[AIO-3568J]Booting Error
Posted at 5/22/2021 11:55:53
I bought AIO-3568J. But there is boorting error. like belows...
where do I fix?
U-Boot 2017.09 (Apr 30 2021 - 11:42:01 +0800)
Model: Rockchip RK3568 Evaluation Board
PreSerial: 2, raw, 0xfe660000
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 7d39f000, fdt: 7b9f9378
Using default environment
Hotkey: ctrl+s
dwmmc@fe2b0000: 1, dwmmc@fe2c0000: 2, sdhci@fe310000: 0
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
boot mode: recovery (misc)
FIT: No fdt blob
Android 11.0, Build 2021.4, v2
Found DTB in recovery part
DTB: rk-kernel.dtb
HASH(c): OK
ANDROID: fdt overlay OK
I2c0 speed: 100000Hz
PMIC: RK8090 (on=0x10, off=0x00)
vdd_logic init 900000 uV
vdd_gpu init 900000 uV
vdd_npu init 900000 uV
io-domain: OK
Model: AIO-3568J HDMI (Android)
Rockchip UBOOT DRM driver version: v1.0.1
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
apll 816000 KHz
dpll 780000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
npll 1200000 KHz
vpll 24000 KHz
hpll 24000 KHz
ppll 200000 KHz
armclk 816000 KHz
aclk_bus 150000 KHz
pclk_bus 100000 KHz
aclk_top_high 500000 KHz
aclk_top_low 400000 KHz
hclk_top 150000 KHz
pclk_top 100000 KHz
aclk_perimid 300000 KHz
hclk_perimid 150000 KHz
pclk_pmu 100000 KHz
Net: eth1: ethernet@fe010000, eth0: ethernet@fe2a0000
Hit key to stop autoboot('CTRL+C'): 0
## Booting FIT Image FIT: No fit blob
FIT: No FIT image
ANDROID: reboot reason: "recovery"
optee api revision: 2.0
Vboot=0, AVB images, AVB verify
read_is_device_unlocked() ops returned that device is UNLOCKED
avb_footer.c:41: ERROR: Footer magic is incorrect.
avb_vbmeta_image.c:65: ERROR: Magic is incorrect.
avb_slot_verify.c:770: ERROR: recovery: Error verifying vbmeta image: invalid vbmeta header
Verify recovery with vbmeta.
avb_slot_verify.c:759: ERROR: vbmeta: Error verifying vbmeta image: OK_NOT_SIGNED
get image from preloaded partition...
ANDROID: Hash OK
Could not find "system" partition
Booting IMAGE kernel at 0x00a80000 with fdt at 0x0a100000...
Fdt Ramdisk skip relocation
## Booting Android Image at 0x00a7f800 ...
Kernel load addr 0x00a80000 size 30265 KiB
RAM disk load addr 0x0a200000 size 20321 KiB
## Flattened Device Tree blob at 0x0a100000
Booting using the fdt blob at 0x0a100000
XIP Kernel Image from 0x00a80000 to 0x00a80000 ... OK
'reserved-memory' ramoops@110000: addr=110000 size=f0000
Using Device Tree in place at 000000000a100000, end 000000000a1222ed
Adding bank: 0x00a00000 - 0x80000000 (size: 0x7f600000)
Total: 1355.444 ms
Starting kernel ...
