[Linux] Android 7.1 upgrade to Ubuntu using SD card
9
Linux Android 7.1 upgrade to Ubuntu using SD card
Posted at 12/14/2019 05:11:20      View5821 | Replies6        Print      Only Author   [Copy Link] 1#
While following the instruction here : http://wiki.t-firefly.com/en/Fir ... 1-upgrade-to-ubuntu, I am trying to unpack the image. But when I run unpack.sh, I see the following error :
start to unpack update.img...
./unpack.sh: line 17: ./bin/rkImageMaker: No such file or directory
Press any key to quit:
The file is there :
$ ls -l ./bin/rkImageMaker
-rwxr-xr-x 1 nhjadhav domain^users 325822 Nov 12 16:54 ./bin/rkImageMaker
Is there anything else that is needed to be done to unpack the image?
Posted at 12/16/2019 10:11:06        Only Author  2#
I had unpacked `FIREFLY-RK3399-UBUNTU18.04-GPT-20190910-0922.img` by following the instruction of wiki just now, and it was no problem for me.  Therefore:
1. Please make sure `ubuntu_sd_update/bin/rkImageMaker` exists.
2. Re-download the `ubuntu_sd_update.zip` and try again.
3. Please try to execute the commands in the command line instead of running `./unpackage`.
Posted at 1/9/2026 15:25:38        Only Author  3#
I find this article to be so motivating, thanks for sharing! The Certification MB-500 dump free download content is truly valuable, and its free.
Posted at 1/11/2026 01:15:16        Only Author  4#
Im in awe of your article, thank you so much for sharing! The Hottest 1z0-1104-25 certification was my key to successpromotion and salary raise. Its now free for everyone. Wishing you all a fast track to promotions!
Posted at 1/11/2026 01:44:41        Only Author  5#
Cant get enough of this content, definitely liking it. I hope the MS-721 reliable test simulator content helps, and it comes at no cost.
Posted at 1/29/2026 01:03:29        Only Author  6#
EMCD-UN-OE-23ԇYΜʂ򤷤Ƥ顢Xhs1991FgF뤳Ȥ˥إפ뤨ޤ Xhs1991EMCD-UN-OE-23ԇYȥ`˥YϤϸƷ|Υȥ`˥YϤǡѩ`Ȥκϸʤ^Ǥޤ⤷ʤmʕrg֤ä㏊ǤΤʤ顢Xhs1991EMCD-UN-OE-23ԇYȥ`˥YϤxӤޤ礦YϤ֤줿顢SԇYΜʂ򤹤뤳ȤǤޤ
Posted at 3/5/2026 22:10:12        Only Author  7#
I learned so much from the articleit was truly beneficial. The DP-900 valid test book questions are freeunlock your promotion and salary raise!
