[Linux] How to rotate screen on Unbuntu 18.04? How to set landscape orientation ?
154
【Linux】 How to rotate screen on Unbuntu 18.04? How to set landscape orientation ?
Posted at 3/30/2023 22:52:04      View:1283 | Replies:6        Print      Only Author   [Copy Link] 1#
  • Type: Self-Compiled Firmware
  • SDK Package Name: rk356x_linux_release_v1.3.0b_20221213
  • Last Commit: 0000-00-00 00:00:00
  • Modification Content: mipi 2 cam configuration
  • Log: no log (2).zip
How to rotate screen on Unbuntu 18.04?I have 800x1280 screen and it have book orientation.
I tryed find Display settings in Ubuntu 18 descktop environment for orientation but found nothing.
Auto rotate screen doesn't works.
How can i change DTS file to do it ?
no log (2).zip
22 Bytes, Down times: 0
Posted at 3/31/2023 09:43:55        Only Author  2#
Posted at 3/31/2023 13:51:29        Only Author  3#
zooora111 Posted at 3/31/2023 09:43
Hi, this may help: https://wiki.t-firefly.com/en/Firefly-Linux-Guide/manual_ubuntu.html#multi-screen ...
yes i saw it before, but it's not about SCREEN rotation, it's about touchscreen rotation.
Posted at 3/31/2023 17:17:39        Only Author  4#
Use xrandr  command  can rotate screen
xrandr --output --rotate <left|right|inverted|normal>
e.g.:
xrandr --output HDMI1 --rotate right
Posted at 3/31/2023 21:49:39        Only Author  5#
895816513 Posted at 3/31/2023 17:17
I tryed it before and it works fine but It's not a best solution.
I need to add 2nd screen settings 1280x800:
horisontal 1280
vertical 800
I need rotate my screen using DTS file, on the kernel level:
&dsi1{
disp_timings1: display-timings {
            native-mode = <&dsi1_timing0>;
            dsi1_timing0: timing0 {
                clock-frequency = <72600000>;//<80000000>;
                hactive = <800>;
                vactive = <1280>;
                hsync-len = <14>;   //20, 50,10
                hback-porch = <26>; //50, 56,10
                hfront-porch = <32>;//50, 30,180
                    vsync-len = <8>;//4
                    vback-porch = <20>;//4
                    vfront-porch = <80>;//8
                    hsync-active = <0>;
                    vsync-active = <0>;
                    de-active = <0>;
                pixelclk-active = <0>;
So i need to add 2nd dsi1_timing:
dsi1_timing1: timing1 {
                clock-frequency = ...;
                hactive = <1280>;
                vactive = <800>;
So probabaly i need enter new values for
clock-frequency,hactive,vactive,hsync-len,hback-porch,hfront-porch,vsync-len,vback-porch,vfront-porch
Can you help me ? How to do it ?
Posted at 4/1/2023 17:14:14        Only Author  6#
Maverick_by_ Posted at 3/31/2023 21:49
I need to add 2nd screen sett ...
Timings are given in the datasheet of a LCD screen, one DSI can only has one group of timings
They are hardware features of a LCD , so you can't just swap hactive and vactive to rotate
The only way is using xrandr
Posted at 3/30/2024 15:06:07        Only Author  7#
Maverick_by_ Posted at 3/31/2023 13:51
How did you solve it?
