New Topic
[Linux] Power Key/button on rk3399-roc-pc
10
Linux Power Key/button on rk3399-roc-pc
Posted at 4/1/2020 13:02:53      View23982 | Replies37        Print      Only Author   [Copy Link] 1#
Can you guys please suggest me on my requirement.
rk3399-roc-pc board has a Power Key/button. As per the schematics this
Power Key/button is connected to GPIO0_A5.
My requirement is can I use this button for board powerup (especially
in linux when we issue "poweroff" command, the board shuts down and it should power back on
after I press the Power Key/button).
For the above to happen, I think this Power Key/button be connected to
PMIC RK808-D IC, am i correct ?
In the schematics, it is not very clear as if such arrangement is
there (though it says it can be an option in
RK3399_BOX_REF_V13_20180821.pdf).
Please suggest/comment on my requirement.
Thanks
Posted at 1/13/2025 15:07:48        Only Author  2#
Dive into abgerny Incredibox and craft musical beats with distinct rhythms, vocals, and melodies while discovering exciting new visual styles.
Posted at 2/26/2025 11:15:52        Only Author  3#
Have you checked if the RK808-D PMIC is configured to handle wake-up events from GPIO0_A5, and does the device tree include the necessary settings for Retro Bowl 25 power key wake-up in your Linux kernel configuration?
Posted at 3/25/2025 12:10:11        Only Author  4#
The Slope game tests even the most seasoned players as they tilt and weave through narrow corridors, sharp angles, and sudden drops. Accuracy is essential.
Posted at 4/3/2025 15:23:17        Only Author  5#
Each track is unique and offers a different kind of drift challenge.
Posted at 4/3/2025 15:24:01        Only Author  6#
The different locales in Drift Hunters are stunning! Each track is unique and offers a different kind of drift challenge.
Posted at 4/9/2025 09:51:37        Only Author  7#
Have you tried checking the GPIO0_A5 pin status after the poweroff command? And have you checked if u-boot or the kernel supports the wake from GPIO function? I think these That's Not My Neighbor details may affect whether the Power button can reactivate the system after shutdown.
Posted at 4/11/2025 17:28:33        Only Author  8#
The power key on RK3399-ROC-PC handles boot/shutdown functions. Piso Wifi Ensure correct GPIO mapping and kernel support for proper button behavior.
Posted at 4/11/2025 22:40:20        Only Author  9#
XBMC/Kodi can run on Linux with the RK3288 Firefly board, utilizing hardware video acceleration. This enables smoother playback of HD and 4K content, reduces CPU usage, Minecraft APK and enhances overall media performance, making it ideal for home theater setups.
Posted at 4/12/2025 15:01:23        Only Author  10#
On the rk3399-roc-pc running Linux, the power key/button can be configured via device tree and input-event handling for shutdown, Minecraft APK is an amazing gaming world which offers engaging suspend, or custom actions using systemd or ACPI scripts.
Return to List
1234
