[Hardware] Camera Color
198
【Hardware】 Camera Color
Posted at 4/6/2019 10:48:06      View:6232 | Replies:6        Print      Only Author   [Copy Link] 1#
I had ROC-RK3399-PC with OV13850
I sucessed Camera Operation
But Color is not normal
Green color is too strong. what is the error?
I used gst-launch-1.0
gst-launch-1.0 v4l2src device=/dev/video0 io-mode=4 ! videoconvert  ! video/x-raw,format=NV12,width=640,height=480 ! autovideosink
vip
Rank: 6Rank: 6
Posted at 4/8/2019 09:23:43        Only Author  2#
It is required to use ISP to adjust the color, afaik.
Check this thread and script inside:
http://bbs.t-firefly.com/forum.p ... &extra=page%3D1
Posted at 4/8/2019 18:23:30        Only Author  3#
thanks..I did it
I needed 3 libraries
1.librkisp.so
2.libgstrkisp.so
3.libxcam_core.so.1  and  libxcam_rkisp.so.1
and run dual-camera-rkisp.sh
Posted at 8/30/2019 19:13:28        Only Author  4#
How did you connect the camera to the board? According to the schematic (https://drive.google.com/drive/f ... aXNTOHIxSDRGOFV4RDA) the OV13850 is a 30 pin camera, while the ROC-RK3399-PC only has 24 pin connectors?
vip
Rank: 6Rank: 6
Posted at 9/4/2019 09:12:52        Only Author  5#
There're two models of OV13850 camera, one is 30pin, the other is 24pin.
Posted at 1/30/2026 06:44:53        Only Author  6#
Sie brauchen nicht so viel Geld und Zeit, nur ungefähr 30 Stunden spezielle Ausbildung, dann können Sie ganz einfach die Palo Alto Networks SD-WAN-Engineer Zertifizierungsprüfung nur einmalig bestehen. ZertPruefung bietet Ihnen die Prüfungsthemen, deren Ähnlichkeit mit den realen Prüfungsübungen sehr groß ist.
Posted at 2/17/2026 17:38:43        Only Author  7#
This article is simply outstanding, thank you for sharing it. This is the PRINCE2Practitioner Exam Guide test that helped me achieve a promotion and raise. It's available to you for free today, and I wish you success in reaching your career goals.
