New Topic
[Linux] AIO-3399C rs232 transfers
11
【Linux】 AIO-3399C rs232 transfers
Posted at 4/26/2019 02:07:52      View:6811 | Replies:9        Print      Only Author   [Copy Link] 1#
I need to transmit/receive data via rs232. AFAIK, AIO-3399C has 4 serial ports. I try to use /dev/ttyS0. It doesn't work. On other end of serial channel sent data aren't received and data sent from other end  aren't received at AIO-3399C. 'setserial' shows only one working serial port of four. I use standard kernel and rootfile from linux-SDK. What should I do to  solve the problem? 'setserial' output is below:
$ setserial -g /dev/ttyS[0123]
/dev/ttyS0, UART: 16550A, Port: 0x0000, IRQ: 37
/dev/ttyS1, UART: unknown, Port: 0x0000, IRQ: 0
/dev/ttyS2: Device or resource busy
/dev/ttyS3, UART: unknown, Port: 0x0000, IRQ: 0
Thank you.
Posted at 4/28/2019 14:37:14        Only Author  2#
Other ttyS had been used by other function.
Seeing link below . There are something new uart you can use.
http://wiki.t-firefly.com/en/AIO-3399J/driver_uart.html
Posted at 6/19/2019 22:51:15        Only Author  3#
I see the below for teh AIO-3399C but the RS232 didn't work for me on /dev/ttysWK1, I connected a USB to RS232 and it worked on /dev/ttyUSB0.
Using the image AIO-3399C-LVDS-UBUNTU18.04-GPT-20190304-1222.img
http://wiki.t-firefly.com/en/AIO-3399C/driver_uart.html
Is anyone successful in using the RS232 on AIO-3399C?
vip
Rank: 6Rank: 6
Posted at 6/24/2019 11:29:07        Only Author  4#
Plz post the hardware connection picture, the kernel device tree setting (related to the series ports) and the test commands so that others can help you.
Posted at 3/2/2022 01:58:45        Only Author  5#
I can confirm that RS232 on the AIO-3399C does not work as described. I followed the steps described here: https://wiki.t-firefly.com/en/AIO-3399J/driver_uart.html
And I tried accessing the ports via Java. No luck, no data is transferred.
Maybe its because parity, stop bits, etc are wrong – but this is not documented, so this is hard to tell.
Posted at 1/11/2026 19:48:00        Only Author  6#
This article really inspired me, thanks for sharing! The Valid DP-900 test guide exam questions are now available for free. Good luck to everyone!
Posted at 1/12/2026 03:52:12        Only Author  7#
The article is absolutely magnificent, thank you for sharing it with us. Wishing you success! Here are the free Pdf NCP-US-6.10 version resources for you!
Posted at 1/14/2026 13:11:38        Only Author  8#
The article was a real source of knowledge for me. Good luck on your exams! Free access to Valid SPLK-4001 exam materials questions now available!
Posted at 1/23/2026 21:11:28        Only Author  9#
I’m really inspired after reading this article, thanks so much for sharing! Free New C-THR96-2505 test testking resources for exam success. Wishing you the best!
Posted at 1/28/2026 08:39:49        Only Author  10#
I’m left in awe by your article, thank you for sharing this treasure! Sharing with you the Valid CHFM exam duration test that helped me get my promotion and raise. It’s free for all today—good luck with your career!
Return to List
12
