Armbian and LibreELEC for rk3288
Posted at 3/21/2021 17:30:37
Versions of ArmbianTV and Libreelec.
Download links for new versions are now located here.
Dir rk3288
https://disk.yandex.ru/d/fRZwre9HDgAKHw?w=1
https://users.armbian.com/balbes150/
https://mega.nz/#F!j9QSDQSQ!6WpasOlbZYIInfw6yo4phQ
Using ArmbianTV.
1. Download,
2. Unpack,
3. burn the resulting image to the SD card.
4. Connect the SD card and turn on the power.
Launch LE
New image Libreelec (unoficcicial)
For rk3288, I release special images LE , there is no need to change anything, the system works immediately after writing to the SD card. All this works with almost all hardware (LAN WiFi HDMI sound) without additional settings.
dir rk3288 \ armv7 (name image rk3288)
https://yadi.sk/d/8vNYuuxynz1L0w?w=1
A prerequisite for starting - you must first erase the u-boot on the eMMC. This can be done using the USB tools, or you can use a special Multitool image created by Jock at this link. Please note DO NOT use Mulltitoo to install the system in eMMC, this will create a serious problem.
https://forum.armbian.com/topic/ ... 8-tv-box-boards-q8/ |
