00002201 80000000 00000108 00000007 00007f00 0
  1703. [  240.356843] 00000040: 00000037 00001201 8000031f 00000108 00000007 00007f00 0
  1704. [  240.357601] 00000060: 00000190 00001206 80000000 00000108 00000007 00007f00 0
  1705. [  240.358359] 00000080: 00000032 00001101 80000000 00000108 00000007 00007f00 0
  1706. [  240.359117] 000000a0: 00000190 00001206 80000000 00000108 00000007 00007f00 0
  1707. [  240.359875] 000000c0: 000000c6 00001202 8000031f 00000008 00000007 00007f00 0
  1708. [  240.360632] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1709. [  240.361389] 00000100: 00000100 00000202 00000140 00006202 00000047 00008743 0
  1710. [  240.362148] 00000120: 00000143 00004343 00000142 00000142 00004242 00008545 0
  1711. [  240.362906] 00000140: 0000010b 00000300 00004a87 00000113 00009382 0000838b 0
  1712. [  240.363664] 00000160: 0000834b 0000018b 00001745 0000001f 00000380 00000380 0
  1713. [  240.364422] 00000180: 00006380 00009200 00000200 00000200 00000200 00000200 0
  1714. [  240.365180] 000001a0: 00000000 00000000 00004242 00000421 00008b00 000002dc 0
  1715. [  240.365937] 000001c0: 00000182 00000001 00000003 0000008b 0000008b 00000142 0
  1716. [  240.366694] 000001e0: 0000853f 0000000b 0000971f 00009797 00009797 00008b8b 0
  1717. [  240.367452] 00000200: 000000d7 000000d7 00000000 00000000 00000000 00000000 0
  1718. [  240.368208] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1719. [  240.368964] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1720. [  240.369720] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1721. [  240.370479] 00000280: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0
  1722. [  240.371236] 000002a0: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 00000000 00000000 0
  1723. [  240.371993] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1724. [  240.372749] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1725. [  240.373506] 00000300: 00000000 00000000 00000000 00000000 00000030 00000000 0
  1726. [  240.374263] 00000320: 00008000 00000000 00000001 00000000 0000000a 00000031 0
  1727. [  240.375020] 00000340: 00000505 00000505 00000000 00000000 00000c04 00000000 0
  1728. [  240.375778] 00000360: 00000000 00000020 00000000 00000000 000000cc 00000000 0
  1729. [  240.376534] 00000380: 00002000 00000000 00000008 00000000 00000000 00000000 0
  1730. [  240.377290] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1731. [  240.378046] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1732. [  240.378802] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1733. [  240.379558] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1734. [  240.380315] 00000420: 00000000 00004070 00000000 00000014 00000000 00000000 0
  1735. [  240.381072] 00000440: 00000000 00000000 00000000 00000000 00001000 00000000 0
  1736. [  240.381828] 00000460: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1737. [  240.382585] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1738. [  240.383341] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1739. [  240.384097] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1740. [  240.384853] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1741. [  240.385610] 00000500: 00000000 00000000 00640064 00000000 00000003 00000000 0
  1742. [  240.386366] 00000520: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1743. [  240.387122] 00000540: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1744. [  240.387879] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1745. [  240.388632] 00000580: 00000004 00000000 00000004 00000946 00000004
  1746. [  240.389175] PMU CRU:
  1747. [  240.389387] 00000000: 000000a9 00001203 80000000 00000108 00000007 00007f00 0
  1748. [  240.390145] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1749. [  240.390904] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1750. [  240.391662] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1751. [  240.392422] 00000080: 0000070d 00001986 00000d0d 0000000d 000002dc 00000200 0
  1752. [  240.393181] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1753. [  240.393940] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1754. [  240.394697] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 0
  1755. [  240.395456] 00000100: 00000600 00000180 00000000 00000000 00000024 00000000 0
  1756. [  240.396211] 00000120: 00000000 00000180 00000000 00000000 00000000
  1757. [  240.396757] Kernel Offset: disabled
  1758. [  240.397069] Memory Limit: none
  1759. [  240.397357] rockchip-thermal ff260000.tsadc: channal 0: temperature(22 C)
  1760. [  240.397954] THERMAL REGS:
  1761. [  240.398204] 00000000: 00000200 00030133 00000031 00000002 00000000 00000000 0
  1762. [  240.398961] 00000020: 000001fd 000001fa 00000000 00000000 0000024e 00000000 0
  1763. [  240.399718] 00000040: 00000279 00000279 00000000 00000000 00000000 00000000 0
  1764. [  240.400476] 00000060: 00000004 00000004 00000753 00000753 00000000 00000000 0
  1765. [  240.401226] 00000080: 00000000 00000000
  1766. [  240.401576] ---[ end Kernel panic - not syncing: hung_task: blocked tasks
  1767. [  252.137485] Watchdog detected hard LOCKUP on cpu 0
  1768. [  252.137908] ------------[ cut here ]------------
  1769. [  252.138337] WARNING: at kernel/watchdog.c:352
  1770. [  252.138723] Modules linked in:
  1771. [  252.139003]
  1772. [  252.139148] CPU: 5 PID: 39 Comm: khungtaskd Not tainted 4.4.52 #22
  1773. [  252.139693] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (
  1774. [  252.140345] task: ffffffc0797924c0 ti: ffffffc078e40000 task.ti: ffffffc078e4
  1775. [  252.141011] PC is at watchdog_timer_fn+0x104/0x2f0
  1776. [  252.141440] LR is at watchdog_timer_fn+0x104/0x2f0
  1777. [  252.141867] pc : [<ffffff80081284c0>] lr : [<ffffff80081284c0>] pstate: 60000
  1778. [  252.142517] sp : ffffffc07ff6bde0
  1779. [  252.142814] x29: ffffffc07ff6bde0 x28: ffffff80090cdf70
  1780. [  252.143298] x27: 0000000000000000 x26: ffffff800908f1f8
  1781. [  252.143781] x25: ffffffc07ff6e210 x24: ffffffc078e43b60
  1782. [  252.144263] x23: 0000000000000000 x22: 0000000000000000
  1783. [  252.144744] x21: ffffff80090cc000 x20: ffffff800908f270
  1784. [  252.145226] x19: ffffff800908f000 x18: 0000000030d00800
  1785. [  252.145707] x17: 0000000000000000 x16: 0000000000000000
  1786. [  252.146187] x15: 0000000000000000 x14: 0ffffffffffffffd
  1787. [  252.146668] x13: 0000000000000000 x12: 0101010101010101
  1788. [  252.147149] x11: 7f7f7f7f7f7f7f7f x10: fefefefefefefeff
  1789. [  252.147630] x9 : 7f7f7f7f7f7f7f7f x8 : 4c20647261682064
  1790. [  252.148110] x7 : 6574636574656420 x6 : ffffff800921982d
  1791. [  252.148590] x5 : 0000000000000002 x4 : 0000000000000005
  1792. [  252.149071] x3 : 0000000000000000 x2 : 0000000000000001
  1793. [  252.149551] x1 : 00000000000001c0 x0 : 0000000000000026
  1794. [  252.150033]
  1795. [  252.150033] PC: 0xffffff8008128440:
  1796. [  252.150475] 8440  b9401c00 f90033a3 f90037a4 97fffeb4 2a0003fb 90007d20 b94f0
  1797. [  252.151252] 8460  54000382 d50339bf b0007d3c 91002281 913dc39c f94037a4 f87b5
  1798. [  252.152024] 8480  34000085 f94033a3 38226823 14000011 91020280 f8626b41 f8626
  1799. [  252.152797] 84a0  eb01007f 54000e40 f8226801 f87b5b80 38206a85 14000007 2a1b0
  1800. [  252.153570] 84c0  d4210000 f87b5b80 52800021 38206a81 9107a274 913d62ba d538d
  1801. [  252.154341] 84e0  f8606820 97fe764c f9401b20 f9401f42 f90037a2 f9401000 d63f0
  1802. [  252.155114] 8500  f94037a2 aa1903e0 97ff55b8 b50000f6 91022694 d538d080 38746
  1803. [  252.155886] 8520  38346816 14000019 97fe8afc 90007d21 f947ac21 36080921 b9403
  1804. [  252.156660]
  1805. [  252.156660] LR: 0xffffff8008128440:
  1806. [  252.157101] 8440  b9401c00 f90033a3 f90037a4 97fffeb4 2a0003fb 90007d20 b94f0
  1807. [  252.157874] 8460  54000382 d50339bf b0007d3c 91002281 913dc39c f94037a4 f87b5
  1808. [  252.158646] 8480  34000085 f94033a3 38226823 14000011 91020280 f8626b41 f8626
  1809. [  252.159419] 84a0  eb01007f 54000e40 f8226801 f87b5b80 38206a85 14000007 2a1b0
  1810. [  252.160192] 84c0  d4210000 f87b5b80 52800021 38206a81 9107a274 913d62ba d538d
  1811. [  252.160965] 84e0  f8606820 97fe764c f9401b20 f9401f42 f90037a2 f9401000 d63f0
  1812. [  252.161736] 8500  f94037a2 aa1903e0 97ff55b8 b50000f6 91022694 d538d080 38746
  1813. [  252.162507] 8520  38346816 14000019 97fe8afc 90007d21 f947ac21 36080921 b9403
  1814. [  252.163281]
  1815. [  252.163281] SP: 0xffffffc07ff6bd60:
  1816. [  252.163721] bd60  00000000 00000000 00000000 00000000 78e43b60 ffffffc0 7ff6e
  1817. [  252.164494] bd80  0908f1f8 ffffff80 00000000 00000000 090cdf70 ffffff80 7ff6b
  1818. [  252.165267] bda0  081284c0 ffffff80 7ff6bde0 ffffffc0 081284c0 ffffff80 60000
  1819. [  252.166039] bdc0  090ccf58 ffffff80 00000000 00000000 00000000 00000080 fffff
  1820. [  252.166812] bde0  7ff6be50 ffffffc0 080fe76c ffffff80 7ff6e210 ffffffc0 7ff6d
  1821. [  252.167583] be00  7ff6dc40 ffffffc0 00000001 00000000 0920a24f ffffff80 090cb
  1822. [  252.168356] be20  081283bc ffffff80 af2c09dd 0000003a 0920a000 ffffff80 78e40
  1823. [  252.169127] be40  00000000 00000000 090ccf58 ffffff80 7ff6bec0 ffffffc0 080fe
  1824. [  252.169906]
  1825. [  252.169906] X6: 0xffffff80092197ad:
  1826. [  252.170346] 97ac  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1827. [  252.171120] 97cc  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1828. [  252.171892] 97ec  00000000 00000001 00000000 30303020 32303330 39383130 39205
  1829. [  252.172663] 980c  312e3235 30393936 58205d36 30203a36 66666678 38666666 32393
  1830. [  252.173435] 982c  300a3a64 32313830 30633438 70205d3e 74617473 36203a65 30303
  1831. [  252.174207] 984c  2030300a 30303030 30303030 4830300a 6964205a 203d2076 730a2
  1832. [  252.174978] 986c  275d305b 65730a0a 7665645f 71657266 696e695f 3b292874 63757
  1833. [  252.175749] 988c  696e6920 676e6974 776f7020 6d5f7265 6c65646f 6d69735f 2e656
  1834. [  252.176522] 98ac  66666666 64626666 66666662 30303030 28202020 32202020 47203
  1835. [  252.177303]
  1836. [  252.177303] X19: 0xffffff800908ef80:
  1837. [  252.177750] ef80  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1838. [  252.178522] efa0  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1839. [  252.179293] efc0  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1840. [  252.180065] efe0  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1841. [  252.180837] f000  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1842. [  252.181608] f020  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1843. [  252.182379] f040  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1844. [  252.183151] f060  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1845. [  252.183926]
  1846. [  252.183926] X20: 0xffffff800908f1f0:
  1847. [  252.184373] f1f0  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1848. [  252.185145] f210  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1849. [  252.185915] f230  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1850. [  252.186687] f250  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1851. [  252.187459] f270  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1852. [  252.188231] f290  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1853. [  252.189003] f2b0  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1854. [  252.189774] f2d0  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1855. [  252.190548]
  1856. [  252.190548] X21: 0xffffff80090cbf80:
  1857. [  252.190996] bf80  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1858. [  252.191767] bfa0  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1859. [  252.192538] bfc0  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1860. [  252.193309] bfe0  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1861. [  252.194080] c000  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1862. [  252.194852] c020  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1863. [  252.195623] c040  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1864. [  252.196395] c060  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1865. [  252.197172]
  1866. [  252.197172] X24: 0xffffffc078e43ae0:
  1867. [  252.197619] 3ae0  0000003d 00000000 00000000 00000000 00000000 00000000 00000
  1868. [  252.198391] 3b00  0925c05a ffffff80 00000000 00000000 0003211c 00000000 00000
  1869. [  252.199165] 3b20  78e43b40 ffffffc0 090e5680 ffffff80 08e27177 ffffff80 00000
  1870. [  252.199935] 3b40  78e43be0 ffffffc0 080e9868 ffffff80 08e22f2a ffffff80 09216
  1871. [  252.200707] 3b60  6c64e51b 00000001 000016a4 00000000 000003e8 00000000 00000
  1872. [  252.201478] 3b80  00000005 00000000 00000002 00000000 09219844 ffffff80 6e756
  1873. [  252.202251] 3ba0  203a6b73 636f6c62 7f7f7f7f 7f7f7f7f fefefeff fefefefe 7f7f7
  1874. [  252.203024] 3bc0  01010101 01010101 00000000 00000000 fffffffd 0fffffff 00000
  1875. [  252.203798]
  1876. [  252.203798] X25: 0xffffffc07ff6e190:
  1877. [  252.204246] e190  ffffffff 00000000 ffffffff ffffffff 00000001 00000000 7ff6e
  1878. [  252.205019] e1b0  7ff6e1a8 ffffffc0 7ff6e1b8 ffffffc0 7ff6e1b8 ffffffc0 08126
  1879. [  252.205791] e1d0  79517cf8 ffffffc0 79517c40 ffffffc0 00020002 00000000 00000
  1880. [  252.206563] e1f0  00000001 00000000 0000003f 00000000 0000003c 00000000 796eb
  1881. [  252.207335] e210  7ff6e210 ffffffc0 7ff6e080 ffffffc0 00000000 00000000 af2c0
  1882. [  252.208106] e230  af2c01c0 0000003a 081283bc ffffff80 7ff6dc40 ffffffc0 00000
  1883. [  252.208879] e250  0812838c ffffff80 63746177 676f6468 0000352f 00000000 00000
  1884. [  252.209652] e270  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1885. [  252.210425]
  1886. [  252.210425] X26: 0xffffff800908f178:
  1887. [  252.210872] f178  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1888. [  252.211643] f198  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1889. [  252.212415] f1b8  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1890. [  252.213187] f1d8  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1891. [  252.213958] f1f8  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1892. [  252.214729] f218  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1893. [  252.215501] f238  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1894. [  252.216273] f258  00000000 00000000 00000000 00000000 00000000 00000000 00000
  1895. [  252.217046]
  1896. [  252.217046] X28: 0xffffff80090cdef0:
  1897. [  252.217494] def0  00000001 00000000 00000001 00000000 000003e8 00000000 7ff7d
  1898. [  252.218266] df10  00000015 00000000 7ff7d500 ffffffc0 00000001 00000000 00000
  1899. [  252.219039] df30  00015000 00000000 7ff7d5c0 ffffffc0 7ff7d580 ffffffc0 00000
  1900. [  252.219810] df50  00000006 00000000 00000005 00000010 7ff7d400 ffffffc0 7feff
  1901. [  252.220583] df70  76e76000 00000040 76e8b000 00000040 76ea0000 00000040 76eb5
  1902. [  252.221354] df90  76eca000 00000040 76edf000 00000040 00000000 00000000 00000
  1903. [  252.222125] dfb0  00000002 00000000 00001415 00000000 00010000 00000000 0007f
  1904. [  252.222897] dfd0  0000effd 00000000 00002000 00000000 00000000 0000fffa 00000
  1905. [  252.223669]
  1906. [  252.223669] X29: 0xffffffc07ff6bd60:
  1907. [  252.224117] bd60  00000000 00000000 00000000 00000000 78e43b60 ffffffc0 7ff6e
  1908. [  252.224890] bd80  0908f1f8 ffffff80 00000000 00000000 090cdf70 ffffff80 7ff6b
  1909. [  252.225660] bda0  081284c0 ffffff80 7ff6bde0 ffffffc0 081284c0 ffffff80 60000
  1910. [  252.226432] bdc0  090ccf58 ffffff80 00000000 00000000 00000000 00000080 fffff
  1911. [  252.227204] bde0  7ff6be50 ffffffc0 080fe76c ffffff80 7ff6e210 ffffffc0 7ff6d
  1912. [  252.227976] be00  7ff6dc40 ffffffc0 00000001 00000000 0920a24f ffffff80 090cb
  1913. [  252.228749] be20  081283bc ffffff80 af2c09dd 0000003a 0920a000 ffffff80 78e40
  1914. [  252.229522] be40  00000000 00000000 090ccf58 ffffff80 7ff6bec0 ffffffc0 080fe
  1915. [  252.230294]
  1916. [  252.230434] ---[ end trace c883920977d80508 ]---
  1917. [  252.230843] Call trace:
  1918. [  252.231067] Exception stack(0xffffffc07ff6bc10 to 0xffffffc07ff6bd40)
  1919. [  252.231638] bc00:                                   ffffff800908f000 00000080
  1920. [  252.232330] bc20: ffffffc07ff6bde0 ffffff80081284c0 ffffff80090e5680 00000000
  1921. [  252.233021] bc40: ffffffc07ff6bc60 ffffff80090e5680 ffffff8008e27177 00000000
  1922. [  252.233712] bc60: ffffffc07ff6bd00 ffffff80080e9868 ffffff8008e2a2af ffffff80
  1923. [  252.234403] bc80: ffffff80090cc000 0000000000000000 0000000000000000 ffffffc0
  1924. [  252.235094] bca0: ffffffc07ff6e210 ffffff800908f1f8 0000000000000026 00000000
  1925. [  252.235785] bcc0: 0000000000000001 0000000000000000 0000000000000005 00000000
  1926. [  252.236476] bce0: ffffff800921982d 6574636574656420 4c20647261682064 7f7f7f7f
  1927. [  252.237167] bd00: fefefefefefefeff 7f7f7f7f7f7f7f7f 0101010101010101 00000000
  1928. [  252.237858] bd20: 0ffffffffffffffd 0000000000000000 0000000000000000 00000000
  1929. [  252.238553] [<ffffff80081284c0>] watchdog_timer_fn+0x104/0x2f0
  1930. [  252.239078] [<ffffff80080fe76c>] __hrtimer_run_queues+0x164/0x290
  1931. [  252.239621] [<ffffff80080fea88>] hrtimer_interrupt+0xac/0x1c4
  1932. [  252.240139] [<ffffff800889a9d0>] arch_timer_handler_phys+0x3c/0x48
  1933. [  252.240690] [<ffffff80080eea08>] handle_percpu_devid_irq+0xc4/0x178
  1934. [  252.241252] [<ffffff80080ea394>] generic_handle_irq+0x30/0x44
  1935. [  252.241766] [<ffffff80080ea6fc>] __handle_domain_irq+0x90/0xc0
  1936. [  252.242283] [<ffffff8008080dfc>] gic_handle_irq+0xcc/0x188
  1937. [  252.242768] Exception stack(0xffffffc07ff6c000 to 0xffffffc07ff6c130)
  1938. [  252.243340] c000: ffffffc078e43b60 0000008000000000 ffffffc078e43c90 ffffff80
  1939. [  252.244031] c020: 0000000080000045 ffffff80090cc000 ffffffc07ff68060 00000000
  1940. [  252.244721] c040: ffffffc078e43c90 ffffffc078e43b60 0000000000000000 00000000
  1941. [  252.245412] c060: 0000000000000000 0000000000000000 0000000000000000 00000000
  1942. [  252.246102] c080: 0000000000000000 0000000000000000 0000000000000000 00000000
  1943. [  252.246792] c0a0: 0000000000000000 0000000000000000 0000000000000000 00000000
  1944. [  252.247483] c0c0: 0000000000000000 0000000000000000 0000000000000000 00000000
  1945. [  252.248173] c0e0: 0000000000000000 0000000000000000 0000000000000000 00000000
  1946. [  252.248864] c100: 0000000000000000 0000000000000000 0000000000000000 00000000
  1947. [  252.249553] c120: 0000000000000000 0000000000000000
  1948. [  252.249988] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
  1949. [  252.250426] [<ffffff80083856a4>] __delay+0x24/0x48
  1950. [  252.250855] [<ffffff80083856ec>] __const_udelay+0x24/0x2c
  1951. [  252.251336] [<ffffff800815dfc4>] panic+0x230/0x23c
  1952. [  252.251766] [<ffffff8008127d60>] watchdog+0x2e0/0x30c
  1953. [  252.252217] [<ffffff80080b9284>] kthread+0xe4/0xec
  1954. [  252.252645] [<ffffff8008082690>] ret_from_fork+0x10/0x40
Copy the code
vip
Rank: 6Rank: 6
Posted at 1/14/2019 17:22:16        Only Author  10#
Hello @navigatoria , you can contact the sale service for warranty.
The last time I check, it only cost you freight from France to China.
Once the board is received and repaired, it'll send to you, with
the freight covered by us.
Return to List
12
