New Topic
Firefly-RK3288 Slackware Arm
1283
vip
Rank: 6Rank: 6
Posted at 3/23/2015 04:07:32      View142229 | Replies113        Print      Only Author   [Copy Link] 1#
do adaptation slackware
ran into a problem after loading
boot.img initrd system does not continue to boot as a base and just goes for a login and password skipping start init scripts
http://fail.pp.ua/boot_slackware.img.7z
http://fail.pp.ua/slackware-minirootfs-0.1.img.7z
  1. FIRMWARE_VER:4.4.2
  2. MACHINE_MODEL:rk30sdk
  3. MACHINE_ID:007
  4. MANUFACTURER:RK30SDK
  5. MAGIC: 0x5041524B
  6. ATAG: 0x60000800
  7. MACHINE: 3066
  8. CHECK_MASK: 0x80
  9. PWR_HLD: 0,0,A,0,1
  10. #KERNEL_IMG: 0x62008000
  11. #FDT_NAME: rk-kernel.dtb
  12. #RECOVER_KEY: 1,1,0,20,0
  13. CMDLINE:console=tty0
  14. console=ttyS2 earlyprintk loglevel=9 root=LABEL=linuxroot rw
  15. rootfstype=ext4 init=/sbin/init initrd=0x62000000,0x00800000
  16. mtdparts=rk29xxnand:0x00008000@0x00002000(resource),0x00008000@0x0000A000(boot),0x00002000@0x00012000(misc),0x0001a000@0x00014000(backup),-@0x0002e000(linuxroot)
Copy the code
donation   irradium
Posted at 3/23/2015 18:08:46        Only Author  2#
This the error line running your boot.img:
mount: mounting /dev/block/mtd/by-name/linuxroot on /mnt failed: No such file or directory
ERROR:  No /sbin/init found on rootdev (or not mounted).  Trouble ahead.
        You can try to fix it. Type 'exit' when things are done.
You need to fix the root= in the parameter, or use a script like
  https://github.com/TeeFirefly/in ... ount/mtd-by-name.sh
in your initramfs to create the block device symlink.
Follow these commands to fix the parameter in your board:
  sudo rkflashkit backup @parameter parm.txt    # fetch parameter from board
  sudo vi parm.t.txt    # modify  "root= /dev/block/mtd/by-name/linuxroot"  to "root=/dev/mmcblk0p5"
  sudo rkflashkit flash @parameter parm.txt    # flash back parameter to board
  sudo rkflashkit reboot   # reboot the device
You might replace /dev/mmcblk0p5  above to fit your actual root dev.
vip
Rank: 6Rank: 6
Posted at 3/30/2015 00:31:44        Only Author  3#
busybee Posted at 3/23/2015 18:08
mount: mounting /dev/block/mtd/by-name/linuxroot on /m ...
thank you very much for your help
all works
1. resize partition firstboot device
2. wifi firmware moved to /lib/firmware
3. wifi enable /etc/rc.d/rc.wifi start|stop (in rc.local)
login: root
password: password
http://fail.pp.ua/RK3288UbootLoader_V2.19.01.bin
http://fail.pp.ua/parameters.txt
http://fail.pp.ua/resource.img
http://fail.pp.ua/boot.img
http://fail.pp.ua/slack-current-miniroot_09Mar15.img
http://fail.pp.ua/flash.sh
donation   irradium
vip
Rank: 6Rank: 6
Posted at 3/30/2015 09:53:45        Only Author  4#
nice job
vip
Rank: 6Rank: 6
Posted at 4/10/2015 03:52:40        Only Author  5#
donation   irradium
vip
Rank: 6Rank: 6
Posted at 4/18/2015 03:46:20        Only Author  6#
new assembly system
info
http://fail.pp.ua/public/board/2
changelog:
  • added image with the desktop xfce
  • installed video driver mali fbdev t76x_r5p0-06rel0
  • support 32 bit color in X
  • added unprivileged user
  • load faster dhcpcd
  • resize partition firstboot device
  • wifi firmware moved to /lib/firmware
  • wifi enable /etc/rc.d/rc.wifi start|stop (in rc.local)
donation   irradium
vip
Rank: 6Rank: 6
Posted at 4/20/2015 04:39:34        Only Author  7#
changelog
  • small hotfix
  • added support in the kernel nfs, xfs, btrfs, jfs
  • info
    donation   irradium
    Posted at 4/20/2015 11:04:40        Only Author  8#
    Send you a PM.
    vip
    Rank: 6Rank: 6
    Posted at 5/4/2015 01:11:14        Only Author  9#
    donation   irradium
    Posted at 5/30/2015 23:22:45        Only Author  10#
    Could you please provide one .img file in order to flash it with the upgrade function of the AndroidTool?
    Or at least provide a "how to" flash slackware with this method.
    Return to List
    12345... 12
