[Linux] [RK3288-PC] - Need support TUN/TAP interface
10
【Linux】 [RK3288-PC] - Need support TUN/TAP interface
Posted at 3/19/2020 10:00:38      View:6195 | Replies:8        Print      Only Author   [Copy Link] 1#
Hi Firefly Dev team,
I am using RK3288PC and have a project which needs to use openVPN
The current Linux firmware does not support TUN/TAP interface.
Do you have any idea to install "tun"? I have found on the internet but all solutions are failed.
If not, do you have any plan to implement this interface to Linux firmware?
______ Environment ______
RK-3288-PC
This issue happens on both SD card and eMMCs,
Linux Ver: Ubuntu 18.04
_________________________
Have a nice working day,
Thanks and Regards,
Felix Nguyen
Posted at 8/18/2022 11:58:49        Only Author  2#
Have you solved this problem yet? Can you give me a solution? Thank you so much
Posted at 1/9/2026 17:46:24        Only Author  3#
Truly a remarkable piece of writing, I’m so thankful for your share. Wish me luck as I’m getting ready to take the New exam cram OMG-OCEB2-FUND100 materials exam!
Posted at 1/17/2026 17:00:13        Only Author  4#
Instant like for this incredible content. This Valid NSE7_CDS_AR-7.6 test camp helped me get a promotion and salary hike. I’m now making it available for free. Wishing you all career success!
Posted at 1/24/2026 03:02:43        Only Author  5#
持ってきた製品があなたにふさわしくないと感じることはよくありますか? Massachusetts-Real-Estate-Salesperson学習ガイドを使用することに決めた場合、問題に遭遇することは決してないことを伝えたいと思います。私たちのMassachusetts-Real-Estate-Salesperson学習教材は、あなたが期待できない高品質を持っています。 Massachusetts-Real-Estate-Salesperson学習教材のガイダンスで経験を積むと、以前よりも短時間で過ごすことができ、明らかに進歩を感じることができます。また、Massachusetts-Real-Estate-Salespersonのテストクイズは、進歩に役立つことがわかります。 。
Posted at 2/3/2026 18:27:10        Only Author  6#
Thank you for sharing; it was truly incredible! Free 300-535 latest practice materials study materials available now—good luck!
Posted at 2/19/2026 19:50:55        Only Author  7#
I’m absolutely amazed by your article, thank you for sharing it! Boost your IT abilities with free Valid test guide C-OCM-2503 files. Wishing you all the best!
Posted at 2/21/2026 20:44:16        Only Author  8#
This article is a masterpiece, I’m so grateful for your sharing. Sharing EMEA-Advanced-Support certification exam infor exam questions for free—promotions and salary growth await!
Posted at 3/8/2026 14:31:04        Only Author  9#
This article is a true masterpiece, thank you for sharing. Enhance your IT knowledge—free Study SPLK-3002 reference shared! Wishing you success!
