[Android] ITX-3588J Android Multi Display Output(different image)
99
【Android】 ITX-3588J Android Multi Display Output(different image)
Posted at 1/11/2023 10:04:20      View:1748 | Replies:8        Print      Only Author   [Copy Link] 1#
hello firefly
I am using ITX-3588J + core-3588J + Android 12.
I want to show different images on hdmi 1/2 output.
Can I get test methods and guides?
UCOM3_1500000_2022-12-29_오후 4_36_24_ITX3588J.zip
36.57 KB, Down times: 1
administrator
Rank: 9Rank: 9Rank: 9
Posted at 1/12/2023 09:40:16        Only Author  2#
Hello, please check this instruction: https://wiki.t-firefly.com/en/Core-3588J/usage_display.html
Posted at 1/12/2023 11:34:05        Only Author  3#
I confirmed that the same screen(Duplicate screen) can be seen on HDMI 1/2.
But I want to see different screens on HDMI 1/2.
I have no idea how to do it.
I would like to inquire if there is an application or guide document.
vip
Rank: 6Rank: 6
Posted at 1/13/2023 14:40:59        Only Author  4#
kjs0708 Posted at 1/12/2023 11:34
But I want to see diffe ...
Which way is what you need ?
Multi-screen splicing
https://www.t-firefly.com/doc/case/474.html
Multi-screen aberration
https://www.t-firefly.com/doc/case/475.html
vip
Rank: 6Rank: 6
Posted at 1/13/2023 16:06:11        Only Author  5#
jpchen Posted at 1/13/2023 14:40
you can install DualVideoScreen.apk to test and push the video name(123.mp4) in the /sdcard/
DualVideoScreen.apk (55.07 KB, Down times: 2)
Posted at 1/16/2023 09:20:55        Only Author  6#
Thanks for your answer
I want a display like "Multi-screen aberration".
" DualVideoScreen.apk " was installed and executed, but there was no response.
(Display Out : HDMI 1(4K) + HDMI 2(1080p) + DP(4K))
Is there any other FW for "Multi-screen aberration"?
Posted at 1/16/2023 10:45:35        Only Author  7#
jpchen Posted at 1/13/2023 16:06
vip
Rank: 6Rank: 6
Posted at 1/29/2023 14:41:40        Only Author  8#
kjs0708 Posted at 1/16/2023 10:45
The following link is Multi-screen aberration
https://drive.google.com/drive/f ... 9Iyj?usp=share_link
Posted at 4/25/2023 07:44:37        Only Author  9#
Thank you for your answer!
I downloaded the link image and checken the operation.
I ran the built-in app "multi-display" and checked the 4 outputs.
Is there any way to get the "multi-display" app source?
