【Linux】
ROC-RK3399-PC Pro, wifi and bluetooth doesn't work
Posted at 2/11/2023 21:03:20
Type:
Self-Compiled Firmware
SDK Package Name:
firefly-sdk-20200629
Last Commit:
0000-00-00 00:00:00
Modification Content:
rootfs: ubuntu 20.04
kernel: 4.4
Log:
dmesg_44pro_0.zip
I have the ROC-RK3399-PC Pro board, but I can't find any information on which device tree to use to build the kernel. When I try to compile it with different rk3399pro-* trees, in all of them wifi and bluetooth don't work!
And which wireless driver should I choose in kernel?
Here is dmesg:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.194 (build@vm-LCoreRep) (neotek: 2190803a4f2022) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #51 SMP Tue Jan 17 01:19:16 CST 2023
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] On node 0 totalpages: 1007616
[ 0.000000] DMA zone: 15864 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 1007616 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7ec6000 s46312 r8192 d31512 u86016
[ 0.000000] pcpu-alloc: s46312 r8192 d31512 u86016 alloc=21*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 991752
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=e3e23f15f8a446da ro rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] software IO TLB: mapped [mem 0xf7e7d000-0xf7ebd000] (0MB)
[ 0.000000] Memory: 3921896K/4030464K available (14526K kernel code, 1890K rwdata, 5696K rodata, 1216K init, 2008K bss, 108568K reserved, 0K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB)
.init : 0xffffff8009450000 - 0xffffff8009580000 ( 1216 KB)
.text : 0xffffff8008080000 - 0xffffff8008eb0000 ( 14528 KB)
.rodata : 0xffffff8008eb0000 - 0xffffff8009450000 ( 5760 KB)
.data : 0xffffff8009580000 - 0xffffff8009758808 ( 1891 KB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
fixed : 0xffffffbffe7fb000 - 0xffffffbffec00000 ( 4116 KB)
PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB)
memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[ 0.000000] ITS: allocated 65536 Devices @f2c80000 (psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GIC: using LPI property table @0x00000000f2c10000
[ 0.000000] ITS: Allocated 1792 chunks for LPIs
[ 0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[ 0.000000] CPU0: using LPI pending table @0x00000000f2c20000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[ 0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[ 0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.002364] Console: colour dummy device 80x25
[ 0.002809] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003800] pid_max: default: 32768 minimum: 301
[ 0.004339] Security Framework initialized
[ 0.004810] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.005452] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006943] Initializing cgroup subsys io
[ 0.007354] Initializing cgroup subsys memory
[ 0.007799] Initializing cgroup subsys devices
[ 0.008231] Initializing cgroup subsys freezer
[ 0.008675] Initializing cgroup subsys perf_event
[ 0.009130] Initializing cgroup subsys net_prio
[ 0.009569] Initializing cgroup subsys pids
[ 0.010003] ftrace: allocating 52028 entries in 204 pages
[ 0.146454] sched-energy: Sched-energy-costs installed from DT
[ 0.147022] CPU0: update cpu_capacity 401
[ 0.147466] ASID allocator initialised with 32768 entries
[ 0.151450] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.152945] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.155393] Detected VIPT I-cache on CPU1
[ 0.155432] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.155469] CPU1: using LPI pending table @0x00000000f2ed0000
[ 0.155531] CPU1: update cpu_capacity 401
[ 0.155535] CPU1: Booted secondary processor [410fd034]
[ 0.156424] Detected VIPT I-cache on CPU2
[ 0.156459] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.156496] CPU2: using LPI pending table @0x00000000f2f00000
[ 0.156554] CPU2: update cpu_capacity 401
[ 0.156558] CPU2: Booted secondary processor [410fd034]
[ 0.157421] Detected VIPT I-cache on CPU3
[ 0.157454] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.157490] CPU3: using LPI pending table @0x00000000f2f50000
[ 0.157546] CPU3: update cpu_capacity 401
[ 0.157549] CPU3: Booted secondary processor [410fd034]
[ 0.158431] Detected PIPT I-cache on CPU4
[ 0.158458] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.158498] CPU4: using LPI pending table @0x00000000f2f90000
[ 0.158536] CPU4: update cpu_capacity 1024
[ 0.158540] CPU4: Booted secondary processor [410fd082]
[ 0.159239] Detected PIPT I-cache on CPU5
[ 0.159267] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.159306] CPU5: using LPI pending table @0x00000000f2fc0000
[ 0.159346] CPU5: update cpu_capacity 1024
[ 0.159349] CPU5: Booted secondary processor [410fd082]
[ 0.159454] Brought up 6 CPUs
[ 0.171815] SMP: Total of 6 processors activated.
[ 0.172266] CPU features: detected feature: GIC system register CPU interface
[ 0.172955] CPU features: detected feature: 32-bit EL0 Support
[ 0.173515] CPU: All CPU(s) started at EL2
[ 0.173947] alternatives: patching kernel code
[ 0.175862] devtmpfs: initialized
[ 0.195570] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.196504] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.197549] xor: measuring software checksum speed
[ 0.207712] 8regs : 2856.000 MB/sec
[ 0.217767] 8regs_prefetch: 2564.000 MB/sec
[ 0.227821] 32regs : 3208.000 MB/sec
[ 0.237875] 32regs_prefetch: 2848.000 MB/sec
[ 0.238304] xor: using function: 32regs (3208.000 MB/sec)
[ 0.238826] pinctrl core: initialized pinctrl subsystem
[ 0.239543] regulator-dummy: no parameters
[ 0.241141] Failed to find legacy iommu devices
[ 0.241963] NET: Registered protocol family 16
[ 0.246666] cpuidle: using governor ladder
[ 0.250679] cpuidle: using governor menu
[ 0.251063] Registered FIQ tty driver
[ 0.251945] vdso: 2 pages (1 code @ ffffff8008eb6000, 1 data @ ffffff8009584000)
[ 0.252670] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.253843] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.270833] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
[ 0.270908] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
[ 0.270983] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
[ 0.271056] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
[ 0.271125] gpiochip_add_data: registered GPIOs 128 to 159 on device: gpio4
[ 0.278668] console [pstore-1] enabled
[ 0.279021] pstore: Registered ramoops as persistent store backend
[ 0.279599] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.283538] console [ttyFIQ0] enabled
[ 0.284223] bootconsole [uart0] disabled
[ 0.285158] Registered fiq debugger ttyFIQ0
[ 0.335499] raid6: int64x1 gen() 468 MB/s
[ 0.352524] raid6: int64x1 xor() 412 MB/s
[ 0.369675] raid6: int64x2 gen() 675 MB/s
[ 0.386744] raid6: int64x2 xor() 601 MB/s
[ 0.403818] raid6: int64x4 gen() 972 MB/s
[ 0.420884] raid6: int64x4 xor() 667 MB/s
[ 0.438032] raid6: int64x8 gen() 789 MB/s
[ 0.455072] raid6: int64x8 xor() 628 MB/s
[ 0.472195] raid6: neonx1 gen() 964 MB/s
[ 0.489267] raid6: neonx1 xor() 675 MB/s
[ 0.506382] raid6: neonx2 gen() 1277 MB/s
[ 0.523459] raid6: neonx2 xor() 984 MB/s
[ 0.540529] raid6: neonx4 gen() 1726 MB/s
[ 0.557622] raid6: neonx4 xor() 1181 MB/s
[ 0.574723] raid6: neonx8 gen() 1687 MB/s
[ 0.591809] raid6: neonx8 xor() 1240 MB/s
[ 0.592191] raid6: using algorithm neonx4 gen() 1726 MB/s
[ 0.592670] raid6: .... xor() 1181 MB/s, rmw enabled
[ 0.593115] raid6: using intx1 recovery algorithm
[ 0.594699] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vccadc-ref[0]'
[ 0.594726] vcc1v8_sys: 1800 mV
[ 0.594901] reg-fixed-voltage vccadc-ref: vcc1v8_sys supplying 1800000uV
[ 0.594957] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc3v3-sys[0]'
[ 0.594974] vcc3v3_sys: 3300 mV
[ 0.595137] reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
[ 0.595193] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcca-0v9[0]'
[ 0.595212] reg-fixed-voltage vcca-0v9: Looking up vin-supply from device tree
[ 0.595345] vcca_0v9: supplied by vcc3v3_sys
[ 0.595765] vcca_0v9: 900 mV
[ 0.595918] reg-fixed-voltage vcca-0v9: vcca_0v9 supplying 900000uV
[ 0.596086] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc5v0-host-regulator[0]' - status (0)
[ 0.596137] vcc5v0_host: no parameters
[ 0.596300] reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
[ 0.596437] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc_hub_en-regulator[0]' - status (0)
[ 0.596481] vcc_hub_en: no parameters
[ 0.596630] reg-fixed-voltage vcc_hub_en-regulator: vcc_hub_en supplying 0uV
[ 0.596797] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-wifi[0]' - status (0)
[ 0.596843] vcc_wifi: 5000 mV
[ 0.597012] reg-fixed-voltage vcc-wifi: vcc_wifi supplying 5000000uV
[ 0.597145] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-pcie[0]' - status (0)
[ 0.597188] vcc_pcie: 5000 mV
[ 0.597344] reg-fixed-voltage vcc-pcie: vcc_pcie supplying 5000000uV
[ 0.597482] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-sd[0]' - status (0)
[ 0.597518] vcc_sd: 3300 mV
[ 0.597688] reg-fixed-voltage vcc-sd: vcc_sd supplying 3300000uV
[ 0.597744] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc5v0-sys[0]'
[ 0.597772] vcc5v0_sys: 5000 mV
[ 0.597923] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
[ 0.597974] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
[ 0.597991] vcc_phy: no parameters
[ 0.598150] reg-fixed-voltage vcc-phy-regulator: vcc_phy supplying 0uV
[ 0.598291] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-lcd-regulator[0]' - status (0)
[ 0.598335] vcc_lcd: no parameters
[ 0.598494] reg-fixed-voltage vcc-lcd-regulator: vcc_lcd supplying 0uV
[ 0.598630] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc_mipi[0]' - status (0)
[ 0.598668] vcc_mipi: no parameters
[ 0.598850] reg-fixed-voltage vcc_mipi: vcc_mipi supplying 0uV
[ 0.598976] of_get_named_gpiod_flags: parsed 'gpio' property of node '/dvdd-1v2[0]' - status (0)
[ 0.599013] dvdd_1v2: no parameters
[ 0.599172] reg-fixed-voltage dvdd-1v2: dvdd_1v2 supplying 0uV
[ 0.599305] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fan-regulator[0]' - status (0)
[ 0.599346] fan_enable: no parameters
[ 0.599511] reg-fixed-voltage fan-regulator: fan_enable supplying 0uV
[ 0.599572] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/poe-12v[0]'
[ 0.599590] poe_12v: 12000 mV
[ 0.599748] reg-fixed-voltage poe-12v: poe_12v supplying 12000000uV
[ 0.599855] rockchip-pinctrl pinctrl: pin gpio4-27 already requested by vcc-wifi; cannot claim for vcc3v3-ngff
[ 0.600736] rockchip-pinctrl pinctrl: pin-155 (vcc3v3-ngff) status -22
[ 0.601321] rockchip-pinctrl pinctrl: could not request pin 155 (gpio4-27) from group vcc3v3-ngff-en on device rockchip-pinctrl
[ 0.602344] reg-fixed-voltage vcc3v3-ngff: Error applying setting, reverse things back
[ 0.603106] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc3v3-ngff[0]' - status (0)
[ 0.603124] vcc3v3_ngff: GPIO 155 is already used
[ 0.603136] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 0.603159] vcc3v3_ngff: unable to resolve supply
[ 0.603169] vcc3v3_ngff: 3300 mV
[ 0.603302] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 0.603325] vcc3v3_ngff: regulator get failed, ret=-517
[ 0.603813] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 0.603834] vcc3v3_ngff: unable to resolve supply
[ 0.603845] reg-fixed-voltage vcc3v3-ngff: vcc3v3_ngff supplying 3300000uV
[ 0.603919] rockchip-pinctrl pinctrl: pin gpio1-17 already requested by vcc-pcie; cannot claim for vcc3v3-pcie
[ 0.604797] rockchip-pinctrl pinctrl: pin-49 (vcc3v3-pcie) status -22
[ 0.605381] rockchip-pinctrl pinctrl: could not request pin 49 (gpio1-17) from group vcc3v3-pcie-en on device rockchip-pinctrl
[ 0.606391] reg-fixed-voltage vcc3v3-pcie: Error applying setting, reverse things back
[ 0.607147] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc3v3-pcie[0]' - status (0)
[ 0.607163] vcc3v3_pcie: GPIO 49 is already used
[ 0.607175] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 0.607197] vcc3v3_pcie: unable to resolve supply
[ 0.607206] vcc3v3_pcie: 3300 mV
[ 0.607339] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 0.607362] vcc3v3_pcie: regulator get failed, ret=-517
[ 0.607849] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 0.607871] vcc3v3_ngff: unable to resolve supply
[ 0.607880] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 0.607901] vcc3v3_pcie: unable to resolve supply
[ 0.607912] reg-fixed-voltage vcc3v3-pcie: vcc3v3_pcie supplying 3300000uV
[ 0.608607] iommu: Adding device ff650000.vpu_service to group 0
[ 0.609233] iommu: Adding device ff660000.rkvdec to group 1
[ 0.609834] iommu: Adding device ff8f0000.vop to group 2
[ 0.610402] iommu: Adding device ff900000.vop to group 3
[ 0.610963] iommu: Adding device ff910000.rkisp1 to group 4
[ 0.611553] iommu: Adding device ff920000.rkisp1 to group 5
[ 0.612562] rk_iommu ff650800.iommu: can't get sclk
[ 0.613265] rk_iommu ff660480.iommu: can't get sclk
[ 0.613923] rk_iommu ff8f3f00.iommu: can't get sclk
[ 0.614525] rk_iommu ff903f00.iommu: can't get sclk
[ 0.615147] rk_iommu ff914000.iommu: can't get sclk
[ 0.615744] rk_iommu ff924000.iommu: can't get sclk
[ 0.616567] SCSI subsystem initialized
[ 0.617071] libata version 3.00 loaded.
[ 0.617277] usbcore: registered new interface driver usbfs
[ 0.617806] usbcore: registered new interface driver hub
[ 0.618372] usbcore: registered new device driver usb
[ 0.619109] media: Linux media interface: v0.10
[ 0.619551] Linux video capture interface: v2.00
[ 0.620043] pps_core: LinuxPPS API ver. 1 registered
[ 0.620489] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.621315] PTP clock support registered
[ 0.622813] Advanced Linux Sound Architecture Driver Initialized.
[ 0.623858] Bluetooth: Core ver 2.21
[ 0.624199] NET: Registered protocol family 31
[ 0.624608] Bluetooth: HCI device and connection manager initialized
[ 0.625176] Bluetooth: HCI socket layer initialized
[ 0.625620] Bluetooth: L2CAP socket layer initialized
[ 0.626084] Bluetooth: SCO socket layer initialized
[ 0.627035] nfc: nfc_init: NFC Core ver 0.1
[ 0.627445] NET: Registered protocol family 39
[ 0.627979] rockchip-cpuinfo cpuinfo: Serial : e3e23f15f8a446da
[ 0.629394] clocksource: Switched to clocksource arch_sys_counter
[ 0.682108] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.683211] NET: Registered protocol family 2
[ 0.684056] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.684970] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[ 0.686477] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.687176] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.687944] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.688961] NET: Registered protocol family 1
[ 0.689675] RPC: Registered named UNIX socket transport module.
[ 0.690203] RPC: Registered udp transport module.
[ 0.690641] RPC: Registered tcp transport module.
[ 0.691063] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.691659] PCI: CLS 0 bytes, default 64
[ 0.692608] Trying to unpack rootfs image as initramfs...
[ 1.109824] Freeing initrd memory: 8656K
[ 1.110986] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.111827] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 1.115961] Initialise system trusted keyring
[ 1.124680] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.126006] NFS: Registering the id_resolver key type
[ 1.126496] Key type id_resolver registered
[ 1.126874] Key type id_legacy registered
[ 1.127251] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 1.128555] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.129329] fuse init (API version 7.23)
[ 1.130040] SGI XFS with security attributes, no debug enabled
[ 1.136265] NET: Registered protocol family 38
[ 1.136706] Key type asymmetric registered
[ 1.137080] Asymmetric key parser 'x509' registered
[ 1.137712] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.138527] io scheduler noop registered
[ 1.138888] io scheduler deadline registered
[ 1.139301] io scheduler cfq registered (default)
[ 1.142946] phy phy-ff770000.syscon:phy@f780.0: Looking up phy-supply from device tree
[ 1.142964] phy phy-ff770000.syscon:phy@f780.0: Looking up phy-supply property in node /syscon@ff770000/phy@f780 failed
[ 1.143942] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc0-supply from device tree
[ 1.143958] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc0-supply property in node /power-management@ff310000/power-controller failed
[ 1.144312] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc1-supply from device tree
[ 1.144326] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc1-supply property in node /power-management@ff310000/power-controller failed
[ 1.144662] phy phy-pcie-phy.1: Looking up phy-supply from device tree
[ 1.144674] phy phy-pcie-phy.1: Looking up phy-supply property in node /pcie-phy failed
[ 1.145003] ace test_init function.
[ 1.145521] ace test_init end.ret=0
[ 1.146220] radar end.ret=0
[ 1.149028] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[ 1.149042] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[ 1.149076] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0)
[ 1.149326] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[ 1.149418] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 1.149971] pwm-backlight backlight: GPIO lookup for consumer enable
[ 1.149982] pwm-backlight backlight: using device tree for GPIO lookup
[ 1.149993] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]'
[ 1.150004] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]'
[ 1.150013] pwm-backlight backlight: using lookup tables for GPIO lookup
[ 1.150023] pwm-backlight backlight: lookup for GPIO enable failed
[ 1.150034] pwm-backlight backlight: Looking up power-supply from device tree
[ 1.150045] pwm-backlight backlight: Looking up power-supply property in node /backlight failed
[ 1.150065] backlight supply power not found, using dummy regulator
[ 1.151081] Module initialized.
[ 1.151644] rk-vcodec ff650000.vpu_service: Looking up vcodec-supply from device tree
[ 1.151657] rk-vcodec ff650000.vpu_service: Looking up vcodec-supply property in node /vpu_service@ff650000 failed
[ 1.151678] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 1.152482] rk-vcodec ff650000.vpu_service: probe device
[ 1.153185] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 1.154350] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 1.154992] rk-vcodec ff650000.vpu_service: init success
[ 1.155681] rk-vcodec ff660000.rkvdec: Looking up vcodec-supply from device tree
[ 1.155694] rk-vcodec ff660000.rkvdec: Looking up vcodec-supply property in node /rkvdec@ff660000 failed
[ 1.155718] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 1.156707] rk-vcodec ff660000.rkvdec: probe device
[ 1.157335] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 1.158289] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 1.158882] rk-vcodec ff660000.rkvdec: init success
[ 1.160909] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.161592] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.163884] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.164567] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.166477] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 1.167530] pwm-regulator vdd-log: GPIO lookup for consumer enable
[ 1.167541] pwm-regulator vdd-log: using device tree for GPIO lookup
[ 1.167554] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log[0]'
[ 1.167565] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log[0]'
[ 1.167574] pwm-regulator vdd-log: using lookup tables for GPIO lookup
[ 1.167584] pwm-regulator vdd-log: lookup for GPIO enable failed
[ 1.167633] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.167645] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.167679] vdd_log: 800 <--> 1100 mV at 1007 mV
[ 1.167853] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.167865] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.167941] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 1.167970] vcc3v3_ngff: unable to resolve supply
[ 1.167981] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 1.168003] vcc3v3_pcie: unable to resolve supply
[ 1.168012] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.168022] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.168501] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.169781] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
[ 1.171773] [drm] Initialized drm 1.1.0 20060810
[ 1.176431] [drm] Rockchip DRM driver version: v1.0.1
[ 1.179178] mali ff9a0000.gpu: Looking up mali-supply from device tree
[ 1.179208] mali ff9a0000.gpu: Failed to get regulator
[ 1.179679] mali ff9a0000.gpu: Power control initialization failed
[ 1.180267] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_gpu-supply from device tree
[ 1.180281] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_gpu-supply property in node /power-management@ff310000/power-controller failed
[ 1.180619] Unable to detect cache hierarchy for CPU 0
[ 1.181866] brd: module loaded
[ 1.187523] loop: module loaded
[ 1.188345] zram: Added device: zram0
[ 1.189072] lkdtm: No crash points registered, enable through debugfs
[ 1.189752] Loading dl1825 driver
[ 1.191782] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[ 1.192954] m25p80 spi32766.0: w25q128 (16384 Kbytes)
[ 1.197501] register spi return v = :0
[ 1.197872] HSI/SSI char device loaded
[ 1.198736] tun: Universal TUN/TAP device driver, 1.6
[ 1.199183] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.200838] rk_gmac-dwmac fe300000.ethernet: Looking up phy-supply from device tree
[ 1.200936] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.201575] rk_gmac-dwmac fe300000.ethernet: TX delay(0x2e).
[ 1.202081] rk_gmac-dwmac fe300000.ethernet: RX delay(0x13).
[ 1.202609] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.203335] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.203963] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.209516] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.210129] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.210583] Ring mode enabled
[ 1.210856] DMA HW capability register supported
[ 1.211255] Normal descriptors
[ 1.211570] RX Checksum Offload Engine supported (type 2)
[ 1.212061] TX Checksum insertion supported
[ 1.212442] Wake-Up On Lan supported
[ 1.212806] Enable RX Mitigation via HW Watchdog Timer
[ 1.213377] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@fe300000[0]' - status (0)
[ 1.283248] libphy: stmmac: probed
[ 1.283608] eth%d: PHY ID 001cc878 at 0 IRQ POLL (stmmac-0:00) active
[ 1.284184] eth%d: PHY ID 001cc878 at 1 IRQ POLL (stmmac-0:01)
[ 1.286118] PPP generic driver version 2.4.2
[ 1.286823] Broadcom 43xx driver loaded [ Features: PNLS ]
[ 1.287400] usbcore: registered new interface driver rtl8192cu
[ 1.287967] usbcore: registered new interface driver rndis_wlan
[ 1.288768] usbcore: registered new interface driver mt7601u
[ 1.289694] <D> We get wifi chip!!!
[ 1.289695] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.10 (r)
[ 1.289703] ======== dhd_wlan_init_plat_data ========
[ 1.289707] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.289710] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: rfkill-wlan driver has not Successful initialized
[ 1.289714] dhd_wlan_init_gpio: unknown oob irqflags !
[ 1.289719] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=-1, oob_irq_flags=0x410
[ 1.289721] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 1.289724] dhd_wifi_platform_load: Enter
[ 1.289788] Power-up adapter 'DHD generic adapter'
[ 1.289847] wifi_platform_set_power = 1
[ 1.289851] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 1.289855] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.289858] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[ 1.296720] <D> Wifi type: 3!!!
[ 1.297020] =======================================================
[ 1.297576] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 1.298124] =======================================================
[ 1.298682] Realtek 8723DU USB WiFi driver (Powered by Rockchip) init.
[ 1.299256] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.299686] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[ 1.300474] RTW: module init start
[ 1.300781] RTW: rtl8723du v5.6.5.1_34252.20190703_COEX20181130-2e2e
[ 1.301342] RTW: build time: Jan 17 2023 01:18:56
[ 1.301773] RTW: rtl8723du BT-Coex version = COEX20181130-2e2e
[ 1.302372] usbcore: registered new interface driver rtl8723du
[ 1.302899] RTW: module init ret=0
[ 1.303219] Rockchip WiFi SYS interface (V1.00) ...
[ 1.303740] usbcore: registered new interface driver rtl8150
[ 1.304285] usbcore: registered new interface driver r8152
[ 1.304832] usbcore: registered new interface driver asix
[ 1.305351] usbcore: registered new interface driver ax88179_178a
[ 1.305936] usbcore: registered new interface driver cdc_ether
[ 1.306495] usbcore: registered new interface driver rndis_host
[ 1.307084] usbcore: registered new interface driver cdc_ncm
[ 1.307637] usbcore: registered new interface driver qmi_wwan
[ 1.308186] usbcore: registered new interface driver cdc_mbim
[ 1.310262] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 1.310865] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_usb3-supply from device tree
[ 1.310879] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_usb3-supply property in node /power-management@ff310000/power-controller failed
[ 1.311814] rockchip-dwc3 usb1: failed to get drvdata dwc3
[ 1.313522] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.314109] ehci-pci: EHCI PCI platform driver
[ 1.314565] ehci-platform: EHCI generic platform driver
[ 1.315773] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.316338] ohci-platform: OHCI generic platform driver
[ 1.317862] usbcore: registered new interface driver cdc_acm
[ 1.318367] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.319116] usbcore: registered new interface driver cdc_wdm
[ 1.319669] usbcore: registered new interface driver uas
[ 1.320189] usbcore: registered new interface driver usb-storage
[ 1.320810] usbcore: registered new interface driver usbserial
[ 1.321352] usbcore: registered new interface driver usbserial_generic
[ 1.321961] usbserial: USB Serial support registered for generic
[ 1.322532] usbcore: registered new interface driver ch341
[ 1.323045] usbserial: USB Serial support registered for ch341-uart
[ 1.323641] usbcore: registered new interface driver cp210x
[ 1.324154] usbserial: USB Serial support registered for cp210x
[ 1.324722] usbcore: registered new interface driver ftdi_sio
[ 1.325262] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.325950] usbcore: registered new interface driver keyspan
[ 1.326487] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 1.327196] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 1.327869] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 1.328547] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 1.329221] usbcore: registered new interface driver option
[ 1.329752] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.330413] usbcore: registered new interface driver oti6858
[ 1.330937] usbserial: USB Serial support registered for oti6858
[ 1.331508] usbcore: registered new interface driver pl2303
[ 1.332022] usbserial: USB Serial support registered for pl2303
[ 1.332591] usbcore: registered new interface driver qcserial
[ 1.333127] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.333790] usbcore: registered new interface driver sierra
[ 1.334304] usbserial: USB Serial support registered for Sierra USB modem
[ 1.335895] usbcore: registered new interface driver usbtouchscreen
[ 1.336772] .. rk pwm remotectl v1.1 init
[ 1.337407] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.338522] sensor_register_slave:mma8452,id=17
[ 1.338930] sensor_register_slave:lis3dh,id=7
[ 1.339324] sensor_register_slave:mma7660,id=18
[ 1.339739] sensor_register_slave:lsm303d,id=22
[ 1.340144] sensor_register_slave:gs_mc3230,id=23
[ 1.340576] [Gsensor] gsensor_init
[ 1.340902] sensor_register_slave:mpu6880_acc,id=24
[ 1.341342] sensor_register_slave:mpu6500_acc,id=25
[ 1.341790] sensor_register_slave:lsm330_acc,id=26
[ 1.342219] sensor_register_slave:akm8975,id=30
[ 1.342631] sensor_register_slave:akm8963,id=31
[ 1.343037] sensor_register_slave:l3g4200d,id=45
[ 1.343463] sensor_register_slave:l3g20d,id=46
[ 1.343868] sensor_register_slave:ewtsa,id=47
[ 1.344262] sensor_register_slave:lsm330_gyro,id=51
[ 1.344709] sensor_register_slave:cm3217,id=53
[ 1.345114] sensor_register_slave:cm3218,id=54
[ 1.346014] i2c /dev entries driver
[ 1.347194] fan53555-regulator 0-0040: GPIO lookup for consumer vsel
[ 1.347207] fan53555-regulator 0-0040: using device tree for GPIO lookup
[ 1.347240] of_get_named_gpiod_flags: parsed 'vsel-gpios' property of node '/i2c@ff3c0000/syr827@40[0]' - status (0)
[ 1.347611] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.348232] fan53555-regulator 0-0040: Looking up vin-supply from device tree
[ 1.348297] fan53555-reg: supplied by vcc5v0_sys
[ 1.350072] vdd_cpu_b: 712 <--> 1500 mV at 1000 mV
[ 1.350466] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 1.350498] vcc3v3_ngff: unable to resolve supply
[ 1.350509] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 1.350532] vcc3v3_pcie: unable to resolve supply
[ 1.350543] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.350555] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.350798] fan53555-regulator 0-0041: GPIO lookup for consumer vsel
[ 1.350808] fan53555-regulator 0-0041: using device tree for GPIO lookup
[ 1.350838] of_get_named_gpiod_flags: parsed 'vsel-gpios' property of node '/i2c@ff3c0000/syr828@41[0]' - status (0)
[ 1.351182] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.351813] fan53555-regulator 0-0041: Looking up vin-supply from device tree
[ 1.351859] fan53555-reg: supplied by vcc5v0_sys
[ 1.353612] vdd_gpu: 712 <--> 1500 mV at 1000 mV
[ 1.353965] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 1.353993] vcc3v3_ngff: unable to resolve supply
[ 1.354003] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 1.354026] vcc3v3_pcie: unable to resolve supply
[ 1.354036] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.354047] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.354751] rk808 0-001b: Pmic Chip id: 0x0
[ 1.358537] rk808 0-001b: GPIO lookup for consumer dvs
[ 1.358549] rk808 0-001b: using device tree for GPIO lookup
[ 1.358562] of_get_named_gpiod_flags: can't parse 'dvs-gpios' property of node '/i2c@ff3c0000/pmic@1b[0]'
[ 1.358573] of_get_named_gpiod_flags: can't parse 'dvs-gpio' property of node '/i2c@ff3c0000/pmic@1b[0]'
[ 1.358582] rk808 0-001b: using lookup tables for GPIO lookup
[ 1.358592] rk808 0-001b: lookup for GPIO dvs failed
[ 1.358602] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.359152] rk808 0-001b: GPIO lookup for consumer dvs
[ 1.359161] rk808 0-001b: using device tree for GPIO lookup
[ 1.359171] of_get_named_gpiod_flags: can't parse 'dvs-gpios' property of node '/i2c@ff3c0000/pmic@1b[1]'
[ 1.359181] of_get_named_gpiod_flags: can't parse 'dvs-gpio' property of node '/i2c@ff3c0000/pmic@1b[1]'
[ 1.359190] rk808 0-001b: using lookup tables for GPIO lookup
[ 1.359198] rk808 0-001b: lookup for GPIO dvs failed
[ 1.359208] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.359806] rk808 0-001b: Looking up vcc1-supply from device tree
[ 1.359885] DCDC_REG1: supplied by vcc3v3_sys
[ 1.360708] vdd_center: 750 <--> 1350 mV at 900 mV
[ 1.360956] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 1.360987] vcc3v3_ngff: unable to resolve supply
[ 1.360998] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 1.361022] vcc3v3_pcie: unable to resolve supply
[ 1.361033] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.361045] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.361099] rk808 0-001b: Looking up vcc2-supply from device tree
[ 1.361142] DCDC_REG2: supplied by vcc3v3_sys
[ 1.361832] vdd_cpu_l: 750 <--> 1350 mV at 900 mV
[ 1.362045] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 1.362071] vcc3v3_ngff: unable to resolve supply
[ 1.362081] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 1.362104] vcc3v3_pcie: unable to resolve supply
[ 1.362113] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.362125] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.362179] rk808 0-001b: Looking up vcc3-supply from device tree
[ 1.362218] DCDC_REG3: supplied by vcc3v3_sys
[ 1.362660] vcc_ddr: at 3300 mV
[ 1.362849] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 1.362876] vcc3v3_ngff: unable to resolve supply
[ 1.362885] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 1.362908] vcc3v3_pcie: unable to resolve supply
[ 1.362918] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.362929] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.362984] rk808 0-001b: Looking up vcc4-supply from device tree
[ 1.363022] DCDC_REG4: supplied by vcc3v3_sys
[ 1.363592] vcc_1v8: 1800 mV
[ 1.363813] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 1.363840] vcc3v3_ngff: unable to resolve supply
[ 1.363850] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 1.363874] vcc3v3_pcie: unable to resolve supply
[ 1.363883] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.363894] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.363950] rk808 0-001b: Looking up vcc6-supply from device tree
[ 1.363989] LDO_REG1: supplied by vcc3v3_sys
[ 1.365210] vcca1v8_codec: 1800 mV
[ 1.365448] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 1.365476] vcc3v3_ngff: unable to resolve supply
[ 1.365486] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 1.365511] vcc3v3_pcie: unable to resolve supply
[ 1.365520] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.365531] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.365588] rk808 0-001b: Looking up vcc6-supply from device tree
[ 1.365628] LDO_REG2: supplied by vcc3v3_sys
[ 1.366695] vcc1v8_hdmi: 1800 mV
[ 1.366922] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 1.366952] vcc3v3_ngff: unable to resolve supply
[ 1.366962] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 1.366987] vcc3v3_pcie: unable to resolve supply
[ 1.366996] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.367007] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.367067] rk808 0-001b: Looking up vcc7-supply from device tree
[ 1.367107] LDO_REG3: supplied by vcc3v3_sys
[ 1.368187] vcc1v8_pmu: 1800 mV
[ 1.368414] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 1.368444] vcc3v3_ngff: unable to resolve supply
[ 1.368453] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 1.368477] vcc3v3_pcie: unable to resolve supply
[ 1.368487] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.368497] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.368559] rk808 0-001b: Looking up vcc9-supply from device tree
[ 1.368598] LDO_REG4: supplied by vcc3v3_sys
[ 1.369674] vccio_sd: 1800 <--> 3000 mV at 3000 mV
[ 1.369891] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 1.369921] vcc3v3_ngff: unable to resolve supply
[ 1.369930] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 1.369956] vcc3v3_pcie: unable to resolve supply
[ 1.369965] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.369976] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.370046] rk808 0-001b: Looking up vcc9-supply from device tree
[ 1.370084] LDO_REG5: supplied by vcc3v3_sys
[ 1.371176] vcca3v0_codec: 3000 mV
[ 1.371403] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 1.371432] vcc3v3_ngff: unable to resolve supply
[ 1.371442] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 1.371468] vcc3v3_pcie: unable to resolve supply
[ 1.371478] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.371488] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.371554] rk808 0-001b: Looking up vcc10-supply from device tree
[ 1.371595] LDO_REG6: supplied by vcc3v3_sys
[ 1.372659] vcc_1v5: 1500 mV
[ 1.372882] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 1.372912] vcc3v3_ngff: unable to resolve supply
[ 1.372922] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 1.372947] vcc3v3_pcie: unable to resolve supply
[ 1.372957] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.372968] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.373036] rk808 0-001b: Looking up vcc7-supply from device tree
[ 1.373077] LDO_REG7: supplied by vcc3v3_sys
[ 1.374153] vcca0v9_hdmi: 900 mV
[ 1.374376] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 1.374420] vcc3v3_ngff: unable to resolve supply
[ 1.374431] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 1.374457] vcc3v3_pcie: unable to resolve supply
[ 1.374466] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.374477] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.374546] rk808 0-001b: Looking up vcc11-supply from device tree
[ 1.374586] LDO_REG8: supplied by vcc3v3_sys
[ 1.375648] vcc_3v0: 3000 mV
[ 1.375870] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 1.375900] vcc3v3_ngff: unable to resolve supply
[ 1.375910] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 1.375936] vcc3v3_pcie: unable to resolve supply
[ 1.375946] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.375957] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.376025] rk808 0-001b: Looking up vcc8-supply from device tree
[ 1.376064] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.376508] vcc3v3_s3: at 3300 mV
[ 1.376703] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 1.376733] vcc3v3_ngff: unable to resolve supply
[ 1.376743] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 1.376769] vcc3v3_pcie: unable to resolve supply
[ 1.376779] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.376790] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.376860] rk808 0-001b: Looking up vcc12-supply from device tree
[ 1.376899] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.377337] vcc3v3_s0: at 3300 mV
[ 1.377533] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 1.377564] vcc3v3_ngff: unable to resolve supply
[ 1.377574] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 1.377601] vcc3v3_pcie: unable to resolve supply
[ 1.377610] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[ 1.377621] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 1.377857] rk808-rtc rk808-rtc: device is disabled
[ 1.378298] rk808-rtc: probe of rk808-rtc failed with error -22
[ 1.378880] of_get_named_gpiod_flags: parsed 'pmic,hold-gpio' property of node '/i2c@ff3c0000/pmic@1b[0]' - status (0)
[ 1.378923] of_get_named_gpiod_flags: can't parse 'pmic,stby-gpio' property of node '/i2c@ff3c0000/pmic@1b[0]'
[ 1.378933] rk808 0-001b: Can not read property pmic,stby-gpio
[ 1.381978] rtc-hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 1.382950] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009bcc000
[ 1.384502] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009bce000
[ 1.385732] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff8009bd0000
[ 1.387098] fusb302 7-0022: GPIO lookup for consumer int-n
[ 1.387111] fusb302 7-0022: using device tree for GPIO lookup
[ 1.387143] of_get_named_gpiod_flags: parsed 'int-n-gpios' property of node '/i2c@ff160000/fusb30x@22[0]' - status (0)
[ 1.387171] fusb302 7-0022: GPIO lookup for consumer vbus-5v
[ 1.387180] fusb302 7-0022: using device tree for GPIO lookup
[ 1.387191] of_get_named_gpiod_flags: can't parse 'vbus-5v-gpios' property of node '/i2c@ff160000/fusb30x@22[0]'
[ 1.387201] of_get_named_gpiod_flags: can't parse 'vbus-5v-gpio' property of node '/i2c@ff160000/fusb30x@22[0]'
[ 1.387211] fusb302 7-0022: using lookup tables for GPIO lookup
[ 1.387221] fusb302 7-0022: lookup for GPIO vbus-5v failed
[ 1.387231] fusb302 7-0022: GPIO lookup for consumer vbus-other
[ 1.387239] fusb302 7-0022: using device tree for GPIO lookup
[ 1.387249] of_get_named_gpiod_flags: can't parse 'vbus-other-gpios' property of node '/i2c@ff160000/fusb30x@22[0]'
[ 1.387259] of_get_named_gpiod_flags: can't parse 'vbus-other-gpio' property of node '/i2c@ff160000/fusb30x@22[0]'
[ 1.387267] fusb302 7-0022: using lookup tables for GPIO lookup
[ 1.387276] fusb302 7-0022: lookup for GPIO vbus-other failed
[ 1.387285] fusb302 7-0022: GPIO lookup for consumer discharge
[ 1.387294] fusb302 7-0022: using device tree for GPIO lookup
[ 1.387304] of_get_named_gpiod_flags: can't parse 'discharge-gpios' property of node '/i2c@ff160000/fusb30x@22[0]'
[ 1.387313] of_get_named_gpiod_flags: can't parse 'discharge-gpio' property of node '/i2c@ff160000/fusb30x@22[0]'
[ 1.387322] fusb302 7-0022: using lookup tables for GPIO lookup
[ 1.387330] fusb302 7-0022: lookup for GPIO discharge failed
[ 1.387340] fusb302 7-0022: GPIO lookup for consumer charge-en
[ 1.387348] fusb302 7-0022: using device tree for GPIO lookup
[ 1.387358] of_get_named_gpiod_flags: can't parse 'charge-en-gpios' property of node '/i2c@ff160000/fusb30x@22[0]'
[ 1.387367] of_get_named_gpiod_flags: can't parse 'charge-en-gpio' property of node '/i2c@ff160000/fusb30x@22[0]'
[ 1.387376] fusb302 7-0022: using lookup tables for GPIO lookup
[ 1.387404] fusb302 7-0022: lookup for GPIO charge-en failed
[ 1.387695] fusb302 7-0022: fusb302 send extcon to disable vbus 5v
[ 1.391302] fusb302 7-0022: port 0 probe success with role ROLE_MODE_DFP, try_role ROLE_MODE_NONE
[ 1.392268] input: Typec_Headphone as /devices/platform/ff160000.i2c/i2c-7/7-0022/input/input1
[ 1.393327] mp8859 7-0066: GPIO lookup for consumer charge-en
[ 1.393337] mp8859 7-0066: using device tree for GPIO lookup
[ 1.393348] of_get_named_gpiod_flags: can't parse 'charge-en-gpios' property of node '/i2c@ff160000/mp8859@66[0]'
[ 1.393358] of_get_named_gpiod_flags: can't parse 'charge-en-gpio' property of node '/i2c@ff160000/mp8859@66[0]'
[ 1.393367] mp8859 7-0066: using lookup tables for GPIO lookup
[ 1.393376] mp8859 7-0066: lookup for GPIO charge-en failed
[ 1.393559] mp8859 7-0066: failed to set slew_rate
[ 1.393985] mp8859 7-0066: register ext0 dev0
[ 1.394485] mp8859 7-0066: mp8859 probe successful
[ 1.394934] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff8009bd2000
[ 1.396451] rockchip-pinctrl pinctrl: pin gpio1-1 already requested by fan-regulator; cannot claim for 4-0022
[ 1.397322] rockchip-pinctrl pinctrl: pin-33 (4-0022) status -22
[ 1.397877] rockchip-pinctrl pinctrl: could not request pin 33 (gpio1-1) from group fusb1-int on device rockchip-pinctrl
[ 1.398846] fusb302 4-0022: Error applying setting, reverse things back
[ 1.399514] fusb302 4-0022: GPIO lookup for consumer int-n
[ 1.399524] fusb302 4-0022: using device tree for GPIO lookup
[ 1.399558] of_get_named_gpiod_flags: parsed 'int-n-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]' - status (0)
[ 1.399568] gpio-33 (fan_enable): gpiod_request: status -16
[ 1.399641] fusb302: probe of 4-0022 failed with error -16
[ 1.400165] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009bd4000
[ 1.402091] IR NEC protocol handler initialized
[ 1.403328] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.05
[ 1.403927] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[ 1.405840] rkisp1 ff910000.rkisp1: GPIO lookup for consumer vsirq
[ 1.405852] rkisp1 ff910000.rkisp1: using device tree for GPIO lookup
[ 1.405865] of_get_named_gpiod_flags: can't parse 'vsirq-gpios' property of node '/rkisp1@ff910000[0]'
[ 1.405875] of_get_named_gpiod_flags: can't parse 'vsirq-gpio' property of node '/rkisp1@ff910000[0]'
[ 1.405884] rkisp1 ff910000.rkisp1: using lookup tables for GPIO lookup
[ 1.405894] rkisp1 ff910000.rkisp1: lookup for GPIO vsirq failed
[ 1.406225] rkisp1 ff920000.rkisp1: rkisp1 driver version: v00.01.05
[ 1.406826] rkisp1 ff920000.rkisp1: Missing rockchip,grf property
[ 1.408624] rkisp1 ff920000.rkisp1: GPIO lookup for consumer vsirq
[ 1.408636] rkisp1 ff920000.rkisp1: using device tree for GPIO lookup
[ 1.408648] of_get_named_gpiod_flags: can't parse 'vsirq-gpios' property of node '/rkisp1@ff920000[0]'
[ 1.408658] of_get_named_gpiod_flags: can't parse 'vsirq-gpio' property of node '/rkisp1@ff920000[0]'
[ 1.408667] rkisp1 ff920000.rkisp1: using lookup tables for GPIO lookup
[ 1.408677] rkisp1 ff920000.rkisp1: lookup for GPIO vsirq failed
[ 1.408936] usbcore: registered new interface driver npu_acm
[ 1.409530] usbcore: registered new interface driver uvcvideo
[ 1.410044] USB Video Class driver (1.1.1)
[ 1.410492] cw201x 2-0062: design_capacity missing!
[ 1.411103] cw_bat_probe cw_init error
[ 1.412187] rockchip-iodomain ff320000.syscon:io-domains: Looking up pmu1830-supply from device tree
[ 1.412430] rockchip-iodomain ff770000.syscon:io-domains: Looking up bt656-supply from device tree
[ 1.412495] rockchip-iodomain ff770000.syscon:io-domains: Looking up wifi-supply from device tree
[ 1.412507] rockchip-iodomain ff770000.syscon:io-domains: Looking up wifi-supply property in node /syscon@ff770000/io-domains failed
[ 1.412540] rockchip-iodomain ff770000.syscon:io-domains: Looking up audio-supply from device tree
[ 1.412616] rockchip-iodomain ff770000.syscon:io-domains: Looking up sdmmc-supply from device tree
[ 1.412679] rockchip-iodomain ff770000.syscon:io-domains: Looking up gpio1830-supply from device tree
[ 1.413592] Boot mode: coldboot
[ 1.414984] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.415946] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[ 1.417211] dw_wdt ff848000.watchdog: Should better to setup a 'resets' property in dt, that must been named with reset
[ 1.418832] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.419754] rtk_btusb: Realtek Bluetooth USB driver ver 3.1.a2fd257.20190430-133301
[ 1.420448] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 1.420893] rtk_btcoex: create workqueue
[ 1.421245] rtk_btcoex: Coex over UDP
[ 1.421819] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ 1.422415] usbcore: registered new interface driver rtk_btusb
[ 1.422938] Bluetooth: Virtual HCI driver ver 1.5
[ 1.423490] Bluetooth: HCI UART driver ver 2.3
[ 1.423892] Bluetooth: HCI UART protocol H4 registered
[ 1.424350] Bluetooth: HCI UART protocol BCSP registered
[ 1.424834] Bluetooth: HCI UART protocol LL registered
[ 1.425292] Bluetooth: HCI UART protocol ATH3K registered
[ 1.425918] Bluetooth: HCI UART protocol Intel registered
[ 1.426462] usbcore: registered new interface driver bfusb
[ 1.426995] usbcore: registered new interface driver btusb
[ 1.428014] cpu cpu0: bin=1
[ 1.428318] cpu cpu0: leakage=23
[ 1.428653] cpu cpu0: Looking up cpu-supply from device tree
[ 1.440729] cpu cpu0: temp=36250, pvtm=147497 (148072 + -575)
[ 1.441448] cpu cpu0: pvtm-volt-sel=1
[ 1.441834] cpu cpu0: bin-scale=34
[ 1.442483] cpu cpu4: bin=1
[ 1.442786] cpu cpu4: leakage=41
[ 1.443102] cpu cpu4: Looking up cpu-supply from device tree
[ 1.455253] cpu cpu4: temp=36250, pvtm=158826 (159181 + -355)
[ 1.455873] cpu cpu4: pvtm-volt-sel=2
[ 1.456248] cpu cpu4: bin-scale=17
[ 1.456881] cpu cpu0: Looking up cpu-supply from device tree
[ 1.457157] cpu cpu0: Looking up cpu-supply from device tree
[ 1.457752] cpu cpu0: avs=0
[ 1.458107] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 1.459269] cpu cpu0: failed to find power_model node
[ 1.460092] cpu cpu4: Looking up cpu-supply from device tree
[ 1.460736] cpu cpu4: avs=0
[ 1.461091] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 1.463055] cpu cpu4: failed to find power_model node
[ 1.464398] sdhci: Secure Digital Host Controller Interface driver
[ 1.464948] sdhci: Copyright(c) Pierre Ossman
[ 1.465340] Synopsys Designware Multimedia Card Interface Driver
[ 1.466824] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.467512] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.468119] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.468691] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.469580] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree
[ 1.469657] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 1.469694] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree
[ 1.469822] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_sdioaudio-supply from device tree
[ 1.469836] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_sdioaudio-supply property in node /power-management@ff310000/power-controller failed
[ 1.470583] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.471246] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.471867] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.472424] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.473293] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 1.474020] dwmmc_rockchip fe320000.dwmmc: Looking up vmmc-supply from device tree
[ 1.474135] dwmmc_rockchip fe320000.dwmmc: Looking up vqmmc-supply from device tree
[ 1.474213] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer cd
[ 1.474222] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
[ 1.474235] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/dwmmc@fe320000[0]'
[ 1.474246] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/dwmmc@fe320000[0]'
[ 1.474256] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
[ 1.474265] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO cd failed
[ 1.474277] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer wp
[ 1.474286] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
[ 1.474296] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@fe320000[0]'
[ 1.474306] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@fe320000[0]'
[ 1.474315] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
[ 1.474324] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO wp failed
[ 1.474505] vccio_sd: unsupportable voltage range: 3300000-3000000uV
[ 1.475080] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 1.475753] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 1.488991] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.502464] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.503398] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.504500] sdhci-arasan fe330000.sdhci: GPIO lookup for consumer wp
[ 1.504512] sdhci-arasan fe330000.sdhci: using device tree for GPIO lookup
[ 1.504524] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/sdhci@fe330000[0]'
[ 1.504535] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/sdhci@fe330000[0]'
[ 1.504545] sdhci-arasan fe330000.sdhci: using lookup tables for GPIO lookup
[ 1.504554] sdhci-arasan fe330000.sdhci: lookup for GPIO wp failed
[ 1.505656] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply from device tree
[ 1.505669] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply property in node /sdhci@fe330000 failed
[ 1.505710] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply from device tree
[ 1.505721] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply property in node /sdhci@fe330000 failed
[ 1.505748] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.506287] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.537180] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.539360] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/power[0]' - status (0)
[ 1.539662] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/user[0]' - status (0)
[ 1.540136] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.541274] usbcore: registered new interface driver usbhid
[ 1.541811] usbhid: USB HID core driver
[ 1.542330] inv_mpu_iio: inv_mpu_init:746
[ 1.543523] rk808-clkout: probe of rk808-clkout failed with error -17
[ 1.545350] rockchip-saradc ff100000.saradc: Looking up vref-supply from device tree
[ 1.546966] usbcore: registered new interface driver snd-usb-audio
[ 1.548695] of_get_named_gpiod_flags: can't parse 'spk-ctl-gpio' property of node '/i2c@ff110000/es8388@11[0]'
[ 1.548710] ES8323 1-0011: Can not read property spk_ctl_gpio
[ 1.549251] of_get_named_gpiod_flags: parsed 'hp-ctl-gpio' property of node '/i2c@ff110000/es8388@11[0]' - status (0)
[ 1.549307] of_get_named_gpiod_flags: parsed 'hp-det-gpio' property of node '/i2c@ff110000/es8388@11[0]' - status (0)
[ 1.549319] gpio-70 (pmic-hold-gpio): gpiod_request: status -16
[ 1.549330] ES8323 1-0011: Failed to request hp_det_gpio
[ 1.549847] ES8323: probe of 1-0011 failed with error -16
[ 1.555602] rockchip-cdndp-sound dp-sound: ASoC: CODEC DAI spdif-hifi not registered
[ 1.556288] rockchip-cdndp-sound dp-sound: rockchip_sound_probe snd_soc_register_card fail -517
[ 1.557217] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.558273] IPVS: Registered protocols (TCP, UDP)
[ 1.558764] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 1.559528] IPVS: Creating netns size=2104 id=0
[ 1.559957] IPVS: ipvs loaded.
[ 1.560239] IPVS: [rr] scheduler registered.
[ 1.560911] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.561502] Initializing XFRM netlink socket
[ 1.562557] NET: Registered protocol family 10
[ 1.563808] NET: Registered protocol family 17
[ 1.564231] NET: Registered protocol family 15
[ 1.564681] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.565816] Bridge firewalling registered
[ 1.566376] Bluetooth: RFCOMM TTY layer initialized
[ 1.566890] Bluetooth: RFCOMM socket layer initialized
[ 1.567370] Bluetooth: RFCOMM ver 1.11
[ 1.567743] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.568213] Bluetooth: BNEP filters: protocol multicast
[ 1.568697] Bluetooth: BNEP socket layer initialized
[ 1.569151] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.569691] Bluetooth: HIDP socket layer initialized
[ 1.570196] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.570977] <rfkill_wlan_init> result: 0
[ 1.571340] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.571963] Key type dns_resolver registered
[ 1.572743] sensor_register_slave:mpu6880_gyro,id=50
[ 1.574081] ov13850 1-0036: driver version: 00.01.03
[ 1.574597] ov13850 1-0036: GPIO lookup for consumer reset
[ 1.574610] ov13850 1-0036: using device tree for GPIO lookup
[ 1.574653] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/i2c@ff110000/ov13850@36[0]' - status (0)
[ 1.574715] ov13850 1-0036: Looking up avdd-supply from device tree
[ 1.574940] ov13850 1-0036: Looking up dovdd-supply from device tree
[ 1.575046] ov13850 1-0036: Looking up dvdd-supply from device tree
[ 1.575488] ov13850 1-0036: GPIO lookup for consumer pwdn
[ 1.575502] ov13850 1-0036: using device tree for GPIO lookup
[ 1.575546] of_get_named_gpiod_flags: parsed 'pwdn-gpios' property of node '/i2c@ff110000/ov13850@36[0]' - status (0)
[ 1.578448] ov13850 1-0036: write SCCB_ID failed
[ 1.579181] ov13850: probe of 1-0036 failed with error -5
[ 1.580384] ov13850 1-0046: driver version: 00.01.03
[ 1.580895] ov13850 1-0046: GPIO lookup for consumer reset
[ 1.580908] ov13850 1-0046: using device tree for GPIO lookup
[ 1.580951] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/i2c@ff110000/ov13850@46[0]' - status (0)
[ 1.580996] ov13850 1-0046: Looking up avdd-supply from device tree
[ 1.581188] ov13850 1-0046: Looking up dovdd-supply from device tree
[ 1.581324] ov13850 1-0046: Looking up dvdd-supply from device tree
[ 1.581703] ov13850 1-0046: GPIO lookup for consumer pwdn
[ 1.581716] ov13850 1-0046: using device tree for GPIO lookup
[ 1.581758] of_get_named_gpiod_flags: parsed 'pwdn-gpios' property of node '/i2c@ff110000/ov13850@46[0]' - status (0)
[ 1.584138] ov13850 1-0046: write SCCB_ID failed
[ 1.584775] ov13850: probe of 1-0046 failed with error -5
[ 1.585761] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 1.586331] Registered cp15_barrier emulation handler
[ 1.586979] Registered setend emulation handler
[ 1.587428] mmcblk1: mmc1:0001 Y2P032 29.1 GiB
[ 1.588310] Loading compiled-in X.509 certificates
[ 1.588683] mmcblk1boot0: mmc1:0001 Y2P032 partition 1 4.00 MiB
[ 1.589204] mmcblk1boot1: mmc1:0001 Y2P032 partition 2 4.00 MiB
[ 1.589835] mmcblk1rpmb: mmc1:0001 Y2P032 partition 3 16.0 MiB
[ 1.590492] wifi_platform_bus_enumerate device present 1
[ 1.590963] ======== Card detection to detect SDIO card! ========
[ 1.591548] sdio: host isn't initialization successfully.
[ 1.592915] Btrfs loaded
[ 1.595161] rga2: Driver loaded successfully ver:3.02
[ 1.595196] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8
[ 1.596112] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_rga-supply from device tree
[ 1.596141] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_rga-supply property in node /power-management@ff310000/power-controller failed
[ 1.596629] rga2: Module initialized.
[ 1.597789] phy phy-ff770000.syscon:usb2-phy@e450.2: Looking up phy-supply from device tree
[ 1.598622] phy phy-ff770000.syscon:usb2-phy@e450.3: Looking up phy-supply from device tree
[ 1.598642] phy phy-ff770000.syscon:usb2-phy@e450.3: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
[ 1.598816] phy phy-ff770000.syscon:usb2-phy@e450.3: Looking up vbus-supply from device tree
[ 1.598833] phy phy-ff770000.syscon:usb2-phy@e450.3: Looking up vbus-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
[ 1.598864] phy phy-ff770000.syscon:usb2-phy@e450.3: Failed to get VBUS supply regulator
[ 1.602108] phy phy-ff7c0000.phy.4: Looking up phy-supply from device tree
[ 1.602131] phy phy-ff7c0000.phy.4: Looking up phy-supply property in node /phy@ff7c0000/dp-port failed
[ 1.602311] phy phy-ff7c0000.phy.5: Looking up phy-supply from device tree
[ 1.602326] phy phy-ff7c0000.phy.5: Looking up phy-supply property in node /phy@ff7c0000/usb3-port failed
[ 1.604539] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[ 1.604558] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[ 1.604615] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0)
[ 1.604906] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[ 1.605051] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 1.606844] mali ff9a0000.gpu: Looking up mali-supply from device tree
[ 1.607230] mali ff9a0000.gpu: leakage=27
[ 1.607653] mali ff9a0000.gpu: Looking up mali-supply from device tree
[ 1.607694] vdd_gpu: could not add device link ff9a0000.gpu err -17
[ 1.607712] vdd_gpu: Failed to create debugfs directory
[ 1.620654] mali ff9a0000.gpu: temp=35625, pvtm=127741 (128017 + -276)
[ 1.623351] mali ff9a0000.gpu: pvtm-volt-sel=2
[ 1.624731] mali ff9a0000.gpu: avs=0
[ 1.626531] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 1.629244] mali ff9a0000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 1.630187] I : [File] : drivers/gpu/arm/midgard_for_linux/backend/gpu/mali_kbase_devfreq.c; [Line] : 315; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 1.632883] mali ff9a0000.gpu: Probed as mali0
[ 1.639032] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 1.639874] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 1
[ 1.640817] xhci-hcd xhci-hcd.4.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 1.641696] xhci-hcd xhci-hcd.4.auto: irq 230, io mem 0xfe800000
[ 1.642640] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.643253] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.643933] usb usb1: Product: xHCI Host Controller
[ 1.644384] usb usb1: Manufacturer: Linux 4.4.194 xhci-hcd
[ 1.644899] usb usb1: SerialNumber: xhci-hcd.4.auto
[ 1.646246] hub 1-0:1.0: USB hub found
[ 1.646681] hub 1-0:1.0: 1 port detected
[ 1.647634] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 1.648526] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 2
[ 1.649325] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.650261] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.650896] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.651560] usb usb2: Product: xHCI Host Controller
[ 1.652010] usb usb2: Manufacturer: Linux 4.4.194 xhci-hcd
[ 1.652530] usb usb2: SerialNumber: xhci-hcd.4.auto
[ 1.653882] hub 2-0:1.0: USB hub found
[ 1.654270] hub 2-0:1.0: 1 port detected
[ 1.657070] xhci-hcd xhci-hcd.4.auto: remove, state 1
[ 1.657593] usb usb2: USB disconnect, device number 1
[ 1.660864] rockchip-dwc3 usb1: failed to get drvdata dwc3
[ 1.664604] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.665452] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 3
[ 1.666333] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 1.672509] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 1.673348] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.673990] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.674648] usb usb3: Product: EHCI Host Controller
[ 1.675074] xhci-hcd xhci-hcd.4.auto: Host not halted after 16000 microseconds.
[ 1.675085] xhci-hcd xhci-hcd.4.auto: Host controller not halted, aborting reset.
[ 1.675171] xhci-hcd xhci-hcd.4.auto: USB bus 2 deregistered
[ 1.676944] usb usb3: Manufacturer: Linux 4.4.194 ehci_hcd
[ 1.677457] usb usb3: SerialNumber: fe380000.usb
[ 1.678829] hub 3-0:1.0: USB hub found
[ 1.679219] hub 3-0:1.0: 1 port detected
[ 1.680443] xhci-hcd xhci-hcd.4.auto: remove, state 1
[ 1.680925] usb usb1: USB disconnect, device number 1
[ 1.682466] xhci-hcd xhci-hcd.4.auto: USB bus 1 deregistered
[ 1.685174] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.686118] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 1
[ 1.687013] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 1.742964] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.743604] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.744247] usb usb1: Product: Generic Platform OHCI controller
[ 1.744788] usb usb1: Manufacturer: Linux 4.4.194 ohci_hcd
[ 1.745282] usb usb1: SerialNumber: fe3a0000.usb
[ 1.747238] hub 1-0:1.0: USB hub found
[ 1.747724] hub 1-0:1.0: 1 port detected
[ 1.751568] input: adc-keys as /devices/platform/adc-keys/input/input2
[ 1.754517] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.755224] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.755865] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.756448] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.757357] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree
[ 1.757528] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 1.757601] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree
[ 1.759931] rockchip-cdndp-sound dp-sound: ASoC: CODEC DAI spdif-hifi not registered
[ 1.760655] rockchip-cdndp-sound dp-sound: rockchip_sound_probe snd_soc_register_card fail -517
[ 1.764266] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[ 1.764290] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[ 1.764352] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0)
[ 1.764781] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[ 1.764899] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 1.768530] rockchip-dwc3 usb1: failed to get drvdata dwc3
[ 1.772720] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-keys/button@0[0]' - status (0)
[ 1.772809] gpio-5 (GPIO Key Power): gpiod_set_debounce: missing set() or set_debounce() operations
[ 1.772843] genirq: Flags mismatch irq 74. 00000083 (GPIO Key Power) vs. 00002008 (hym8563)
[ 1.773631] gpio-keys gpio-keys: Unable to claim irq 74; error -16
[ 1.774226] gpio-keys: probe of gpio-keys failed with error -16
[ 1.774873] ==gsl_ts_init==
[ 1.775249] ret=0
[ 1.775838] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_edp-supply from device tree
[ 1.775865] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_edp-supply property in node /power-management@ff310000/power-controller failed
[ 1.775972] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_iep-supply from device tree
[ 1.775995] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_iep-supply property in node /power-management@ff310000/power-controller failed
[ 1.776831] rtc-hym8563 0-0051: setting system clock to 2023-01-17 07:47:27 UTC (1673941647)
[ 1.809303] vcc_sd: disabling
[ 1.809614] vcc_mipi: disabling
[ 1.809900] dvdd_1v2: disabling
[ 1.810187] vcc3v3_pcie: disabling
[ 1.811510] ret 1024
[ 1.812138] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vdu-supply from device tree
[ 1.812156] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vdu-supply property in node /power-management@ff310000/power-controller failed
[ 1.812241] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vcodec-supply from device tree
[ 1.812254] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vcodec-supply property in node /power-management@ff310000/power-controller failed
[ 1.812323] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '01:18:04', on 'Jan 17 2023'.
[ 1.814532] Mali: Mali device driver loaded
[ 1.815144] rkisp1 ff910000.rkisp1: clear unready subdev num: 1
[ 1.817530] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 1.818112] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 1.818749] rkisp1: update sensor failed
[ 1.819114] rkisp1: subdev link fail, remove isp device
[ 1.824998] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp0-supply from device tree
[ 1.825022] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp0-supply property in node /power-management@ff310000/power-controller failed
[ 1.825204] iommu: Removing device ff910000.rkisp1 from group 4
[ 1.825802] rkisp1 ff920000.rkisp1: clear unready subdev num: 1
[ 1.826607] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 1.827158] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 1.827748] rkisp1: update sensor failed
[ 1.828102] rkisp1: subdev link fail, remove isp device
[ 1.829516] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp1-supply from device tree
[ 1.829531] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp1-supply property in node /power-management@ff310000/power-controller failed
[ 1.829625] iommu: Removing device ff920000.rkisp1 from group 5
[ 1.831369] ALSA device list:
[ 1.831712] No soundcards found.
[ 1.833312] Freeing unused kernel memory: 1216K
[ 2.118502] vendor storage:20190527 ret = 0
[ 3.591517] failed to power up DHD generic adapter, 1 retry left
[ 3.608284] wifi_platform_set_power = 0
[ 3.608678] ======== PULL WL_REG_ON(-1) LOW! ========
[ 3.609139] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 3.609613] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[ 3.609624] wifi_platform_bus_enumerate device present 0
[ 3.609629] ======== Card detection to remove SDIO card! ========
[ 3.609634] sdio: host isn't initialization successfully.
[ 3.609737] wifi_platform_set_power = 1
[ 3.609741] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 3.609747] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 3.609753] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[ 3.910540] wifi_platform_bus_enumerate device present 1
[ 3.911034] ======== Card detection to detect SDIO card! ========
[ 3.911592] sdio: host isn't initialization successfully.
[ 4.156205] EXT4-fs (mmcblk1p7): mounted filesystem with ordered data mode. Opts: (null)
[ 4.446985] EXT4-fs (mmcblk1p8): recovery complete
[ 4.448266] EXT4-fs (mmcblk1p8): mounted filesystem with ordered data mode. Opts: (null)
[ 4.770830] cgroup: cgroup2: unknown option "nsdelegate"
[ 4.784073] systemd[1]: systemd 245.4-4ubuntu4.0neotek01 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 4.788105] systemd[1]: Detected architecture arm64.
[ 4.801832] systemd[1]: Set hostname to <neotek>.
[ 4.948999] systemd[1]: Configuration file /lib/systemd/system/npu-S11.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.087914] random: systemd: uninitialized urandom read (16 bytes read, 94 bits of entropy available)
[ 5.088855] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 5.089969] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 5.092147] systemd[1]: Created slice system-modprobe.slice.
[ 5.092937] random: systemd: uninitialized urandom read (16 bytes read, 94 bits of entropy available)
[ 5.094746] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 5.095507] random: systemd: uninitialized urandom read (16 bytes read, 94 bits of entropy available)
[ 5.097230] systemd[1]: Created slice User and Session Slice.
[ 5.097945] random: systemd: uninitialized urandom read (16 bytes read, 94 bits of entropy available)
[ 5.099262] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 5.100273] random: systemd: uninitialized urandom read (16 bytes read, 94 bits of entropy available)
[ 5.101599] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.102616] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
[ 5.104070] random: systemd: uninitialized urandom read (16 bytes read, 94 bits of entropy available)
[ 5.104898] systemd[1]: Reached target Local Encrypted Volumes.
[ 5.105601] random: systemd: uninitialized urandom read (16 bytes read, 94 bits of entropy available)
[ 5.106850] systemd[1]: Reached target Remote File Systems.
[ 5.107470] random: systemd: uninitialized urandom read (16 bytes read, 94 bits of entropy available)
[ 5.108714] systemd[1]: Reached target Slices.
[ 5.109220] random: systemd: uninitialized urandom read (16 bytes read, 95 bits of entropy available)
[ 5.110391] systemd[1]: Reached target Swap.
[ 5.110897] random: systemd: uninitialized urandom read (16 bytes read, 95 bits of entropy available)
[ 5.112281] systemd[1]: Listening on Syslog Socket.
[ 5.112956] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 5.121497] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 5.122640] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.123640] systemd[1]: Listening on Journal Socket.
[ 5.124591] systemd[1]: Listening on udev Control Socket.
[ 5.125467] systemd[1]: Listening on udev Kernel Socket.
[ 5.126555] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 5.129623] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.133183] systemd[1]: Mounting Kernel Debug File System...
[ 5.137474] systemd[1]: Mounting Kernel Trace File System...
[ 5.143002] systemd[1]: Starting Journal Service...
[ 5.148353] systemd[1]: Starting Set the console keyboard layout...
[ 5.149498] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
[ 5.151049] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 5.153802] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 5.158649] systemd[1]: Starting Load Kernel Modules...
[ 5.162643] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 5.167958] systemd[1]: Starting udev Coldplug all Devices...
[ 5.174260] systemd[1]: Mounted POSIX Message Queue File System.
[ 5.175547] systemd[1]: Mounted Kernel Debug File System.
[ 5.176905] systemd[1]: Mounted Kernel Trace File System.
[ 5.187941] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 5.196096] systemd[1]: Finished Load Kernel Modules.
[ 5.200127] systemd[1]: Mounting FUSE Control File System...
[ 5.201192] systemd[1]: Condition check resulted in Kernel Configuration File System being skipped.
[ 5.203018] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 5.204152] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 5.207428] systemd[1]: Starting Load/Save Random Seed...
[ 5.211581] systemd[1]: Starting Apply Kernel Variables...
[ 5.216835] systemd[1]: Starting Create System Users...
[ 5.222300] systemd[1]: Mounted FUSE Control File System.
[ 5.243738] systemd[1]: Finished Apply Kernel Variables.
[ 5.246919] systemd[1]: Finished Create System Users.
[ 5.249736] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 5.279948] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 5.282969] systemd[1]: Starting udev Kernel Device Manager...
[ 5.284577] systemd[1]: Finished Set the console keyboard layout.
[ 5.285361] systemd[1]: Reached target Local File Systems (Pre).
[ 5.285697] systemd[1]: Reached target Local File Systems.
[ 5.288868] systemd[1]: Starting Set console font and keymap...
[ 5.289496] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 5.309223] systemd[1]: Finished Set console font and keymap.
[ 5.371113] systemd[1]: Started udev Kernel Device Manager.
[ 5.381674] systemd[1]: Finished udev Coldplug all Devices.
[ 5.477834] systemd[1]: Started Journal Service.
[ 5.511588] systemd-journald[424]: Received client request to flush runtime journal.
[ 5.520228] systemd-journald[424]: File /var/log/journal/152d075b18a8465080302ccb9cfe6776/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 5.911486] failed to power up DHD generic adapter, 0 retry left
[ 5.927669] wifi_platform_set_power = 0
[ 5.927689] ======== PULL WL_REG_ON(-1) LOW! ========
[ 5.927696] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 5.927702] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[ 5.927709] wifi_platform_bus_enumerate device present 0
[ 5.927715] ======== Card detection to remove SDIO card! ========
[ 5.927722] sdio: host isn't initialization successfully.
[ 5.928217] failed to power up DHD generic adapter, max retry reached**
[ 5.928269] unregister wifi platform drivers
[ 5.928276] wifi_platform_bus_enumerate device present 0
[ 5.928281] ======== Card detection to remove SDIO card! ========
[ 5.928287] sdio: host isn't initialization successfully.
[ 5.928834] ======== dhd_wlan_deinit_plat_data ========
[ 5.928845] dhd_module_init: Failed to load the driver, try cnt 0
[ 5.928894] dhd_module_init: Failed to load driver max retry reached**
[ 5.928900] dhd_module_init: Exit err=-19
[ 6.027000] random: nonblocking pool is initialized
[ 6.053686] IPVS: Creating netns size=2104 id=1
[ 6.066196] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 6.066273] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 6.066288] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 6.066313] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 6.066335] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree
[ 6.066458] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[ 6.066485] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree
[ 6.067469] rockchip-cdndp-sound dp-sound: ASoC: CODEC DAI spdif-hifi not registered
[ 6.068178] rockchip-cdndp-sound dp-sound: rockchip_sound_probe snd_soc_register_card fail -517
[ 6.070735] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[ 6.070750] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[ 6.070787] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0)
[ 6.070936] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[ 6.071020] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[ 6.075187] rockchip-dwc3 usb1: failed to get drvdata dwc3
[ 6.294555] IPVS: Creating netns size=2104 id=2
[ 6.777503] tty_port_close_start: tty->count = 1 port count = 2.
[ 6.937722] cfg80211: World regulatory domain updated:
[ 6.937753] cfg80211: DFS Master region: unset
[ 6.937760] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 6.937772] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.937780] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 6.937788] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.937796] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 6.937804] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 6.937811] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 6.937819] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.937826] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 8.074111] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
Copy the code
