New Topic
compiled sdk not booting with update.img
20
Posted at 1/13/2015 05:29:07      View8146 | Replies10        Print      Only Author   [Copy Link] 1#
Hey guys I have a quick question maybe someone here can help me out. When I upload my kernel, boot,system ,misc the system works fine as it should but when I upload update.img the box doesnt boot at all.
If i replace my resource.img with the original one from the firefly? extracted from the firmware and make my new firmware the box boots no problems. Is there something special needing done with resource.img. I was debugging a little and i noticed my??resource.img unpacked fine with ? kernel/resource_tool --unpack resource.img but the firefly one didnt is there anything special we need to do to this file to make the box boot properly
Posted at 1/14/2015 14:51:59        Only Author  2#
Our resource.img can be unpacked using following instructions:
~$ mkdir /tmp/t
~$ cd /tmp/t
/tmp/t$ cp ~/proj/firefly-44/kernel/resource.img .
/tmp/t$ ~/proj/firefly-44/kernel/resource_tool --unpack .
Dump header:
partition version:0.0
header size:1
index tbl:
offset:1        entry size:1        entry num:2
Dump Index table:
entry(0):
path:rk-kernel.dtb
offset:3        size:98693
entry(1):
offset:196        size:17184
Unack resource.img to . successed!
/tmp/t$ ls -l
total 236
-rw-r--r-- 1 djw users  17184 1  14 14:45 logo.bmp
-rw-r--r-- 1 djw users 117760 1  14 14:45 resource.img
-rw-r--r-- 1 djw users  98693 1  14 14:45 rk-kernel.dtb
/tmp/t$ ~/proj/firefly-44/kernel/scripts/dtc/dtc  -I dtb rk-kernel.dtb -O dts -o firefly-rk3288-kernel.dts
/tmp/t$ head firefly-rk3288-kernel.dts
/dts-v1/;
#address-cells = <0x1>;
#size-cells = <0x1>;
compatible = "rockchip,rk3288";
rockchip,sram = <0x1>;
interrupt-parent = <0x2>;
chosen {
The resource.img contains a bitmap and a dtb. Please check your compiling.
Posted at 1/18/2015 20:21:36        Only Author  3#
Hi sorry I though I posted to this earlier. I done somethign to the sdk it was my bad. Im not sure what i done but I just re downloaded it and all is well now. Thanks for the reply. Everythign is working as it should be. I have one more question though if you done mind. If i compile a new resource.dat is there any way to upload it on with Linux_Upgrade_Tool_v1.2 I dont seen any option for it. I have to flash a full firmware every time. It seems the windows AndroidTool Release v2.3 supports this only problem is its just a quick re flashing the firmware by the time you copy the files to a windows partition and reboot.
Posted at 1/19/2015 14:33:41        Only Author  4#
Please try:
sudo?upgrade_tool di resource /path/to/resource.img
Posted at 1/14/2026 08:07:48        Only Author  5#
I really appreciate your article, it has been truly eye-opening. Free CPMAI valid vce exam simulator available for improving your IT skills. Wishing you the best!
Posted at 1/16/2026 12:30:26        Only Author  6#
Thank you for your article, it was a true eye-opener. This is the Reliable C1000-189 exam pattern test that led to my promotion and salary raise. It's free for you todayhope you succeed in your career pursuits!
Posted at 1/21/2026 06:24:37        Only Author  7#
I was so impressed by the quality of the article. Free Valid exam CTFL-AcT registration to help you enhance your IT skills. Wishing you good luck!
Posted at 1/23/2026 18:59:24        Only Author  8#
Thank you for your article; it really opened my eyes. Sharing Real CFE-Financial-Transactions-and-Fraud-Schemes question materials for free with you allbest of luck!
restricted members
Posted at 1/31/2026 00:06:12        Only Author  9#
ExamPassdump를 검색을 통해 클릭하게된 지금 이 순간 IT인증자격증취득Fortinet NSE7_SOC_AR-7.6시험은 더는 힘든 일이 아닙니다. 다른 분들이Fortinet NSE7_SOC_AR-7.6시험준비로 수없는 고민을 할때 고객님은 저희 Fortinet NSE7_SOC_AR-7.6덤프로 제일 빠른 시일내에 시험을 패스하여 자격증을 손에 넣을수 있습니다.
Posted at 2/18/2026 12:33:29        Only Author  10#
JpshikenϡՓȌg¤_k˻ŤUY֤ČTҤˤäƥѥ뤵줿CGSSԇYϤθߤϸʤṩ뤿ᡢdzˁޤ CGSSȥ`˥󥰥֥쥤פԇƤ顢CGSSǥɤُ뤹ǰˡϤǟoϤΥǥE Certified Global Sanctions SpecialistԇYκϸĤǤʤrgȥͥ륮`򹝼sǤ뤿ᡢCGSSԇYΜʂُ뤹ޤ
Return to List
12
