Dual boot on Firefly-RK3288
10
Posted at 1/10/2015 14:02:54      View:12215 | Replies:6        Print      Only Author   [Copy Link] 1#
Brief introduction
As we all know the Firefly-RK3288 supported by Ubuntu and Android. So it’s excellent to realize the dual boot on Firefly.
Now let’s take a look at the dual boot on Firefly-RK3288.
Recovery mode
There is a recovery mode on Android. It runs independent image including the kernel and initramfs in recovery partitionThis partition is the best place for Linux.
Partition
Let’s take a look at the partition on Android. You can get the information by CMDLINE in parameter file.
  1. FIRMWARE_VER:4.4.2
  2. MACHINE_MODEL:rk30sdk
  3. MACHINE_ID:007
  4. MANUFACTURER:RK30SDK
  5. MAGIC: 0x5041524B
  6. ATAG: 0x60000800
  7. MACHINE: 3066
  8. CHECK_MASK: 0x80
  9. PWR_HLD: 0,0,A,0,1
  10. #KERNEL_IMG: 0x62008000
  11. #FDT_NAME: rk-kernel.dtb
  12. #RECOVER_KEY: 1,1,0,20,0
  13. CMDLINE:console=ttyFIQ0 androidboot.hardware=rk30board androidboot.console=ttyFIQ0 board.ap_has_alsa=0 init=/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00020000@0x00414000(radical_update),-@0x00434000(user)
Copy the code
The CMDLINE will be sent to kernel. The “mtdparts” indicates the partition, the format shows as the follow.
  1. 0x00002000@0x00002000(uboot)
  2.   Size                offset        partition name
  3. The unit is 512 bytes (i.e. traditional disk sector size).
Copy the code
The partition information above turn into a table shows as below
Size(Byte)
Partition name
4M
uboot
4M
misc
16M
resource
16M
kernel
32M
boot
32M
recovery
52M
backup
128M
cache
4M
kpanic
768M
system
4M
metadata
1G
userdata
64M
radical_update
Full size-2152M
user
  • Uboot: this is used to store the stage two of u-boot. The Firefly-RK3288 uses the eMMC instead the flash, so u-boot needn’t to be divided into two stage. That explains why the uboot partition is not used on Firefly.
  • Misc: This partition is used to control the boot mode. The following will introduce about this.
  • Resource: store the boot pictures and the information about Device Tree.
  • Kernel: storage for kernel.
  • Boot: storage for initramfs of normal boot. Note that, while OTA upgrade, both  boot partition and recovery partition store the initramfs, the kernel partition doesn’t work at this moment.
  • Recovery: storage for kernel and initramfs which enter recovery mode needs.
  • Backup: It’s designed by Rockchip and used for backup image storage. However, it’s useless for Firefly-RK3288.
  • Cache: cache partition for Android.
  • Kpanic: the kernel panic for Android.
  • System: the system partition for Android.(mount point is  /system)
  • Metadata: metadata partition of Rockchip. Unknown function.
  • Userdata: data partition of Android(mount point is /data)
  • Radical_update: the update partition of Rockchip. Unknown function.
  • User: internal storage partition(mount point is /mnt/sdcard)
In order to boot Linux from Android, we need to add a “linuxroot” partition to store root file system of Linux. We choose to replace the radical_update partition and give 3G for this partition so as to be compatible.
1G
userdata
3136M
linuxroot
Full size-5224M
user
Modify the parameter file and set the CMDLINE as below.
  1. CMDLINE:console=ttyFIQ0 androidboot.hardware=rk30board androidboot.console=ttyFIQ0 board.ap_has_alsa=0 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00620000@0x00414000(linuxroot),-@0x00a34000(user)
Copy the code
How to boot Linux.
Then, we will talk about how to boot Linux. Due to the Linux is stored in recovery disk, so boot Linux equal to enter the recovery mode. Here are some ways to get to this point.
1. Unplug USB cable, press the revocery key on Firefly and turn on it.(no mater first power on, reboot or press the reset key). This way is temporary switch. If you don’t press the recovery key next time will not reach to the recovery mode(boot Linux).
2. Restore the factory setting in the Android setting. Actrually, restore factory setting function has been remove from Android. If hasn’t been remove, this may help you boot Linux.
3. Firelfy-RK3288 add an switch system option at the shutdown menu(click the shutdown button at the bottom of the screen) for Android.
4. Flash the rkst/Image/misc.img of SDK to misc partition.
Step 2 to 4 are switch to recovery mode through write misc partition. This is a way to boot Linux for Android.
You can check the content of misc.img using hexdump command.
  1. $ hexdump -C rkst/Image/misc.img
  2. 00000000  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
  3. *
  4. 00004000  62 6f 6f 74 2d 72 65 63  6f 76 65 72 79 00 00 00  |boot-recovery...|
  5. 00004010  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
  6. *
  7. 00004040  72 65 63 6f 76 65 72 79  0a 2d 2d 77 69 70 65 5f  |recovery.--wipe_|
  8. 00004050  61 6c 6c 00 00 00 00 00  00 00 00 00 00 00 00 00  |all.............|
  9. 00004060  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
  10. *
  11. 0000c000
Copy the code
From the massage above, you can see the first 16K(0x4000)Byte are 0, and are followed by a “boot-recovery”, “recovery”and “--wipe_all” command.
Boot bootloader(means  u-boot) will read the content from this partition. If boot the “boot-recovery”,that will load the recovery partition.
First boot
Although remove the restore factory setting function from Android, the initial setting still necessary.
We add a symbol file “/firstboot”to Linux root file system. Once detect this file is exist while boot the Linux,the system will take this boot as the first boot and will do the follow initial setting.
  • Expand the root file system using resize2fs and fix size of the file system.
  • Format the userdata partition
  • Format the cache partition
  • Format the metadata partition
  • Format the user partition
  • Delet the symble file “/firstboot”
  • Back to the Android system.
See “etc/rc.local”for More realization details.
  1. /usr/local/bin/mtd-by-name.sh
  2. if [ -e /firstboot ]; then
  3.     echo "======Expanding the rootfs..."
  4.     resize2fs /dev/block/mtd/by-name/linuxroot
  5.     if [ -e /dev/block/mtd/by-name/userdata ]; then
  6.         echo "=======Formatting userdata(/data)..."
  7.         mkfs.ext4 /dev/block/mtd/by-name/userdata
  8.         echo "=======Formatting metadata(/metadata)..."
  9.         mkfs.ext4 /dev/block/mtd/by-name/metadata
  10.         echo "=======Formatting cache(/cache)..."
  11.         mkfs.ext4 /dev/block/mtd/by-name/cache
  12.         echo "=======Formatting user(/sdcard)..."
  13.         mkfs.vfat /dev/block/mtd/by-name/user
  14.         # reboot to android
  15.         dd if=/dev/zero of=/dev/block/mtd/by-name/misc bs=16k count=3
  16.         rm -f /firstboot
  17.         sync
  18.         reboot
  19.     fi
  20.     rm -f /firstboot
  21. fi
Copy the code
How to switch Linux from Android
Write a script to format the misc partition and reboot. Then you can switch back to Linux.
  1. sudo dd if=/dev/zero of=/dev/block/mtd/by-name/misc bs=16k count=3
  2. sudo reboot
Copy the code
The script is /usr/local/bin/b2android.sh.
Posted at 1/10/2015 16:59:00        Only Author  2#
Yeah!!!?
This is a great 3ad!!! Thanks a lot for these details. I think that now I can grab some info about how to manage the parameter file!! And this is what i was searching for!!
Thanks a lot Andy!
Posted at 1/16/2015 01:57:20        Only Author  3#
Andy, again you have answered many of my questions, other than the "dual Boot".  Thanks for the tutorial on the parameter.
Posted at 1/26/2026 04:57:30        Only Author  4#
Your article really stuck with me, I’m sincerely grateful. The Valid practice CIS-HAM test fee exam is upon me. Wish me the best of luck!
Posted at 2/1/2026 08:28:47        Only Author  5#
我們Testpdf提供的培訓工具包含我們的IT專家團隊研究出來的備考心得和相關的考試材料。也有關於IBM C1000-189認證考試的考試練習題和答案。以我們Testpdf在IT行業中的高信譽度可以給你提供100%的保障,為了讓你更安心的選擇購買我們,你可以先嘗試在網上下載我們提供的關於IBM C1000-189認證考試的部分考題及答案。
