New Topic
[Hardware] Stuck in Maskrom
67
【Hardware】 Stuck in Maskrom
Posted at 12/25/2020 21:24:25      View:6330 | Replies:12        Print      Only Author   [Copy Link] 1#
My firefly rk3399 is now stuck in maskrom
the linux upgrade tool fail either at reset device or at prepare idb
I even tried rkdeveloptool and it seems to work
when it wrote idbloader, uboot and trust.bin
but when I restarted the board it was back in maskrom
also some times I can't the emmc info even after erasing it
is there a way that I can boot from sd card all the time?
vip
Rank: 6Rank: 6
Posted at 12/26/2020 02:13:29        Only Author  2#
If you shorten emmc (be careful, i've occasionally killed my one) you can boot from sdcard and erase all data from emmc. In fact, you only have to erase u-boot area, then board will always boot from sdcard
Posted at 12/26/2020 03:24:01        Only Author  3#
thanks I will try but I think I might have killed the emmc
Posted at 12/26/2020 20:50:49        Only Author  4#
not working
vip
Rank: 6Rank: 6
Posted at 12/27/2020 16:52:08        Only Author  5#
Which image and how do you flash on sdcard? It must contain working u-boot. Btw, do you use UART for debugging?
Posted at 12/28/2020 04:09:06        Only Author  6#
I tried with an Armbian image and the UART and nothing happens
I have nothing on the uart.  the only thing I see is the network light blinking
Posted at 12/28/2020 04:44:34        Only Author  7#
ok rechecked the wiring and now the uart works
here what I get:
DDR Version 1.24 20191016
In
Channel 0: DDR3, 800MHz
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
Channel 1: DDR3, 800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x2020
ch 1 ddrconfig = 0x101, ddrsize = 0x2020
pmugrf_os_reg[2] = 0x3AA17AA1, stride = 0xD
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 244
mmc: ERROR: SDHCI:Transfer data timeout
mmc: ERROR: SDHCI ERR:cmd:0x153a,stat:0x0
mmc: ERROR: Tuning procedure failed, falling back to fixed sampling clock
mmc: ERROR: tuning execution failed
emmc reinit
emmc reinit
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=29754MB
FwPartOffset=2000 , 0
StorageInit ok = 35213656
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret0)
GPT 0x3380ec0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
hdr 0000000003380880 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
Load OK, addr=0x200000, size=0xb1cb0
RunBL31 0x40000
NOTICE:  BL31: v1.3(debug):42583b6
NOTICE:  BL31: Built : 07:55:13, Oct 15 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1190): pd status 3e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2020.07-armbian (Dec 11 2020 - 22:39:11 +0100)
SoC: Rockchip rk3399
Reset cause: POR
Model: Firefly-RK3399 Board
DRAM:  3.9 GiB
PMIC:  RK808
Cannot find regulator pwm init_voltage
MMC:   mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial@ff1a0000
Out:   serial@ff1a0000
Err:   serial@ff1a0000
Net:   eth0: ethernet@fe300000
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found U-Boot script /boot/boot.scr
3185 bytes read in 6 ms (517.6 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1
116 bytes read in 6 ms (18.6 KiB/s)
13506866 bytes read in 585 ms (22 MiB/s)
27507200 bytes read in 1179 ms (22.2 MiB/s)
76119 bytes read in 15 ms (4.8 MiB/s)
2698 bytes read in 11 ms (239.3 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 09000000
## Loading init Ramdisk from Legacy Image at 06000000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    13506802 Bytes = 12.9 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to f5234000, end f5f158f2 ... OK
   Loading Device Tree to 00000000f51b9000, end 00000000f5233fff ... OK
Starting kernel ...
and it freeze there
Posted at 12/28/2020 05:08:17        Only Author  8#
more informaton with earlycon=on
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.9.14-rockchip64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #20.11.3 SMP PREEMPT Fri Dec 11 20:50:18 CET 2020
[    0.000000] Machine model: Firefly-RK3399 Board
[    0.000000] earlycon: uart0 at MMIO32 0x00000000ff1a0000 (options '1500000n8')
[    0.000000] printk: bootconsole [uart0] enabled
Posted at 1/20/2021 22:18:32        Only Author  9#
ok no matter which kernel I try it won't start and currently I don't know what to do
vip
Rank: 6Rank: 6
Posted at 1/21/2021 15:35:32        Only Author  10#
I remember that after applying two patches i could boot ARMtix. Writing this from it right now
Return to List
12
