[General] Armbian and LibreELEC for rk3399
885
Posted at 5/18/2021 19:49:56        Only Author  41#
Ver 20210517 kernel 5.10.37
Posted at 6/9/2021 19:56:35        Only Author  42#
ArmbianTV er 20210608 kernel 5.10.42 and 5.12.9 Please note that the kernel config has changed significantly.
Libreelec kernel 5.10.42
Posted at 6/14/2021 21:18:10        Only Author  43#
new version of Armbian and Libreelec 20210614 with core 5.10.43.
Added support for analog audio and a standard remote control.
To switch to analog sound on LE, after selecting the device in the settings, you need to restart the system to turn on the sound.
Posted at 6/21/2021 20:30:58        Only Author  44#
Ver 20210621 Armbian  and Libreelec
fixed analog sound and remote control
vip
Rank: 6Rank: 6
Posted at 6/23/2021 00:28:35        Only Author  45#
Does this board use the same rt5640 audio codec as Firefly-RK3399? If yes, is there any publicly available patch which can enable onboard sound on Firefly-RK3399 with mainline kernel?
Posted at 6/23/2021 14:01:16        Only Author  46#
The P1 uses a different 8388 chip (it now works with the main core). There is a driver for the 5640, but I did not check its operation. May need additional patches or settings.
Posted at 7/5/2021 14:24:03        Only Author  47#
The ArmbianTV and Libreelec version is 20210703.
Kernel 5.10.47 and 5.12.14.
Fixed the installation of the media package for the Buster-legacy version (kernel 4.4).
Posted at 7/22/2021 14:37:52        Only Author  48#
ver 20210721 kernel 5.10.52 \ 5.12.19
Posted at 7/22/2021 22:08:35        Only Author  49#
The first test version of AltLinux images (Russian Linux) for Firefly Station P1 is available.
https://en.altlinux.org/Main_Page
Starting the system is similar to starting Armbian\LE. Download the image, unpack it, burn it to a medium SD \ USB, connect it to P1 and turn on the power. At the first start, you need to perform several steps to configure the system.
https://disk.yandex.ru/d/pS0lB8a1ODeLPg
Posted at 8/19/2021 14:31:08        Only Author  50#
ver 20210816 kernel 5.10.59
