[Linux] Booting from SD card
36
【Linux】 Booting from SD card
Posted at 7/19/2022 05:20:21      View:1308 | Replies:3        Print      Only Author   [Copy Link] 1#
Hello,
I am following the directions to boot Ubuntu 18.04 from sd card, using the SD Disk tool and the ubuntu image on the google drive. However, when I plug the sd card into my board, Android boots up instead of ubuntu. Any idea of how to fix this? I followed the steps in the wiki, so I don't think I'm missing anything there. Is there a way for me to force it to boot from the card?
Posted at 7/19/2022 10:04:10        Only Author  2#
Firefly didn't provide ubuntu18 firmware, where did you get it?
I believe the cause of the problem is the wrong firmware.
Please use ROC-RK3588S-PC Ubuntu20.04 firmware to make SD card.
Posted at 7/20/2022 02:11:54        Only Author  3#
Liuth Posted at 7/19/2022 10:04
I believe the cause of the problem  ...
Now getting a new error- tried two different downloads (most current and second most current) off of the google drive from https://en.t-firefly.com/doc/download/142.html , extracted with 7-zip, but when I hit create, it gives me opening firmware failds
Posted at 7/21/2022 09:48:22        Only Author  4#
ejaybennett Posted at 7/20/2022 02:11
Now getting a new error- tried two different downloads (most current and second most current) off  ...
Maybe you need to format sd card to FAT32 first
And try sd card that is 8 or 16G, bigger than 16G may have problems, the sd tool is bad in compatible
