New Topic
[Linux] UI is not smooth with Linux
89
Linux UI is not smooth with Linux
Posted at 10/15/2019 17:07:26      View7485 | Replies18        Print      Only Author   [Copy Link] 1#
I am currently using RK3399 with Expansion board and POE image file. But, the Firefly UI doesn't respond to the commands. I have to click on Shutdown atleast 10 times before it activates the command. Has anyone experienced this and is there any solution?
Posted at 10/16/2019 11:25:03        Only Author  2#
On a Raspberry Pi. Reflash and see if it persists?  What about amd x64 Kali?
Posted at 10/16/2019 18:49:44        Only Author  3#
I have reflashed the board several times but it still has the same problem.
Posted at 10/17/2019 15:36:19        Only Author  4#
slow refresh?  commands (ie "command prompt") or GUI?
POE image file?
Posted at 10/17/2019 16:39:01        Only Author  5#
GUI and Development board with POE and Expansion Board
Posted at 10/19/2019 11:45:49        Only Author  6#
You implied there's an image to use the expansion?  And you're saying that running commands is slow?  If you boot up and then shut down after a full boot is it still slow?
Posted at 10/21/2019 15:28:06        Only Author  7#
UI is not responsive even after full boot up.
Posted at 10/22/2019 05:06:58        Only Author  8#
Switch the flash/eMMC and boot up 16.04...persistent?  If so, seems hardware related. Put an ssd in the expansion?  Brand?  What about Wifi/bt e key?  Brand?
Posted at 10/22/2019 05:08:00        Only Author  9#
How is it being powered?  Which that up too. If using POE switch to usbc...
Posted at 10/23/2019 17:50:44        Only Author  10#
Could you send me a bootup Image file with Ubuntu 16.04 including kernel?
Return to List
12
