Using imx219 camera with thunder boot
Posted at 4/28/2022 09:10:21
I have a camera with a imx219 sensor that is connected to the mother board (JD4-
RV11091126) with Core-1126-JD4 and I have managed to capture frames in normal mode (build file aio-rv1126-jd4-BE-45.mk).
When I enable thunder boot with aio-rv1126-jd4-BE-45-tb-v11.mk no frames are captured.
How to fix this?
- grep '' /sys/class/video4linux/video*/name
- /sys/class/video4linux/video0/name:rkisp_rawrd0_m
- /sys/class/video4linux/video1/name:rkisp_rawrd1_l
- /sys/class/video4linux/video10/name:rkisp_rawrd2_s
- /sys/class/video4linux/video11/name:rkisp-mipi-luma
- /sys/class/video4linux/video12/name:stream_cif_mipi_id0
- /sys/class/video4linux/video13/name:stream_cif_mipi_id1
- /sys/class/video4linux/video14/name:stream_cif_mipi_id2
- /sys/class/video4linux/video15/name:stream_cif_mipi_id3
- /sys/class/video4linux/video16/name:rkcif-mipi-luma
- /sys/class/video4linux/video2/name:rkisp-statistics
- /sys/class/video4linux/video3/name:rkisp_mainpath
- /sys/class/video4linux/video4/name:rkisp_selfpath
- /sys/class/video4linux/video5/name:rkisp_rawwr0
- /sys/class/video4linux/video6/name:rkisp_rawwr1
- /sys/class/video4linux/video7/name:rkisp-input-params
- /sys/class/video4linux/video8/name:rkisp_rawwr2
- /sys/class/video4linux/video9/name:rkisp_rawwr3
Copy the code
- v4l2-ctl -d /dev/video4 --set-fmt-video=width=640,height=480,pixelformat=NV12
- --stream-mmap=3 --stream-skip=3 --stream-to=/tmp/nv12.bin --stream-count=100 --s
- tream-poll
- select timeout
Copy the code
- [ 41.913678] rkisp0: rkisp_isp_sd_s_power on:1
- [ 41.914059] videodev: v4l2_open: video6: open (0)
- [ 41.914137] video6: VIDIOC_QUERYCAP: driver=rkisp_v4, card=rkisp_selfpath, bus=platform:rkisp-vir0, version=0x0004136f, capabilities=0x84201000, device_caps=0x04201000
- [ 41.914167] video6: VIDIOC_QUERY_EXT_CTRL: id=0x980001, type=6, name=User Controls, min/max=0/0, step=0, default=0, flags=0x00000044, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
- [ 41.914185] video6: VIDIOC_TRY_EXT_CTRLS: which=0x0, count=0, error_idx=0
- [ 41.914198] video6: VIDIOC_QUERYCTRL: id=0x980001, type=6, name=User Controls, min/max=0/0, step=0, default=0, flags=0x00000044
- [ 41.914211] video6: VIDIOC_G_SELECTION: type=vid-cap, target=0, flags=0x0, wxh=1920x1080, x,y=0,0
- [ 41.914224] video6: VIDIOC_QUERYCAP: driver=rkisp_v4, card=rkisp_selfpath, bus=platform:rkisp-vir0, version=0x0004136f, capabilities=0x84201000, device_caps=0x04201000
- [ 41.914465] video6: VIDIOC_QUERY_EXT_CTRL: id=0x980001, type=6, name=User Controls, min/max=0/0, step=0, default=0, flags=0x00000044, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
- [ 41.914486] video6: VIDIOC_QUERY_EXT_CTRL: id=0x980001, type=6, name=User Controls, min/max=0/0, step=0, default=0, flags=0x00000044, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
- [ 41.914502] video6: VIDIOC_QUERY_EXT_CTRL: id=0x980911, type=1, name=Exposure, min/max=0/4095, step=1, default=1575, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
- [ 41.914563] video6: VIDIOC_QUERY_EXT_CTRL: id=0x980913, type=1, name=Gain, min/max=256/43663, step=1, default=256, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
- [ 41.914589] video6: VIDIOC_QUERY_EXT_CTRL: id=0x980914, type=2, name=Horizontal Flip, min/max=0/1, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
- [ 41.914618] video6: VIDIOC_QUERY_EXT_CTRL: id=0x980915, type=2, name=Vertical Flip, min/max=0/1, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
- [ 41.914642] video6: VIDIOC_QUERY_EXT_CTRL: id=0x9e0001, type=6, name=Image Source Controls, min/max=0/0, step=0, default=0, flags=0x00000044, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
- [ 41.914658] video6: VIDIOC_QUERY_EXT_CTRL: id=0x9e0901, type=1, name=Vertical Blanking, min/max=686/686, step=1, default=686, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
- [ 41.914723] video6: VIDIOC_QUERY_EXT_CTRL: id=0x9e0902, type=1, name=Horizontal Blanking, min/max=1524/1524, step=1, default=1524, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
- [ 41.914752] video6: VIDIOC_QUERY_EXT_CTRL: id=0x9e0903, type=1, name=Analogue Gain, min/max=256/2816, step=1, default=512, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
- [ 41.914776] video6: VIDIOC_QUERY_EXT_CTRL: id=0x9f0001, type=6, name=Image Processing Controls, min/max=0/0, step=0, default=0, flags=0x00000044, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
- [ 41.914792] video6: VIDIOC_QUERY_EXT_CTRL: id=0x9f0901, type=9, name=Link Frequency, min/max=0/0, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
- [ 41.914816] video6: VIDIOC_QUERY_EXT_CTRL: id=0x9f0902, type=5, name=Pixel Rate, min/max=0/182463120, step=1, default=182463120, flags=0x00000004, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
- [ 41.914839] video6: VIDIOC_QUERY_EXT_CTRL: id=0x9f0903, type=3, name=Test Pattern, min/max=0/13, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
- [ 41.914862] video6: VIDIOC_QUERY_EXT_CTRL: error -22: id=0xc09f0903, type=0, name=, min/max=0/0, step=0, default=0, flags=0x00000000, elem_size=0, elems=0, nr_of_dims=0, dims=0,0,0,0
- [ 41.914884] video6: VIDIOC_G_FMT: type=vid-cap-mplane, width=1920, height=1080, format=NV12, field=none, colorspace=0, num_planes=1, flags=0x0, ycbcr_enc=0, quantization=1, xfer_func=0
- [ 41.914962] plane 0: bytesperline=1920 sizeimage=3110400
- [ 41.914982] rkisp0: rkisp_set_fmt: stream: 1 req(640, 480) out(640, 480)
- [ 41.914984] video6: VIDIOC_S_FMT: type=vid-cap-mplane, width=640, height=480, format=NV12, field=none, colorspace=0, num_planes=1, flags=0x0, ycbcr_enc=0, quantization=1, xfer_func=0
- [ 41.914996] plane 0: bytesperline=640 sizeimage=460800
- [ 41.915072] video6: VIDIOC_SUBSCRIBE_EVENT: error -25: type=0x2, id=0x0, flags=0x0
- [ 41.915090] video6: VIDIOC_SUBSCRIBE_EVENT: error -25: type=0x5, id=0x0, flags=0x0
- [ 41.915101] video6: VIDIOC_G_INPUT: error -25: value=0
- [ 41.915252] rkisp0: vid-cap-mplane count 3, size 460800
- [ 41.915308] rkisp0: rkisp_alloc_buffer buf:0xc804000~0xcaa7000 size:2764800
- [ 41.915316] rkisp0: rkisp_alloc_common_dummy_buf buf:0xc804000 size:2764800
- [ 41.915336] videobuf2_common: __setup_offsets: buffer 0, plane 0 offset 0x00000000
- [ 41.915349] videobuf2_common: __setup_offsets: buffer 1, plane 0 offset 0x00071000
- [ 41.915360] videobuf2_common: __setup_offsets: buffer 2, plane 0 offset 0x000e2000
- [ 41.915364] videobuf2_common: __vb2_queue_alloc: allocated 3 buffers, 1 plane(s) each
- [ 41.915369] video6: VIDIOC_REQBUFS: count=3, type=vid-cap-mplane, memory=mmap
- [ 41.915400] video6: VIDIOC_QUERYBUF: 00:00:00.00000000 index=0, type=vid-cap-mplane, flags=0x00002000, field=any, sequence=0, memory=mmap
- [ 41.915417] plane 0: bytesused=0, data_offset=0x00000000, offset/userptr=0x0, length=460800
- [ 41.915422] timecode=00:00:00 type=0, flags=0x00000000, frames=0, userbits=0x00000000
- [ 41.915435] video6: VIDIOC_QUERYBUF: 00:00:00.00000000 index=1, type=vid-cap-mplane, flags=0x00002000, field=any, sequence=0, memory=mmap
- [ 41.915449] plane 0: bytesused=0, data_offset=0x00000000, offset/userptr=0x71000, length=460800
- [ 41.915453] timecode=00:00:00 type=0, flags=0x00000000, frames=0, userbits=0x00000000
- [ 41.915460] video6: VIDIOC_QUERYBUF: 00:00:00.00000000 index=2, type=vid-cap-mplane, flags=0x00002000, field=any, sequence=0, memory=mmap
- [ 41.915473] plane 0: bytesused=0, data_offset=0x00000000, offset/userptr=0xe2000, length=460800
- [ 41.915478] timecode=00:00:00 type=0, flags=0x00000000, frames=0, userbits=0x00000000
- [ 41.915593] videobuf2_common: vb2_mmap: buffer 0, plane 0 successfully mapped
- [ 41.915597] videodev: v4l2_mmap: video6: mmap (0)
- [ 41.915674] videobuf2_common: vb2_mmap: buffer 1, plane 0 successfully mapped
- [ 41.915677] videodev: v4l2_mmap: video6: mmap (0)
- [ 41.915747] videobuf2_common: vb2_mmap: buffer 2, plane 0 successfully mapped
- [ 41.915750] videodev: v4l2_mmap: video6: mmap (0)
- [ 41.915819] videobuf2_common: vb2_core_qbuf: qbuf of buffer 0 succeeded
- [ 41.915821] video6: VIDIOC_QBUF: 00:00:00.00000000 index=0, type=vid-cap-mplane, flags=0x00002003, field=any, sequence=0, memory=mmap
- [ 41.915834] plane 0: bytesused=0, data_offset=0x00000000, offset/userptr=0x0, length=460800
- [ 41.915839] timecode=00:00:00 type=0, flags=0x00000000, frames=0, userbits=0x00000000
- [ 41.915897] videobuf2_common: vb2_core_qbuf: qbuf of buffer 1 succeeded
- [ 41.915900] video6: VIDIOC_QBUF: 00:00:00.00000000 index=1, type=vid-cap-mplane, flags=0x00002003, field=any, sequence=0, memory=mmap
- [ 41.915912] plane 0: bytesused=0, data_offset=0x00000000, offset/userptr=0x71000, length=460800
- [ 41.915917] timecode=00:00:00 type=0, flags=0x00000000, frames=0, userbits=0x00000000
- [ 41.915976] videobuf2_common: vb2_core_qbuf: qbuf of buffer 2 succeeded
- [ 41.915978] video6: VIDIOC_QBUF: 00:00:00.00000000 index=2, type=vid-cap-mplane, flags=0x00002003, field=any, sequence=0, memory=mmap
- [ 41.915991] plane 0: bytesused=0, data_offset=0x00000000, offset/userptr=0xe2000, length=460800
- [ 41.915995] timecode=00:00:00 type=0, flags=0x00000000, frames=0, userbits=0x00000000
- [ 41.916003] video6: VIDIOC_G_FMT: type=vid-cap-mplane, width=640, height=480, format=NV12, field=none, colorspace=0, num_planes=1, flags=0x0, ycbcr_enc=0, quantization=1, xfer_func=0
- [ 41.916017] plane 0: bytesperline=640 sizeimage=460800
- [ 41.916057] rkisp0: rkisp_start_streaming 1
- [ 41.916076] rkisp0: CSI ch0 vc:0 dt:0x2b 1920x1080
- [ 41.916081] rkisp0: CSI ch1 vc:0 dt:0x2b 1920x1080
- [ 41.916085] rkisp0: CSI ch2 vc:0 dt:0x2b 1920x1080
- [ 41.916089] rkisp0: CSI ch3 vc:0 dt:0x2b 1920x1080
- [ 41.916094] rkisp0: CSI ch4 vc:0 dt:0x2b 1920x1080
- [ 41.916192] rkisp0: CSI2RX_IDS 0x2b2b2b2b 0x0000002b
- [ 41.916201] rkisp0: stream 1 rsz/scale: 1920x1080 -> 640x480
- [ 41.916204] rkisp0: chroma scaling 960x1080 -> 320x240
- [ 41.916245] RSZ_CTRL 0x0000000f/0x0000000f
- [ 41.916245] RSZ_SCALE_HY 21823/21823
- [ 41.916245] RSZ_SCALE_HCB 21800/21800
- [ 41.916245] RSZ_SCALE_HCR 21800/21800
- [ 41.916245] RSZ_SCALE_VY 29094/29094
- [ 41.916245] RSZ_SCALE_VC 14517/14517
- [ 41.916245] RSZ_PHASE_HY 0/0
- [ 41.916245] RSZ_PHASE_HC 0/0
- [ 41.916245] RSZ_PHASE_VY 0/0
- [ 41.916245] RSZ_PHASE_VC 0/0
- [ 41.916249] rkisp0: stream 1 crop disabled
- [ 41.916275] rkisp0: CSI2RX CTRL0:0x20820000 CTRL1:0x1
- [ 41.916275] WR CTRL RAW0:0x2e0200 RAW1:0x200 RAW2:0x100
- [ 41.916275] RD CTRL:0x0
- [ 41.916286] rkisp0: SP streaming = 1, MP streaming = 0
- [ 41.916289] rkisp0: CIF_ID 0x02001909
- [ 41.916307] rkisp rkisp-vir0: can not get first iq setting in stream on
- [ 41.916320] rkisp0: SP streaming = 1, MP streaming = 0
- [ 41.917675] rkisp0: SP streaming = 1, MP streaming = 0 MI_CTRL 0x193a4002
- [ 41.917675] ISP_CTRL 0x80446117 MIPI_CTRL 0x20820001
- [ 41.917693] rockchip-mipi-dphy-rx ff4b8000.csi-dphy: stream on:1
- [ 41.917705] rockchip-mipi-dphy-rx: data_rate_mbps 912
- [ 41.921106] rockchip-mipi-dphy-rx ff4b8000.csi-dphy: stream on:0
- [ 41.922155] rkisp0: SP streaming = 1, MP streaming = 0
- [ 41.922167] rkisp0: streaming(MP:1, SP:0), MI_CTRL:193a4002, ISP_CTRL:80446106, MIPI_CTRL:20820001
- [ 41.922363] rkisp0: rkisp_free_buffer buf:0xc804000~0xcaa7000
- [ 41.922379] videobuf2_common: vb2_buffer_done: done processing on buffer 2, state: 3
- [ 41.922384] videobuf2_common: vb2_buffer_done: done processing on buffer 0, state: 3
- [ 41.922387] videobuf2_common: vb2_buffer_done: done processing on buffer 1, state: 3
- [ 41.922391] videobuf2_common: vb2_start_streaming: driver refused to start streaming
- [ 41.922395] video6: VIDIOC_STREAMON: error -5: type=vid-cap-mplane
- [ 41.923565] videobuf2_common: __vb2_buf_mem_free: freed plane 0 of buffer 0
- [ 41.923574] videobuf2_common: __vb2_buf_mem_free: freed plane 0 of buffer 1
- [ 41.923583] videobuf2_common: __vb2_buf_mem_free: freed plane 0 of buffer 2
- [ 41.923650] rkisp0: rkisp_isp_sd_s_power on:0
- [ 41.923678] videodev: v4l2_release: video6: release
Copy the code
