[Linux] Enable onboard sound on mainline kernel
1562
vip
Rank: 6Rank: 6
【Linux】 Enable onboard sound on mainline kernel
Posted at 10/17/2020 21:05:19      View:4211 | Replies:2        Print      Only Author   [Copy Link] 1#
Hi all!
I am using Firefly RK3399 with mainline kernel (distro: ARMtix) but i can't make onboard sound work. By default it is not detected at all.
I've tried to tweak kernel a bit, namely i added kernel config option which added a module for rt5640 codec to kernel and set "okay" status for i2s1 node in board device tree. With this rebuilt kernel ALSA detects the existance of rt5640 codec, i can hear a snap when i plug in headphones but no sound is played/recorded even with aplay/arecord utilities. What else should i do to make sound work?
Before running mainline kernel i used Rockchip one from slarm64 image for this board. The result was same as with patched mainline kernel
Posted at 1/11/2026 11:01:57        Only Author  2#
Thank you for bringing such an extraordinary article! The material in 1z0-1104-25 practice exam fee is extensive and offered freely to support your learning goals.
Posted at 1/13/2026 17:02:37        Only Author  3#
This article has helped me clarify my plans for future development. The Reliable HPE7-A07 braindumps ppt questions helped me secure a raise and promotion, and today, I’m sharing them for free!
