RK-3399 PC turns off when an application is opened.
Posted at 8/9/2019 16:48:03
RK 3399-PC automatically tuns off when I open Chromium Browser. Please find the attached log.
- [ 1.040514] usbcore: registered new interface driver sierra
- [ 1.041036] usbserial: USB Serial support registered for Sierra USB modem
- [ 1.042783] usbcore: registered new interface driver usbtouchscreen
- [ 1.043588] .. rk pwm remotectl v1.1 init
- [ 1.044201] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
- [ 1.045287] sensor_register_slave:mma8452,id=17
- [ 1.045708] sensor_register_slave:lis3dh,id=7
- [ 1.046100] sensor_register_slave:mma7660,id=18
- [ 1.046504] sensor_register_slave:lsm303d,id=22
- [ 1.046917] sensor_register_slave:gs_mc3230,id=23
- [ 1.047337] [Gsensor] gsensor_init
- [ 1.047667] sensor_register_slave:mpu6880_acc,id=24
- [ 1.048105] sensor_register_slave:mpu6500_acc,id=25
- [ 1.048542] sensor_register_slave:lsm330_acc,id=26
- [ 1.048976] sensor_register_slave:akm8975,id=30
- [ 1.049379] sensor_register_slave:akm8963,id=31
- [ 1.049789] sensor_register_slave:l3g4200d,id=45
- [ 1.050203] sensor_register_slave:l3g20d,id=46
- [ 1.050605] sensor_register_slave:ewtsa,id=47
- [ 1.051003] sensor_register_slave:lsm330_gyro,id=51
- [ 1.051441] sensor_register_slave:cm3217,id=53
- [ 1.051850] sensor_register_slave:cm3218,id=54
- [ 1.052784] i2c /dev entries driver
- [ 1.054370] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
- [ 1.055067] fan53555-reg: supplied by vcc5v0_sys
- [ 1.057860] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
- [ 1.058524] fan53555-reg: supplied by vcc5v0_sys
- [ 1.061370] rk808 0-001b: Pmic Chip id: 0x0
- [ 1.065258] rk808-regulator rk808-regulator: there is no dvs0 gpio
- [ 1.065872] rk808-regulator rk808-regulator: there is no dvs1 gpio
- [ 1.066510] DCDC_REG1: supplied by vcc3v3_sys
- [ 1.067705] DCDC_REG2: supplied by vcc3v3_sys
- [ 1.068717] DCDC_REG3: supplied by vcc3v3_sys
- [ 1.069422] DCDC_REG4: supplied by vcc3v3_sys
- [ 1.070324] LDO_REG1: supplied by vcc3v3_sys
- [ 1.071872] LDO_REG2: supplied by vcc3v3_sys
- [ 1.073263] LDO_REG3: supplied by vcc3v3_sys
- [ 1.074682] LDO_REG4: supplied by vcc3v3_sys
- [ 1.076081] LDO_REG5: supplied by vcc3v3_sys
- [ 1.077482] LDO_REG6: supplied by vcc3v3_sys
- [ 1.078916] LDO_REG7: supplied by vcc3v3_sys
- [ 1.080306] LDO_REG8: supplied by vcc3v3_sys
- [ 1.081737] SWITCH_REG1: supplied by vcc3v3_sys
- [ 1.082477] SWITCH_REG2: supplied by vcc3v3_sys
- [ 1.086325] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
- [ 1.087411] rk808 0-001b: Can not read property pmic,stby-gpio
- [ 1.087968] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80093f6000
- [ 1.089367] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80093f8000
- [ 1.090590] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff80093fa000
- [ 1.092351] fusb302 7-0022: Can't get property of role, set role to default DRP
- [ 1.093169] fusb302 7-0022: fusb302 send extcon to disable vbus 5v
- [ 1.096491] fusb302 7-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
- [ 1.098269] mp8859 7-0066: set mp8859 out 12v ok
- [ 1.098705] mp8859 7-0066: register ext0 dev0
- [ 1.099213] mp8859 7-0066: mp8859 probe successful
- [ 1.099673] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff80093fc000
- [ 1.101123] rockchip-pinctrl pinctrl: pin gpio1-1 already requested by vcc_mipi; cannot claim for 4-0022
- [ 1.101975] rockchip-pinctrl pinctrl: pin-33 (4-0022) status -22
- [ 1.102504] rockchip-pinctrl pinctrl: could not request pin 33 (gpio1-1) from group fusb1-int on device rockchip-pinctrl
- [ 1.103467] fusb302 4-0022: Error applying setting, reverse things back
- [ 1.104517] fusb302 4-0022: Can't get property of role, set role to default DRP
- [ 1.113532] fusb302 4-0022: port 1 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
- [ 1.114358] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80093fe000
- [ 1.116191] IR NEC protocol handler initialized
- [ 1.117439] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.00
- [ 1.118032] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
- [ 1.120147] rkisp1 ff920000.rkisp1: rkisp1 driver version: v00.01.00
- [ 1.120739] rkisp1 ff920000.rkisp1: Missing rockchip,grf property
- [ 1.122749] usbcore: registered new interface driver uvcvideo
- [ 1.123262] USB Video Class driver (1.1.1)
- [ 1.123706] cw201x 2-0062: design_capacity missing!
- [ 1.124971] cw201x 2-0062: the new ATHD have not set
- [ 1.161794] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
- [ 1.162774] cw201x 2-0062: cw2015/cw2013 driver v1.2 probe sucess
- [ 1.166415] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
- [ 1.167370] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
- [ 1.168887] Bluetooth: Virtual HCI driver ver 1.5
- [ 1.169451] Bluetooth: HCI UART driver ver 2.3
- [ 1.169863] Bluetooth: HCI UART protocol H4 registered
- [ 1.170319] Bluetooth: HCI UART protocol LL registered
- [ 1.170786] Bluetooth: HCI UART protocol ATH3K registered
- [ 1.171323] usbcore: registered new interface driver bfusb
- [ 1.171955] usbcore: registered new interface driver btusb
- [ 1.172968] cpu cpu0: bin=1
- [ 1.173270] cpu cpu0: leakage=21
- [ 1.197222] cpu cpu0: temp=28750, pvtm=149458 (150953 + -1495)
- [ 1.198294] cpu cpu0: pvtm-volt-sel=2
- [ 1.198801] cpu cpu0: bin-scale=34
- [ 1.199718] cpu cpu4: bin=1
- [ 1.200047] cpu cpu4: leakage=37
- [ 1.212501] cpu cpu4: temp=28750, pvtm=155426 (156349 + -923)
- [ 1.213178] cpu cpu4: pvtm-volt-sel=2
- [ 1.213577] cpu cpu4: bin-scale=17
- [ 1.215635] cpu cpu0: avs=0, target-scale=34
- [ 1.216140] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
- [ 1.218640] cpu cpu4: avs=0, target-scale=17
- [ 1.219146] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
- [ 1.222337] sdhci: Secure Digital Host Controller Interface driver
- [ 1.222915] sdhci: Copyright(c) Pierre Ossman
- [ 1.223334] Synopsys Designware Multimedia Card Interface Driver
- [ 1.225328] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
- [ 1.226051] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
- [ 1.226688] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
- [ 1.227252] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
- [ 1.228259] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
- [ 1.228859] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
- [ 1.230843] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
- [ 1.231508] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
- [ 1.232136] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
- [ 1.232712] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
- [ 1.233586] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
- [ 1.234992] vccio_sd: unsupportable voltage range: 3300000-3000000uV
- [ 1.235568] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
- [ 1.236250] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
- [ 1.239614] fusb302 7-0022: CC connected in CC1 as UFP
- [ 1.247732] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 1.258773] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
- [ 1.259841] sdhci-pltfm: SDHCI platform and OF driver helper
- [ 1.262313] sdhci-arasan fe330000.sdhci: No vmmc regulator found
- [ 1.262864] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
- [ 1.289799] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
- [ 1.292177] hidraw: raw HID events driver (C) Jiri Kosina
- [ 1.293283] usbcore: registered new interface driver usbhid
- [ 1.293807] usbhid: USB HID core driver
- [ 1.294385] inv_mpu_iio: inv_mpu_init:746
- [ 1.297289] rockchip-dmc dmc: unable to get devfreq-event device : dfi
- [ 1.301309] usbcore: registered new interface driver snd-usb-audio
- [ 1.307428] rockchip-cdndp-sound dp-sound: ASoC: CODEC DAI spdif-hifi not registered
- [ 1.308128] rockchip-cdndp-sound dp-sound: rockchip_sound_probe snd_soc_register_card fail -517
- [ 1.309025] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
- [ 1.310287] ip_tables: (C) 2000-2006 Netfilter Core Team
- [ 1.310921] Initializing XFRM netlink socket
- [ 1.311960] NET: Registered protocol family 10
- [ 1.313492] NET: Registered protocol family 17
- [ 1.313934] NET: Registered protocol family 15
- [ 1.314594] Bluetooth: RFCOMM socket layer initialized
- [ 1.315083] Bluetooth: RFCOMM ver 1.11
- [ 1.315437] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
- [ 1.315985] Bluetooth: HIDP socket layer initialized
- [ 1.316483] [WLAN_RFKILL]: Enter rfkill_wlan_init
- [ 1.317253] [WLAN_RFKILL]: Enter rfkill_wlan_probe
- [ 1.317720] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6354
- [ 1.318326] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
- [ 1.318962] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
- [ 1.319696] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
- [ 1.320493] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
- [ 1.321141] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
- [ 1.321610] [WLAN_RFKILL]: Exit rfkill_wlan_probe
- [ 1.322098] [BT_RFKILL]: Enter rfkill_rk_init
- [ 1.322897] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
- [ 1.323643] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
- [ 1.324378] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
- [ 1.325109] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
- [ 1.325843] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
- [ 1.326489] [BT_RFKILL]: Request irq for bt wakeup host
- [ 1.327013] [BT_RFKILL]: ** disable irq
- [ 1.327483] [BT_RFKILL]: bt_default device registered.
- [ 1.328024] Key type dns_resolver registered
- [ 1.328728] sensor_register_slave:mpu6880_gyro,id=50
- [ 1.333235] ov13850 1-0036: write SCCB_ID failed
- [ 1.333889] ov13850: probe of 1-0036 failed with error -5
- [ 1.337624] ov13850 1-0046: write SCCB_ID failed
- [ 1.338273] ov13850: probe of 1-0046 failed with error -5
- [ 1.339503] Registered cp15_barrier emulation handler
- [ 1.340065] Registered setend emulation handler
- [ 1.341508] Loading compiled-in X.509 certificates
- [ 1.342476] mp8859 7-0066: mp8859 get notify
- [ 1.342696] rga2: Module initialized.
- [ 1.343239] mp8859 7-0066: mp8859 get ufp 1 dp 0
- [ 1.344760] mp8859 7-0066: set mp8859 out 12v ok
- [ 1.344889] phy phy-ff770000.syscon:usb2-phy@e450.3: Failed to get VBUS supply regulator
- [ 1.347165] phy phy-ff770000.syscon:usb2-phy@e460.5: Failed to get VBUS supply regulator
- [ 1.350722] rockchip-drm display-subsystem: defer getting devfreq
- [ 1.351705] rockchip-vop ff900000.vop: missing rockchip,grf property
- [ 1.352685] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008b251e8)
- [ 1.353447] rockchip-vop ff8f0000.vop: missing rockchip,grf property
- [ 1.354286] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008b251e8)
- [ 1.355873] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
- [ 1.356490] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
- [ 1.357342] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
- [ 1.360755] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008b19fd8)
- [ 1.362311] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
- [ 1.363387] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
- [ 1.364167] rockchip-drm display-subsystem: bound fec00000.dp (ops 0xffffff8008b1aff8)
- [ 1.364176] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
- [ 1.364179] [drm] No driver support for vblank timestamp query.
- [ 1.383393] fusb302 7-0022: 0000 max vol cur 0 0
- [ 1.383902] fusb302 7-0022: max vol cur 15000 3000
- [ 1.424751] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
- [ 1.425791] rockchip-iodomain ff770000.syscon:io-domains: Setting to 1800000 done
- [ 1.452782] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
- [ 1.561468] fusb302 7-0022: PD connected as UFP, fetching 5V
- [ 1.614717] fusb302 7-0022: rec unknown init vdm msg
- [ 1.661911] mp8859 7-0066: mp8859 get notify
- [ 1.662315] mp8859 7-0066: mp8859 get ufp 1 dp 1
- [ 1.665377] mp8859 7-0066: set mp8859 out 12v ok
- [ 1.671020] dwmmc_rockchip fe320000.dwmmc: Successfully tuned phase to 100
- [ 1.671705] mmc0: new ultra high speed SDR50 SDXC card at address aaaa
- [ 1.673767] mmcblk0: mmc0:aaaa SL128 119 GiB
- [ 1.702492] mmcblk0: p1 p2 p3 p4 p5
- [ 1.707611] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 2560x1440p60, type: 11
- [ 1.730054] dwhdmi-rockchip ff940000.hdmi: Rate 241500000 missing; compute N dynamically
- [ 1.734951] Freeing drm_logo memory: 616K
- [ 1.823033] Console: switching to colour frame buffer device 320x90
- [ 1.920914] rockchip-drm display-subsystem: fb0: frame buffer device
- [ 1.927689] mali ff9a0000.gpu: leakage=28
- [ 1.951641] mali ff9a0000.gpu: temp=28750, pvtm=125917 (126515 + -598)
- [ 1.953066] mali ff9a0000.gpu: pvtm-volt-sel=2
- [ 1.954514] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
- [ 1.955423] mali ff9a0000.gpu: Protected mode not available
- [ 1.956478] mali ff9a0000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
- [ 1.957180] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
- [ 1.958266] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 414; [Func] : kbase_devfreq_init(); success initing power_model_simple.
- [ 1.960320] mali ff9a0000.gpu: Probed as mali0
- [ 1.963474] random: nonblocking pool is initialized
- [ 1.965404] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
- [ 1.966105] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 1
- [ 1.966959] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
- [ 1.967792] xhci-hcd xhci-hcd.10.auto: irq 230, io mem 0xfe800000
- [ 1.968578] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
- [ 1.969194] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
- [ 1.969844] usb usb1: Product: xHCI Host Controller
- [ 1.970279] usb usb1: Manufacturer: Linux 4.4.167 xhci-hcd
- [ 1.970777] usb usb1: SerialNumber: xhci-hcd.10.auto
- [ 1.971635] hub 1-0:1.0: USB hub found
- [ 1.972070] hub 1-0:1.0: 1 port detected
- [ 1.972749] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
- [ 1.973404] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 2
- [ 1.974166] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
- [ 1.975006] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
- [ 1.975613] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
- [ 1.976304] usb usb2: Product: xHCI Host Controller
- [ 1.976762] usb usb2: Manufacturer: Linux 4.4.167 xhci-hcd
- [ 1.977300] usb usb2: SerialNumber: xhci-hcd.10.auto
- [ 1.978281] hub 2-0:1.0: USB hub found
- [ 1.978705] hub 2-0:1.0: 1 port detected
- [ 1.980612] xhci-hcd xhci-hcd.10.auto: remove, state 1
- [ 1.981118] usb usb2: USB disconnect, device number 1
- [ 2.000741] xhci-hcd xhci-hcd.10.auto: Host not halted after 16000 microseconds.
- [ 2.001389] xhci-hcd xhci-hcd.10.auto: Host controller not halted, aborting reset.
- [ 2.002118] xhci-hcd xhci-hcd.10.auto: USB bus 2 deregistered
- [ 2.002791] xhci-hcd xhci-hcd.10.auto: remove, state 1
- [ 2.003272] usb usb1: USB disconnect, device number 1
- [ 2.004360] xhci-hcd xhci-hcd.10.auto: USB bus 1 deregistered
- [ 2.366999] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
- [ 2.644881] phy phy-ff770000.syscon:usb2-phy@e450.3: charger = USB_FLOATING_CHARGER
- [ 2.650903] rockchip-dwc3 usb0: USB peripheral connected
- [ 2.654489] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
- [ 2.655471] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 1
- [ 2.656454] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
- [ 2.657397] xhci-hcd xhci-hcd.11.auto: irq 231, io mem 0xfe900000
- [ 2.658525] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
- [ 2.659184] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
- [ 2.659881] usb usb1: Product: xHCI Host Controller
- [ 2.660341] usb usb1: Manufacturer: Linux 4.4.167 xhci-hcd
- [ 2.660885] usb usb1: SerialNumber: xhci-hcd.11.auto
- [ 2.662577] hub 1-0:1.0: USB hub found
- [ 2.663135] hub 1-0:1.0: 1 port detected
- [ 2.664286] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
- [ 2.665173] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 2
- [ 2.666013] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
- [ 2.666939] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
- [ 2.667554] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
- [ 2.668240] usb usb2: Product: xHCI Host Controller
- [ 2.668706] usb usb2: Manufacturer: Linux 4.4.167 xhci-hcd
- [ 2.669232] usb usb2: SerialNumber: xhci-hcd.11.auto
- [ 2.670495] hub 2-0:1.0: USB hub found
- [ 2.670970] hub 2-0:1.0: 1 port detected
- [ 2.672212] xhci-hcd xhci-hcd.11.auto: remove, state 1
- [ 2.672740] usb usb2: USB disconnect, device number 1
- [ 2.674055] xhci-hcd xhci-hcd.11.auto: USB bus 2 deregistered
- [ 2.674835] xhci-hcd xhci-hcd.11.auto: remove, state 1
- [ 2.675333] usb usb1: USB disconnect, device number 1
- [ 2.676831] xhci-hcd xhci-hcd.11.auto: USB bus 1 deregistered
- [ 2.680778] ehci-platform fe380000.usb: EHCI Host Controller
- [ 2.681581] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
- [ 2.682512] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
- [ 2.688708] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
- [ 2.689568] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
- [ 2.690216] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
- [ 2.690892] usb usb1: Product: EHCI Host Controller
- [ 2.691340] usb usb1: Manufacturer: Linux 4.4.167 ehci_hcd
- [ 2.691877] usb usb1: SerialNumber: fe380000.usb
- [ 2.693193] hub 1-0:1.0: USB hub found
- [ 2.693601] hub 1-0:1.0: 1 port detected
- [ 2.698909] ehci-platform fe3c0000.usb: EHCI Host Controller
- [ 2.699748] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
- [ 2.700644] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
- [ 2.706759] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
- [ 2.707613] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
- [ 2.708280] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
- [ 2.708958] usb usb2: Product: EHCI Host Controller
- [ 2.709406] usb usb2: Manufacturer: Linux 4.4.167 ehci_hcd
- [ 2.709939] usb usb2: SerialNumber: fe3c0000.usb
- [ 2.711189] hub 2-0:1.0: USB hub found
- [ 2.711596] hub 2-0:1.0: 1 port detected
- [ 2.713513] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
- [ 2.714446] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
- [ 2.715397] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
- [ 2.771155] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
- [ 2.771827] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
- [ 2.772487] usb usb3: Product: Generic Platform OHCI controller
- [ 2.773084] usb usb3: Manufacturer: Linux 4.4.167 ohci_hcd
- [ 2.773590] usb usb3: SerialNumber: fe3a0000.usb
- [ 2.775349] hub 3-0:1.0: USB hub found
- [ 2.775835] hub 3-0:1.0: 1 port detected
- [ 2.778343] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
- [ 2.779404] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
- [ 2.780375] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
- [ 2.836171] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
- [ 2.836832] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
- [ 2.837504] usb usb4: Product: Generic Platform OHCI controller
- [ 2.838083] usb usb4: Manufacturer: Linux 4.4.167 ohci_hcd
- [ 2.838602] usb usb4: SerialNumber: fe3e0000.usb
- [ 2.840347] hub 4-0:1.0: USB hub found
- [ 2.840807] hub 4-0:1.0: 1 port detected
- [ 2.843046] input: adc-keys as /devices/platform/adc-keys/input/input1
- [ 2.846616] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
- [ 2.847391] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
- [ 2.848066] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
- [ 2.848636] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
- [ 2.849817] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
- [ 2.850403] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
- [ 2.851933] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
- [ 2.864752] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 2.875856] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
- [ 2.877347] rockchip-dmc dmc: Failed to get leakage
- [ 2.877901] rockchip-dmc dmc: Failed to get pvtm
- [ 2.878635] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
- [ 2.879226] rockchip-dmc dmc: failed to get vop pn to msch rl
- [ 2.880009] rockchip-dmc dmc: could not find power_model node
- [ 2.881889] asoc-simple-card hdmi-sound: i2s-hifi <-> ff8a0000.i2s mapping ok
- [ 2.885073] rockchip-cdndp-sound dp-sound: spdif-hifi <-> ff870000.spdif mapping ok
- [ 2.885869] hdmi-audio-codec hdmi-audio-codec.9.auto: ASoC: Failed to create Playback debugfs file
- [ 2.887558] input: rockchip-cdndp-sound DP Jack as /devices/platform/dp-sound/sound/card1/input2
- [ 2.890436] input: gpio-keys as /devices/platform/gpio-keys/input/input3
- [ 2.891614] ==gsl_ts_init==
- [ 2.891965] ret=0
- [ 2.893143] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:07 UTC (1358499007)
- [ 2.900850] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
- [ 2.918575] vcc_mipi: disabling
- [ 2.918885] dvdd_1v2: disabling
- [ 2.919216] ret 1024
- [ 2.920280] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '14:46:49', on 'Jun 24 2019'.
- [ 2.922710] Mali: Mali device driver loaded
- [ 2.924090] rockchip-pinctrl pinctrl: unsupported driver strength 20
- [ 2.924652] rockchip-pinctrl pinctrl: pin_config_set op failed for pin 122
- [ 2.925271] usb-ext-charge usb-charge: Error applying setting, reverse things back
- [ 2.926722] usb-ext-charge usb-charge: register ext0 dev0
- [ 2.927205] usb-ext-charge usb-charge: uec get notify
- [ 2.927678] usb-ext-charge usb-charge: uec get ufp 1 pd 1
- [ 2.928168] usb-ext-charge usb-charge: usb status 2 battery_online 0 poe_online 0
- [ 2.928859] usb-ext-charge usb-charge: probe success
- [ 2.929915] ALSA device list:
- [ 2.930185] #0: rockchip,hdmi
- [ 2.930465] #1: rockchip-cdndp-sound
- [ 2.938793] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
- [ 2.980810] mmc_host mmc2: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
- [ 3.013697] usb 2-1: new high-speed USB device number 2 using ehci-platform
- [ 3.128820] usb 2-1: New USB device found, idVendor=1a40, idProduct=0101
- [ 3.129496] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
- [ 3.130220] usb 2-1: Product: USB 2.0 Hub [MTT]
- [ 3.132337] hub 2-1:1.0: USB hub found
- [ 3.132925] hub 2-1:1.0: 4 ports detected
- [ 3.408702] usb 2-1.4: new low-speed USB device number 3 using ehci-platform
- [ 3.418746] EXT4-fs (mmcblk0p5): recovery complete
- [ 3.419252] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
- [ 3.420104] VFS: Mounted root (ext4 filesystem) on device 179:5.
- [ 3.429410] devtmpfs: mounted
- [ 3.430142] Freeing unused kernel memory: 1088K
- [ 3.517724] usb 2-1.4: New USB device found, idVendor=03f0, idProduct=034a
- [ 3.518431] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
- [ 3.519170] usb 2-1.4: Product: HP Elite USB Keyboard
- [ 3.519737] usb 2-1.4: Manufacturer: Chicony
- [ 3.533373] input: Chicony HP Elite USB Keyboard as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.4/2-1.4:1.0/0003:03F0:034A.0001/input/input4
- [ 3.588500] hid-generic 0003:03F0:034A.0001: input,hidraw0: USB HID v1.10 Keyboard [Chicony HP Elite USB Keyboard] on usb-fe3c0000.usb-1.4/input0
- [ 3.602912] input: Chicony HP Elite USB Keyboard as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.4/2-1.4:1.1/0003:03F0:034A.0002/input/input5
- [ 3.655794] hid-generic 0003:03F0:034A.0002: input,hidraw1: USB HID v1.10 Device [Chicony HP Elite USB Keyboard] on usb-fe3c0000.usb-1.4/input1
- [ 4.098643] systemd[1]: System time before build time, advancing clock.
- [ 4.111933] cgroup: cgroup2: unknown option "nsdelegate"
- [ 4.154464] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
- [ 4.157817] systemd[1]: Detected architecture arm64.
- Welcome to Ubuntu 18.04.3 LTS!
- [ 4.171458] systemd[1]: Set hostname to <firefly>.
- [ 4.334691] vendor storage:20160801 ret = -1
- [ 4.408308] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
- [ 4.409099] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
- [ 4.689173] systemd[1]: File /lib/systemd/system/systemd-udevd.service:34 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
- [ 4.690713] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
- [ 5.228154] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
- [ OK ] Started Forward Password Requests to Wall Directory Watch.
- [ 5.230775] systemd[1]: Created slice User and Session Slice.
- [ OK ] Created slice User and Session Slice.
- [ 5.231784] systemd[1]: Reached target Remote File Systems.
- [ OK ] Reached target Remote File Systems.
- [ 5.232752] systemd[1]: Reached target User and Group Name Lookups.
- [ OK ] Reached target User and Group Name Lookups.
- [ 5.233837] systemd[1]: Reached target Swap.
- [ OK ] Reached target Swap.
- [ 5.235864] systemd[1]: Created slice System Slice.
- [ OK ] Created slice System Slice.
- [ 5.296516] systemd[1]: Created slice system-serial\x2dgetty.slice.
- [ OK ] Created slice system-serial\x2dgetty.slice.
- [ 5.298513] systemd[1]: Listening on Journal Socket.
- [ OK ] Listening on Journal Socket.
- [ 5.314924] systemd[1]: Starting Load Kernel Modules...
- Starting Load Kernel Modules...
- [ 5.316786] systemd[1]: Reached target Slices.
- [ OK ] Reached target Slices.
- [ 5.318391] systemd[1]: Listening on Syslog Socket.
- [ OK ] Listening on Syslog Socket.
- [ 5.327642] systemd[1]: Mounting Kernel Debug File System...
- Mounting Kernel Debug File System...
- [ 5.331652] systemd[1]: Listening on Journal Socket (/dev/log).
- [ OK ] Listening on Journal Socket (/dev/log).
- [ 5.345004] systemd[1]: Starting Set the console keyboard layout...
- Starting Set the console keyboard layout...
- [ 5.349656] systemd[1]: Starting Journal Service...
- Starting Journal Service...
- [ 5.354219] systemd[1]: Starting Remount Root and Kernel File Systems...
- Starting Remount Root and Kernel File Systems...
- [ 5.355839] systemd[1]: Listening on udev Kernel Socket.
- [ OK ] Listening on udev Kernel Socket.
- [ 5.382479] systemd[1]: Starting Create list of required static device nodes for the current kernel...
- Starting Create list of required st…ce nodes for the current kernel...
- [ 5.384608] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
- [ OK ] Listening on /dev/initctl Compatibility Named Pipe.
- [ 5.387106] systemd[1]: Listening on udev Control Socket.
- [ OK ] Listening on udev Control Socket.
- [ 5.393357] systemd[1]: Starting udev Coldplug all Devices...
- Starting udev Coldplug all Devices...
- [ 5.396171] systemd[1]: Started Load Kernel Modules.
- [ OK ] Started Load Kernel Modules.
- [ 5.401813] systemd[1]: Started Remount Root and Kernel File Systems.
- [ OK ] Started Remount Root and Kernel File Systems.
- [ 5.404070] systemd[1]: Started Create list of required static device nodes for the current kernel.
- [ OK ] Started Create list of required sta…vice nodes for the current kernel.
- [ 5.409129] systemd[1]: Starting Create Static Device Nodes in /dev...
- Starting Create Static Device Nodes in /dev...
- [ 5.466140] systemd[1]: Starting Load/Save Random Seed...
- Starting Load/Save Random Seed...
- [ 5.472964] systemd[1]: Mounting Kernel Configuration File System...
- Mounting Kernel Configuration File System...
- [ 5.479658] systemd[1]: Starting Apply Kernel Variables...
- Starting Apply Kernel Variables...
- [ 5.486065] systemd[1]: Mounting FUSE Control File System...
- Mounting FUSE Control File System...
- [ 5.580501] systemd[1]: Started Load/Save Random Seed.
- [ OK ] Started Load/Save Random Seed.
- [ OK ] Started Apply Kernel Variables.
- [ OK ] Mounted Kernel Debug File System.
- [ OK ] Mounted Kernel Configuration File System.
- [ OK ] Mounted FUSE Control File System.
- [ OK ] Started Create Static Device Nodes in /dev.
- Starting udev Kernel Device Manager...
- [ OK ] Started udev Coldplug all Devices.
- [ OK ] Started Journal Service.
- Starting Flush Journal to Persistent Storage...
- [ OK ] Started Flush Journal to Persistent Storage.
- [ OK ] Started Set the console keyboard layout.
- [ OK ] Reached target Local File Systems (Pre).
- [ OK ] Reached target Local File Systems.
- Starting Create Volatile Files and Directories...
- Starting Set console font and keymap...
- Starting Tell Plymouth To Write Out Runtime Data...
- [ OK ] Started Tell Plymouth To Write Out Runtime Data.
- [ OK ] Started Set console font and keymap.
- [ OK ] Started Create Volatile Files and Directories.
- Starting Update UTMP about System Boot/Shutdown...
- Starting Network Time Synchronization...
- Starting Network Name Resolution...
- [ OK ] Started Update UTMP about System Boot/Shutdown.
- [ OK ] Started udev Kernel Device Manager.
- [ OK ] Started Dispatch Password Requests to Console Directory Watch.
- [ OK ] Reached target Local Encrypted Volumes.
- [ OK ] Started Network Time Synchronization.
- [ OK ] Reached target System Initialization.
- [ OK ] Listening on D-Bus System Message Bus Socket.
- [ OK ] Started Daily Cleanup of Temporary Directories.
- [ OK ] Reached target Paths.
- [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
- Starting Socket activation for snappy daemon.
- [ OK ] Reached target System Time Synchronized.
- [ OK ] Started Message of the Day.
- [ OK ] Started Discard unused blocks once a week.
- [ OK ] Started Daily apt download activities.
- [ OK ] Started Daily apt upgrade and clean activities.
- [ OK ] Reached target Timers.
- [ OK ] Started Network Name Resolution.
- [ OK ] Listening on Socket activation for snappy daemon.
- [ OK ] Reached target Sockets.
- [ OK ] Reached target Basic System.
- Starting System Logging Service...
- Starting LSB: automatic crash report generation...
- Starting Dispatcher daemon for systemd-networkd...
- Starting Accounts Service...
- [ OK ] Started Set the CPU Frequency Scaling governor.
- [ OK ] Started D-Bus System Message Bus.
- Starting WPA supplicant...
- Starting Network Manager...
- Starting Restore /etc/resolv.conf i…fore the ppp link was shut down...
- Starting Disk Manager...
- [ OK ] Started Regular background program processing daemon.
- Starting Adbd for linux...
- Starting Avahi mDNS/DNS-SD Stack...
- Starting Login Service...
- Starting Save/Restore Sound Card State...
- Starting Modem Manager...
- Starting Snappy daemon...
- [ OK ] Reached target Host and Network Name Lookups.
- [ OK ] Started System Logging Service.
- [ OK ] Found device /dev/ttyFIQ0.
- [ OK ] Started Save/Restore Sound Card State.
- [ OK ] Started WPA supplicant.
- [ OK ] Started Login Service.
- Starting Authorization Manager...
- [ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
- [ OK ] Created slice system-systemd\x2dbacklight.slice.
- Starting Load/Save Screen Backlight…ightness of backlight:backlight...
- [ OK ] Reached target Sound Card.
- Starting Load/Save RF Kill Switch Status...
- [ OK ] Started Avahi mDNS/DNS-SD Stack.
- [ OK ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
- [ OK ] Started Restore /etc/resolv.conf if…before the ppp link was shut down.
- [ OK ] Started Load/Save RF Kill Switch Status.
- [ OK ] Started Authorization Manager.
- [ OK ] Started Accounts Service.
- Starting bluetooth-toggle...
- [ OK ] Started LSB: automatic crash report generation.
- [ OK ] Started bluetooth-toggle.
- [ OK ] Started Modem Manager.
- [ OK ] Started Snappy daemon.
- Starting Wait until snapd is fully seeded...
- [ OK ] Started Wait until snapd is fully seeded.
- Starting Hostname Service...
- [ OK ] Started Hostname Service.
- Starting Network Manager Script Dispatcher Service...
- [ OK ] Started Network Manager Script Dispatcher Service.
- [ OK ] Started Dispatcher daemon for systemd-networkd.
- [ OK ] Started Adbd for linux.
- [ OK ] Started Network Manager.
- [ OK ] Reached target Network.
- Starting OpenBSD Secure Shell server...
- Starting /etc/rc.local Compatibility...
- Starting Permit User Sessions...
- [ OK ] Started Permit User Sessions.
- [ OK ] Started /etc/rc.local Compatibility.
- Starting Hold until boot process finishes up...
- Starting Light Display Manager...
- [ OK ] Started Hold until boot process finishes up.
- [ OK ] Started Serial Getty on ttyFIQ0.
- Starting Set console scheme...
- [ OK ] Started Set console scheme.
- [ OK ] Created slice system-getty.slice.
- [ OK ] Started Getty on tty1.
- [ OK ] Reached target Login Prompts.
- [ OK ] Started Disk Manager.
- [ OK ] Started Light Display Manager.
- [ OK ] Started OpenBSD Secure Shell server.
- [ OK ] Reached target Multi-User System.
- [ OK ] Reached target Graphical Interface.
- Starting Update UTMP about System Runlevel Changes...
- [ OK ] Started Update UTMP about System Runlevel Changes.
- Ubuntu 18.04.3 LTS firefly ttyFIQ0
- firefly login: firefly
- Password:
- Login timed out after 60 seconds.
- firefly login: Stopping Save/Restore Sound Card State...
- [ OK ] Stopped target Graphical Interface.
- Stopping bluetooth-toggle...
- [ OK ] Stopped target Multi-User System.
- Stopping Regular background program processing daemon...
- Stopping Modem Manager...
- Stopping System Logging Service...
- Stopping OpenBSD Secure Shell server...
- Stopping Authorization Manager...
- Stopping Adbd for linux...
- Stopping Avahi mDNS/DNS-SD Stack...
- [ OK ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
- Stopping Accounts Service...
- [ OK ] Stopped target Sound Card.
- Stopping LSB: automatic crash report generation...
- [ OK ] Stopped Wait until snapd is fully seeded.
- Stopping RealtimeKit Scheduling Policy Service...
- [ OK ] Stopped target Timers.
- [ OK ] Stopped Discard unused blocks once a week.
- [ OK ] Stopped Daily apt upgrade and clean activities.
- [ OK ] Stopped Daily apt download activities.
- Stopping Session c2 of user firefly.
- Stopping User Manager for UID 1000...
- Stopping Bluetooth service...
- [ OK ] Stopped target Host and Network Name Lookups.
- [ OK ] Stopped Daily Cleanup of Temporary Directories.
- [ OK ] Stopped Message of the Day.
- [ OK ] Stopped target System Time Synchronized.
- Stopping Light Display Manager...
- [ OK ] Stopped target Login Prompts.
- Stopping Serial Getty on ttyFIQ0...
- Stopping Daemon for power management...
- Stopping Dispatcher daemon for systemd-networkd...
- Stopping Disk Manager...
- Stopping Getty on tty1...
- [ OK ] Stopped System Logging Service.
- [ OK ] Stopped Dispatcher daemon for systemd-networkd.
- [ OK ] Stopped Accounts Service.
- [ OK ] Stopped Regular background program processing daemon.
- [ OK ] Stopped Avahi mDNS/DNS-SD Stack.
- [ OK ] Stopped Authorization Manager.
- [ OK ] Stopped bluetooth-toggle.
- [ OK ] Stopped Getty on tty1.
- [ OK ] Stopped Disk Manager.
- [ OK ] Unmounted /run/user/1000/gvfs.
- [ OK ] Stopped OpenBSD Secure Shell server.
- [ OK ] Stopped RealtimeKit Scheduling Policy Service.
- [ OK ] Stopped Serial Getty on ttyFIQ0.
- [ OK ] Stopped Modem Manager.
- [ OK ] Stopped User Manager for UID 1000.
- [ OK ] Stopped Bluetooth service.
- [ OK ] Stopped Daemon for power management.
- [ OK ] Stopped Save/Restore Sound Card State.
- [ 205.427173] configfs-gadget gadget: unbind function 'Function FS Gadget'/ffffffc0eff2c438
- [ OK ] Stopped Adbd for linux.
- [ OK ] Removed slice system-serial\x2dgetty.slice.
- [ OK ] Removed slice system-getty.slice.
- [ OK ] Stopped /etc/rc.local Compatibility.
- [ OK ] Stopped Session c2 of user firefly.
- [ OK ] Removed slice User Slice of firefly.
- Stopping Login Service...
- [ OK ] Stopped LSB: automatic crash report generation.
- [ OK ] Stopped Login Service.
- [ OK ] Stopped Light Display Manager.
- Stopping Permit User Sessions...
- [ OK ] Stopped Permit User Sessions.
- [ OK ] Stopped target User and Group Name Lookups.
- [ OK ] Stopped target Remote File Systems.
- [ OK ] Stopped target Network.
- Stopping Network Manager...
- Stopping Network Name Resolution...
- Stopping WPA supplicant...
- [ OK ] Stopped WPA supplicant.
- [ OK ] Stopped Network Name Resolution.
- [ OK ] Stopped Network Manager.
- Stopping D-Bus System Message Bus...
- [ OK ] Stopped D-Bus System Message Bus.
- [ OK ] Stopped target Basic System.
- [ OK ] Stopped target Slices.
- [ OK ] Removed slice User and Session Slice.
- [ OK ] Stopped target Paths.
- [ OK ] Stopped target Sockets.
- [ OK ] Closed Socket activation for snappy daemon.
- [ OK ] Closed Syslog Socket.
- [ OK ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
- [ OK ] Closed D-Bus System Message Bus Socket.
- [ OK ] Stopped target System Initialization.
- [ OK ] Stopped target Local Encrypted Volumes.
- [ OK ] Stopped Dispatch Password Requests to Console Directory Watch.
- [ OK ] Stopped Forward Password Requests to Wall Directory Watch.
- Stopping Load/Save Random Seed...
- Stopping Load/Save Screen Backlight…ightness of backlight:backlight...
- [ OK ] Stopped Apply Kernel Variables.
- [ OK ] Stopped Load Kernel Modules.
- Stopping Update UTMP about System Boot/Shutdown...
- Stopping Network Time Synchronization...
- [ OK ] Stopped Load/Save Random Seed.
- [ OK ] Stopped Network Time Synchronization.
- [ OK ] Stopped Load/Save Screen Backlight Brightness of backlight:backlight.
- [ OK ] Removed slice system-systemd\x2dbacklight.slice.
- [ OK ] Stopped Update UTMP about System Boot/Shutdown.
- [ OK ] Stopped Create Volatile Files and Directories.
- [ OK ] Stopped target Local File Systems.
- Unmounting /run/user/1000...
- [ OK ] Unmounted /run/user/1000.
- [ OK ] Reached target Unmount All Filesystems.
- [ OK ] Stopped target Swap.
- [ OK ] Stopped target Local File Systems (Pre).
- [ OK ] Stopped Remount Root and Kernel File Systems.
- [ OK ] Stopped Create Static Device Nodes in /dev.
- [ OK ] Reached target Shutdown.
- [ OK ] Reached target Final Step.
- Starting Power-Off...
Copy the code |
