[General] DIfficulty in Compiling Ubuntu firmware
19
【General】 DIfficulty in Compiling Ubuntu firmware
Posted at 12/28/2022 19:42:45      View:1016 | Replies:2        Print      Only Author   [Copy Link] 1#
Hello Community,
I'm trying to Compile Ubuntu Firmware for our custom usecases for the Firefly rk3399 DVK kit.
I'm following "https://wiki.t-firefly.com/en/Firefly-RK3399/linux_compile_gpt.html#" link.
As part of the step 1.1.2 Download Firefly_Linux_SDK sub-volume compressed package :
I have downloaded Firefly_Linux_SDK Source through link:
Image 1: Downloaded Files from drive link
After download is complete I've verified MD5 codes as per the defined step, MD5 codes are as mentioned in website.
After confirming that it is correct, I need to follow step 1.1.3 unpacking the SDK sub volumes.
This is where I'm facing issues,
I tried executing
"cat rk3399_linux_release_v2.5.1_20210301_firefly_split-005.file0 | tar -xzv " command
but it is throwing me below error :
I'm unable to get pass through this error, Can someone please let me know if i missed anything and how to get pass this issue.
please find the attached log.
Thanks and regards,
Pranay
error log.zip
4.35 KB, Down times: 1
Posted at 12/29/2022 09:55:07        Only Author  2#
Hello, delete the unpacked file and execute the "cat rk3399_linux_release_v2.5.1_20210301_split_dir/*firefly_split* | tar -xzv" command
Posted at 12/29/2022 17:17:13        Only Author  3#
Hello,
Thanks for the reply.
The problem was when we download fiels from drive it will be downloaded as separate files and some in zip files and website instructions expects all to be in single folder with name "rk3399_linux_release_v2.5.1_20210301_split_dir". I've done that and everything seems okay now
Regards,
Pranay.
Downloaded files.png (65.68 KB, Down times: 38)
Downloaded files.png (65.68 KB, Down times: 36)
