Board boots into recovery mode
Posted at 4/18/2022 15:25:06
My board seems to boot into recovery mode instead of normal mode. I have tested two boards and the same problem occurs, so it can't be a hardware issue. Why doesn't it boot normally?
My log:
DDR Version V1.08 20210825
LPDDR4, 328MHz
BW=32 Col=10 Bk=8 CS0 Row=15 CS=1 Die BW=16 Size=1024MB
change to: 328MHz
change to: 528MHz
change to: 784MHz
change to: 924MHz(final freq)
out
U-Boot SPL board init
U-Boot SPL 2017.09(u-boot commit id: 617c0aeae793895dfbcfad2e0d67ce0620736a93)(sdk version: rv1126_rv1109_linux_release_20220324_v2.2.5b.xml)-g617c0aeae7-dirty #fredrik (Apr 17 2022 - 12:05:31)
unknown raw ID phN
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 2
spl: mmc init failed with error: -123
Trying to boot from MMC1
SPL: A/B-slot: _a, successful: 0, tries-remain: 7
## Verified-boot: 0
## Checking optee 0x08400000 (gzip @0x08600000) ... sha256(04121033ce...) + sha256(447872e443...) + OK
## Checking uboot 0x00400000 (gzip @0x00600000) ... sha256(581842953e...) + sha256(8e0a8af4fe...) + OK
## Checking fdt 0x004b6b24 ... sha256(80f00e7967...) + OK
Jumping to U-Boot(0x00400000) via OP-TEE(0x08400000)
Total: 148.254 ms
I/TC:
I/TC: cpu feature:0x0
I/TC: RV1126 SoC
I/TC: cpu_st=0xe0
I/TC: Next entry point address: 0x00400000
I/TC: OP-TEE version: 3.13.0-549-gef7f159d #derrick.huang (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #1 Thu Oct 28 10:52:10 CST 2021 arm
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
U-Boot 2017.09(u-boot commit id: 617c0aeae793895dfbcfad2e0d67ce0620736a93)(sdk version: rv1126_rv1109_linux_release_20220324_v2.2.5b.xml)-g617c0aeae7-dirty #fredrik (Apr 17 2022 - 12:05:31 +0200)
Model: Rockchip RV1126 Evaluation Board
PreSerial: 2, raw, 0xff570000
DRAM: 1021.7 MiB
Sysmem: init
Relocation Offset: 00000000
Relocation fdt: 3bbf9910 - 3bbfedec
CR: M/C/I
Using default environment
dwmmc@ffc50000: 0, dwmmc@ffc60000: 1
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
boot mode: recovery (misc)
FIT: no signed, no conf required
DTB: rk-kernel.dtb
HASH(c): OK
I2c0 speed: 400000Hz
PMIC: RK8090 (on=0x40, off=0x00)
vdd_npu_vepu 800000 uV
vdd_arm 800000 uV
io-domain: OK
Model: Firefly Core-RV1126-JD4 Board
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
apll 816000 KHz
dpll 462000 KHz
gpll 1188000 KHz
cpll 500000 KHz
hpll 1400000 KHz
aclk_pdbus 500000 KHz
hclk_pdbus 198000 KHz
pclk_pdbus 99000 KHz
aclk_pdphp 297000 KHz
hclk_pdphp 198000 KHz
hclk_pdaudio 148500 KHz
hclk_pdcore 198000 KHz
pclk_pdpmu 99000 KHz
Net: eth0: ethernet@ffc40000
Hit key to stop autoboot('CTRL+C'): 0
## Booting FIT Image at 0x3ac1f900 with size 0x00dd7000
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at 3ac1f900 ...
Using 'conf' configuration
optee api revision: 2.0
TEEC: Waring: Could not find security partition
## Verified-boot: 0
Trying 'kernel' kernel subimage
Description: unavailable
Type: Kernel Image
Compression: uncompressed
Data Start: 0x3ac39500
Data Size: 7423288 Bytes = 7.1 MiB
Architecture: ARM
OS: Linux
Load Address: 0x02008000
Entry Point: 0x02008000
Hash algo: sha256
Hash value: d83c2b05a30510a53abbe2b98d1ce40b9c52b2cc414ba962e4ee741164a1f594
Verifying Hash Integrity ... sha256+ OK
## Loading ramdisk from FIT Image at 3ac1f900 ...
Trying 'ramdisk' ramdisk subimage
Type: RAMDisk Image
Data Start: 0x3b34db00
Data Size: 6983035 Bytes = 6.7 MiB
Architecture: ARM
OS: Linux
Load Address: 0x0a200000
Entry Point: unavailable
Hash algo: sha256
Hash value: 36097fb4fd2c408b8c97a7c53b10cf8933aaa4df040f97cc2241dba26c0dc237
Loading ramdisk from 0x3b34db00 to 0x0a200000
## Loading fdt from FIT Image at 3ac1f900 ...
Trying 'fdt' fdt subimage
Type: Flat Device Tree
Data Start: 0x3ac20100
Data Size: 103010 Bytes = 100.6 KiB
Architecture: ARM
Load Address: 0x08300000
Hash algo: sha256
Hash value: dd30c3c38c8bfe69807dd28e4d9f4f86a1a081ee8d3e4711646b46531484355c
Loading fdt from 0x08300000 to 0x08300000
Booting using the fdt blob at 0x08300000
Loading Kernel Image from 0x3ac39500 to 0x02008000 ... OK
'reserved-memory' ramoops@8000000: addr=8000000 size=100000
Using Device Tree in place at 08300000, end 0831c261
Adding bank: 0x00000000 - 0x08400000 (size: 0x08400000)
Adding bank: 0x08648000 - 0x40000000 (size: 0x379b8000)
Total: 419.9 ms
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Linux version 4.19.111 (fredrik@fredrik-Aspire-A515-55) (kernel commit id: 85988bd7b1fc67ac96e868b90f4e676f44c713ae) (sdk version: rv1126_rv1109_linux_release_20220324_v2.2.5b.xml) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #38 SMP PREEMPT Sat Apr 16 10:36:37 CEST 2022
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Firefly Core-RV1126-JD4 Board
[ 0.000000] earlycon: uart8250 at MMIO32 0xff570000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x00000000, size 0 MiB
[ 0.000000] Reserved memory: created CMA memory pool at 0x3f800000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x2f800000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node isp, compatible id shared-dma-pool
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 15 pages/cpu s32204 r8192 d21044 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 259512
[ 0.000000] Kernel command line: user_debug=31 storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal ro rootwait earlycon=uart8250,mmio32,0xff570000 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 cgroup_enable=memory swapaccount=1 snd_aloop.index=7
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] mem auto-init: stackff, heap allocff, heap freeff
[ 0.000000] Memory: 742872K/1046240K available (10240K kernel code, 417K rwdata, 2532K rodata, 1024K init, 323K bss, 33032K reserved, 270336K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xb0000000 - 0xf0000000 (1024 MB)
[ 0.000000] pkmap : 0xafe00000 - 0xb0000000 ( 2 MB)
[ 0.000000] modules : 0xaf000000 - 0xafe00000 ( 14 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (11232 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 418 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 324 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x328/0x4ac with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000753] Switching to timer-based delay loop, resolution 41ns
[ 0.002655] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.003612] pid_max: default: 4096 minimum: 301
[ 0.004217] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.004841] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.006279] CPU: Testing write buffer coherency: ok
[ 0.007121] /cpus/cpu@f00 missing clock-frequency property
[ 0.007644] /cpus/cpu@f01 missing clock-frequency property
[ 0.008164] /cpus/cpu@f02 missing clock-frequency property
[ 0.008683] /cpus/cpu@f03 missing clock-frequency property
[ 0.009199] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.010505] Setting up static identity map for 0x100000 - 0x100060
[ 0.011251] rcu: Hierarchical SRCU implementation.
[ 0.012347] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
[ 0.014408] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.016136] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.017870] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.018008] smp: Brought up 1 node, 4 CPUs
[ 0.020006] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.020586] CPU: All CPU(s) started in SVC mode.
[ 0.021924] devtmpfs: initialized
[ 0.049444] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.049515] Unpacking initramfs...
[ 0.050929] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.051840] futex hash table entries: 16 (order: -2, 1024 bytes)
[ 0.052662] pinctrl core: initialized pinctrl subsystem
[ 0.054538] NET: Registered protocol family 16
[ 0.055737] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.058528] cpuidle: using governor menu
[ 0.058931] Registered FIQ tty driver
[ 0.060033] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.060771] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.063663] console [pstore-1] enabled
[ 0.064336] pstore: Registered ramoops as persistent store backend
[ 0.064955] ramoops: attached 0x100000@0x8000000, ecc: 0/0
[ 0.113607] cryptd: max_cpu_qlen set to 1000
[ 0.115210] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 0.121482] rk_iommu ffb00f00.iommu: version = 1
[ 0.122541] rk_iommu ffb20800.iommu: version = 1
[ 0.123484] rk_iommu ffb60e00.iommu: version = 1
[ 0.124584] rk_iommu ffb80480.iommu: version = 1
[ 0.125612] rk_iommu ffb90800.iommu: version = 1
[ 0.126682] rk_iommu ffbb0f00.iommu: version = 1
[ 0.128204] SCSI subsystem initialized
[ 0.128874] usbcore: registered new interface driver usbfs
[ 0.129452] usbcore: registered new interface driver hub
[ 0.130155] usbcore: registered new device driver usb
[ 0.130738] media: Linux media interface: v0.10
[ 0.131214] videodev: Linux video capture interface: v2.00
[ 0.131778] pps_core: LinuxPPS API ver. 1 registered
[ 0.132243] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.133108] PTP clock support registered
[ 0.135111] Advanced Linux Sound Architecture Driver Initialized.
[ 0.136373] Bluetooth: Core ver 2.22
[ 0.136785] NET: Registered protocol family 31
[ 0.137204] Bluetooth: HCI device and connection manager initialized
[ 0.137803] Bluetooth: HCI socket layer initialized
[ 0.138266] Bluetooth: L2CAP socket layer initialized
[ 0.138816] Bluetooth: SCO socket layer initialized
[ 0.139885] rockchip-cpuinfo cpuinfo: SoC : 11260000
[ 0.140367] rockchip-cpuinfo cpuinfo: Serial : 1cb2e4589fab0089
[ 0.142111] clocksource: Switched to clocksource arch_sys_counter
[ 0.145353] NET: Registered protocol family 2
[ 0.146689] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.147438] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.148226] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.149067] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.149829] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.150434] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.151282] NET: Registered protocol family 1
[ 0.153846] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.157274] Initialise system trusted keyrings
[ 0.158023] workingset: timestamp_bits=29 max_order=18 bucket_order=0
[ 0.166313] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.169695] Key type asymmetric registered
[ 0.170096] Asymmetric key parser 'x509' registered
[ 0.170619] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.171309] io scheduler noop registered
[ 0.171677] io scheduler deadline registered
[ 0.172300] io scheduler cfq registered (default)
[ 0.172747] io scheduler mq-deadline registered
[ 0.173171] io scheduler kyber registered
[ 0.173709] io scheduler bfq registered
[ 0.178446] phy phy-ff4c0000.usb2-phy.1: Linked as a consumer to regulator.5
[ 0.181283] phy phy-ff4c8000.usb2-phy.2: Linked as a consumer to regulator.4
[ 0.185989] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 0.186868] pwm-backlight backlight: Linked as a consumer to regulator.0
[ 0.187855] mpp_service mpp-srv: 92c80ddf68f6 author: Yandong Lin 2021-08-10 video: rockchip: mpp: workaround patch for rv1126 iommu issue
[ 0.189042] mpp_service mpp-srv: probe start
[ 0.190417] iommu: Adding device ffb80000.rkvdec to group 3
[ 0.190976] mpp_rkvdec ffb80000.rkvdec: Linked as a consumer to ffb80480.iommu
[ 0.191832] mpp_rkvdec ffb80000.rkvdec: probing start
[ 0.193075] mpp_rkvdec ffb80000.rkvdec: shared_niu_a is not found!
[ 0.193657] rkvdec_init:1190: No niu aclk reset resource define
[ 0.194213] mpp_rkvdec ffb80000.rkvdec: shared_niu_h is not found!
[ 0.194789] rkvdec_init:1193: No niu hclk reset resource define
[ 0.195701] mpp_rkvdec ffb80000.rkvdec: probing finish
[ 0.196997] iommu: Adding device ffbb0000.rkvenc to group 5
[ 0.197552] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to ffbb0f00.iommu
[ 0.198538] mpp_rkvenc ffbb0000.rkvenc: probing start
[ 0.199720] mpp_rkvenc ffbb0000.rkvenc: venc regulator not ready, retry
[ 0.200344] rkvenc_init:1202: failed to add venc devfreq
[ 0.202019] iommu: Adding device ffb90400.vdpu to group 4
[ 0.202625] mpp_vdpu2 ffb90400.vdpu: Linked as a consumer to ffb90800.iommu
[ 0.203384] mpp_vdpu2 ffb90400.vdpu: probe device
[ 0.204398] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[ 0.204958] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[ 0.205800] mpp_vdpu2 ffb90400.vdpu: probing finish
[ 0.206920] iommu: Adding device ffb90000.vepu to group 4
[ 0.207455] mpp_vepu2 ffb90000.vepu: Linked as a consumer to ffb90800.iommu
[ 0.208209] mpp_vepu2 ffb90000.vepu: probe device
[ 0.209229] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[ 0.209782] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[ 0.210561] mpp_vepu2 ffb90000.vepu: probing finish
[ 0.211573] iommu: Adding device ffb20000.iep to group 1
[ 0.212151] mpp-iep2 ffb20000.iep: Linked as a consumer to ffb20800.iommu
[ 0.212885] mpp-iep2 ffb20000.iep: probe device
[ 0.214043] mpp-iep2 ffb20000.iep: allocate roi buffer failed
[ 0.214804] mpp-iep2 ffb20000.iep: probing finish
[ 0.215560] mpp_service mpp-srv: probe success
[ 0.221207] dma-pl330 ff4e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.221927] dma-pl330 ff4e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.224858] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.226498] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.228030] ff560000.serial: ttyS0 at MMIO 0xff560000 (irq = 30, base_baud = 1500000) is a 16550A
[ 0.231302] random: fast init done
[ 0.231993] random: crng init done
[ 0.232135] iommu: Adding device ffb00000.vop to group 0
[ 0.232893] rockchip-vop ffb00000.vop: Linked as a consumer to ffb00f00.iommu
[ 0.248669] loop: module loaded
[ 0.249754] zram: Added device: zram0
[ 0.254526] libphy: Fixed MDIO Bus: probed
[ 0.256221] PPP generic driver version 2.4.2
[ 0.256901] PPP BSD Compression module registered
[ 0.257348] PPP Deflate Compression module registered
[ 0.257839] PPP MPPE Compression module registered
[ 0.258290] NET: Registered protocol family 24
[ 0.258897] usbcore: registered new interface driver r8152
[ 0.259478] usbcore: registered new interface driver asix
[ 0.260044] usbcore: registered new interface driver ax88179_178a
[ 0.260662] usbcore: registered new interface driver cdc_ether
[ 0.261278] usbcore: registered new interface driver net1080
[ 0.261858] usbcore: registered new interface driver cdc_subset
[ 0.262498] usbcore: registered new interface driver zaurus
[ 0.263101] usbcore: registered new interface driver cdc_ncm
[ 0.263691] usbcore: registered new interface driver qmi_wwan
[ 0.266053] dwc3 ffd00000.dwc3: Failed to get clk 'ref': -2
[ 0.273076] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.273698] ehci-platform: EHCI generic platform driver
[ 0.277830] ehci-platform ffe00000.usb: EHCI Host Controller
[ 0.278408] ehci-platform ffe00000.usb: new USB bus registered, assigned bus number 1
[ 0.279358] ehci-platform ffe00000.usb: irq 61, io mem 0xffe00000
[ 0.292208] ehci-platform ffe00000.usb: USB 2.0 started, EHCI 1.00
[ 0.293105] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.293877] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.294549] usb usb1: Product: EHCI Host Controller
[ 0.295008] usb usb1: Manufacturer: Linux 4.19.111 ehci_hcd
[ 0.295577] usb usb1: SerialNumber: ffe00000.usb
[ 0.296865] hub 1-0:1.0: USB hub found
[ 0.297284] hub 1-0:1.0: 1 port detected
[ 0.298455] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.299096] ohci-platform: OHCI generic platform driver
[ 0.300250] ohci-platform ffe10000.usb: Generic Platform OHCI controller
[ 0.300912] ohci-platform ffe10000.usb: new USB bus registered, assigned bus number 2
[ 0.301810] ohci-platform ffe10000.usb: irq 62, io mem 0xffe10000
[ 0.363174] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 0.363960] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.364633] usb usb2: Product: Generic Platform OHCI controller
[ 0.365184] usb usb2: Manufacturer: Linux 4.19.111 ohci_hcd
[ 0.365749] usb usb2: SerialNumber: ffe10000.usb
[ 0.367090] hub 2-0:1.0: USB hub found
[ 0.367503] hub 2-0:1.0: 1 port detected
[ 0.369661] usbcore: registered new interface driver cdc_wdm
[ 0.370318] usbcore: registered new interface driver usb-storage
[ 0.371041] usbcore: registered new interface driver option
[ 0.371599] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.373367] i2c /dev entries driver
[ 0.375794] rk808 0-0020: chip id: 0x8090
[ 0.376262] rk808 0-0020: No cache defaults, reading back from HW
[ 0.383285] rk808 0-0020: source: on=0x40, off=0x00
[ 0.383764] rk808 0-0020: support dcdc3 fb mode:-22, -1328928868
[ 0.384330] rk808 0-0020: support pmic reset mode:0,0
[ 0.389321] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.389988] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 0.390648] DCDC_REG1: supplied by vcc5v0_sys
[ 0.391786] DCDC_REG2: supplied by vcc5v0_sys
[ 0.392955] DCDC_REG3: supplied by vcc5v0_sys
[ 0.393859] DCDC_REG4: supplied by vcc5v0_sys
[ 0.394764] DCDC_REG5: supplied by vcc5v0_sys
[ 0.395858] LDO_REG1: supplied by vcc_buck5
[ 0.396876] LDO_REG2: supplied by vcc_buck5
[ 0.397749] LDO_REG3: supplied by vcc_buck5
[ 0.398625] LDO_REG4: supplied by vcc_buck5
[ 0.399561] LDO_REG5: supplied by vcc_buck5
[ 0.400448] LDO_REG6: supplied by vcc_buck5
[ 0.400901] vcc_dvdd: Bringing 1100000uV into 1200000-1200000uV
[ 0.402077] LDO_REG7: supplied by vcc5v0_sys
[ 0.403017] LDO_REG8: supplied by vcc5v0_sys
[ 0.404058] LDO_REG9: supplied by vcc5v0_sys
[ 0.405090] SWITCH_REG1: supplied by vcc5v0_sys
[ 0.406027] SWITCH_REG2: supplied by vcc3v3_sys
[ 0.408829] input: rk805 pwrkey as /devices/platform/ff3f0000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0
[ 0.412743] rk808-rtc rk808-rtc: registered as rtc0
[ 0.413783] rk808-rtc rk808-rtc: setting system clock to 2017-08-04 09:00:02 UTC (1501837202)
[ 0.418448] rockchip-mipi-csi2: probe success, v4l2_devnull)!
[ 0.420452] rkcifhw ffae0000.rkcif: no iommu attached, using non-iommu buffers
[ 0.421150] rkcifhw ffae0000.rkcif: assigned reserved memory node isp
[ 0.421879] rkcif rkcif_dvp: rkcif driver version: v00.01.0a
[ 0.422528] rkcif rkcif_dvp: attach to cif hw node
[ 0.422987] rkcif rkcif_dvp: rkcif wait line 0
[ 0.424533] rkcif_dvp: cif_subdev_notifier: no subdev be found!
[ 0.425093] rkcif_dvp: Failed to register subdev notifier(-19)
[ 0.426675] rkcif rkcif_dvp: detach to cif hw node
[ 0.427236] rkcif rkcif_mipi_lvds: rkcif driver version: v00.01.0a
[ 0.427900] rkcif rkcif_mipi_lvds: attach to cif hw node
[ 0.428404] rkcif rkcif_mipi_lvds: rkcif wait line 0
[ 0.429968] rkcif rkcif_mipi_lvds: Entity type for entity rockchip-mipi-csi2 was not initialized!
[ 0.430798] rockchip-mipi-csi2: Async registered subdev
[ 0.433761] rkisp_hw ffb50000.rkisp: is_thunderboot: 0
[ 0.434259] rkisp_hw ffb50000.rkisp: Missing rockchip,grf property
[ 0.435179] rkisp_hw ffb50000.rkisp: iommu is disabled, using non-iommu buffers
[ 0.435923] rkisp_hw ffb50000.rkisp: assigned reserved memory node isp
[ 0.436885] rkisp rkisp-vir0: rkisp driver version: v01.06.02
[ 0.437653] rkisp rkisp-vir0: No memory-region-thunderboot specified
[ 0.438508] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 0.439340] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[ 0.440117] rkisp rkisp-vir0: Entity type for entity rkisp-bridge-ispp was not initialized!
[ 0.445352] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.20
[ 0.446254] rockchip-iodomain fe020000.syscon:io-domains: vccio2(3300000 uV) supplied by vccio_sd
[ 0.447202] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.16
[ 0.448032] rockchip-iodomain fe020000.syscon:io-domains: vccio3(1800000 uV) supplied by vcc_1v8
[ 0.449027] rockchip-iodomain fe020000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[ 0.449950] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.23
[ 0.450785] rockchip-iodomain fe020000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[ 0.451723] rockchip-iodomain fe020000.syscon:io-domains: vccio6(3300000 uV) supplied by vcc_3v3
[ 0.452716] rockchip-iodomain fe020000.syscon:io-domains: vccio7(1800000 uV) supplied by vcc_1v8
[ 0.453652] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.14
[ 0.454477] rockchip-iodomain fe020000.syscon:io-domains: pmuio0(1800000 uV) supplied by vcc1v8_pmu
[ 0.455470] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.11
[ 0.456299] rockchip-iodomain fe020000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_sys
[ 0.459460] cw201x 2-0062: design_capacity missing!
[ 0.460280] cw_bat_probe cw_init error
[ 0.461805] rockchip-thermal ff5f0000.tsadc: tsadc trimmed value = 0
[ 0.462877] rockchip-thermal ff5f0000.tsadc: tsadc is probed successfully!
[ 0.464038] rockchip-thermal ff5f8000.tsadc: tsadc trimmed value = 4
[ 0.464929] rockchip-thermal ff5f8000.tsadc: tsadc is probed successfully!
[ 0.466587] Bluetooth: HCI UART driver ver 2.3
[ 0.467013] Bluetooth: HCI UART protocol H4 registered
[ 0.467662] Bluetooth: HCI UART protocol Broadcom registered
[ 0.468511] cpu cpu0: bin=0
[ 0.468852] cpu cpu0: leakage=1.250
[ 0.469348] cpu cpu0: Linked as a consumer to regulator.9
[ 0.481564] cpu cpu0: temp=35700, pvtm=95748 (95668 + 80)
[ 0.482232] cpu cpu0: pvtm-volt-sel=1
[ 0.482664] cpu cpu0: Dropping the link to regulator.9
[ 0.483198] cpu cpu0: bin-scale=5
[ 0.483982] cpu cpu0: Linked as a consumer to regulator.9
[ 0.484552] cpu cpu0: Dropping the link to regulator.9
[ 0.485267] cpu cpu0: Linked as a consumer to regulator.9
[ 0.487004] cpu cpu0: avs=0
[ 0.487719] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 0.488462] cpu cpu0: failed to read out thermal zone (-22)
[ 0.490101] cpu cpu0: failed to find power_model node
[ 0.490697] cpuidle: enable-method property 'psci' found operations
[ 0.491464] cpuidle: enable-method property 'psci' found operations
[ 0.492316] cpuidle: enable-method property 'psci' found operations
[ 0.493066] cpuidle: enable-method property 'psci' found operations
[ 0.494367] Synopsys Designware Multimedia Card Interface Driver
[ 0.495501] dwmmc_rockchip ffc50000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.496190] dwmmc_rockchip ffc50000.dwmmc: Using internal DMA controller.
[ 0.496822] dwmmc_rockchip ffc50000.dwmmc: Version ID is 270a
[ 0.497401] dwmmc_rockchip ffc50000.dwmmc: DW MMC controller at irq 56,32 bit host data width,256 deep fifo
[ 0.498427] mmc_host mmc0: card is non-removable.
[ 0.511863] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.526336] dwmmc_rockchip ffc60000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.527075] dwmmc_rockchip ffc60000.dwmmc: Using internal DMA controller.
[ 0.527773] dwmmc_rockchip ffc60000.dwmmc: Version ID is 270a
[ 0.528357] dwmmc_rockchip ffc60000.dwmmc: DW MMC controller at irq 57,32 bit host data width,256 deep fifo
[ 0.529505] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.21
[ 0.530279] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.20
[ 0.542277] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.556392] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.557233] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[ 0.557897] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[ 0.558492] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 58,32 bit host data width,256 deep fifo
[ 0.559691] dwmmc_rockchip ffc70000.dwmmc: allocated mmc-pwrseq
[ 0.560340] mmc_host mmc1: card is non-removable.
[ 0.560887] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 200000000Hz, actual 198000000HZ div = 0)
[ 0.561826] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 90
[ 0.564030] mmc0: new HS200 MMC card at address 0001
[ 0.566096] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[ 0.567177] mmcblk0boot0: mmc0:0001 8GTF4R partition 1 4.00 MiB
[ 0.568376] mmcblk0boot1: mmc0:0001 8GTF4R partition 2 4.00 MiB
[ 0.569809] mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB, chardev (241:0)
[ 0.575491] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.577830] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[ 0.590259] usbcore: registered new interface driver usbkbd
[ 0.590830] usbcore: registered new interface driver usbmouse
[ 0.592951] rockchip-saradc ff5e0000.saradc: Linked as a consumer to regulator.16
[ 0.594523] rksfc_base v1.1 2016-01-08
[ 0.595304] rksfc ffc90000.sfc: rksfc_probe clk rate = 79200000
[ 0.596004] rkflash_dev_init enter
[ 0.596395] sfc nor id: 0 0 0
[ 0.596671] rkflash[1] is invalid
[ 0.596674] rkflash_dev_init enter
[ 0.597362] sfc_nand id: 0 0 0
[ 0.597655] rkflash[2] is invalid
[ 0.601789] rk817-codec rk817-codec: DMA mask not set
[ 0.602882] rk817_codec_parse_dt_property: rk809 have no io-channels defined
[ 0.605030] Freeing initrd memory: 6820K
[ 0.607905] NET: Registered protocol family 17
[ 0.608351] NET: Registered protocol family 15
[ 0.609248] Bluetooth: RFCOMM TTY layer initialized
[ 0.609801] Bluetooth: RFCOMM socket layer initialized
[ 0.610535] Bluetooth: RFCOMM ver 1.11
[ 0.610956] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 0.611524] Bluetooth: HIDP socket layer initialized
[ 0.611991] [BT_RFKILL]: Enter rfkill_rk_init
[ 0.612491] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 0.613416] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 0.613977] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275s
[ 0.614634] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 0.615299] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 0.616175] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 8, flags = 0.
[ 0.616937] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 0.617429] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 0.618750] flash vendor_init_thread!
[ 0.619240] flash vendor storage:20170308 ret = -1
[ 0.619926] Registering SWP/SWPB emulation handler
[ 0.622264] Loading compiled-in X.509 certificates
[ 0.623918] rga2: Driver loaded successfully ver:3.2.56726
[ 0.624647] rga2: Module initialized.
[ 0.624994] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.625476] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 0.627436] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.629526] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.632827] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.636754] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[ 0.637922] vendor storage:20190527 ret = 0
[ 0.647074] mpp_rkvenc ffbb0000.rkvenc: probing start
[ 0.648428] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to regulator.8
[ 0.649206] mpp_rkvenc ffbb0000.rkvenc: bin=0
[ 0.649668] mpp_rkvenc ffbb0000.rkvenc: leakage=1.125
[ 0.650244] mpp_rkvenc ffbb0000.rkvenc: Failed to get pvtm
[ 0.650809] mpp_rkvenc ffbb0000.rkvenc: bin-scale=37
[ 0.651598] mpp_rkvenc ffbb0000.rkvenc: avs=0
[ 0.652329] mpp_rkvenc ffbb0000.rkvenc: failed to find power_model node
[ 0.652969] mpp_rkvenc ffbb0000.rkvenc: failed to initialize power model
[ 0.653811] mpp_rkvenc ffbb0000.rkvenc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 0.654720] mpp_rkvenc ffbb0000.rkvenc: failed to read out thermal zone (-22)
[ 0.656480] mpp_rkvenc ffbb0000.rkvenc: probing finish
[ 0.657509] input: adc-keys as /devices/platform/adc-keys/input/input1
[ 0.660913] asoc-simple-card rk809-sound: rk817-hifi <-> ff800000.i2s mapping ok
[ 0.661650] asoc-simple-card rk809-sound: ASoC: no source widget found for MICBIAS1
[ 0.662432] asoc-simple-card rk809-sound: ASoC: Failed to add route MICBIAS1 -> direct -> Mic Jack
[ 0.663288] asoc-simple-card rk809-sound: ASoC: no sink widget found for IN1P
[ 0.663972] asoc-simple-card rk809-sound: ASoC: Failed to add route Mic Jack -> direct -> IN1P
[ 0.664790] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOL
[ 0.665513] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOL -> direct -> Headphone Jack
[ 0.666379] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOR
[ 0.667082] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOR -> direct -> Headphone Jack
[ 0.669853] input: rockchip,rk809-codec Headphone Jack as /devices/platform/rk809-sound/sound/card0/input2
[ 0.674613] dhd_module_init: in Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8)
[ 0.675457] ======== dhd_wlan_init_plat_data ========
[ 0.675943] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 0.676567] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=99, oob_irq_flags=0x414
[ 0.677270] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 0.677671] dhd_wifi_platform_load: Enter
[ 0.678044] Power-up adapter 'DHD generic adapter'
[ 0.678544] wifi_platform_set_power = 1, delay: 200 msec
[ 0.679125] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 0.679626] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 0.680087] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[ 0.680946] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 0.744266] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 0.748704] mmc1: new high speed SDIO card at address 0001
[ 0.774698] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.70
[ 0.775478] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 0.776159] usb 1-1: Product: USB2.0 Hub
[ 0.777702] hub 1-1:1.0: USB hub found
[ 0.778426] hub 1-1:1.0: 4 ports detected
[ 0.985842] wifi_platform_bus_enumerate device present 1
[ 0.986374] ======== Card detection to detect SDIO card! ========
[ 0.986950] mmc1:mmc host rescan start!
[ 1.003952] bcmsdh_register: register client driver
[ 1.005365] bcmsdh_sdmmc_probe: Enter num=1
[ 1.007238] bcmsdh_sdmmc_probe: Enter num=2
[ 1.007669] bus num (host idx)=1, slot num (rca)=1
[ 1.008125] found adapter info 'DHD generic adapter'
[ 1.009616] sdioh_attach: set sd_f2_blocksize 256
[ 1.011685] sdioh_attach: sd clock rate = 0
[ 1.018659] dhdsdio_probe : no mutex held. set lock
[ 1.020537] F1 signature read @0x18000000=0x1542a9a6
[ 1.028340] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x2 pkg:0x4
[ 1.030524] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 1.031354] [dhd] dhd_conf_set_chiprev : chip=0xa9a6, chiprev=2
[ 1.034977] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 1.036319] dhd_log_dump_init: kernel log buf size = 128KB; logdump_prsrv_tailsize = 80KB; limit prsrv tail size to = 19KB
[ 1.039526] dhd_attach(): thread:dhd_watchdog_thread:55 started
[ 1.040883] dhd_attach(): thread:dhd_dpc:56 started
[ 1.041636] dhd_attach(): thread:dhd_rxf:57 started
[ 1.042170] dhd_deferred_work_init: work queue initialized
[ 1.042716] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 -> mode 2
[ 1.043448] get_mem_val_from_file: File [/data/misc/wifi/.memdump.info] doesn't exist
[ 1.044166] dhd_get_memdump_info: MEMDUMP ENABLED = 3
[ 1.044636] sdioh_cis_read: func_cis_ptr[0]=0x1070
[ 1.057948] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 1.058549] Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8)
[ 1.059711] Register interface [wlan0] MAC: 10:2c:6b:7e:18:4a
[ 1.059711]
[ 1.060568] dhd_dbg_detach_pkt_monitor, 2100
[ 1.060978] dhd_bus_devreset: == Power OFF ==
[ 1.061580] dhd_bus_stop: making DHD_BUS_DOWN
[ 1.062007] bcmsdh_oob_intr_unregister: Enter
[ 1.062128] usb 1-1.3: new high-speed USB device number 3 using ehci-platform
[ 1.062508] bcmsdh_oob_intr_unregister: irq is not registered
[ 1.063642] dhd_bus_devreset: making dhdpub up FALSE
[ 1.064104] dhd_txglom_enable: enable 0
[ 1.064459] dhd_bus_devreset: making DHD_BUS_DOWN
[ 1.064893] dhd_bus_devreset: WLAN OFF DONE
[ 1.065342] wifi_platform_set_power = 0, delay: 0 msec
[ 1.065920] ======== PULL WL_REG_ON(-1) LOW! ========
[ 1.066409] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 1.066853] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[ 1.067673] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 1.068167] dhdsdio_probe : the lock is released.
[ 1.069060] dhd_module_init: Exit err=0
[ 1.069719] ==gsl_ts_init==
[ 1.070019] ret=0
[ 1.070222] rkcif rkcif_mipi_lvds: clear unready subdev num: 1
[ 1.070783] rockchip-mipi-csi2: No link between dphy and sensor
[ 1.071585] rockchip-mipi-csi2: No link between dphy and sensor
[ 1.072189] rkcif_mipi_lvds: Async subdev notifier completed
[ 1.073505] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.081671] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
