[Linux] Is it possible to use two os04a10 cams?
60
【Linux】 Is it possible to use two os04a10 cams?
Posted at 7/25/2022 14:41:30      View:1265 | Replies:2        Print      Only Author   [Copy Link] 1#
If possible, how do I use it?
Posted at 2/10/2024 01:18:59        Only Author  2#
Hi,
I have  AIO-1126-JD4     +    DM-M10R800      +       OS04A10
I flash it by ubuntu (based on wiki). But I can not find which /dev/videX is related to OS04A10
Could you guide me. What is number of your /dev/video ?
你好,
我有AIO-1126-JD4 + DM-M10R800 + OS04A10
我用ubuntu(基于wiki)刷了它。 但我找不到哪个 /dev/videX 与 OS04A10 相关
你能指导一下吗? 你的 /dev/video 的编号是多少?
Posted at 2/12/2024 04:31:51        Only Author  3#
nimadibaj Posted at 2/10/2024 01:18
Hi,
Hi again,
This commands work fine :
v4l2-ctl   -d    /dev/v4l-subdev5   --set-ctrl   'band_stop_filter=1'
v4l2-ctl   -d    /dev/v4l-subdev5   --set-ctrl   'band_stop_filter=0'
But I can not get frame from OS04A10 sensor :
v4l2-ctl    -d   /dev/video5   --stream-mmap   --stream-count=1   --stream-to=/home/firefly/out.yuv
Result of above command : rkisp0: check video link or isp input
Please guide me.
