Does anybody know how fast spi maximum frequency
9
Posted at 3/27/2015 14:26:39      View:4597 | Replies:5        Print      Only Author   [Copy Link] 1#
Is max clock frequency  24MHz? 14MHz?
vip
Rank: 6Rank: 6
Posted at 3/30/2015 14:19:38        Only Author  2#
A summary of the frequency ratio restrictions between the bit-rate clock (sclk_out / sclk_in) and the SPI peripheral clock (spi_clk) are described as,
When SPI Controller works as master, the Fspi_clk>= 2 × (maximum Fsclk_out)
When SPI Controller works as slave, the Fspi_clk>= 6 × (maximum Fsclk_in)
Posted at 4/9/2015 17:29:14        Only Author  3#
zhansb Posted at 3/30/2015 14:19
A summary of the frequency ratio restrictions between the bit-rate clock (sclk_out / scl ...
what is the maximun Fspi_clk?
Posted at 1/21/2026 02:54:22        Only Author  4#
What an incredible article, thank you for letting us read it. The 350-601 valid exam pass4sure test questions are now available for free—your career success is just a step away!
Posted at 2/1/2026 23:13:53        Only Author  5#
Thank you for your insightful article, it really left a mark. The Hot C_ABAPD_2507 questions questions are crucial for your promotion and salary raise—now available for free!
Posted at 2/6/2026 19:50:03        Only Author  6#
The article is full of inspiration, thank you for sharing it! Get the 312-50 reliable new test format test questions for free—your promotion and salary boost are within reach!
